EDA实验与实践 dac_test 5 j2 Y2 z/ B0 B; x* z: J. k
9 J2 W4 r( r8 m4 L8 v. a: Smodule dac_test(clock,key,wr_act,wr_data,seg,dig);5 Q6 j9 M* O- P$ r& t5 q- q
input clock; //系统时钟(48MHz)
3 b0 \) o* @$ r! P% f' Rinput[4:0] key; //按键输入(KEY1~KEY5)0 k9 A# R8 P9 Q" `6 ]0 j1 U' \
output wr_act; //发送数据使能
# h$ Q- A( f. `; youtput[10:0]wr_data; //要发送的数据6 N( S7 l& G6 Y5 J0 {, p
output[7:0]seg; //数码管段码输出' N; J, Z7 x! k$ c6 |0 L' S
output[7:0]dig; //数码管位码输出
& [+ \; u: c) x! d) l+ P//I/O寄存器/ q' O+ |/ Z2 d: D$ z1 j) D0 }
reg[10:0]wr_data; / ], d( h. U1 @% \, t3 ^2 ^
reg wr_act;
: s) f9 C0 P. Sreg[7:0]seg;
8 x0 U) }. A- E2 mreg[7:0]dig;
, ~' Z, ^- T! v1 }2 h3 y//内部寄存器: E% ^2 i$ r# I8 J: k t- X
reg[16:0]count; //时钟分频计数器, n3 m8 t" S9 O$ W- N8 ~1 F: `7 T" S
reg[4:0]dout1,dout2,dout3; //消抖寄存器+ _2 ]8 B) ^7 m" u8 m& p
reg[4:0]buff; //边沿检测寄存器
7 D1 t1 z- @% b8 vreg[1:0] cnt; //数码管扫描计数器
$ {9 x3 x4 J0 ~/ h( Wreg[3:0]disp_dat; //数码管扫描显存
& n! q& l# R7 O. dreg div_clk; //分频时钟3 X" L+ n! z! Z
wire[4:0] key_edge;
( N' t' p1 h. g! [/ l7 }- X1 P3 g! h
* G; O7 j* U$ n3 D//时钟分频部分; T7 U, c( K2 u" f) w
always @(posedge clock)
$ P& M: S: k0 c% Sbegin
, y$ r5 N Q4 X, E2 ~ if (count < 17'd120000)/ X0 F3 \# c3 v* y% ?
begin1 A$ G) C/ {4 ~6 \& J* v# B
count <= count + 1'b1;
; ^+ O3 ^! V7 Y/ J6 I0 S3 H div_clk <= 1'b0;# M& q5 ~- p8 C8 M1 R/ h; `
end
) }0 g* x) n+ k! t: ~" x, \! V4 k else
. ?/ M1 z3 E8 y begin
8 n4 `' ~0 W$ }* m count <= 17'd0;
, ^7 ?# Y' R' p! ]+ W div_clk <= 1'b1;8 t' W7 W3 J* ^9 z# B5 J
end
3 _6 M. Y4 k; |# Jend2 N7 s! } v6 ~: H) g+ L
; w5 V: j! `/ Q: t
//按键消抖部分
9 X. S: n4 L9 Dalways @(posedge clock). Q: Y' ^) U" D" f f9 r- k
begin3 K x; {' ?, Q9 J
if(div_clk)' s% a3 J# T- F, { N2 g4 Y, j; k8 f/ Y
begin
, w6 c; Q4 z2 F: F5 b6 ^1 L4 ^4 U dout1 <= key;5 M6 @% S$ B3 [/ [/ A
dout2 <= dout1;
6 f! g$ R% h; F. C; E! R dout3 <= dout2;. U; N3 y, M2 s* a- Y! ^! z) o
end
* ]2 y! w2 c8 U, _$ t3 Z3 bend# ?$ i$ |* C8 W; ?1 z( [
" T# \' Y! `, O$ d# Y' T& d7 H$ {//按键边沿检测部分
* x/ B' ^$ k( yalways @(posedge clock)! O! E! s) \! O& D: h) }
begin2 _( L2 w& l+ |! ~) A
buff <= dout1 | dout2 | dout3;( {+ V$ w. j( K6 Y, T5 R& ?
end
. v) f% `; f l& \' L" j" k5 O% l1 D0 h% L
assign key_edge = ~(dout1 | dout2 | dout3) & buff;
6 S4 |7 t7 _" n( C+ x! g# q7 G
, F* l- g6 p+ R
: {+ W8 _' f+ L( P0 s$ k3 zalways @(posedge clock) //按键1
, ^6 G* S2 j$ V7 @! \3 n0 O3 Obegin
/ p/ S( k. T G- x if(key_edge[0]) //下降沿检测$ B1 L } J5 e& a/ ]9 G
wr_data[10:9] <= wr_data[10:9] + 1'b1;
9 X1 U% E% [9 M+ c( `end
* J) B+ M; H. I- i# A/ i L$ G
% i( `" \% a' q: L, G/ }' `always @(posedge clock) //按键2
. ~/ q5 u$ a& H, Mbegin' F4 _' ~2 g2 O+ _8 R( m
if(key_edge[1]) //下降沿检测
. M, H6 ?) z: O, T4 U% }! w0 F" Q0 V wr_data[7:4] <= wr_data[7:4] + 1'b1;
