基于FPGA的秒表的设计 7 `/ L5 S9 o) y0 P& x( t) W7 x
/ D( Q+ Q5 X, O/ T; g5 H
课程设计刚做完,发个秒表的程序分享下。
6 q5 H0 f; T8 @9 } c实验版是Altera公司的ep2c5q208c8,晶振为50Mhz。. c( r W: V4 A# O$ Q% E7 S8 @
功能为复位,启停,用6为数码管显示。精确到1/100s。
: A- G; F- e& [5 q" ?/ ]1 Y程序为:8 s& T3 h7 d! Q C
LIBRARY IEEE;3 I3 x8 s3 D- P" v# _
USE IEEE.STD_LOGIC_1164.ALL;* u2 x4 Q! w5 [" M) b+ s. x
USE IEEE.STD_LOGIC_UNSIGNED.ALL;7 k7 L% E6 a* ~' u* u1 \
--------------实体----------------1 \! M9 I* H5 T4 g9 ?7 ^' ~6 P+ C
ENTITY jishuqi IS8 r$ D9 w, s5 u/ `7 B. G
PORT(start_stop,res,clk:IN STD_LOGIC;
& b; H$ |' G4 D8 ^7 C- Fsel:OUT STD_LOGIC_VECTOR (2 DOWNTO 0);( m k3 A# u9 x1 r" w1 H( U
data:OUT STD_LOGIC_VECTOR (6 DOWNTO 0));+ F' H" q/ W7 E* k# i. q8 s
END jishuqi;
( ^. T- b1 x: j1 S: _' D1 [2 G/ _--------------构造体-------------------------------------( f2 E5 F( |6 C1 |3 d& d
ARCHITECTURE rtl OF jishuqi IS& l* I4 q) z6 {1 V( w% Q
SIGNAL clk_1:STD_LOGIC;$ T7 K# A) O1 x# d
SIGNAL clk_2:STD_LOGIC;
3 H; M$ }$ I0 E: X: I% SSIGNAL Flag_1:STD_LOGIC:='0';8 k" g, ~) I$ C* [ d9 ]
SIGNAL Flag_2:STD_LOGIC:='0';* E8 r, c6 M$ i: H0 u3 R5 g* C2 H
BEGIN
) d+ W8 `) h4 q9 z# K. A---------------分频-----------------------------------# U3 n- ]$ w9 ]' R) q
PROCESS(clk)
' G+ t! L' {) tVARIABLE count:integer:=0;
! _4 u( T' U9 b) d4 G- QBEGIN2 ~- n0 h4 O# a) Z: q. b. l0 X8 F
IF(clk'event AND clk='1') THEN3 N8 h4 F; {* W0 F( O
count:=count+1;
3 V1 w' B: [9 h( ^' rIF(count <= 390) THEN7 j7 S. g6 {& z9 ^3 s1 O
clk_1<='0';
! q- G' W0 @& jEND IF;' A( E% ^1 ]& }2 ?! V. c! u
IF(count > 390 ) THEN* V' j0 g4 y! |2 _! r& j0 ]
clk_1<='1';6 l7 U2 x% ~- N7 ^% ^6 w8 [$ C
END IF;/ |& z" b) l7 f; d+ ~: }
IF(count >= 790 ) THEN" `+ e2 y6 [; M: I
count:=0;
: A: ]% f# m3 }# ^6 gEND IF;: o0 P$ U: U3 u: o5 `( g
END IF;* n3 O, ~4 b2 o' T, L5 a6 ~
END PROCESS;
+ k+ g* w% u2 p-------------------------------------------------------- . D' d9 L0 c' _: r. H- e& D
PROCESS(clk)
' C: K4 [4 _/ ?3 o2 B" iVARIABLE count_1:integer:=0;
3 j1 M9 [/ T8 Z! ^! U5 E: cBEGIN7 T0 W5 H2 M) h' T
IF(clk'event AND clk='1') THEN/ k8 {# p. [) I! q* r7 v* w
count_1 := count_1 + 1;& Y7 e+ q) m; S$ D, l
IF(count_1 <= 159999) THEN; d8 Z) p5 H0 {# ^
clk_2 <= '0';
8 I' p7 q; I) x0 g8 l" B: N* KEND IF;
) f- \5 w$ O* F# h% yIF(count_1 > 159999) THEN- K9 D; g. l$ v# f; j! l7 i2 G7 S
clk_2 <= '1';
1 X3 L# j) |2 l% Q, f3 T) DEND IF;3 c4 t" i* Y! [
IF(count_1 >= 319999) THEN0 A i* |: H! n% q
