请教大神,
* ]9 s' N7 A- t& L9 ]) ^# u( s) A' S' c# d5 v0 K
我根据特权同学的FPGA教程,写了一个VGA的程序。程序下进去后,提示. u; G! m" |# Z2 a+ u
输入信号超出范围。我的电脑最低分辨率800*600,程序里是640*480.
8 V) C9 V( X% W }然后我改了一下,不超出范围了,却提示节点模式。! T; I6 n4 r8 x- ]
程序如下:
" ]3 y3 I4 q0 @module VGA(# }0 o; Z% p2 M/ }; C3 A v% Y
clk,rst_n, //系统控制
$ n( G& G9 x+ G( j3 S1 F( K hsync,vsync,; b( @" o- l3 f0 N) }' T8 l
vga_r,vga_g,vga_b //VGA控制
x7 Z! s2 N5 `0 l9 I0 r( G );
9 p x3 V0 h6 X4 \
9 H% Z( g2 F* x6 T$ `0 a( kinput clk; //50M
) q$ s' p9 O3 ^ I1 c: c6 Finput rst_n; //低电平复位
3 E. G: f- Y1 P) i//FPGA与VGA接口信号
3 L: i2 @0 O7 ~output hsync; //行同步信号8 T* K' b$ c( d- |: r
output vsync; //场同步信号
! v/ u9 M- Q Goutput[2:0] vga_r;
1 U; Z0 J- p. I# Ooutput[2:0] vga_g;
9 H# Z6 H' R8 N: Z7 w; moutput[1:0] vga_b;
% V8 \! e" y9 W l6 Z* X# U: o9 `' `" j' F% I! z
//坐标计数 D D% Z) m# D4 d& h( h1 h
reg[10:0] x_cnt; //行坐标, D9 k9 w8 W! e8 ]
reg[9:0] y_cnt; //列坐标
. N i2 [. e! ?/ q: \$ u4 E J0 L# c L4 Y
always @(posedge clk or negedge rst_n); @( P. G+ |8 g7 h6 x
if(!rst_n) x_cnt <= 10'd0;
8 k X; a$ C/ C% i; Nelse if(x_cnt == 10'd1039) x_cnt <= 10'd0;# r$ p9 q, q% H6 I
else x_cnt <= x_cnt+1'b1;. L% ~! s9 x2 G2 ~* v% I$ Q
# g0 T* y2 k9 [% c Hif(!rst_n) y_cnt <= 10'd0;
, {6 ^3 i) ]1 i, v- ^5 u& relse if(y_cnt == 10'd665) y_cnt <= 10'd0;
' ]: S- l8 N# eelse if(x_cnt == 10'd1039) y_cnt <= y_cnt+1'b1;' A7 U R3 `% k/ N9 g/ [
//VGA场同步,行同步信号/ b( W, b" P# K2 z
reg hsync_r,vsync_r; //同步信号) M3 i8 {3 b7 k
always @(posedge clk or negedge rst_n)1 a7 g6 l+ s5 I5 l! J+ P
if(!rst_n) hsync_r <= 1'b1;
2 d6 a; Y/ {( o D0 k* velse if(x_cnt == 10'd0) hsync_r <= 1'b0; //产生hsync信号, x' C; Y' K J% Y2 c; N# I
else if(x_cnt == 10'd120) hsync_r <= 1'b1;$ k6 Z! F( E+ u9 z. p
$ L: s7 ~3 M* S, R& o, U- ^always @(posedge clk or negedge rst_n)5 E! Q8 o+ e% d& Z" |' {. ^6 E4 Q
if(!rst_n) vsync_r <= 1'b1;
. @2 b/ ^$ s% P- D ]8 nelse if(y_cnt == 10'd0) vsync_r <= 1'b0; //产生vsync信号( N9 }7 |1 j0 O5 [ m
else if(y_cnt == 10'd6) vsync_r <= 1'b1;
& Y8 j: p1 ?8 T5 w* u$ b
9 S5 f4 l4 U4 A! R1 J8 m- Xassign hsync =hsync_r;
