EDA实验与实践 crc5_test & m: K6 P$ D" }, m% W0 ^
: {( ~0 |# G+ {6 l0 G. N+ t( A' B! Amodule crc5_test(clock,key,sdata,rdata,crc,dload,rst_n,led,seg,dig);
, r/ v0 V& H' A* }$ oinput clock; //系统时钟(48MHz)- K- @9 G( J# r9 p: C* O
input[4:0] key; //按键输入(KEY1~KEY5)+ ^: ^! {4 ?# l: c3 _/ Y
output[11:0]sdata; //3位16进制数输出(在数码管1~3显示)
! @* a A" g. E% t" l: S5 w* m: _" Minput[11:0]rdata; //3位16进制数输入(在数码管6~8显示)
; u1 D- ^1 M5 R( v9 xinput[4:0]crc; //crc冗余码输入, P# z% ]7 W) I8 m E$ U
output dload; //加载信号输出
$ z6 p( m+ Y9 S& n* a/ toutput rst_n; //复位信号输出1 t% j ~% c4 S( P g
output[1:0]led; //LED输出指示
4 M3 h% r% K' O" goutput[7:0]seg; //数码管段码输出% l: D& s/ n) T7 }# O' c/ D
output[7:0]dig; //数码管位码输出
( j& y. i9 N6 U5 B# W! U; b5 A. P1 @4 t+ r( p
reg[11:0]sdata_r;* ?8 _$ T. m& D: I( ^; v
reg[7:0]seg_r;
# ]7 Z4 z, G4 H |% {7 Breg[7:0]dig_r;
; E l# `7 V! Z* {( N/ o3 v- greg dload_r;! v9 ?) H3 I- u9 v
; G4 o% Y3 ]) {reg[16:0]count; //时钟分频计数器8 i% l- H5 E r! A0 |0 p
reg[4:0]dout1,dout2,dout3; //消抖寄存器 b L; \4 o; {- v7 X
reg[4:0]buff; //边沿检测寄存器6 ^. i0 k( g/ ~4 r8 b; Z
reg[2:0]cnt3; //数码管扫描计数器
* m. X! |' N1 t0 P! Zreg[3:0]disp_dat; //数码管扫描显存
9 ]$ q; v/ M+ w$ ]- Breg div_clk; //分频时钟,用于消抖和扫描
3 k# j Z7 u7 {0 m# u" M$ |wire[4:0]key_edge; //按键消抖输出) u J7 F1 T9 u. f
0 F& d$ v: _/ \0 ?/ w//信号输出
3 `4 h; s/ a- x, N/ O, L8 v8 [assign seg = seg_r;, V; g8 W( l/ @) n" U( ]
assign dig = dig_r;
0 J5 ]+ g) [2 _$ v$ K7 Y% B8 Oassign sdata = sdata_r; 5 Z, A3 k+ P( U: ^4 Q9 F
assign dload = dload_r;3 y+ H+ A6 t0 B& j
assign led = {~dload_r,rst_n};
# B/ U" @& m6 T& c: G; v//时钟分频部分
5 }$ U8 Q) d5 A0 E5 o/ talways @(posedge clock). S/ e, E* |8 x5 i E, q$ s- g, P5 d
begin4 ]0 x9 k( L3 Z- y5 R
if (count < 17'd120000)0 B0 l' j7 T0 N# U- f
begin
4 I/ F6 |* R8 o/ }! E, `: r count <= count + 1'b1;
5 Z. c: A5 L$ U3 E/ z B div_clk <= 1'b0;5 |, M2 A0 T7 Q+ x" P5 Z X* o
end% L7 W3 t5 \: T: c: I
else
m: R0 E3 z: w' U- i5 t begin% x4 | }# q" Q$ n/ Q
count <= 17'd0;2 C- C+ Q1 T2 l! E) r' P2 E' \) w
div_clk <= 1'b1;
. I8 b: z- a- k. B end3 y) K7 H) F# g, E
end5 w- ]5 H7 G9 i/ {
! X* \ b* k, j, O7 X* w
//按键消抖部分
3 q* _- U# N& ^& i+ P/ Galways @(posedge clock)
9 G9 [. }% f0 T: o2 W6 F0 e, Tbegin, j0 E' E& \3 R+ E! R