count_1 := 0;$ M6 p0 \/ ]7 w8 |: f) r- g
END IF;
+ z, H8 Y+ z; v! O# DEND IF;8 [/ A. M, Z. i' F- P8 C! W6 `: v: u
END PROCESS;
- q( q4 O6 x3 F8 Q7 C--------------------计数----------------------------------- 4 P' m" s. X. r& N# l
PROCESS(clk_1,clk_2,start_stop,res)
* a3 K& ]7 g0 W' @$ a% z% H7 ZVARIABLE temp:integer:=0;9 m7 i, a: w- y) r; [, I8 J; j
VARIABLE odata:integer:=0;: }7 _% y- m" A j# i5 A
VARIABLE second_1:integer:=0;
[5 K8 E, N3 Y& M V- kVARIABLE second_2:integer:=0;
' m, _& d% B0 I$ d; cVARIABLE second_3:integer:=0;
- T! B& e, d% `VARIABLE second_4:integer:=0;
; P; i! O0 {# c5 `6 fVARIABLE second_5:integer:=0;
" d1 w* `' A$ }) l4 OVARIABLE second_6:integer:=0; % m) F& X, ^* Z
BEGIN2 l* ]& L/ m8 l
IF(clk_2'EVENT AND clk_2='1' AND Flag_1 = '1') THEN
. Y1 a9 P2 ]; u( }" Bsecond_1 := second_1 + 1;
) B# R7 N, E" l) q' H; K2 P3 z" ?IF(second_1 = 10) THEN/ h* T$ b; T o- }' ^1 d i( p
second_1 := 0;
' P% G" E8 z/ Q* O2 I" o9 x6 Jsecond_2 := second_2 + 1;/ ^- `4 |: L: ^/ a7 k0 E: R% m
END IF;
' P0 N# Q5 V: Q) ]3 S# s; l& PIF(second_2 = 10) THEN
9 j5 J/ c+ R. i. b$ jsecond_2 := 0;
+ t% ]9 v' m* n: m& fsecond_3 := second_3 + 1;( O6 J$ ^+ F3 s# ?* R. L7 \9 }- S
END IF;* u! ~ p1 h. w% O2 T4 V' m7 h- p* d. a
IF(second_3 = 10) THEN
! f+ A$ U# I6 w% c! c- ?second_3 := 0;
+ h6 ^% S4 v$ y$ @* o7 ~- M/ Ysecond_4 := second_4 + 1; L+ O- x& V0 `+ `* V7 R. r
END IF;8 t& K; h3 N5 D! i% p' u# x
IF(second_4 = 6) THEN
G9 v, d+ k7 f$ T8 p2 k8 n- `second_4 := 0;
& N) ^3 j* q+ Msecond_5 := second_5 + 1;
/ e- w8 t ] D& m) B* k* lEND IF;
- z9 L2 a; t+ @! f; C8 r2 aIF(second_5 = 10) THEN" f( C' y! Q) M V! n( b
second_5 := 0;. B6 ~# d7 U0 p/ y9 Q
second_6 := second_6 + 1;% a- s. |; N/ c- q; c |
END IF;
0 z* s1 ~, X1 ? v( EIF(second_6 = 6) THEN
* c+ G: ?( S ] jsecond_6 := 0;. J( z( `* u% { H3 f! h4 Q
END IF;' M8 x+ f5 }) v
END IF;$ z" P, `# {( f& @/ q6 V; }0 i
if (res='1') then1 `, q/ v/ C+ y& L- ~0 B
second_1:=0;
9 O% F+ U$ B+ O$ R( Csecond_2:=0;
4 v% E0 x8 V( J/ Ysecond_3:=0;# p3 O K" M4 z( A. q: A
second_4:=0;8 l% L/ s. h! n& O' X
second_5:=0;5 u4 Y D, t0 H9 ?& X; ^' k
second_6:=0;
/ ^1 {6 T' h- F8 d7 K7 A! Iend if;
4 O1 J; l( C7 g8 A6 T: i( T
4 z3 P2 X7 G: E
1 a7 n! f: x8 R* h9 e5 d-----------------------位选------------------------------------
$ |! `4 L& ]1 R% P3 IIF(clk_1'EVENT AND clk_1='1') THEN
1 M; @+ c; p5 @ J( ^temp:= temp + 1;
9 C, [1 h( a5 oIF(temp = 1) THEN W$ i4 q) G/ O* v5 A2 x
sel <= "010";
