求大神指导一下到底哪里错了,已经调试了三四天了,不管怎么调temp的值都是0.。。 module DS18B20
0 V$ @# y+ a4 Q3 P( r8 D(
" _9 B" Q0 K. I E* @CLK48M,
! b1 Z3 q f6 B//RST,
7 w6 e' _+ o aDQ,( K' N2 V C- N& N6 m" X
temp
7 X3 {3 k( [* t. u$ P; X, [# I);1 `5 }) a% b# J% K
//Port declaration0 v+ J" A$ L. Y! F* M
input CLK48M; \ A8 b8 k2 ^5 J8 O
//input RST;
v& e6 |6 D, vinout DQ; , f9 f% c$ s+ z" F8 R
output [11:0] temp; reg [7:0] Cnt;# n6 V( ~& S: @3 C; @6 O0 { u
reg clk1MHz; always@(posedge CLK48M)! D. I1 z# r7 j+ J) ]
begin0 X6 Q& Q/ O( W2 B& U: k8 b
if(Cnt==8'd23)
( m2 y4 N* \) K7 @8 a k0 rbegin
2 l! _- a6 V1 xCnt<=8'd0;1 F4 d2 c; t$ ^* f+ c+ Y. ?7 W( S
clk1MHz<=~clk1MHz;6 _' I- S3 u0 O# d
end
% B3 Y" [7 U4 n9 D+ [else& ~1 l4 ~, U. _+ n/ K2 _6 d) R
Cnt<=Cnt+8'd1;8 K+ G' E* r! A
end* D; b5 N6 d8 c& n( J* f
8 v. X, O% t5 W& ]" \* c
parameter IDLE = 11'b000_0000_0001,. E1 X9 {* ?) I7 m* C0 Y" b* {2 [
DO_RESET = 11'b000_0000_0010,
. p7 u& R5 D: v3 X, o, f3 W) }; s" hCMD_CC = 11'b000_0000_0100,6 {6 y6 H' A; s6 g5 T
CMD_44 = 11'b000_0000_1000,
1 l$ Z, Q1 x3 A3 @CMD_BE = 11'b000_0001_0000,
) W: g3 ~. V9 [5 ]WRITE_BYTE = 11'b000_0010_0000,
7 P; y! |; @4 }' C+ \/ lWrite_High = 11'b000_0100_0000,
. I1 o1 l. S P6 V. \Write_Low = 11'b000_1000_0000,( W \3 v$ i5 w* z. D1 ?6 I
WAIT_750ms = 11'b001_0000_0000,
' ?- M# C& M X! P0 M4 f9 k VREAD_BIT = 11'b010_0000_0000,$ ^8 v# v* u& x* `: ?
GET_TMP = 11'b100_0000_0000,$ C4 w3 d# A( U( T
WAIT_4MS = 11'b100_1000_1000;% `; v5 g2 a) |8 `8 O4 n: w
//-------------------------------------------------------------------$ B* A$ U$ f- w' r# h
reg [10:0] state;
* v y8 O" H7 Q- B$ b% Creg [31:0] counter;- \ H$ Y8 v ^( P! D; r$ j
reg DQ;# h* t# r- u; L% |9 a4 L' ?9 h
reg [7:0] write_byte;//中间寄存器,保存主机要写的指令字节
) c% ?3 N5 |8 f0 P J$ m5 Lreg [3:0] write_byte_cnt;
1 q+ x% m& }6 E4 mreg [1:0] byte_flag; G) _5 Q5 G) p2 P: ^5 k
reg [3:0] read_bit;
5 R: Q6 \; j/ F/ x. Freg[11:0] temp;//12位温度数据% P# P: J6 d1 ?: I9 L/ m g
reg TMP_bit; always@(posedge clk1MHz)2 J0 @: r7 ~: K D: j
begin9 f# X' _. @8 Z8 T; i P4 h
