查看: 433|回复: 1
怎么建PSPICE模型?
发表于 2019-7-9 13:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在安森美网站下了个  ntr4003n  NMOS 的仿真模型,本来以为网上注明的是 Pspice Model  可以直接用,谁知编辑完用的时候发现模型的原理图封装不对,显示的是个方框加3个引脚,我要怎么改才能让它变成NMOS的图形啊? 希望能帮我改下,把TXT文档贴出来。在网上找了点资料,可是没看明白怎么改,呵呵。& h0 k1 e3 ?2 L7 Q( `: |
ntr4003n.LIB 用TXT打开后的资料如下:
# P5 a  n5 J5 R+ z% m1 I
  |1 `9 \% W# S! o.SUBCKT ntr4003n 1 2 3& R6 y8 W9 [4 U
8 K6 h$ U2 s! F- u*      Model Generated by MODPEX     *
, s, w2 L* z. n4 M6 Q+ B*Copyright(c) Symmetry Design Systems*
+ w- g3 n% Y  r# P4 m* x- v2 C2 w*         All Rights Reserved        *5 ~2 j2 T$ g  q; p1 k; O! V
*    UNPUBLISHED LICENSED SOFTWARE   *+ \% x. i: }- w* f- `
*   Contains Proprietary Information *
5 G, S% ^7 S5 ^7 k1 R- ~*      Which is The Property of      *# f' u3 r4 P* `7 }. M; @
*     SYMMETRY OR ITS LICENSORS      *
, k+ N" B" ?+ h1 k+ m  d*Commercial Use or Resale Restricted *
8 M8 _0 D( b1 ?* L+ I*   by Symmetry License Agreement    *
# Y5 i' n. R/ R: ^' Z**************************************2 x8 T" Q, x7 q$ r4 W
* Model generated on May 16, 06
1 ]( q, G/ K6 u* MODEL FORMAT: PSpice
3 a9 }* s# S. L$ w1 z0 z0 y* Symmetry POWER MOS Model (Version 1.0)
+ D5 G5 n, Z) k9 S! Y* External Node Designations. E8 _- O3 R- ^( g( l. n7 Z
* Node 1 -> Drain
0 E8 O8 t$ [( t2 @  e: \! \* Node 2 -> Gate
3 w' {+ [4 I  a" E* Node 3 -> Source
. R( g; [6 A9 x8 CM1 9 7 8 8 MM L=100u W=100u
7 q1 v/ ~" S) J* Default values used in MM:* |9 K" K. O& ~7 R* q: o0 C
* The voltage-dependent capacitances are
: g2 ^2 L3 C( m$ b" I* not included. Other default values are:
. f9 ^) d3 A/ j6 c3 |) m' i*   RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0
* q$ F( B$ b7 `5 I3 s4 s' e' c' H.MODEL MM NMOS LEVEL=1 IS=1e-32- P* g/ i$ s% f" \
+VTO=1.37964 LAMBDA=0 KP=0.469867: ?1 G/ D$ K+ m9 [9 V
+CGSO=1.1933e-07 CGDO=2.34268e-086 _' e' r0 Z& W$ V; m
RS 8 3 0.271134
7 r& V# S4 L5 a2 ZD1 3 1 MD* e* ~1 [2 ]* ~, a  p% u" Z
.MODEL MD D IS=8.75564e-11 RS=0.148365 N=1.34243 BV=307 o8 N2 R! R3 c) d+ r/ x
+IBV=0.0001 EG=1.04252 XTI=1 TT=2.5e-09
" \. ^! X7 H* ~+CJO=2.48216e-11 VJ=0.5 M=0.365164 FC=0.1
4 p9 d5 [( x. `) E9 G9 q% l" ARDS 3 1 1.76e+10' L; o  |+ }1 T8 O0 o
RD 9 1 0.0001" x  Z( M  Q! |; r1 M  U+ ]
RG 2 7 362.8535 y& T+ N3 m( _6 ^
D2 4 5 MD1- m) d6 Q+ O* G* F6 t" C
* Default values used in MD1:, f) @. G( L: S' \8 D& n2 l
*   RS=0 EG=1.11 XTI=3.0 TT=0+ O% Y" {9 X( S9 u; E
*   BV=infinite IBV=1mA
  n& {, U; w+ |3 v* _) d) R4 N.MODEL MD1 D IS=1e-32 N=50
% h; {7 ]4 k/ r. K' ]  A! m+CJO=2.43047e-11 VJ=0.438588 M=0.61035 FC=1e-081 ~& y; [; b3 I/ |1 z
D3 0 5 MD22 L# C5 A; y1 K& c
* Default values used in MD2:
6 C1 b( r' V+ }( E0 o*   EG=1.11 XTI=3.0 TT=0 CJO=0
8 y/ l- {  O- _4 W. D0 \5 Q*   BV=infinite IBV=1mA! |% J( ~$ s  h
.MODEL MD2 D IS=1e-10 N=0.55944 RS=3.00001e-06
' E3 u4 V3 c+ s  T: ORL 5 10 17 p% @( O; S& A2 Z8 [
FI2 7 9 VFI2 -1* \. t* f6 w  L  q: y6 x
VFI2 4 0 0
/ E* y- E2 m+ w0 \* A; [8 VEV16 10 0 9 7 1
+ v; H- h  ]) J8 h7 N0 kCAP 11 10 1.95866e-10
. L$ J% ~! z7 s0 X, D4 BFI1 7 9 VFI1 -14 t8 M6 |4 p8 c/ \
VFI1 11 6 0
( ^; ?& p+ F5 e% Z- O5 k5 fRCAP 6 10 1
7 ]/ X: y2 x5 ~* _$ ^9 C' ~7 ID4 0 6 MD3
$ w! B( @, w8 u# k; ?0 M: [" @* Default values used in MD3:
& p; L8 j! H4 r*   EG=1.11 XTI=3.0 TT=0 CJO=0) \3 Q& m) n: t& w9 ]
*   RS=0 BV=infinite IBV=1mA: ]) }( Q% l% l7 f) j* i( |
.MODEL MD3 D IS=1e-10 N=0.55944
6 z/ ^+ u. w: b/ ]& C.ENDS ntr4003n3 u/ P- R; e9 t: e+ Y3 h6 P8 A* p
9 l7 ]+ C6 Q% Z, l. U补充问题(ERROR -- Model QMMBT2222ALT1 used by Q_Q1 is undefined  怎么解决啊,所有我自己从网站上下的 .LIB 文件 生成模型后,仿真的时候都提示这个错误)
; e: t5 c3 O4 \( W* B) u; ?" Y( Y; L) W
: \% V' q1 R: r& [" j6 `
6 E, T4 M9 H9 M# @% P; Y+ a
8 Y) a: z- `- O/ B
发表于 2019-7-9 17:55 | 只看该作者
好像右键 editpart
GMT+8, 2025-10-1 02:48 , Processed in 0.109375 second(s), 23 queries , Gzip On.