7 A$ X! h9 B$ V6 k) l8 F7 f( kassign vsync = vsync_r;+ {5 J6 ?+ t* J. t& F
//有效显示标志位产生
8 p- t/ B" y) R1 D! S' x$ |# O5 rreg valid_yr; //行显示有效信号
: u3 l' |7 o9 _* m2 ~ j3 Palways @(posedge clk or negedge rst_n)8 c6 R V* m/ Q0 l, \- m+ I
if(!rst_n) valid_yr <= 1'b0;
3 g5 _2 ]+ K) o" [2 m& |else if(y_cnt == 10'd32) valid_yr <= 1'b1;$ i& p8 F# o6 [# j8 S0 A
else if(y_cnt == 10'd632) valid_yr <= 1'b0;
% O8 Y# Q/ i" L% o- ^wire valid_y=valid_yr;
9 k% j9 `0 s z% e& ^, rreg valid_r;
' I5 Z9 y9 q. S1 X$ Z+ xalways @(posedge clk or negedge rst_n)
# B! h0 G9 f0 r, k# F7 }8 ^3 Cif(!rst_n) valid_r <= 1'b0;
% [* F) a- U% y0 {3 k1 Helse if((x_cnt == 10'd187) && valid_y) valid_r <= 1'b1;% d/ I/ S$ E( D$ s
else if((x_cnt == 10'd987) && valid_y) valid_r <= 1'b0;9 h4 O. x8 E7 O7 f) q: ?6 @
& I1 j1 I# f, ~ ~0 Vwire valid=valid_r;
5 ?1 E% `8 P {% t$ Vwire[9:0] x_dis; //横坐标显示有效区域0-639
4 F/ y9 [$ Q/ z% \" N5 a5 J* Dwire[9:0] y_dis; //纵坐标显示有效区域0-479
: H0 r3 _' \) E" l" L+ rassign x_dis = x_cnt - 10'd187;
5 B* P( q0 w) uassign y_dis = y_cnt - 10'd33;- l$ D" z2 G+ `# a/ v
//VGA色彩信号产生" |8 P% c, ?9 ^7 B
/* ' p% N$ n, w2 v
RGB = 000 黑色 RGB = 100 红色# U5 G4 o* X8 c# P5 d
= 001 蓝色 = 101 紫色
/ K, l0 W& A& Z = 010 绿色 = 110 黄色
" t) Y* B; C$ x! F* n6 Q2 U = 011 青色 = 111 白色
2 b) m, Z) B2 F) J( g/ q */* q1 Q K; D; ]" J7 ]; f( F* Y
/ |6 `$ w- \* S; _: J7 _一共640*480个像素点,需要显示256种颜色;' J# f1 H$ y# Z% v$ x! V
那么每个颜色显示区域为40*30,就正好。. K% q* K" `8 [& s" M+ y$ n
*/ x5 s4 j1 i: ^, V8 U; c9 g
reg[7:0] vga_rgb; //VGA色彩显示寄存器( ~: U1 l* \' Y; {" W; y
always @(posedge clk)* |" t& y6 V# f5 C$ X1 H9 W
if(!valid) vga_rgb <= 8'd0;9 ^6 j* p0 s8 J" y# ]* H! T: u
else begin. v/ E0 `) `6 K: ?2 `: @% R
case(x_dis)
7 e W! U* ^, T" \ ?2 Y 10'd0: begin //当x坐标画到0时,让显示色彩数据根据当前的y坐标值重新( K8 c. T" K9 W7 B, C# V0 Z& S
if(y_dis >= 10'd0 && y_dis < 10'd30) vga_rgb <= 8'd0;
6 T8 O6 r& D/ ]! ?1 F else if(y_dis >= 10'd30 && y_dis < 10'd60) vga_rgb <= 8'd16;
Y/ U/ ^2 L$ b0 \7 w8 L; l- ? else if(y_dis >= 10'd60 && y_dis < 10'd90) vga_rgb <= 8'd32;, R! Q5 y9 F+ n, I, t- S# s3 P( Y