case(state)) v5 M& M& d9 D6 [
IDLE:. B1 C# j" U: ]
begin) u' j# E. \2 G0 O$ t# \
DQ<=1'bz;//空闲状态释放数据总线,由外接上拉电阻将DQ数据线置高/ z3 Z B) b# ^# |0 l
counter<=0; M! A9 o% a6 M9 S: g+ y
write_byte_cnt<=4'b0000;
8 y9 O( F2 F% ~byte_flag<=2'b00;
8 u4 s6 l% D0 H/ {$ g `read_bit<=4'b0;+ @0 W0 s( Y; {2 k0 o9 z5 ]$ `
state<=DO_RESET;
4 Y% D' I e2 ^end; K8 ~4 T, f& f3 ~, j
DO_RESET://主机拉低数据总线持续至少480us,然后释放总线
% V' J" s7 u5 G4 V( a1 hbegin
( W6 F- ]) e" {1 l2 Tif(counter<=480)6 E( n! B3 E/ v8 }, _
begin- y. V% q5 ?1 x/ S* n8 {+ |; W+ z
DQ<=1'b0;//拉低数据线480us9 M( {4 h, [6 k- M% [
counter<=counter+1'b1;3 k+ c! K2 w' n# ^3 z
end
" N9 x, O5 [9 Z1 V* }5 u3 |else if(counter>480 && counter<=780)
9 r% z& m; o! L* Vbegin
4 s4 L/ U; ?+ F' O# A. ]- RDQ<=1'bz;//释放数据总线60us+240us=300us/ Z3 B/ Y' t8 w4 B9 w1 i5 z
* T! T" v1 N# m: {* S# ~4 V( A9 Pif(DQ)//检测从机是否发送Presence Pulse(持续60us~240us低电平)
( ^: p9 w" y( G, H3 c, r+ D/ zbegin3 K7 u4 I# }$ f6 {! s! V# J
state<=CMD_CC;
, c$ ]1 Y5 D( @$ R' ^" S. lcounter<=0;+ a+ O/ o# f! M( z t" b& ]" |# T5 v
end
% i+ R ^/ Z ?else/ Z; S; p, t. x' @- a
begin
: L7 S* \; @, J2 H1 N1 @9 mstate<=IDLE;/ N9 s6 @# ~( |
end
9 I& D: e; F2 y# D, ~' tend8 N7 Y: N6 j/ e7 g% x
end
7 g+ E: E; [6 P4 dCMD_CC:
' Z% h/ ], B& `8 cbegin
s; N! A' z; U7 U& g4 ]write_byte<=8'hCC;! U1 f' y( Y& r* S' l
state<=WRITE_BYTE;
# h4 f7 n' w, x: w% b" e# fend7 V+ t) a% `6 G2 B! _- J% d
WRITE_BYTE://写指令字节,由低位向高位依次写入从机
; ^6 G- f, K" { Y7 R7 vbegin/ }* L6 j4 f# v0 r: ^
case(write_byte_cnt)6 f U$ `; E) m2 T; {- [( ~* | {: n6 ~2 l
4'b0000:
# u8 H8 g: k% S P; ?# Ebegin8 u% Y# t# i3 y; n& ^. h
state<=write_byte[0]?Write_High:Write_Low;, [. w L" x/ F, P8 e% w
write_byte_cnt<=write_byte_cnt+1'b1;& z8 H9 L3 w1 Q; c+ [; ^
end
% F `6 p5 Z& |* k' l5 Q9 \: ^6 F4'b0001:
2 G, `8 p) `% O+ {% J: mbegin% M$ G) z* p! n) p3 c
state<=write_byte[1]?Write_High:Write_Low;% g2 L" g+ A# F; N X! e/ w
W4 q# Q6 n+ w5 I) hend
' g, `8 k+ ]1 I* V/ Y2 d' F% D( ~) F4'b0010:' \4 j/ B" _# C( L4 b4 G4 L- P
begin5 ?7 k: H* ^7 F( C- i8 L
state<=write_byte[2]?Write_High:Write_Low;
