查看: 309|回复: 1
FPGA串行控制LCD12864
    2019-11-20 15:00
    发表于 2019-4-28 10:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    FPGA串行控制LCD12864
    2 r  A! D0 J& H6 `
    : h9 A9 Y7 }+ ^; V2 C8 d. D4 s
    1 K. R" A1 x$ P$ L1 j" G
    : t8 i" l2 |; ~& k, s$ H3 E
    library ieee;
    " j. k" U' L* ruse IEEE.std_logic_1164.all;: Z5 j# O1 h6 W* D
    use IEEE.std_logic_unsigned.all;) \# ^" O  p  P  T
    use work.lcdchar.all;% x3 _. A4 k7 u1 d# C. s# x
    - w8 ~/ }# s1 B+ q/ B. r  s0 sentity display12864 is        --LCD12864 display2 \0 c5 ^9 y6 F0 t
    generic( fclk : integer :=50000000);
    ! U  L% d  D( J8 x7 \9 E" K        port(9 }* }7 S+ f- m# ~& Y
                    n_rst                : in std_logic;
    ! D+ U4 x8 L# I& ~! J                clk_in                : in std_logic;
    3 P6 h) c- T: ]                en                        : in std_logic;
    2 [& u) s( a8 f- @# U                SID                        : out std_logic;/ `8 ^" a/ r/ A& C; x, `
                    SCLK                : out std_logic
    & _$ a! F6 w, @8 a+ w                );
    ; [' j' C7 ?0 q4 ^4 M3 x/ R0 ]end display12864;+ I9 N: T/ t* f1 h
    ' v8 \4 W$ a: m2 F; s1 Y& V
    architecture rtl of display12864 is
    $ A6 T- L+ m# H
    $ V: D$ ~( `& i! f2 dconstant div_num : integer :=fclk/500000;
    ' H  @5 t5 c* s9 c" v8 C1 z7 x/ k6 Z/ ^* ]" p
    --attention : '\' and '"' can't be displayed.6 Z; h8 h, o2 m3 p( P) H/ [
    constant line1_str : string:="     test1      ";0 [( i9 f/ P& C& d/ ?' v$ o* t
    constant line2_str : string:="       2        ";
    0 t: Z( u+ G: Z% Oconstant line3_str : string:="        3       ";+ ~7 y3 G6 @% e$ O0 F2 C
    constant line4_str : string:="       4        ";
    3 B9 n( x! q5 h! Q8 C* Y  Q- Q
    % Q# ~) a* w# f: h! ]signal clk_500KHz         : std_logic;( j7 x9 M2 P( J; X, P
    signal LCD_cnt                : integer range 0 to 71;
    $ g+ K& Y, [# z/ e9 P- ]2 V0 lsignal LCD_Data                : std_logic_vector(7 downto 0);
      Q4 k( M2 R( q9 t/ J" Msignal rs,LCD_cnt_en: std_logic;2 N$ ]5 `- W: S5 [' a! O& S
    , T; z$ a8 J6 ~4 z" }
    signal clr                        : std_logic;! C: ?4 b5 C2 [$ n$ h1 s" {
    signal bit_cnt                : integer range 0 to 25;$ E, W0 K3 j  E* @/ ~
    signal delay_over        : std_logic;
    5 r% i3 w% ?8 c6 Y+ Wconstant delay_10ms        : integer := 500000/100;--delay 10 ms
    / b! P+ A7 x/ w" Uconstant delay_1ms        : integer := 500000/1000;--delay 1 ms6 ~; ~1 R, q- I8 ^& o
    begin
    * R; p& S$ \( y7 ^) O$ o0 l/ w2 F8 C2 A; g
    --frequency division
    7 o3 ]. s7 k, ]4 a# |# [3 z6 v        process(clk_in,n_rst)                ' ^- O5 U$ U: l
            variable div_cnt : integer range 0 to div_num-1 ;
    4 U* X  }. a2 `        begin: G3 u8 k! L! C9 ]5 \6 m/ C
            if(n_rst='0')then4 h; X0 ~8 C0 E! x2 ^
                    div_cnt:=0;
    5 O9 b# W& S9 n6 E5 }1 n; ?% R) q        elsif(clk_in'event and clk_in='1') then
    + I& U5 _& m7 o                if(en='1')then9 J9 x0 x- [& W" i8 ], d* |
                            if(div_cnt>=div_num-1) then
    $ M" C% Z$ V% A7 @                                div_cnt:=0;
    2 s9 o6 B% ?8 K7 Z/ o; ^9 B- w! Z7 g                        else2 d) |+ t- A) E2 e8 J  l
                                    if (div_cnt < div_num/2) then
    $ ^" D, v1 r" L/ r; u! Q  G                                        clk_500KHz<='1';
    % m' F/ m4 ~1 n, s4 I                                else / {7 E9 W6 P& F- Q1 n
                                            clk_500KHz<='0';' G8 k. S5 k3 ~' {8 D' d
                                    end if;. w5 F; R4 [. i! ^0 @, Q$ g
                                    div_cnt:=div_cnt + 1;) \/ e6 v/ U8 G5 @" _
                            end if;7 G, n5 `9 T% P3 b& v
                    end if;9 D* m+ v2 i/ ?