if(div_clk)
0 Y. Y- i3 B/ B$ m7 j begin/ O$ _) o$ w" n. s8 q
dout1 <= key;4 y0 l1 C9 S% E& V2 U+ B
dout2 <= dout1;
q1 ~ @ s$ t+ _/ |1 t dout3 <= dout2;
5 a% `! Y% p: ^, O- ~' I! E, \ end
/ z1 E) k' k+ x/ i0 m) H: j; p6 Tend% Q/ v6 B: o3 \& G+ j+ u
3 z' L% T R9 `2 u% L
//按键边沿检测部分
y) W D5 l: S7 a9 u/ ?: Valways @(posedge clock)
- I. v* f- E$ r Vbegin2 t# }. u( L2 s% ^
buff <= dout1 | dout2 | dout3;
, e$ D3 S8 Z; W% @& Q6 T' i. _( J6 {end
8 P4 s, \) a) g& V% v1 a//下降沿检测
6 Y* {1 Q# J1 X: `assign key_edge = ~(dout1 | dout2 | dout3) & buff;
; a6 f# ?" Z' o( b V
% B# i9 `/ M' Y) n2 r
! k1 r2 l$ y! g F2 m2 L//3位16进制数输出部分. m$ H. b/ ?% s; Y# b+ ^
always @(posedge clock) //按键1& g+ J" [3 {5 @
begin$ _: q& m$ K, b1 Z
if(key_edge[0]) //下降沿检测9 j/ Z8 _3 i4 q# d( Z' p
sdata_r[11:8] <= sdata_r[11:8] + 1'b1;
2 o# R) d( |- }: q3 l/ D- u! q9 |end
- u# x( }; v" o% H- }( e( z+ K4 X; _9 N2 G- M
always @(posedge clock) //按键2" T! u- h$ l; i/ I
begin( E' j) p U8 T0 ?
if(key_edge[1]) //下降沿检测
# p- ?9 U' {+ k* P7 g' \ sdata_r[7:4] <= sdata_r[7:4] + 1'b1;& q& x. J& U. ^/ Q$ K
end
. g) b: C; R+ P5 e
, W6 W0 f1 E* h- f! N: ]$ Ealways @(posedge clock) //按键3
" a( U- F4 K; V- Ubegin2 P$ u- e: X/ @3 X3 Z
if(key_edge[2]) //下降沿检测
' _% C# X3 z: W1 [) }# ? sdata_r[3:0] <= sdata_r[3:0] + 1'b1;# d# S# f& I* e# V1 T$ ^1 g
end" y$ J5 k0 Q3 V% w. {
8 W! u( a9 w$ I& P7 f2 F) g% l$ ^# Oalways @(posedge clock) //按键4
1 _# K2 K* U1 Q- X& w5 Y0 ~begin$ h( X: B) J/ y0 l
if(key_edge[3]) //下降沿检测
4 I' q/ c# T& C8 y' K \ dload_r <= ~dload_r;) i2 _' S; A/ S! l! G2 W
end
6 U# `% g4 @! ^8 c0 z1 l( ]; x/ J
( q% R+ s! P7 R/ wassign rst_n = buff[4]; //按键5
6 e5 O" y/ d/ w5 S1 \# D5 e& u+ x& P) f. Y
//数码管扫描显示部分$ C) R% E' W* Q; L& Q
always @(posedge clock) //定义上升沿触发进程
: \5 f: V. z0 P6 ?4 Wbegin: ~* j0 q3 I# R4 L
if(div_clk)
$ ?0 d5 _' L y cnt3 <= cnt3 + 1'b1;7 b2 a5 ^/ q4 r! \5 L. @; \
end+ I# U+ l# x t# u* F
1 e- e- G$ n% x1 ?1 \
always @(posedge clock) 0 }/ G5 A. c1 c6 |8 x+ w: H
begin
% j- f* z2 I4 p2 N2 _! F% m if(div_clk): h, C5 X4 l X+ j* Q' k, R9 i
begin$ f: L6 M, r" Z! o4 [
case(cnt3) //选择扫描显示数据 f8 w0 z) K5 |# e+ z
3'd0:disp_dat = sdata_r[11:8]; //第一个数码管
3 C0 k' W+ C; M: W7 p- H 3'd1:disp_dat = sdata_r[7:4]; //第二个数码管