+ l8 U- G; B! E( w. M7 v- iwrite_byte_cnt<=write_byte_cnt+1'b1;! a, K# b0 ?( g( X# w- K% ^
end
" H9 E4 o; ?# I; r, i! A4 @4'b0011:
/ b4 r Q7 \/ Q9 t* Z4 wbegin
% ^8 c; f) M# \) e3 j: \state<=write_byte[3]?Write_High:Write_Low;
' p! i8 L: ]( Z! }. [( f! Swrite_byte_cnt<=write_byte_cnt+1'b1;1 D6 J) Y0 N) w& ] K- H: |( V
end
( O) D# T" B; p6 [8 ^) F4 g% c+ T4'b0100:. K2 T3 h9 }8 q N) v$ k9 c
begin l% y' R8 o: i4 W- k8 _9 `; d3 G
state<=write_byte[4]?Write_High:Write_Low;
5 f& e: h" l( @* u) Owrite_byte_cnt<=write_byte_cnt+1'b1;# M) L0 N) R6 [9 K- [1 k2 A
end
" m3 Z3 E% i) i1 C8 g4'b0101:! L" T# f0 Z; v1 a
begin3 k4 ?) g( g+ }7 F
state<=write_byte[5]?Write_High:Write_Low;
B4 N7 w# Y, ]8 X3 A& Ywrite_byte_cnt<=write_byte_cnt+1'b1;
# y& X5 z6 @ c, J. cend1 @5 r+ s0 r7 Y2 d$ d) a, R
4'b0110:
6 L+ o+ f) _" [, |" |, vbegin
+ k' l3 P; @# _% [; Bstate<=write_byte[6]?Write_High:Write_Low;5 Q/ t& Z+ ?( H# F
write_byte_cnt<=write_byte_cnt+1'b1;6 M6 U5 ~* `; B T7 g
end
/ ?- p3 Q" {& l: t4'b0111:
9 P5 M( p' l4 |begin
: u: T7 O9 I/ h5 S d" kstate<=write_byte[7]?Write_High:Write_Low;" z* ^& `3 Q1 @2 b/ t3 G4 ~+ F0 G
% B# w% g1 ]; G1 j) `end
4 r4 z) S1 @2 p" U9 \# L4'b1000://8bit字节写完后在此处进行状态转换
: l! o5 [7 \9 n; Qbegin% `9 o R+ L. B
write_byte_cnt<=4'b0000;6 l* _) G) y( A R
case(byte_flag)2 J, t' K. @) \5 s* \+ ^& M
2'b00:
: Y% F% W6 Y+ @5 b r3 O( ^begin' K8 e( u8 n( ?6 ]6 w
state<=CMD_44;
) `. }! e/ \9 T! N, X2 kbyte_flag<=2'b01;
5 a7 r2 M* E& U+ N5 Nend
' l9 l! }: C- h7 |* e7 m2'b01:
+ V8 g0 j( x7 x$ _! rbegin3 D; [& a8 ?4 s1 {
state<=DO_RESET;
- ?: Y e, v; \: Dbyte_flag<=2'b10;4 ~( K/ H. R0 B" g5 v1 Y1 y/ ]
end
5 F2 q% u3 z/ r2'b10:+ s3 \! q+ ~ ~' j) G8 C
begin
) m+ B/ H# P2 x9 H* ]/ |! Cstate<=CMD_BE;
) n2 F9 X5 P8 [; @* ] ^byte_flag<=2'b11;
3 Q0 I) X2 v* U- v5 N& T, Nend, p5 z& y1 Z; a) _) a, v
2'b11:0 w: T/ ?# C0 B, Q3 l. M
begin
0 T! ]6 }: p$ Q s {state<=GET_TMP;
6 g0 r( p% y6 I ]$ H( e+ ^. ubyte_flag<=2'b00; ^" d! m3 u! B* b6 c1 D# U- A
end0 p3 k5 \+ B6 h6 u
endcase
9 K: J( p$ e3 Q, R: D/ S* Z! kend