            end if;
    - r3 [: }7 f1 B6 m        end process;
    / E% G8 J8 z0 n8 z& r2 e% M% G/ T& R1 j: _* p! h# p3 r' k* v  s% h
            process(clk_500KHz,n_rst)
    1 c  p0 a1 ]5 `  @: |2 N        begin  |& K0 {1 x0 A5 _0 n8 j
            if(n_rst='0')then
    : a8 S' I& Z+ N3 t                LCD_cnt<=0;
    0 J* U/ x( B8 Y  t9 ?                rs<='0';
    3 }7 e! ^5 {, F1 w- v9 f2 e" e                LCD_Data<=x"00";* Y$ E( X* h5 f3 I6 E* f- c4 j, [
            elsif(clk_500KHz'event and clk_500KHz='1')then; ?  q' a+ z4 T
                    if(en='1')then
    7 {) }$ q8 e0 E' D) ?, I9 ?. j1 |                        if(LCD_cnt>=71)then
    % G" Y+ ^4 F0 _$ w- F                                LCD_cnt<=4;% L3 g, F$ a9 ~; L+ ~
                            elsif(delay_over='1')then
    . H. o3 \" H! x! L! U                                LCD_cnt<=LCD_cnt+1;
    ) v9 m+ K" o6 |# G                        else
    - {; q% ^2 o% U6 N+ N* L                                LCD_cnt<=LCD_cnt;% s) Z1 ^9 ]9 c
                            end if;
    - H' I0 X! W* B% n9 I7 Z" a                        case LCD_cnt is
    ) m7 F3 {' M$ Z# X/ d: Z5 M                                when 0                =>        rs<='0';LCD_Data<=x"30";1 d: Y% \  Z  b
                                    when 1                =>        rs<='0';LCD_Data<=x"01";4 r% U, f& u4 V4 H3 |+ S
                                    when 2                =>        rs<='0';LCD_Data<=x"06";
    & L4 _3 w; M! ^1 |4 K                                when 3                =>        rs<='0';LCD_Data<=x"0c";
    4 M+ Q0 Y" e# o2 G, T1 r& M. G
    ! H" n+ f! m/ n                                when 4                =>        rs<='0';LCD_Data<=x"80";                --first line' h% \0 U, [( N8 ^
                                    when 5                =>        rs<='1';LCD_Data<=str2vector(line1_str,1);, r- e# a' B4 w% i: \5 N4 Z$ o+ J" }' n
                                    when 6                =>        rs<='1';LCD_Data<=str2vector(line1_str,2);
    2 c$ q: v  p, N. K                                when 7                =>        rs<='1';LCD_Data<=str2vector(line1_str,3);
    / ?% n" r5 J6 }, Y                                when 8                =>        rs<='1';LCD_Data<=str2vector(line1_str,4);
    / d) [1 g+ G! M3 d                                when 9                =>        rs<='1';LCD_Data<=str2vector(line1_str,5);
    ) r, Q; O8 t# X: P" q7 n                                when 10                =>        rs<='1';LCD_Data<=str2vector(line1_str,6);$ y2 H- i3 i% M! x/ ?, O
                                    when 11                =>        rs<='1';LCD_Data<=str2vector(line1_str,7);% @6 l. ~" u3 T# E
                                    when 12                =>        rs<='1';LCD_Data<=str2vector(line1_str,8);: T, V1 n, q+ m' X2 N5 Q" n# f8 h
                                    when 13                =>        rs<='1';LCD_Data<=str2vector(line1_str,9);4 u# w$ K* ?6 E, Y
                                    when 14                =>        rs<='1';LCD_Data<=str2vector(line1_str,10);
    ! M; @9 B: X  O& X  k; H, W                                when 15                =>        rs<='1';LCD_Data<=str2vector(line1_str,11);
    7 B# l2 D' E, `. z                                when 16                =>        rs<='1';LCD_Data<=str2vector(line1_str,12);0 Y7 v  E8 y( l/ \+ R
                                    when 17                =>        rs<='1';LCD_Data<=str2vector(line1_str,13);8 t& p1 ], v6 m. v8 c
                                    when 18                =>        rs<='1';LCD_Data<=str2vector(line1_str,14);
