記事本內容如下所示,注:我在自己家里電腦導入可以成功,惟獨在公司里的電腦行不通,
$ F1 O+ ?9 j+ `自已做的part Type 庫也有拷到公司里,也有添加自已做的part Type 庫,導入PADS Layout
+ i3 v- _# E, T, K5 B就沒有自己所做的PCB封裝.
8 v) Q m1 f2 d$ W/ A0 L9 y @& K
, r+ w5 r; P2 B0 C' A7 @Reading file -- e:\PADS Projects\padsnet.asc2 K" F0 j! U' ?6 j3 w
Can't find part Type item < MS-CARD_PART >
( o5 s) c: `3 H: ]5 ~JP2 [email=MS-CARD_PART@MS-CARD]MS-CARD_PART@MS-CARD[/email]
1 {# R0 B$ e) {! ZCan't find part Type item < SD/MMC3.2_PART >
- t$ g* \8 U. G9 m9 WJP3 [email=SD/MMC3.2_PART@SD]SD/MMC3.2_PART@SD[/email]
$ m1 S: |% O) Y; s# L6 \Can't find part Type item < SM/XD-CARD_PART >; \. n+ C$ }& G$ q
JP1 [email=SM/XD-CARD_PART@SM/XD]SM/XD-CARD_PART@SM/XD[/email]- F* {1 U4 f6 t/ s6 f3 G; _
Can't find part Type item < USB-MINI_PART >
4 r, E0 [: x7 q: \JP4 [email=USB-MINI_PART@USB-MIINI]USB-MINI_PART@USB-MIINI[/email]( I3 B; y- D0 J; D! S1 C
Can't find part Type item < AU6457 >
+ A6 R" b" v6 [* X7 v0 jU1 [email=AU6457@AU6475A]AU6457@AU6475A[/email]
. u4 t" B/ x6 D' sCan't find part Type item < PH2.0-5_PART >
6 |. {! |0 |7 V# HJP6 [email=PH2.0-5_PART@WAF2001-90S5]PH2.0-5_PART@WAF2001-90S5[/email]2 t5 Q' }+ {9 X' S* `1 k1 z
Can't find part Type item < AMS117-3.3V >
/ \; D7 Z% |- p uU2 [email=AMS117-3.3V@AMS1117]AMS117-3.3V@AMS1117[/email]
l+ @& T. i% B2 E9 XCan't find part Type item < CF-CARD_PART >
0 b. K! d, N1 t, Y6 ^JP7 [email=CF-CARD_PART@CF]CF-CARD_PART@CF[/email]0 }8 h5 l1 \) Z, S8 F6 p
*Part name not found JP71 s6 l- v$ _! g, V& D3 }
JP7.41 ; W i1 |- |2 G5 O1 U
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFRST
7 Y& T5 T$ p9 a7 g; E' h*Part name not found JP7
: @) t* e, d$ i- m" ?: PJP7.5 . R( b' x2 h8 N, i1 B5 B% z
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD6
1 w5 M9 P1 G2 R9 b$ V$ X% D$ {6 y*Part name not found JP7$ z8 t ~3 l2 ^3 f$ \4 F+ G. i! Y
JP7.23 5 G) \5 J9 M! x9 L! A$ [/ a
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFSA2
# r5 W! ? {0 e4 q8 y" ^*Part name not found JP78 {" |; x7 I7 z. G6 I, M
JP7.19 - n0 `) ~; ~! A- m
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFSA1: C1 F) d8 T! a3 D
*Part name not found JP76 m4 f4 X3 P: i- p8 |$ z" V
JP7.21
! Q l5 `+ x3 ^' t*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFSA0
2 b" R. \3 b; N9 n*Part name not found JP1# x8 e% O% ~: P* a1 l0 G, ^
JP1.A11 JP1.7 ' Q6 l% r* p7 K- ?( M
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD1, \, M2 o7 U" B3 \7 o2 Y
*Part name not found JP1' v4 r! v7 Z9 p4 O- y
JP1.A10 JP1.6 * M$ r: t+ n) t9 S
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD0
& Y* S: E( p3 T*Part name not found JP1 X ?, R3 b5 {/ {
JP1.25 JP1.5 JP1.A8
/ J7 I1 _/ J/ }*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDWPN0 U% E8 p1 _" B( ~, \) o2 d, I
*Part name not found JP11 n; M0 M% O8 E
JP1.4 JP1.A7 R8.1