6 t( z% C7 M2 j4 x. k( |8 pdefault:write_byte_cnt<=4'b0000;1 _' g) u1 a9 {: E9 h# p' L) \
endcase% z: Z. L, j- J
end$ O# q" q& Q! R, q, H5 {
Write_High://写‘1’时序:主机拉低数据线1~27us,然后释放数据总线30~数千us." m$ C5 l& d4 y% y
begin
$ u0 _$ s3 |2 I0 H$ Mif(counter<=8)//拉低数据线15us(至少1us): P! N' p9 x* J1 z4 T5 ^) l
begin
1 L/ V- X6 L1 K1 |) v% U0 S. {2 qDQ<=1'b0;3 R8 Z4 C) i6 q6 x/ Q1 a
6 [0 B8 A- F( P: C3 a4 N8 Q1 l' Cend* b5 n* Z9 j; g9 I: P9 r% a/ H
else if(counter>8 && counter begin
* ?) [) a* K' m- _1 N4 [DQ counter end( J& q( W, [7 y% @+ r4 T2 a# `
else 5 ^3 n( R/ L" i, \) r6 x U
begin
' f. ~$ u6 Y7 g$ [, E. i, icounter state end8 ?8 G# Y; T8 W( z
end& C8 Z" |- [8 L5 w+ o% B! }
Write_Low://写‘0’时序:主机拉低数据线30~227us,然后释放数据总线1us~数千us.
. L8 V& _" |( kbegin
. b% ]* n$ y# V8 z% `if(counter begin
0 A" F3 v7 V4 H. q3 O4 g9 u NDQ counter end
$ t: }( k$ p8 `else if(counter>78 && counter begin( @) d. p3 c' s
DQ counter end1 l! c9 H) x! c5 T ^* Q/ p1 \" {1 M
else
0 A, p& j) r* G$ a" }6 U. I1 J1 Nbegin, J$ H3 L# m! T7 r
counter state end
- m$ k% y B9 L) hend& V8 ^* G$ ` Q4 v5 w* j. ]7 S
CMD_44:
, g( b) p0 M! q* S0 r6 Bbegin
6 X. G' V2 e6 P+ v$ owrite_byte state end
( ]9 z7 u: ~# ?! n& S+ f5 S3 D0 lWAIT_750ms:
# S1 Q4 e E; Ebegin3 c' \2 d+ H- |" L
if(counter>750000)//实际上只等待几us甚至不等待也可以
- H! E% {# k* qbegin4 i, P( A& |$ m9 L# n0 [
state<=DO_RESET;% M( g" X- ^) ]4 D9 }& c4 ?
counter<=0;1 s6 R' ]' d/ ~! P q+ \( T
end9 _$ `9 k8 b$ n! T' ?! h7 b
else! i6 N( F/ I% S" C( [$ d E
counter<=counter+1'b1;! u+ r `- w# d6 D0 s3 |
end0 I3 s! {( L: R5 N: }0 n9 W: h+ W
CMD_BE:
2 w# S3 k- r$ y+ @& a8 Ebegin
S. T: B( h- G* n( U6 Wwrite_byte<=8'hBE;' w. y0 g0 z# i9 @' \' q( ~
state<=WRITE_BYTE;2 u+ n0 U3 j1 V4 V" H) H( X
end
( i g: h9 {+ Y% sGET_TMP:
- j# I/ l1 m' ~. \begin
7 N. H9 L5 c. M" y% @case(read_bit)
" B' H( j- ~; `9 E( K2 }5 y$ @4'h0:
5 I, O& {" e" J; ?- q3 Q* E- I" x4 r! Wbegin: Z1 y+ L1 c- ~9 C' N' Z! o
state<=READ_BIT;
: ^0 f% p" A! F4 Jread_bit<=read_bit+1'b1;* `& y1 g3 e% [% w6 M
end
0 V4 T) j' a$ E: y4'h1:
