Quiet Expert is a tool that predicts where in a printed circuit board (PCB) design electro-
6 `$ F/ p4 h4 v! fmagnetic interference (EMI) is likely to create a problem. Quiet Expert is an expert system that* S- b( Q7 z- g0 R! U
works by analyzing the design’s physical layout, part geometries, and electrical characteristics
+ d% S6 H; e/ w) t3 Qfor conditions known to generate EMI problems. In other words, Quiet Expert automates the' Q% Q9 ]4 f9 I- t* u+ N
process of checking the PCB layout for design rule violations., a: a$ P+ u _$ @: a6 J
What Quiet Expert brings to your design process is efficiency. It is much faster and more! w6 _9 Y9 v5 p' m' o2 P# D2 _
accurate than manually checking your layout to make sure that every part of it conforms to your+ i& |( d q+ h7 P4 C1 u! [3 g
design rules. Quiet Expert also runs much faster and requires significantly less automation-
% V) U" q4 `$ J, h( a9 z- D; ?! @setup effort than simulation tools. A design that might take months to setup and days to run/ q! D$ ]5 Q% }" i& X) Z! c! v
through a simulation tool might take only a few days to setup and less than an hour to run4 M$ E, _8 ~: ^3 v
through Quiet Expert. |