! X; ^6 z4 \: f7 p! A3 S5 q x9 k( f*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDWEB* z% ]! F! b T/ C3 p
2 c' W, Y" l! R; a( k. FJP1.2 JP1.A5
7 X$ Q+ W z4 a! m! Z/ M- A$ g- d0 A*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCLE
" X2 O3 j# |+ n" x# T4 f*Part name not found JP1" ~" a' ^* J' p
JP1.3 JP1.A6 . B% `4 q. I3 O: h$ w b, p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDALE
/ o' e7 p6 K7 r/ h0 L% W*Part name not found JP1; h8 \- ?* _3 @- C `
JP1.21 JP1.A4 R7.1 - s# L7 l9 L: A* t
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCEB
8 [3 E) w( {% s- T*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCLK8 G) z2 j0 N V6 ~$ G
*Part name not found JP20 j- o) l4 H' R) o. O
JP2.4 0 Y$ z0 c% R6 R# V
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSD2
: Y/ s; ?, J8 i6 ?8 ]*Part name not found JP28 a6 h2 @9 y* D% X7 B( V+ X
JP2.3
/ @$ j8 h' F+ w, ]6 J( e" ]*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSD0
; L$ D& l7 V8 D& U+ `8 G*Part name not found U2* D$ n" F$ Q& v+ v6 J3 Q
R13.1 R15.2 U2.2 C14.1 C13.1 # v. A9 _7 F/ J2 f4 ~% q, g, f4 Z4 i6 b
*Part name not found JP75 n8 b* n! |% t% ?+ I. w# W% C( y
C16.1 R4.1 JP7.34 4 G% W }* r; l0 N
*Part name not found JP3
. {4 r& e3 a% `8 r: e, BJP3.4 C5.1 ' J: E& r$ V' {1 _
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDPWR
3 r3 k, |! Z/ m, i*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSPWR
# I+ K! Z$ G0 }9 \8 K: M*Part name not found JP1 t' a& L$ A4 `4 N/ s* {5 B3 W
JP1.A18 R8.2 R5.2 JP1.22 JP1.12
; [# ^1 d% [: |; r7 g D5 Z*Part name not found JP7
' h% u( v' [! ~& X: h; g, J% vJP7.30
0 ?) B! B6 h. V% ]*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD145 w1 P* v0 _, o5 B( u! z5 S) O
9 u5 |% \) M' S. |0 ]/ F7 eJP7.6
2 W6 A. v5 q4 I* V" B, i% V$ e*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD7+ i( ^( K. u( O& K
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFRDN4 r+ p& j! m1 V" H' S1 x( ^
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFWRN
: @# k0 v, Z. P/ h*Part name not found JP1) q2 ?$ D4 H) K1 H1 _- a( U+ e3 J
JP1.16 JP1.A17 2 z( @! L, X: y
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD7
' E$ I2 d1 w9 F! E- r% S& g*Part name not found JP1
/ {4 A K" C# E0 m( x- ~' PJP1.15 JP1.A16
5 a3 n$ q I8 `$ u*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD6
, C1 f' d4 X j& W: m. T*Part name not found JP1* c3 a( m' \; l- |* ?3 C& _
JP1.14 JP1.A15 3 c8 |7 U7 h$ j4 t2 J) T
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD54 {( D" B( B' Z$ x
*Part name not found JP1& c: `% U4 ?( p6 R
JP1.13 JP1.A14 : {8 d- f: l9 F2 G* g( v3 }2 ^
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD4
9 B# \7 m( ~1 t9 V# R" V( T+ F*Part name not found JP1
# [% q# k0 g+ m, ]* cJP1.A13 JP1.9 " O% ~' N/ r2 ?$ A6 H5 V. K( _
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD39 r0 `5 V9 X' j( r; K, L% j ?