% ]9 G8 {5 c6 y- V G1 i, o 3'd2:disp_dat = sdata_r[3:0]; //第三个数码管8 {' J/ \- V# D5 y
3'd3:disp_dat = rdata[11:8]; //第四个数码管
5 S* y x& G9 w! ?6 n 3'd4:disp_dat = rdata[7:4]; //第五个数码管
/ C2 ~+ W p9 ~9 H# G 3'd5:disp_dat = rdata[3:0]; //第六个数码管
6 V9 i& o6 {) G7 Z 3'd6:disp_dat = {3'd0,crc[4]}; //第七个数码管
% r2 T% g- r. @: m% L( U 3'd7:disp_dat = crc[3:0]; //第八个数码管
8 h+ r |5 A; g B$ Q% ~ endcase
# ^, m M5 K+ Q case(cnt3) //选择数码管显示位
9 } D4 N$ x; s7 ^: n" Y 3'd0:dig_r = 8'b01111111; //选择第一个数码管显示
" u5 f5 U4 t7 J8 n* G! b" Z' ~ 3'd1:dig_r = 8'b10111111; //选择第二个数码管显示8 C' v- i1 b5 b4 S/ S
3'd2:dig_r = 8'b11011111; //选择第三个数码管显示
+ l' i7 m& K# s0 f% P q' H9 Y# _+ w# x! s 3'd3:dig_r = 8'b11101111; //选择第四个数码管显示
2 |$ }7 z" r V. _ 3'd4:dig_r = 8'b11110111; //选择第五个数码管显示 \2 s3 K) O) o; s9 N+ ]3 C
3'd5:dig_r = 8'b11111011; //选择第六个数码管显示4 g) _" U/ e4 v- c: X1 }4 v
3'd6:dig_r = 8'b11111101; //选择第七个数码管显示1 z& `( z* L, Y0 P+ q, h* l7 [
3'd7:dig_r = 8'b11111110; //选择第八个数码管显示
9 z- O8 p1 w2 f O$ J endcase ( e* {0 Y7 [5 P
end
9 D6 x( Q3 k% N$ d Tend
5 ?5 h' t/ G) W- w) t% U& }1 @, l+ `1 ]) O6 G
always @(disp_dat)+ D! Y' m- `+ {/ r' Q( c- H
begin
( X6 T' G& w6 P8 f2 F2 } case(disp_dat) //七段译码
% B0 n5 ?- e; }2 G8 X 4'h0:seg_r = 8'hc0; //显示0
( f3 S, A: n0 u, h* j; Q9 r 4'h1:seg_r = 8'hf9; //显示1
( R k& P) L+ O- A* { 4'h2:seg_r = 8'ha4; //显示2! \" y- c/ s. r5 i5 I
4'h3:seg_r = 8'hb0; //显示3
5 x' T- [# ~5 ^8 Q9 b 4'h4:seg_r = 8'h99; //显示4
4 {5 P! e9 q- T5 E8 F 4'h5:seg_r = 8'h92; //显示5' ^4 a8 } N* U# J* r9 P' j
4'h6:seg_r = 8'h82; //显示6
5 k# X7 g# O$ w! M" ^5 W3 y" Y% t8 O 4'h7:seg_r = 8'hf8; //显示7
7 F# B$ Q0 M ]5 K. S, t 4'h8:seg_r = 8'h80; //显示8& C: z, y T: B: i. P/ T! ]' m
4'h9:seg_r = 8'h90; //显示9. F6 d; c4 S7 B+ J& G* ]
4'ha:seg_r = 8'h88; //显示a. b( a# ^9 y2 U# D8 }
4'hb:seg_r = 8'h83; //显示b+ p1 }( t. N$ C7 v) [- W8 l" E" m
4'hc:seg_r = 8'hc6; //显示c$ ?/ E- y4 k7 S1 m( T8 N5 x
4'hd:seg_r = 8'ha1; //显示d
5 |/ z. C% t# E, A4 _0 M 4'he:seg_r = 8'h86; //显示e/ h. y% w) |$ F9 n3 Q8 @
4'hf:seg_r = 8'h8e; //显示f
( s, W9 [+ Q, i+ g0 Z endcase
5 s- t* n( V! B+ c0 G3 u0 q& Gend
& _$ [5 F r1 E. j8 \5 R! p3 n
4 y( |: O3 o1 W- u# _7 y0 Hendmodule
9 }" s. ~( y3 _% Y% M( J& y |
