查看: 762|回复: 2
真心求救 请教pspice 噪声分析的问题???
发表于 2019-6-6 20:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
$ M! H, K. Q5 H/ a3 n0 X
电路原理图7 X+ O4 p, |! R
; I" E6 ?7 p, H4 l% ~' d- D/ K
+ _" N4 |& o5 ^5 C$ T! y3 d, [ ( u( z( D: I3 _4 K6 r
/ K- a! T8 p  N, G; V" c
  f$ u9 E! o1 c8 ?8 {" l& `仿真设置图7 Y% P6 d  }6 |! w0 M" ^5 l
, j/ T. p" m0 ^5 M4 j( m
, ~# ?% P7 B7 a- Y . H2 v5 @0 Z/ {! k' ~
. p2 f/ }6 L' u* r9 Y7 y, Z
; M% n& K2 J0 y/ q7 G3 c' Q( \9 D, z9 C  l9 ^
$ X, t# X2 ?9 u
+ I9 ]" x' l( W" J  j2 t' M, k
0 h' e+ r% v+ f. q( S8 y2 H4 m
得到的网表1 P2 L2 N( N' a  n4 F/ M. H# d
** Creating circuit file "3-schematic1-3.18.2.sim.cir"
1 U' D7 d3 ^, c- {3 {' R** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
% m  q( ]% R( l*Libraries: 4 Z3 D% `# V! P2 Y: @
* Local Libraries :  \, x" D6 T/ `( ]/ @7 T
.LIB "..\capture\library\Pspice\op7.lib" ) Z+ z1 a" H- d5 V# O9 V# Y6 N- f
* From [PSPICE NETLIST] section of C:\Program Files\orcadLite\PSpice\PSpice.ini file:9 I$ ?; h" q% f, p' J, g
.lib "nom.lib"
7 [3 M# U. K, D( R: v2 h/ e*Analysis directives:
! z) e# Z8 [  O- k.AC DEC 10000 1 1G" @+ a3 v* c% g+ k0 ~
.NOISE vout V_V4 1$ C# @% Y! J& q4 o0 h
-------$1 Y' J, \: @2 j! `1 ~
ERROR -- Must be independent source (I or V)7 p/ Z" v* D  Z# V$ n( s7 t
.PROBE V(*) I(*) W(*) D(*) NOISE(*) / j4 j+ X" v: ]
.INC ".\3-SCHEMATIC1.net"
  `' M; a$ O/ C1 a4 D' n! A' g! Z$ B) G
**** INCLUDING 3-SCHEMATIC1.net ****
  |' p7 o2 K5 E/ Q$ G! Q' K1 a* source 3  g* V" w0 |! }9 ~4 d1 F1 Q7 _
X_U3         0 N02392 VDD VSS VOUT OP-07 $ h0 Y, W  `  S) w. D  j, {0 f
V_V++         VDD 0 11Vdc5 z. d& K: i6 l' r& \3 R' L8 u
C_C1         VIN N02392  20f
; e- g5 P  G+ T+ KC_C2         N02392 VOUT  500f  4 r  l9 g; p# x
V_V4         VIN 0 DC 10Vdc AC 1Vac
1 X) ?8 Y. I( z: wV_V--         0 VSS 11Vdc% i# \2 j( V9 a3 u2 W
R_R1         N02392 VOUT  100000k
& J1 O" t" v+ p3 O/ H& N**** RESUMING 3-schematic1-3.18.2.sim.cir ****3 {2 ^8 ~: z7 z
.END
3 r8 O3 m2 {0 [$ j+ _% b+ p( x
, U& g. Z5 H$ u" D) i" b' |( V请教上述问题的解决办法???
# C0 Y+ j0 V2 j1 O* U0 D8 M% K) |7 P3 T; k8 B
, m1 o( `7 V% q: g" m$ `8 \& r/ s$ H5 S) u6 I
4 w" h6 q% w2 E
7 c" q" S6 I2 N" W6 l2 o% m4 O: Y+ w
$ u' V0 t0 P2 m8 G1 Y3 h, |1 q% n
2 n$ ]5 o/ }3 P# _# \" S
7 ]7 l; D! |* E8 ?2 {% U' O
( e' [$ u& Z. W/ Y. r7 x& {& j9 Y5 Z
- n  ^) u6 Y0 z- |, v/ X5 k* Y" T
9 d$ N5 M; w' J. Y
  E! q; z* m7 j6 C9 z+ m0 O7 V9 v0 j
发表于 2019-11-7 16:43 | 只看该作者
设置窗口中 output voltage 设为 V(Vout ),可参见附件Help截图
GMT+8, 2025-10-1 06:39 , Processed in 0.140625 second(s), 26 queries , Gzip On.
