摘自一个对常见simulator的评论,其中LTspice和ngspice是开源软件。
5 `5 o. S, Q% } h' g# Y( x
9 ~8 y6 z2 _1 k! WMy short answer is to just go with LTSpice, it is one of the best simulators on the market and it is free. You can't really beat that. But if you would like a breakdown feel free to read my personal opinions. HSPICE: - Advantages: HSPICE is widely considered one of the most accurate simulators on the market. However I have no actual experience using it.
- Disadvantages: As you said, it is expensive, proprietary, and as far as I know has no schematic capture features.
- Overall: If you REQUIRE reliable results (Military or high end industrial) then HSPICE is the way to go. Otherwise, I would avoid it.
$ Z0 C% v* k& b u2 S# U ) r e0 ~+ N' e% o, T
: }' M2 y7 U" m; `7 l5 q {7 X, Q