    7 O% }) Z& O/ v( K) Y. }                                when 19                =>        rs<='1';LCD_Data<=str2vector(line1_str,15);$ B0 @" s2 t0 G0 O3 p
                                    when 20                =>        rs<='1';LCD_Data<=str2vector(line1_str,16);
    9 v: Y7 y* n1 g8 i! F
    ! G* A) \# D2 d4 J                                when 21                =>        rs<='0';LCD_Data<=(x"90");        --second line
    : b4 ]7 o4 l8 L                                when 22                =>        rs<='1';LCD_Data<=str2vector(line2_str,1);
    % @  v+ J+ t2 c$ r7 `                                when 23                =>        rs<='1';LCD_Data<=str2vector(line2_str,2);
    9 l  X) T5 C/ n8 \0 P$ T                                when 24                =>        rs<='1';LCD_Data<=str2vector(line2_str,3);- }3 t# j4 d& Z  X' o! [% X
                                    when 25                =>        rs<='1';LCD_Data<=str2vector(line2_str,4);$ |( P5 e% @/ u9 L3 c0 z! ^/ z
                                    when 26                =>        rs<='1';LCD_Data<=str2vector(line2_str,5);' ^1 k! e6 W. G' f, m
                                    when 27                =>        rs<='1';LCD_Data<=str2vector(line2_str,6);
    ' _, \+ x9 v0 W( Q- E! f* S                                when 28                =>        rs<='1';LCD_Data<=str2vector(line2_str,7);2 G! c+ @8 {1 R) _1 a2 F) J& |+ F
                                    when 29                =>        rs<='1';LCD_Data<=str2vector(line2_str,8);
    ; U* X  O; s, H8 H( ]" X  V                                when 30                =>        rs<='1';LCD_Data<=str2vector(line2_str,9);1 C; V" y2 }1 J( a
                                    when 31                =>        rs<='1';LCD_Data<=str2vector(line2_str,10);
    ! }9 X! C  R2 J/ G                                when 32                =>        rs<='1';LCD_Data<=str2vector(line2_str,11);
    8 I0 Q% c# B) j  ~: F# A4 E' q                                when 33                =>        rs<='1';LCD_Data<=str2vector(line2_str,12);- y) r/ z3 m6 j1 J0 Y- ]
                                    when 34                =>        rs<='1';LCD_Data<=str2vector(line2_str,13);" E. R* |* J$ `5 }  J% h
                                    when 35                =>        rs<='1';LCD_Data<=str2vector(line2_str,14);" c; E4 d% ~) c5 K2 D9 `! C
                                    when 36                =>        rs<='1';LCD_Data<=str2vector(line2_str,15);& j* ?/ S; U; i: p% h2 M, o. v, Q
                                    when 37                =>        rs<='1';LCD_Data<=str2vector(line2_str,16);
    8 ]3 c2 S2 Z- _. ~
    : A1 p/ W4 S8 M; g! y9 O4 {$ g                                when 38                =>        rs<='0';LCD_Data<=(x"88");        --third line9 o. c9 B% K( T3 t6 N
                                    when 39                =>        rs<='1';LCD_Data<=str2vector(line3_str,1);
    " K6 h" q" V- E# r                                when 40                =>        rs<='1';LCD_Data<=str2vector(line3_str,2);' \9 x! U0 b" ?: o1 G
                                    when 41                =>        rs<='1';LCD_Data<=str2vector(line3_str,3);/ j2 L7 b" k0 |
                                    when 42                =>        rs<='1';LCD_Data<=str2vector(line3_str,4);6 p: r* X( [3 N, @6 V# C* O
                                    when 43                =>        rs<='1';LCD_Data<=str2vector(line3_str,5);
    ; N& J" W* W$ l/ i- m: r6 H9 l                                when 44                =>        rs<='1';LCD_Data<=str2vector(line3_str,6);
