查看: 321|回复: 1
FPGA cyclone3代芯片,利用lvds_rx IP核进行LVDS信号采集出现问题
发表于 2019-5-27 16:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在Quartus软件里进行Pin Planner设置出现了以下错误提示:
* e% l2 ]4 `# y5 u4 G希望各位大神能帮忙解答!
5 O0 @* E  g* p* f6 P+ R2 H错误提示1:: H7 M0 P' j2 F9 W6 w
Error: The input pin RX_IN has I/O standard LVDS_E_3R, but the selected device does not support input pin operation with I/O standard LVDS_E_3R
错误提示2:) x% W8 Q7 \6 _2 E/ U% f# N
Error: Pad 106 of non-differential I/O pin 'RX_IN1[2]' in pin location AB5 is too close to pad 105 of differential I/O pin 'RX_IN1[3]' in pin location AB6  --  pads must be separated by a minimum of 4 pads. Use the Pad View of Pin Planner to debug.
楼主初级入门,不太明白。因为检查了cyclone3的引脚表,都是支持差分IO的  但是在软件里设置就老出问题。
7 ^5 F$ z$ e7 p4 f6 e! D) S0 p
GMT+8, 2025-10-9 22:58 , Processed in 0.125000 second(s), 23 queries , Gzip On.