1 I/ j# _' t9 e' Fbegin# k9 w3 ~' K: E6 h+ M' L
state<=READ_BIT;5 I8 v! b. f# y4 F0 }
0 ~9 n6 \+ b0 `# g0 Y: h/ ]2 t2 X" Xtemp[0]<=TMP_bit;
. J& t$ Q5 a+ J- send
" b7 B3 E0 z( P$ g9 S$ I4'h2:
* Y, e. S2 A0 d: q4 T$ Xbegin$ A- [" _$ s* M: x3 ~7 J2 K6 F
state<=READ_BIT;
9 L: [: }9 u3 B7 a6 Z* kread_bit<=read_bit+1'b1;" `" O5 g+ m6 O8 U# ~& t) s
temp[1]<=TMP_bit;
" L2 i8 Y. Z7 }6 V, S0 X2 |, f% Kend
4 D9 d$ b0 D7 D# F! v- `! Q8 t4'h3:, H% S/ @8 y& T0 w9 P* y
begin4 ]& c2 v$ ~6 F* K6 s7 `2 n6 h/ j
state<=READ_BIT;3 D* q0 D0 v$ e% M3 Y, g* ~# s( B
# t4 G4 X% a' h2 jtemp[2]<=TMP_bit;
6 w1 W* X$ w$ ^5 P7 g" ]end
# O& e( Y6 `0 I0 {- m/ G& g" d8 R4'h4:
' \) `" W8 c( V% Y" H& wbegin/ H& q6 A8 X$ |5 n& q G" H3 X: [
state<=READ_BIT;
5 j1 U( f+ C0 jread_bit<=read_bit+1'b1;( u; M, ]; W- g1 S! ]
temp[3]<=TMP_bit;- K6 y% o8 B$ x; `# G: Z2 ^+ D
end
+ _4 Q% z' V, G9 B4'h5:" k4 S3 Z- c$ A: b9 Y" C' C7 g3 M5 f
begin
3 j- X( m: c& e6 u6 s7 Lstate<=READ_BIT;1 }) U5 z4 s. [3 B! `
" n7 U' k! r/ I+ z/ F' @temp[4]<=TMP_bit; d( g/ V- d' {0 A( O0 p
end) z) A) e9 f( \7 i/ x
4'h6:
/ A/ w4 k$ z9 F8 U2 |1 bbegin
0 D! G7 U& p+ q: l& @9 Sstate<=READ_BIT;
- C9 ^& ~' w. B* \/ `8 H5 ~0 [read_bit<=read_bit+1'b1;9 \/ ^; _- r; \# F
temp[5]<=TMP_bit;
0 @3 Y3 C9 n* hend
9 s, A7 P: N0 g# u" `4'h7:1 P7 X5 j/ P' ]# r& B; m+ q
begin' c; K) Z, X. T2 p
state<=READ_BIT;' _6 `. v# I0 M7 [+ H
read_bit<=read_bit+1'b1;8 s+ ?) ?+ O% M& x8 Y* y
temp[6]<=TMP_bit;% [, ^6 j+ Q% V$ ~! C8 B# [3 a2 K
end
% J# g0 O9 j" |# n# p% G- V4'h8:
* ^$ t9 N0 S* {3 E' Ibegin
) p4 c3 g) F: |4 Y/ k4 Kstate<=READ_BIT;
2 r9 }7 m% {8 Xread_bit<=read_bit+1'b1;' H, c& t# a4 v5 K
temp[7]<=TMP_bit;
7 R& r( f- }2 e& `& e( } Fend$ i9 {' O7 ` {' U, V# S8 ^; |
4'h9:
% }8 S, f: I! Hbegin& c2 v0 [) m0 O5 k4 u
state<=READ_BIT;! E2 {9 A( {, G8 V) U
0 \5 V" V5 }$ ^, v) S: _8 ttemp[8]<=TMP_bit;; `: o! w2 o" B+ Y7 c# H
end
7 n* h% v( x+ y9 L, S, i* T( i4'hA:1 u% ?6 B# F. X; Q
begin' q+ L$ ~. q! V5 ?) n% b3 e' @# g
state<=READ_BIT;" K% Q/ W/ k# r; b. A) W* n& E/ x