    8 B5 t7 S1 g; }0 e2 S: }                                when 45                =>        rs<='1';LCD_Data<=str2vector(line3_str,7);2 i& Y( |& j" V* d" l, ^
                                    when 46                =>        rs<='1';LCD_Data<=str2vector(line3_str,8);. L# M$ I+ W- m. F; M  O
                                    when 47                =>        rs<='1';LCD_Data<=str2vector(line3_str,9);; W8 R$ f* p0 k% I9 B
                                    when 48                =>        rs<='1';LCD_Data<=str2vector(line3_str,10);1 A  v( I2 g* d: P! v" ]0 V
                                    when 49                =>        rs<='1';LCD_Data<=str2vector(line3_str,11);# t# T0 p$ |* y0 c; w: }, `9 o5 U
                                    when 50                =>        rs<='1';LCD_Data<=str2vector(line3_str,12);2 a" l: _, I  E
                                    when 51                =>        rs<='1';LCD_Data<=str2vector(line3_str,13);' Q; V9 S" T/ p  N9 i6 j* K; z* O
                                    when 52                =>        rs<='1';LCD_Data<=str2vector(line3_str,14);# P6 F( o! g0 A
                                    when 53                =>        rs<='1';LCD_Data<=str2vector(line3_str,15);
    4 i% g' L# `, T( @9 r  N                                when 54                =>        rs<='1';LCD_Data<=str2vector(line3_str,16);
    + w' c" X  T- C) {
    : C% k. L" a, }. E                                when 55                =>        rs<='0';LCD_Data<=(x"98");        --forth line5 h, u0 G5 O7 Y* f$ K" s
                                    when 56                =>        rs<='1';LCD_Data<=str2vector(line4_str,1);
    : F& X; |; t, c, i5 L1 L# `                                when 57                =>        rs<='1';LCD_Data<=str2vector(line4_str,2);
    5 g. n$ m5 c8 G) U7 d8 y, G                                when 58                =>        rs<='1';LCD_Data<=str2vector(line4_str,3);
    + r/ n; ^' }$ \6 a- j- @                                when 59                =>        rs<='1';LCD_Data<=str2vector(line4_str,4);
    # q3 t* P3 {( f* C; s( k5 j                                when 60                =>        rs<='1';LCD_Data<=str2vector(line4_str,5);6 ?4 |  b8 B7 m! l* F$ o% J
                                    when 61                =>        rs<='1';LCD_Data<=str2vector(line4_str,6);6 v% q4 q$ v1 h# R$ Z' R
                                    when 62                =>        rs<='1';LCD_Data<=str2vector(line4_str,7);
    % S! }! g7 b0 d; |* n$ B                                when 63                =>        rs<='1';LCD_Data<=str2vector(line4_str,8);
    ! ]' w6 n6 R3 J4 S6 O                                when 64                =>        rs<='1';LCD_Data<=str2vector(line4_str,9);& P7 {) i( Y8 }& T# C
                                    when 65                =>        rs<='1';LCD_Data<=str2vector(line4_str,10);- w. d( X. H+ E7 R
                                    when 66                =>        rs<='1';LCD_Data<=str2vector(line4_str,11);
    4 R% c+ l3 d, ?% |                                when 67                =>        rs<='1';LCD_Data<=str2vector(line4_str,12);+ S& ]  b  j2 `2 a7 J& [: m
                                    when 68                =>        rs<='1';LCD_Data<=str2vector(line4_str,13);9 H  f( n( D5 B9 n7 |
                                    when 69                =>        rs<='1';LCD_Data<=str2vector(line4_str,14);
    " x8 a. h! ]2 b/ O( L4 Y( l                                when 70                =>        rs<='1';LCD_Data<=str2vector(line4_str,15);5 \4 ~. U  T. C' o2 {$ @3 }- a* Q