*Part name not found JP13 f0 l$ }* T5 { l8 `
JP1.A12 JP1.8
* J+ z$ N, h h' L1 ~( P*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDD2* `, ^+ `2 j; }* h9 f: [, a4 Z! M
*Part name not found JP3* ^1 M3 a8 w V# s4 e, ~$ S
JP3.1
, Y# J* O1 D! f*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD3( a8 i3 I+ d8 ~1 ?( S
( y" w' h! z( U- _- `) yJP3.9
$ |5 }9 d/ e9 ?5 {5 R3 J. _, D" X( [6 i* j*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD29 [; @' I: P# N4 e# Y1 k; S1 Y
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSCLK9 a5 {& ^0 E' X! J% Y9 K
*Part name not found JP2$ {; b5 U- |) v
JP2.5 5 }( S7 H6 @# P, |* W0 Y3 |
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSINS
8 J0 _! [+ x V, h1 `! W* X*Part name not found JP7
* W2 Y) r9 \ c5 k* Z2 C% YJP7.11 JP7.50 JP7.8 JP7.10 JP7.12
5 K8 f+ d3 X, c, L$ ~*Part name not found JP7
8 i2 b# s1 R' t7 ?2 J# kJP7.14 JP7.16 JP1.1 JP1.23 JP1.A1 ! H1 w1 ?# c2 X" U J
' ^# E* u9 P' k k/ x; WJP1.A9 JP3.3 C5.2 C6.2 C8.2 ' `$ ?7 z0 Z6 i5 x! T) H
*Part name not found JP4$ o0 Y. q x9 F" s; ~7 f9 I
C7.2 C10.2 JP4.4 JP4.5 JP6.4
) D' e3 j9 @7 s+ X* g3 D*Part name not found JP6( u0 b, B1 M$ o* u$ p
JP6.5 C9.2 C12.2 U2.1 LED1.K 6 z: D0 h6 @% t% b
*Part name not found JP71 Y* ^& ~/ I- b, v1 F
JP7.7 JP7.9 JP7.17 JP7.15 JP7.39
( _. `3 `6 @' w" d. l6 ?*Part name not found JP1
" \6 Z* z1 M9 NC18.2 C19.2 JP1.26 JP1.11 JP1.10
6 a/ i4 A. P, H# I*Part name not found JP7
, W1 s" u1 a" S ^C20.2 R2.1 JP7.1 JP1.18 C11.2 4 G" t b( c% _5 p0 G* X* P# J
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal VCC1.8
8 v1 c/ _ F0 H2 a*Part name not found U18 c" L9 O& ]/ M
U1.1 JP7.29
, Q+ Q& f- U' u" Z- J+ D8 A: a*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD13
1 V; m" s" S8 d) E+ X6 [8 y*Part name not found U1
% O& R8 c- J$ \# v% x1 @U1.2 JP7.4 ) y3 T0 q- B' v6 {! y) S+ @6 O# F
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD5
& c. {3 T) k; y; I2 \6 n' P+ N*Part name not found U1! w0 u8 w W$ `9 L5 I
U1.3 JP7.28 2 k: h; s* l2 d6 \ m+ |% ~3 U5 j
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD12: `' Z* o6 j2 V0 S% W0 T
*Part name not found JP7' t/ n; B7 ~$ R
JP7.3 4 A4 b3 g# ?' q! g7 b# w1 v0 E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD4+ n9 T. x7 T& k( C8 Q
*Part name not found JP7- [( ?/ e- N- Z$ ?& t! F5 R
JP7.27 9 W" j9 g v- T$ ^4 U3 q
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD11
; D- y+ ^! B$ Z*Part name not found JP7+ f" i! N, J( c% z! Q
JP7.2 ' n1 E( r& g- ]5 v
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD3- q2 L+ o# @) q9 u/ Z6 p1 ~
*Part name not found JP7! l7 E! e" B1 c% R( X8 z
JP7.25 C15.1
4 S1 i& n( U: w( n2 I& H1 o& G6 o. y*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFCD
d4 {' i7 e4 q# l3 s. y& S8 o*Part name not found JP7$ b7 L# {( f( n6 ^ I3 h