: V7 H0 l) v' q1 {temp[9]<=TMP_bit;% }- s; v- N3 y0 d2 ?, o
end
* `" v: W" @9 \6 h- f5 W4'hB:9 l" C/ x8 @9 w
begin
6 s% i* J/ d* A, Y1 }state<=READ_BIT;3 O! L5 R* |4 V( }+ i: q$ m
read_bit<=read_bit+1'b1;# B# F& s5 M! X# E; e
temp[10]<=TMP_bit;
6 C! a# ~" J: W f9 Tend
- D c, k, ^0 `" S4'hC:) x6 R& Z* z5 u( a: j
begin. [4 h; `0 _* V! n
state<=WAIT_4MS;2 ?) v2 n0 W. q+ C7 g1 c
read_bit<=4'h0;, o, Q; d% j/ \& R: _. [9 B4 h
temp[11]<=TMP_bit;/ w3 Y: K* y2 q+ r+ u- w
end4 }" Z! w k* l5 F6 b. E
default:read_bit<=4'h0;! u u" k% n4 X8 z5 W: B) y
endcase 2 [. H9 q3 f S2 O4 d
end
. S& R5 z+ e; N' ] jREAD_BIT://读时序:主机拉低数据总线约2~4us,然后释放数据总线2~4us,再读取DQ数据线上的值
: Z' {# x: G# c: ^* W: l8 n9 nbegin ' i6 R7 S0 G+ `# ] U+ i! Z
if(counter>=0 && counter<=3)+ D7 ?2 C& S- P+ P& V: p9 p- S2 \
begin
2 F2 c; Z9 N' ]( a; vDQ<=1'b0;//主机拉低数据总线约5us& k, x' I& j: U6 f$ g
( e# z. T* C, ?# A" Dend1 T' R9 Y. R/ T1 g: E/ F8 {7 ~4 q
else if(counter>=4 && counter<=7)//最迟必须在29us处释放数据线
( Q. g0 G4 c G' ^begin4 x4 }7 g |0 a
DQ<=1'bz;//释放数据总线5us" e l. \3 E: {
6 f, b) J7 }* s0 zend
% P% _" F8 j- I1 Y. T/ e& jelse if(counter==8)1 v/ G$ n' L" o; f1 K; f- c+ _+ k
begin
+ X8 z# Z2 R# I* ?8 U8 c6 N W& ^* I7 n- O) k7 P$ n
8 E8 b5 n& t3 b1 p% B2 n9 }" ]& cTMP_bit<=DQ; 2 N) o1 r/ F8 O$ }6 J9 m/ w/ V
end) L! u+ X$ _( ?
else if(counter>=9 && counter begin$ k8 E7 Y; z6 B; X3 p3 x7 Q4 R
counter end
2 |. ?& }: \5 l; x% Eelse
/ l0 W: J+ s5 g) {+ J% `" ]begin
# u6 I) M( i; h9 \state counter end/ Y! ^/ b, M9 \7 W' B0 I# j% U# r
end
8 y& g, {6 j3 b) Y" g, A* N. d" HWAIT_4MS:
& G1 ~% p. N' X8 Dbegin) _1 r; z' Z H9 X9 ~+ T
if(counter>4000)1 P2 {; F- `7 ?: a( h k* p* N
begin ) I, b0 w( B$ m! T
state<=IDLE;
0 N6 l) j/ s: N# G% v1 Z3 ]counter<=0;! R* `6 v3 s; A4 w T- N0 r
end
( \) H/ S9 n5 p$ f: }* N! o3 delse8 Q3 Y- L- P6 c1 Q1 h6 L
begin
/ h2 i$ H, i5 _counter<=counter+1'b1;) p8 I1 b3 `. m7 e# k2 |) D! l
end
* ^- H P& K# i2 O! Z0 v1 Nend
/ Z+ X6 @/ M; t( _default:state<=IDLE;
/ a* g( Z$ \0 O# V4 jendcase end 2 z* [3 J- o2 l5 ?5 S# @4 Z
endmodule
, t# ~4 R- A# z+ B4 M+ u |
