# E. W' P* |) L" v& m6 E6 o* w7 |4 Z4 o5 e) s: F0 q
Thermal shock that can be expected in the vehicle environment is simulated by the rate of change shown on the9 V, m# R2 B3 Q
recommended thermal shock profile portrayed in Figure 2C usually specified as no greater than 5 min. The thermal / c; v% a% F# ?4 X. h" Ishock test should begin with a 2 h presoak at –40 °C/–40 °F. The test item should be transferred to the hot chamber' q5 O4 g N4 s5 E2 k5 f
(85 °C/185 °F) where it should remain for 2 h, then transferred back to the cold chamber (–40 °C/–40 °F) where it should 4 m: m) z$ o6 h7 \: S( gremain for an additional 2 h. Each transfer should be accomplished in 1 min or less. The 2 h dwell in the hot chamber' B3 E& m9 z3 s; B6 F
and 2 h dwell in the cold chamber constitute one thermal shock cycle.4 P3 ]7 ~9 |( o7 a" ]' ^) J& M/ ]1 A
请教大神, 5 min 和1 min 分别指哪个过程的时间?感谢!
