查看: 1645|回复: 1
小白问一个很白痴的问题,关于 pspice仿真,求救
发表于 2019-5-16 16:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是在用Pspice 验证微分电路的电路图。可是无法创建网表。) ]$ \7 n/ ?# D
问题好想出在器件的参数设置,请问器件的参数该怎么设置呢?
6 M5 Y9 J$ ?: n+ n) ]* B1 n; X
3 R. ~& O7 g1 Q; I3 T& D-----------------------session log 显示如下
/ d. l/ Q# m! Q5 w- Z
6 ]- _! v% ]% I5 U  ^& l0 V- |
0 M  f2 [) _& g8 x: ~
' e- K& r+ c$ W5 n. B0 U  I--------------------------------------------------------------------------------------------------------------------------------------9 Q  M" u! ~( c( ?
The following 1 points have been identified as net connectivity change points from the last operation
7 s5 f1 g3 i; c  K--------------------------------------------------------------------------------------------------------------------------------------
6 c/ P' v" h( ]0 e' t; [(2.90, 1.80)
7 l8 d8 ^4 s; E( x--------------------------------------------------------------------------------------------------------------------------------------5 s. s' U. y( P* T) F- `* o, m: C
- i  G+ y6 f; G4 q0 p--------------------------------------------------------------------------------------------------------------------------------------; p% N' u- i- m, p
(4.10, 2.10)
3 w2 J! J+ o7 K. v% u$ Q. v7 K--------------------------------------------------------------------------------------------------------------------------------------
  @9 s  U; M  y. rThe following 1 points have been identified as net connectivity change points from the last operation
8 P+ p. F( i) Z* ]3 n: ^--------------------------------------------------------------------------------------------------------------------------------------8 u$ n. l  ], |
(4.10, 2.60)
* q2 z; N0 |6 r+ }; m+ o3 V" ~--------------------------------------------------------------------------------------------------------------------------------------
( ]' d9 ]) y& ]  I2 kThe following 1 points have been identified as net connectivity change points from the last operation
3 p3 b0 K8 j2 e1 l6 `--------------------------------------------------------------------------------------------------------------------------------------
& C  a! g0 ^) M7 C# e4 U, X(2.80, 2.60)
; L, q! H' U% r" d7 d' S. [" t* ~5 \Creating PSpice Netlist8 g( _4 S4 Q" _  Z
Writing PSpice Flat Netlist E:\PSPICE9.2\PROJECTS\TEST-0425-1-SCHEMATIC1.net" x3 @1 z; O- f7 {9 S
WARNING [NET0093]   No PSpiceTemplate for R1, ignoring  v9 W1 ^# ]1 f- N2 Y& g
WARNING [NET0093]   No PSpiceTemplate for C1, ignoring7 h- s: w3 T6 [8 d  g& U5 T6 @7 X. H
ERROR [NET0085]   Part V1 has no 'VOFF' property" i  ~/ }/ ^; o1 K$ u
ERROR [NET0085]   Part V1 has no 'VAMPL' property6 z4 J  {3 Y0 f# {1 r
ERROR [NET0085]   Part V1 has no 'FREQ' property9 t* l7 Z9 P. Q% N5 L7 l
Creating PSpice Netlist# m1 n9 v( \6 |* |- \. C
2 J3 J; v$ F) m* ~WARNING [NET0093]   No PSpiceTemplate for R1, ignoring& W. p6 I7 Q% }# u$ |" M
WARNING [NET0093]   No PSpiceTemplate for 1NF, ignoring5 [% b% X; T& S8 D
PSpice netlist generation complete
7 t' @, X; ?' V2 kCreating PSpice Netlist
% r, G+ n) a+ U! D( [Writing PSpice Flat Netlist E:\PSPICE9.2\PROJECTS\TEST-0425-1-SCHEMATIC1.net3 \- E7 l9 r% `' ^' ?- O
  {5 q6 K( l( h6 AWARNING [NET0093]   No PSpiceTemplate for C1, ignoring3 @! B0 g6 f: s7 b5 B1 w+ t
, k, T, |6 x+ T% ^0 |! o3 NCreating PSpice Netlist- H+ {: [+ E1 e
, M  Q- t1 S' `4 J$ ^WARNING [NET0093]   No PSpiceTemplate for R1, ignoring: c3 y- H% R1 t
* O* P# I. b# I6 C. Y/ f0 f) bPSpice netlist generation complete
7 L' @8 v, {& H+ f; K! R8 ILayout Footprint Libraries read from directories listed in the section 'Layout Footprints' of the initialization file.
# z! {4 Z1 W# _* A+ hCreating PSpice Netlist
  b1 _5 i6 u0 G$ U6 l2 O9 r8 vWriting PSpice Flat Netlist E:\PSPICE9.2\PROJECTS\TEST-0425-1-SCHEMATIC1.net
' T" h& h7 M  w2 `7 s4 xWARNING [NET0093]   No PSpiceTemplate for R1, ignoring( V' M6 i7 K3 m- ~8 x( P
' ]. U) Q4 W" kPSpice netlist generation complete
3 O' {! B5 U7 S' D
: W, s1 M. L/ ~2 d, y' s& u) ~
GMT+8, 2025-9-30 23:17 , Processed in 0.125000 second(s), 23 queries , Gzip On.