else if(y_dis >= 10'd90 && y_dis < 10'd120) vga_rgb <= 8'd48;
0 u9 _4 z4 @/ I/ A+ W else if(y_dis >= 10'd120 && y_dis < 10'd150) vga_rgb <= 8'd64;6 z9 M1 h8 ?; m A5 E& N }
else if(y_dis >= 10'd150 && y_dis < 10'd180) vga_rgb <= 8'd80;: D ]& [' O& N1 F
else if(y_dis >= 10'd180 && y_dis < 10'd210) vga_rgb <= 8'd96;, s8 z- R V1 Y1 d6 f# c& ~
else if(y_dis >= 10'd210 && y_dis < 10'd240) vga_rgb <= 8'd112;
6 S" q, [( k! s8 c9 b else if(y_dis >= 10'd240 && y_dis < 10'd270) vga_rgb <= 8'd128;7 j- q. `6 D: M8 f) p( J k- X% {) M
else if(y_dis >= 10'd270 && y_dis < 10'd300) vga_rgb <= 8'd144;9 M7 C4 x# O' A+ n; M, y9 ^
else if(y_dis >= 10'd300 && y_dis < 10'd330) vga_rgb <= 8'd160;+ K5 F( Q' F- J2 R) o. o
else if(y_dis >= 10'd330 && y_dis < 10'd360) vga_rgb <= 8'd176; @/ N6 s( f$ l& k' [1 u6 A! d
else if(y_dis >= 10'd360 && y_dis < 10'd390) vga_rgb <= 8'd192;! s8 C2 \) z3 i7 Y4 D$ O6 [
else if(y_dis >= 10'd390 && y_dis < 10'd420) vga_rgb <= 8'd208;; E: Q, x8 r" [ ^
else if(y_dis >= 10'd420 && y_dis < 10'd450) vga_rgb <= 8'd224;, ]: m$ W7 C/ ]$ n0 V" ~
else if(y_dis >= 10'd450 && y_dis < 10'd480) vga_rgb <= 8'd240;; C: O, r5 s) V/ [3 A( l
else if(y_dis >= 10'd480 && y_dis < 10'd510) vga_rgb <= 8'd256;
1 u' E7 m( m0 @2 [7 f3 K, ~) K else if(y_dis >= 10'd510 && y_dis < 10'd540) vga_rgb <= 8'd272;
9 t" W: c" n: p- q else if(y_dis >= 10'd540 && y_dis < 10'd570) vga_rgb <= 8'd288;
. ]; @- ?6 e3 l' w else vga_rgb <= 8'd304;
# v U" c) e; b {6 r1 F end. [' a2 a ]$ n1 x
10'd40,10'd80,10'd120,10'd160,10'd200,10'd240,10'd280,10'd320,10'd360,10'd400,10'd440,10'd480,
3 Z/ `- x; y% L i+ e 10'd520,10'd560,10'd600,10'd640,10'd680,10'd720,10'd760,10'd800: vga_rgb <= vga_rgb + 1'b1;
/ t0 L! P& k6 u% g/ O% S$ x default:;
7 v! }5 r- j" U* Z endcase6 c! `5 i5 M5 x8 F) t+ I' } Y
end% E6 @9 w; F' |9 B, w. r- |
assign vga_r = vga_rgb[7:5];
$ ]: F! p* ^7 eassign vga_g = vga_rgb[4:2];
, B5 H0 |& D1 W( Cassign vga_b = vga_rgb[1:0];
# b7 `+ A+ J% v, I7 z5 F. qendmodule, h5 G5 l$ Y5 h @3 D$ X4 b
请大神帮忙看看,非常感谢!$ O% q3 A: V7 M$ ?' C
