, `$ O# }+ E* R! ?
先上程序/ b+ p. p+ a+ }$ }, v$ \! S
module max7219(clk,rst_n,clk1,load,din);
% q$ A& j; J# h7 R& Rinput clk,rst_n;
R4 J5 N" `5 o# }5 Toutput clk1,load,din;: z' p e9 O2 G
. N- ^: `1 J8 g: A$ n* l9 f
3 f' f$ ?) h( ^//reg[11:0] cnt;/ ^. w1 K" _: a
reg[11:0] cnt1;
* h1 N9 F5 Q; _* u
$ v& \: s2 j" A: ~1 Y" T& ]0 d, }2 h- p$ h% ]9 l* P
always @(posedge clk or negedge rst_n)
/ y7 V/ y4 Q: i. C: w if(!rst_n) 1 c/ v% x7 J3 x4 P$ Y
cnt1 <= 0;! }8 d4 u* c a* t
7 b. f! W% _5 c$ |! ` . n! A0 g) f7 j$ u
else if(cnt1==12'd2560) 5 l$ G2 v4 i& [" B
cnt1 <= 0;$ G; a; N$ H% o. b: D
. U. D/ G- G" A( B0 s else cnt1 <= cnt1+1'b1;
, W$ i4 A% a! P' e% d , {0 M* R8 z) l7 J6 L: E3 L
reg clk1_r,din_r;! N6 F! D8 e u& ~- y: h
function Write_Max7219_byte;( d0 k2 c0 D$ }8 I$ y8 \& N- u8 }3 P
input [7:0] byte;$ ^6 Z% U, A" x7 T$ l
1 t$ K# o( Q# z- V; \* b# U9 } 5 ?7 q. [9 o: x1 S, t U
//always @(negedge clk1)4 X' V- Y) m7 t: I. L( ^
begin
& D. \! s! W0 B6 | case(cnt1)& E$ a( R4 }0 s# C+ }% Q
12'd0:
- i9 G4 J, {/ ]3 {9 E6 x E begin8 Z' _( @" V! j3 W! P3 z" \
clk1_r=0;& u7 Z( Y, z1 t" B9 O; `
din_r=byte[7];: f- z; A! A0 y) V
clk1_r=1;- `9 e! ]2 B a. m) _
end
3 B& }! m# M! g5 L1 K 12'd320:% ~" R) D L- C9 p
begin* n) o' U3 s. N6 M
clk1_r=0;
6 W8 B( [: V5 n `% ^ din_r=byte[6];( \* D9 T# l: W8 X7 Y
clk1_r=1;
* [- R7 X9 j) { end
( W9 q8 C# H( \# p7 x% _0 s4 }
$ N; v t+ W; g 12'd640:
) o9 j& l$ m1 r1 E1 {" b begin
# X- R0 _2 e( N! L7 `' ] clk1_r=0;
- I% v' b' V; n9 | din_r=byte[5];) {& @+ Z/ G- Z# G8 d! R; B C. x
clk1_r=1;9 I8 c5 X# @: M! r, d2 w
end# g6 n9 ~" S" Y8 R6 t3 A' B
' `& A `4 G2 n+ {6 C; a 12'd960:, o Q, q3 [8 s+ ~! m
begin5 ]; [. e/ _# M" |4 F: f
clk1_r=0; V i% n) J5 @! F. i- L
din_r=byte[4];1 V" i& D, L4 r9 Y; d( C
clk1_r=1;
- `: g- H: X6 Z end$ Q( G& W% o0 F1 e" [5 ?% D
12'd1280:
& c8 Z$ s0 y. |. e, ?; n begin) r S3 m& K/ A8 w, ^. F6 N
clk1_r=0;
* {' n+ f% r! s! N, F# p c" r* V- } din_r=byte[3];
7 P: F: I9 B, d: W3 V. t clk1_r=1;
4 o: u7 i6 I3 B7 C; ~! f6 n5 B; c7 _ end7 v, Y7 u9 [ F& Q3 ~! Q
12'd1600:
' U: e% R9 g! `' R4 d T4 m begin
# z1 ~0 c% ~7 H) S8 I1 [ clk1_r=0;$ E% e/ [& T& r; Z7 E) W
din_r=byte[2];% Z" m; e/ m% Q* }. L/ R
clk1_r=1;
8 ~5 X% y5 W2 |4 L2 d end; c5 m" @+ S# o! U8 j$ E
12'd1920:
8 c( M3 u5 ~6 D, {4 u begin I* S, E5 O1 L e8 G9 U: x
clk1_r=0;6 q$ Q( ~+ I( I5 ]
din_r=byte[1];