JP7.49 * G& t# S+ M+ n6 M1 S# f
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD10
8 t( g: j! j( k/ H" Q*Part name not found JP7; x# z3 T& n! L/ M, H
JP7.48 0 t G5 K& s" `( h! s4 @5 X, E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD92 z t+ I) L* q7 Z
*Part name not found JP79 ]' v1 T! ^0 w
JP7.18 . }( b# y5 \# \. D1 Y5 C
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD2
2 K! ?" H7 X& I3 e$ {) q4 \*Part name not found JP7$ E1 L9 P& S5 u
JP7.47
6 T! I0 v5 A% {3 q. b8 R$ [*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD81 E3 w8 ~8 w& f- D% M& f2 g: L8 b3 V
" C2 X- l% i) EJP7.22 3 u( W# V6 ]; h
# k$ Q+ C; [; p1 D! V; a- \2 M* R2 }*Part name not found JP7
. v" L# k1 l# R# T* \JP7.20
- V% _+ q$ `* C4 b& _, D. c*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD0
* `) }( u* }/ T*Part name not found JP4
' N6 F3 m L" i+ A+ Y( HJP4.3 JP6.3
" @" q- Q6 t' g" V- ~*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal DP; [) K1 Y+ s+ t$ i. y1 Z2 s
5 k! L5 ?) I" f7 P, ~. aJP4.2 JP6.2 4 c, P# ?9 o( q( t. d( @
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal DM
4 e0 k/ v3 f' g: Z& k8 t*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$9544
& d( }1 q* F! Z" R" Z, m+ e( X*Part name not found JP7
" |& W& W/ T0 ^. a. q. x' MR3.2 JP7.35 C17.1
* H% C& t3 {* i7 T& V9 {5 \" t+ z*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFWRN1# c: J }" Y, E; e/ _
*Part name not found JP76 {8 P' a" e! n* }6 e+ v
JP7.42 3 A9 x* B+ s, w, V2 t
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFWTN5 A/ P, R3 u& g4 W7 B8 W! J0 O
# [: Y r {8 }, V0 T1 j: OJP1.19 JP1.A2 R5.1
! ~8 Q U4 q. D! K, ^9 @! |*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDRBY1 Y+ N0 U) p9 f# N) k
*Part name not found JP1- Z, ~8 s' ?$ b% E2 i2 L+ `
JP1.20 JP1.A3 R6.1
8 O5 J7 l6 m% f# ?. y a: [5 u( U*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDREB! Q* ]$ s. a; U
*Part name not found JP11 z }+ {( \6 b1 z, \7 `
JP1.24 & x, G: i/ w- u
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SMCDN# ^9 z" I6 D& f/ Q. b+ Q) q! Y1 P
*Part name not found JP38 j8 m4 g: s: [2 e- P; X4 ^
JP3.2
( k: M6 \4 @3 \4 T9 n*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCMD
Z: e% \ w m& e, _# S*Part name not found JP7: u$ R* z2 }9 J' o, @6 Y
JP7.13 C4.1 JP7.44 JP7.32 JP7.36 - ^. y( ]6 a& u/ W# X5 o$ O
$ t, u$ C5 {; H4 iJP7.38
7 G3 l0 K/ A+ g( s1 L) T*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFPWR3 \( x6 P9 F9 D9 ?9 |- t+ B
+ `; _5 A! F! y. k( cJP1.A19
4 k9 d" f/ P0 |6 a8 h o$ c*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCD
8 h1 S- s4 Z1 [2 j! B7 q' f& \0 R* x*Part name not found JP3" r. |- B! s6 v8 s
JP3.7 5 ^% K% k: g5 ^2 L
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD0