                                    when 71                =>        rs<='1';LCD_Data<=str2vector(line4_str,16);
    $ \# V6 e6 h4 }; J! \8 H                                * ^' o3 T) G$ d
                                    when others        =>        rs<='1';LCD_Data<=x"00";        % u% j, u! E. ?- e
                            end case;) Q8 a% L! M$ h/ n5 g& c
                    end if;
    1 f3 O: Q' d: f- y        end if;
    6 h7 O. c9 O  ^( ~( a        end process;
    ' t& x( g& f/ @& X  G0 z/ H+ W( I% Z4 n
    --delay 10 ms counter 3 e( W- I! R1 Z7 H0 Y1 N
    0 M( a4 T% x( @- g( p% O        variable cnt : integer range 0 to delay_10ms-1 ;
    , W* ~) y% R, v7 i! y( U        begin
    ( f% P; R6 C+ O. {9 E) ]1 M        if(n_rst='0')then
    * L0 X* `- B6 r9 C" }- K( N                cnt:=0;
    3 H/ m; s! A" Q. |4 c+ I' o: q                delay_over<='0';9 Y) o* V/ t9 E5 `$ d3 m. D+ L4 {
                    clr<='1';
    1 U9 i% T. Q9 u, P; d        elsif(clk_500KHz'event and clk_500KHz='1') then
    ! t3 t- t% S' d+ F                if(LCD_cnt<=4)then
    " s2 o* m( j" }% j( o% W# F                        if(cnt=delay_10ms-1)then, w6 n  z1 ^* j7 Y. u
                                    delay_over<='1';
    & d# X0 _7 q: y                                clr<='1';
    $ A# o. o1 M) W6 a  l                                cnt:=0;
    ) ?9 R# _; g' N4 r                        else6 R) m, z! F' P5 d" g
                                    delay_over<='0';
    / v0 l5 |  j- x2 O% K                                clr<='0';! b. M& M4 s! r; e: q6 Y
                                    if(bit_cnt=25)then
    0 M/ ~, w9 q/ K+ y2 z% q$ T                                        cnt:=cnt+1;
    6 K* ^& G1 D3 [$ A5 j& R                                end if;
    + u5 k$ N* V3 f4 f8 w' M9 p2 g8 ]" B                        end if;
    7 _5 L) o% o- [+ G3 {% z! G                else
    " u5 m1 H$ e0 ?2 o& r( O! k# Z& @                        if(cnt=delay_1ms-1)then1 _8 P4 |1 t3 V9 B2 o% Z
                                    delay_over<='1';& m- F8 N" Z$ v' f5 f
                                    clr<='1';
    $ Y9 i5 o$ o5 x/ x; I                                cnt:=0;; A. u: X& C7 V2 f
                            else
    + H0 v1 H: _; h1 A/ a+ o                                delay_over<='0';
    & O3 m3 t" _* C                                clr<='0';! D0 w0 S" d& y, Z
                                    if(bit_cnt=25)then
    ; J8 Z) I& H. S# f* @: w' I                                        cnt:=cnt+1;, s' _2 c) f  t
                                    end if;
      a/ ^8 A# X; P: X- Q0 @                        end if;
    . G+ j4 W1 y, w+ ^' a                end if;
    5 f; s: ?1 t" h        end if;) P: ~: A- T! F. O
            end process;
    + N' r( e. P& z3 K7 s' C        7 Z1 I1 R+ B# A! u* Y& p2 p, P; ?
    --output SCLK
    ! ~9 i6 y5 i- [/ f3 P5 a        process(clk_in,n_rst)
    & C% U8 C: M1 r        begin
    7 K6 Y5 Z; d4 p        if(n_rst='0')then2 T8 Y* [3 R) \
                    SCLK<='0';* l& ~0 r* j0 y( f: p. V
    0 \# q- g' Y; V% L5 b/ @' c: O4 t                if(en='1')then$ F; S/ x+ Q' M1 i4 r
                            if(bit_cnt>0 and bit_cnt<25)then0 l  b0 S2 ?) v$ H7 G9 V
                                    SCLK <= not clk_500KHz;6 W2 N9 O: `4 w
                            else
    ) D. d3 A+ T$ m/ u0 ]                                SCLK <= '0';  t) e" i* Y" g* f% G* O* |/ [: t
                            end if;
    " m: L, I  s, `4 n# k+ B                end if;% M( }6 d& f. A8 p/ V; l0 D
            end if;$ z* R1 M, M, k% ?