% J2 D2 L. J" g; Y clk1_r=1;- g0 r% b+ Q; r
end
* @+ N; d |( {6 n: [ 12'd2240:. v# e Q* E2 L! \2 u+ ` S
begin Q' V! Z5 K' K+ Z p
clk1_r=0;
/ p/ v7 m$ K0 S0 Q" b din_r=byte[0];2 N+ |+ O1 t1 d2 w: r+ J
clk1_r=1;; m# q- J5 H" {8 S% j
end
k/ U6 J0 ]* s$ s9 d8 p
; E. l3 }/ D! p2 V5 b6 K endcase' `+ f3 M+ x/ ?6 `
end! h* ]/ _+ C3 Q% O7 p, I# o% B
endfunction1 D* j* a& d+ W" g" f
1 C4 X N0 W2 n. z1 g
assign clk1=clk1_r;" Y( G+ ?- D' w3 r8 y
assign din=din_r;6 w# p/ D& N |. L
9 q3 u8 s7 ^; T# [* hreg load_r;$ w ]9 v2 n( i+ @
# W; [7 U7 D, J
function Write_Max7219;
" z1 q1 k! q) U9 S' }% d3 E9 d7 Finput [7:0] addr;
+ ?4 x9 C9 S6 f5 v& Q' F! f! binput [7:0] dat;
, ]) z0 i8 Y5 m6 A X4 rreg a,b;# w2 _1 a w F, a) E0 X* |7 c9 W
//always @(posedge clk or negedge rst_n)! N) C1 I9 v5 ?2 G$ C8 ~+ t$ f. {$ O
begin. d% z( B% {1 }& U& A
//load_r<=1'b0;6 I8 T: I' t9 J S0 z
a=Write_Max7219_byte(addr);/ e) g9 Y9 a7 B# I+ A
b=Write_Max7219_byte(dat);4 e) k5 a3 ^& U5 A! x
//load_r=1'b1;
) S# G3 r( Z' }/ @8 a end, g# H9 u7 I. Q# G5 U
endfunction
% a7 ~" j( I9 M4 Iassign load=load_r;
# A( X( A1 p3 |$ V1 u' d# `$ }8 z2 z
4 h# D4 m3 C* q% V* freg a;
) f* z( p7 O- u: Dalways @(posedge clk)( s( v9 X: Y8 Z0 S, x2 g( d) r
) I3 H! m8 s0 {# N7 M' @5 Z1 u begin
- J7 ~$ ]8 `! {% Q8 V2 u4 M9 L load_r<=1'b0;
% h. _; z x. L! a8 A //a=Write_Max7219(SHUT_DOWN, 8'd1); //Normal Operation XXXXXXX1 Shutdown Mode XXXXXXXX0
2 D* V) Y4 O' \. W& j9 G$ J a=Write_Max7219(8'hc, 8'd1);
" C) m& f& i0 M' d2 B5 m6 l a=Write_Max7219(8'hf, 8'd0); //Normal Operation XXXXXXX0 Display Test Mode! j: m) L" m" P* o5 @& j6 u/ ^. H
# w) M) w+ R1 P" @ @
, x8 ^9 q6 r2 i# X6 F# N; D a=Write_Max7219(8'h9, 8'hff); //Decode Mode Select D7~D0 1 B decode 0 No decode: u8 h; Q+ c- |5 \; {" x3 m" \
a=Write_Max7219(8'hb, 8'd4); //SCAN LIMIT 0~7 0xX0~0xX7- U6 I/ v2 ]" w( s; i, _
a=Write_Max7219(8'ha, 8'd4); //Set Intensity 0xX0~0xXf
: q8 A6 w, A9 ` a=Write_Max7219(1,1);
8 w1 f% B! C& l2 M2 G, A& p2 A a=Write_Max7219(2,2);% Y# D! x. F! {% ?
a=Write_Max7219(3,8);5 ?" I# i' K; j& u+ L: H7 q
a=Write_Max7219(4,6);
H6 A t( g8 ] load_r<=1'b1;
: V, c9 y h/ P6 Z! R end' g" X& _% \8 C8 m7 \! f
endmodule
% W) {9 a+ Z. Z; ^, y! K+ x请教大神,* A* k) {) w! W6 p8 K& y
我写了个FPGA驱动MAX7219的程序,本来四个
4 _8 R* t, `( I- i0 R3 `4 [: v数码管应该显示1286的,可是要么全亮,要么不亮。
/ ?) Q- `4 ^/ V8 a7 g非常感谢! |