+ s; e" N7 m/ `+ V5 R*Part name not found JP35 v7 t/ M$ |# P
JP3.8 & K9 }" v5 f7 v$ G. a/ m
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDD1) X2 S% G7 G* w J4 b
*Part name not found JP3% Q! K9 o/ i! i
JP3.10 , T' v; j* l# ?5 \ a
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDWP k1 g4 n% M( c7 T8 [
*Part name not found JP3* O2 j6 ]+ {6 E; p& C' A
JP3.11
% A! q. C# ^9 w( q+ O, r) S*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCD
2 S( B% N! |3 d6 r2 c*Part name not found JP2
5 b1 z# V4 k! y, |$ F; aJP2.1
$ o V$ M( w2 V*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSBS
+ ]* d2 \( I1 i( V) X5 E*Part name not found JP3( ?3 Z. N; A" p! B6 Y
R9.1 JP3.5 C6.1 7 X$ D$ B0 L9 b4 b
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal SDCLK1( Y: D, V0 e4 ~4 }2 }- u% \
% u& @- Q, p; C8 R( R! U, l( |: rJP2.2 / C3 C# X3 E9 o1 A4 {
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSD1
# Z- g& |( f; C9 X# x*Part name not found JP4
; R) @+ v( Y/ K. v; xL1.1 JP4.1 JP6.1 - `( O$ Y4 m ^ k& G0 p
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal +5V
, t0 y! k/ x+ q% p9 x*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal XDCISN
& L: p, I3 u ]8 k*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal DECV# }9 D: x4 @+ ^3 Z1 W$ d, e" `) r! i
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal VCCREG
8 `% h2 F8 D/ b! ~7 {*Part name not found U2
* A c8 u6 d4 s" \R11.2 L1.2 U2.3 C12.1 C11.1
]3 ] l3 B6 P& b) i*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CLED5 A+ a6 q/ P9 v( [/ T# S
*Part name not found JP7/ h6 a9 X! m7 l2 A: J; g/ T1 o- r6 q
JP7.31
7 I- @& X8 [' R" \9 E*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal CFD15
' y; A& |* j8 GATTRIBUTE VALUES+ x2 P# G6 Y8 V9 @( W( |5 ?
Error: Component U1 not found, b$ G% M/ H* {: E$ j
Warning: deleting signal CFRST
9 I2 m# g) I* j; c4 n# e2 R& jWarning: deleting signal CFD68 Q$ |( S1 \9 `5 s
Warning: deleting signal CFSA2
6 `+ m* [3 N) w; m* TWarning: deleting signal CFSA1& P2 U% L* _8 V/ S4 V0 p
Warning: deleting signal CFSA0( Y2 A. O2 A/ d
Warning: deleting signal XDD1
1 X6 _. b$ `! t6 p# ^Warning: deleting signal XDD0* i- T4 l& _, I
Warning: deleting signal XDWPN
y2 X3 e! m2 _% aWarning: deleting signal XDWEB
% B/ Y* U' p0 m Q T% m! \Warning: deleting signal XDCLE4 V( B2 f9 F% ?- V) M6 y( l( { \
Warning: deleting signal XDALE) L; z4 B! K ^1 S) e
Warning: deleting signal XDCEB
+ P- Q& _3 u( ]8 n# qWarning: deleting signal SDCLK4 ` z! Z; n' y- Y7 l
Warning: deleting signal MSD2
y) T+ r' f3 \/ aWarning: deleting signal MSD0 p4 ?3 O! {: k8 d9 F
Warning: deleting signal SDPWR# {; }: l# T5 c" a5 {$ s6 x
Warning: deleting signal MSPWR
7 _) L0 q$ n/ U$ I0 ~Warning: deleting signal CFD145 B/ I" j; o" ]3 \( B