* `6 K6 _! @) I5 }end7 d7 S+ X2 G& L8 W3 ^+ U
R8 j/ |( X, M' l/ G" ?( ~always @(posedge clock) //按键3
4 m: Q5 g/ G& _, Y. C2 bbegin E; k* K) Y4 Y" B& G& Y0 X
if(key_edge[2]) //下降沿检测4 E- J4 P2 `; f M! h7 U. n
wr_data[3:0] <= wr_data[3:0] + 1'b1;$ X. n' ? k6 K) j7 Y8 _
end
% i- V$ }; e+ s6 u
! h: ]" c. n6 e3 K0 [9 R, r' F& Xalways @(posedge clock) //按键4
5 Y c% q5 C: d! z; j2 Gbegin; {% E6 r/ k0 I4 k/ ?
if(key_edge[3]) //下降沿检测/ m+ o* C/ x2 R0 D& E5 Y' h0 J
wr_data[8] <= ~wr_data[8];/ s; h V. X! Q) B- q8 P
end
; c1 C( ^* Y% {8 k$ l, h- a
9 H3 G& ]& @& `always @(posedge clock) //按键5
3 ~2 k( q! ~/ b1 ]# ybegin' P' v+ {3 K6 |" ^' f2 J! J( \ Q
if(key_edge[4]) //下降沿检测
3 X9 C0 [) W& q' S5 `9 o. e wr_act <= 1'b1;
/ h& D: x% D1 ~8 g else
) ~5 g* n& m8 Z& l wr_act <= 1'b0; " I3 h) ?% g7 `, E4 D8 T7 x
end
4 Q6 k4 e5 e; e. S$ L3 X$ Y) C7 G; T( Y# |& K4 q" U( b
9 R$ Y4 e, b) U" \' t
//数码管扫描显示部分
- y! A1 ^. t" B1 t+ salways @(posedge clock) //定义上升沿触发进程
g# s$ u/ W. o, `begin2 `+ s3 I& m# Q# Q* Q4 z0 Q
if(div_clk)
" L& O# G6 h/ N F. e. b7 A cnt <= cnt + 1'b1;# D3 B9 i; X& j2 I t, P
end0 n6 ?( A z1 g8 ~0 h
5 K% y& }& [ t3 yalways @(posedge clock) 3 A: V1 x/ S/ O4 K) N/ t
begin
; ]# G0 }* _% I) f if(div_clk)# M O$ T: c8 K
begin
4 ] Y$ G0 K) f1 W% b case(cnt) //选择扫描显示数据+ @$ `# n* y% Q n' a5 k
2'd0:disp_dat = wr_data[10:9] + 4'd1; //第一个数码管
- p0 k# G5 N" `) ]0 H c( d0 y5 @ 2'd1:disp_dat = wr_data[7:4]; //第三个数码管) r0 q: T. T. d5 J& R8 T. I
2'd2:disp_dat = wr_data[3:0]; //第四个数码管: Z7 m0 D9 l$ N
2'd3:disp_dat = {3'b0,wr_data[8]}; //第八个数码管2 F$ a) k6 y V( e _8 n9 u/ o# a
endcase+ o. l2 W) l( j8 Z. K: I
case(cnt) //选择数码管显示位: }5 @, A" e$ W4 Z7 G0 t
2'd0:dig = 8'b01111111; //选择第一个数码管显示
( N- N" {; g0 Q- X) n 2'd1:dig = 8'b11011111; //选择第三个数码管显示; X. x" V( b* G0 q& I$ l2 n
2'd2:dig = 8'b11101111; //选择第四个数码管显示
1 _. ~ z8 L( t' o" i 2'd3:dig = 8'b11111110; //选择第八个数码管显示1 n5 C0 n8 d9 r0 y0 ]5 {
endcase
) H; r3 w) Y" p. Y0 A$ L end
- d5 I7 e2 @5 Tend
: m$ v: Z3 d0 @; o; J% ~$ B. U3 d- Y: E" o0 ]( @/ j
always @(disp_dat)1 d6 e" w0 r5 G8 }( L0 U1 O6 E2 M& A
begin
4 n- J9 {. R y case(disp_dat) //七段译码
" i9 y2 G1 H) `2 H5 m 4'h0:seg = 8'hc0; //显示0
6 U7 Z# |- |4 T' U, e, u2 s% J7 _% O( R 4'h1:seg = 8'hf9; //显示14 E- Z1 f$ P9 W0 j
4'h2:seg = 8'ha4; //显示2
( [. w4 D/ k" W& P 4'h3:seg = 8'hb0; //显示36 S# c2 c$ c# [, ?
4'h4:seg = 8'h99; //显示4
8 ~3 F2 Q: \! _" V& V# k1 K 4'h5:seg = 8'h92; //显示5
" A6 D8 F" S1 g5 Z1 O) S 4'h6:seg = 8'h82; //显示6
% s, B: `* d, ?+ [. | 4'h7:seg = 8'hf8; //显示7, @4 h! L2 [6 c' c" F) H1 M
4'h8:seg = 8'h80; //显示81 p# R! }3 `: S5 c
4'h9:seg = 8'h90; //显示9
1 [: r; r; k9 H- G( R, u 4'ha:seg = 8'h88; //显示a
5 q/ A+ p) ]7 n* m+ S: a 4'hb:seg = 8'h83; //显示b; U: w$ ?6 O, G3 h$ w
4'hc:seg = 8'hc6; //显示c
: u6 h8 p5 r4 g- s$ E 4'hd:seg = 8'ha1; //显示d# N h+ W# ?, g5 X( S) |
4'he:seg = 8'h86; //显示e( x2 N w2 ~& ~( i0 i2 P
4'hf:seg = 8'h8e; //显示f. i' E' D; f: {4 J& O, g. H
endcase
9 \" L0 B6 M& a+ A8 dend
( F' k+ X9 T5 [* l6 l% q+ D4 |8 i' C3 ]& c9 m0 F4 [3 i
endmodule% |5 |, H. l6 O5 \$ m& O$ \- L
