想用Pspice做场效应管MTP2P50E和BUK456800的电路仿真,但是没有它们的模型,想用一个现成的管子修改一下,挑了一个F1020,edit pspice model后发现模型的描述看不太懂,不太明白怎么修改,还请达人帮忙啊!
" J; L$ F& [8 e4 I: i
, N) F& i1 w. O! J1 J: v- C0 Q* ~+ i& U2 y
模型表述如下:
, C% X% P3 b5 j8 \! k" `
9 I2 J! Z: b7 ?7 X K' C
" m3 I0 f: |4 m* ]) ^*POLYFET RF DEVICES! L' A8 g3 `' L# b: U
*FEB 15 1994
* c1 W4 |4 M1 G, S* x*PHONE 805)484-4210; FAX 805)494-3393 CONTACT:MR. S.K. LEONG9 e6 M. o2 T6 }" t# |" G+ m6 R
*HIGH POWER, HIGH FREQUENCY, RF N-CHANNEL VERTICAL DMOS MOSFET. Z5 Y5 a) B& D5 \
*TO GENERATE S PARAMETER MATCHING DATA SHEET, SET VG=3.58V FOR IDQ=800MA
6 Z( Y7 F& ^( x3 r*; `+ U4 Z2 E. x& Q/ k" X& l
*MODEL APPLICABLE FOR ALL F1B 4 DIE IN AP AND AK PACKAGE. F1021 USE
0 r, p- K) U, V- v! v3 p2 R*BELOW AS EXAMPLE.6 P& H8 r3 a& L n/ P- L
* NOTE:- HP/EESOF USES 'GATE DRAIN SOURCE' ORDER
' d, r& s5 B d8 g4 t' r* ( ;D G S )
& R8 G1 z+ M( U1 K; _.SUBCKT F1021/PF 20 10 302 d4 D+ j" ~% v! p7 a
LG 10 11 0.87N
8 E7 s% C- M* Z3 O: R, kRGATE 11 12 0.61* d2 g8 v' h: m5 j. V4 Y
CG 10 30 0.12P/ s% z* E. r7 M) C
CRSS 12 17 14.2P
( N3 }( n$ z- b. U- r2 cCISS 12 14 130P
; `# ?) D9 _% M9 JLS 14 30 0.09N
/ y& w, F& l1 `/ r( sCS 14 30 0.06P8 W% a, t1 W1 b$ m- H* l2 k1 }
LD 17 20 0.75N$ m$ e, F1 _) w
CD 20 30 0.45P
2 u6 B: ~. w( y* F9 Q( g4 [ x8 i4 dR_RC 16 17 8.2
$ w3 a: U5 f& C% B' J9 UC_RC 14 16 61P
* o; H$ h0 }/ h8 a/ v7 M, qMOS 13 12 14 14 F1021MOS L=1.1U W=0.24 ;D G S B LEVEL1& n$ J& _: j9 |& a7 H
JFET 17 14 13 F1021JF ;D G S
% T5 e$ E, q7 T# r9 l" l- bDBODY 14 17 F1021DB N
/ P, V# I9 N: }3 d3 E.MODEL F1021MOS NMOS (VTO=3 KP=1.7E-5 LAMBDA=0.1 RD=0.1 RS=0.09)' P- A; U+ J+ X \% K
.MODEL F1021JF NJF (VTO=-6.8 BETA=0.2 LAMBDA=5)6 n( A1 p _' D! Z' c4 N
.MODEL F1021DB D (CJO=192P RS=0.25 VJ=0.7 M=0.35 BV=65)
; R" C1 z" j" c2 O1 X.ENDS, e: M8 C7 b" b0 p8 C7 c
7 n7 F# _# x- H! W$ P5 O; y+ F) `" y% I" A {& S
5 K* Y9 m* o1 B* h9 h' A( u
/ D. a1 o/ D$ N) `; R y4 K7 t m/ q
1 e. R' L7 {" W3 e
" L) D# f- Z2 M% \5 k d# l Y: ?