Warning: deleting signal CFD79 q7 {' d8 |" J% P
Warning: deleting signal CFRDN2 I3 [' E( w# s7 h _
Warning: deleting signal CFWRN' J6 B8 g2 ~3 ]( b! \
Warning: deleting signal XDD7
; l% [- _5 F. z" x0 {6 r: p) {Warning: deleting signal XDD6! C( Y _6 a2 ^: D I* T. S+ s- [
Warning: deleting signal XDD5
) u! F) r! d% J1 v; N5 SWarning: deleting signal XDD4
' U; D( l q+ G0 tWarning: deleting signal XDD31 X2 C- l( h" f
Warning: deleting signal XDD2( @. Y9 a0 p) }8 a0 I& G8 }" @
Warning: deleting signal SDD3
" Y5 Q' j O9 S: N. n. _; ?9 hWarning: deleting signal SDD25 a, U, ]3 o7 ~, ]; |. ?1 p# h
Warning: deleting signal MSCLK2 k' C7 h0 ~* R+ ?8 `- }- A) b
Warning: deleting signal MSINS
) c9 H( i2 p- q9 J/ f: }1 B6 k6 N7 NWarning: deleting signal VCC1.8
5 e( y& X( D( P5 `; K7 d! e: tWarning: deleting signal CFD13
1 Y8 E9 O) G# w- qWarning: deleting signal CFD5
6 b- n+ {+ j4 Q- R. B. S" @" c; j: qWarning: deleting signal CFD129 o; w1 {0 A% b$ U
Warning: deleting signal CFD48 S% |" m- O7 ] j$ I; U
Warning: deleting signal CFD11* A9 ]6 l& ^& ^# k
Warning: deleting signal CFD3
' B& m7 O* d$ c; TWarning: deleting signal CFCD
/ j s$ Y0 x3 {- h3 B# EWarning: deleting signal CFD10( x5 ]0 I, }! T9 K
Warning: deleting signal CFD9: h% v6 n6 N, {* U) L0 D( U; H$ b
Warning: deleting signal CFD2, j. i, \ ]. A! v: F
Warning: deleting signal CFD8
% z# m9 U0 ?6 S+ ^Warning: deleting signal CFD1% r5 e& ]4 @$ Y8 q
Warning: deleting signal CFD05 w& ^/ u' P) d* Z+ E
Warning: deleting signal DP
# v, ~( z# b5 q! bWarning: deleting signal DM
" S; i: U3 f, lWarning: deleting signal $$$95443 C3 n$ J W) f& j3 w; e+ W
Warning: deleting signal CFWRN14 _" f7 d. l. u* E7 m
Warning: deleting signal CFWTN
- G' F, \! a: b. b! oWarning: deleting signal XDRBY t8 C4 Q3 e( h, [5 h
Warning: deleting signal XDREB
3 ?: @0 }# }7 k, A+ m6 XWarning: deleting signal SMCDN
: V' P& _* ]4 W+ w. C/ V# X( Q/ PWarning: deleting signal SDCMD
8 B* W# i# `( R Z( u7 o6 j6 xWarning: deleting signal CFPWR
3 [) k+ z4 f6 t8 NWarning: deleting signal XDCD) t( x: p# w+ ^) n6 K
Warning: deleting signal SDD0% z5 Y8 S6 Y& ^6 c; J, m2 }' `
Warning: deleting signal SDD1/ o0 \; }$ k' q, w, ^
Warning: deleting signal SDWP
, G" `# r5 b! V z) L9 zWarning: deleting signal SDCD$ d, `; {7 ^1 T7 p
Warning: deleting signal MSBS' X2 m/ U7 n3 e6 p2 x- F
Warning: deleting signal SDCLK1
+ G3 o3 a- i% e, J! ~8 X- q5 {Warning: deleting signal MSD1
, @5 @& r+ o* e- n# eWarning: deleting signal +5V
; d6 h5 b: {6 p8 q: yWarning: deleting signal XDCISN& L) g/ F5 Z t+ y* k \1 j
Warning: deleting signal DECV
& P1 A* @4 B7 T% q1 {Warning: deleting signal VCCREG
k2 j& D" @' b/ M4 ]. |0 sWarning: deleting signal CLED4 O* O2 [ T& l
Warning: deleting signal CFD15
$ u$ A( U5 H; v; x/ ^**INPUT WARNINGS FOUND** |