' h9 I& V7 F2 U, {3 k/ x$ vodata := second_6;+ C( j+ V% o: c
ELSIF(temp = 2) THEN- s4 J6 w( E0 c c9 x$ {% j. |
sel <= "011";
! D+ c* t0 F5 x6 a! } O! ^odata := second_5;
' W v0 T6 c) y+ u& Z- f& O. [ELSIF(temp = 3) THEN
. N) N+ S2 H3 L3 T4 X6 ^' W* R# Usel <= "100";) G x. r. n! `$ `
odata := second_4;+ p9 C: ]. r4 o- o/ [( l
ELSIF(temp = 4) THEN+ {% m0 x7 o) Z+ P8 ^ b4 J+ r
sel <= "101";( B/ d! N A+ ~4 ~
odata := second_3;
% _' q( P2 v! W' U- y: W) v9 Q+ Y nELSIF(temp = 5) THEN3 g, V# o/ ^, W
sel <= "110";3 ^+ }% b5 n# j4 r/ e6 Y
odata := second_2;
# o" E- @! Q1 h* Y: e0 L% NELSIF(temp = 6) THEN
* _2 ?1 y+ P) Q" l: Z E; Q1 w# p5 bsel <= "111";: W. y* Z' l4 \, Q
odata := second_1;
& O: {6 {8 I. G. S7 L* ]temp:= 0;
. ^3 ]$ }4 `/ C$ x2 B) FEND IF;0 Z+ E8 A" Q$ ?2 }1 B$ S
END IF;
9 v! k# g7 B* A; e' S" u% c----------------------显示--------------------------------
3 c$ r2 y* _) YIF(odata = 0) THEN data<="0111111";! M, }7 A) G- ^+ e# f
ELSIF(odata = 1) THEN data<="0000110";# [4 u* Z3 H6 O' h
ELSIF(odata = 2) THEN data<="1011011";
, k+ I: P* J9 }$ f) T0 cELSIF(odata = 3) THEN data<="1001111";/ k1 h& {0 S; O7 C) j
ELSIF(odata = 4) THEN data<="1100110";2 R7 Q# b* ]8 y
ELSIF(odata = 5) THEN data<="1101101";8 t4 J! a$ c- b& V' _
ELSIF(odata = 6) THEN data<="1111101";! o7 h. o0 l9 t% k( Y; Q' _' }
ELSIF(odata = 7) THEN data<="0000111";
$ N- e1 Z* x! @* c3 EELSIF(odata = 8) THEN data<="1111111";
. @2 F" A- s; d5 O9 nELSIF(odata = 9) THEN data<="1101111";
+ w- ]2 {4 @9 g* t1 VELSE
% K( O1 Z6 |; Q* _: _* g& ~data<="XXXXXXX";
6 f$ c& r6 o! |4 @END IF;# r7 |8 G3 {) ~% Y3 L i
END PROCESS;, M" |- T3 x0 Q$ X! n2 i' m2 _
---------------------起停------------------------------------. v+ a( Z' U; ? s8 g! I+ `3 y
PROCESS(start_stop)
: ^ L# c" l& s1 j: D2 fBEGIN5 p7 D4 x# ]: o# H7 f
IF(start_stop'EVENT AND start_stop='0') THEN5 @5 \9 v, Z# x9 @+ c& W- p
Flag_1 <= NOT Flag_1;
0 |+ m1 c" D. W7 p2 i# |END IF;
/ V; V) ]4 i0 C! B) _4 E, GEND PROCESS;+ \' J6 R+ h, v7 v1 ~
END rtl;
+ _; w ?8 ^2 A0 e/ u
! J5 S/ R( r& b1 z! V/ S9 v8 \: w6 b另一个秒表程序
9 R! i2 n$ l3 X8 I9 a2 F
0 [) ]5 `6 k+ ^6 W4 k太长,以压缩包形式发送。。。。% W" S5 e* N, ^6 E) U+ e9 a. P
希望飘过的朋友们也可以发送自己的秒表程序分享下。还有模块化的写法有机会在发个吧。
# d, W9 o1 ?3 y! ~- d) X8 c9 K) V w: q
; x% G1 p, M, s6 f6 H: N2 l
网上的秒表资料,附几个程序。
- a5 Q) L) F/ h, K" O% v: \" o; ]8 Q& S
压缩包内也有几个秒表程序,仅供参考。具体更具自己的题目要求改写即可!欢迎更多的秒表程序。。。。。9 X3 K0 |* Q, l
! k4 J, b T( W7 \7 T, _7 Q4 l