            end process;! L- Z. g" x& g: m5 u8 `
    * Y( K4 P* g) h1 c% r, u--output SID
    4 o8 N; p2 o' a7 B. |$ M9 k        process(clk_500KHz,n_rst)
    ) m$ a" T# P5 c8 H' e1 p" C        begin, [: B" Q  A; o0 i5 x
            if(n_rst='0')then
    % @: s; S& f. V; v                SID<='0';/ ?1 D3 F8 }7 i, A& z& J* @
                    bit_cnt<=0;
    ' w+ x- {2 O6 a  r3 g" ]        elsif(clk_500KHz'event and clk_500KHz='1')then
    / Y9 {* G7 Z) q8 w. o8 w                if(clr='1')then
    " c+ g5 k' I3 s) T& J                        SID<='0';
    9 B5 C# }# M* v) B                        bit_cnt<=0;0 ?% u  B& k( r: k) K, ^1 h# [" J8 b
                    else
    4 }2 p/ \7 F5 B) ?" s6 A                        case bit_cnt is
    ; ^  u0 _4 [! K  F+ F- _2 S                                when 0                =>        SID<='1';bit_cnt<=bit_cnt+1;6 n8 R3 C; m9 v/ E, f7 {
                                    when 1                =>        SID<='1';bit_cnt<=bit_cnt+1;
    0 V- a8 B: p7 W                                when 2                =>        SID<='1';bit_cnt<=bit_cnt+1;& A" x& Q4 y$ j5 N
                                    when 3                =>        SID<='1';bit_cnt<=bit_cnt+1;
    - Z: G& ~! m( u. `! d                                when 4                =>        SID<='1';bit_cnt<=bit_cnt+1;
    - T. ^1 J, H6 ~* S4 h- _                                when 5                =>        SID<='0';bit_cnt<=bit_cnt+1;' g5 k  Y# d9 h% [0 I9 @
                                    when 6                =>        SID<=rs ;bit_cnt<=bit_cnt+1;
    - c) l1 t8 s- P+ X0 d" y                                when 7                =>        SID<='0';bit_cnt<=bit_cnt+1;+ `5 G# X+ ?- o, B. R: k
                                    when 8                =>        SID<=LCD_Data(7);bit_cnt<=bit_cnt+1;1 r& R; N( \' F4 {1 Z1 Y  a
                                    when 9                =>        SID<=LCD_Data(6);bit_cnt<=bit_cnt+1;
    7 N* Y8 ~: B  g! @1 c! v, e+ v                                when 10                =>        SID<=LCD_Data(5);bit_cnt<=bit_cnt+1;
    9 a/ y$ w( h# I0 ?; W                                when 11                =>        SID<=LCD_Data(4);bit_cnt<=bit_cnt+1;
    , U  f7 ?9 E- `                                when 12                =>        SID<='0';bit_cnt<=bit_cnt+1;, x: F  v/ ]! g' T7 m
                                    when 13                =>        SID<='0';bit_cnt<=bit_cnt+1;
    7 C4 B+ f, W9 J* |                                when 14                =>        SID<='0';bit_cnt<=bit_cnt+1;7 V- v% @6 Q& K) Z8 [' x4 x1 H, u
                                    when 15                =>        SID<='0';bit_cnt<=bit_cnt+1;
    ) i) f1 ^$ X& Z' j6 F+ W$ b                                when 16                =>        SID<=LCD_Data(3);bit_cnt<=bit_cnt+1;; n8 U0 [* D! p
                                    when 17                =>        SID<=LCD_Data(2);bit_cnt<=bit_cnt+1;( G8 c0 h7 ^/ u: f
                                    when 18                =>        SID<=LCD_Data(1);bit_cnt<=bit_cnt+1;& G) u  r  w- {# f; P: b
                                    when 19                =>        SID<=LCD_Data(0);bit_cnt<=bit_cnt+1;
    1 `4 T1 t# v7 Q) `0 r1 Y9 o$ e                                when 20                =>        SID<='0';bit_cnt<=bit_cnt+1;
    5 {. i9 n6 C! f# v                                when 21                =>        SID<='0';bit_cnt<=bit_cnt+1;! a* t3 k8 t& t- H/ Z$ z( B/ V
                                    when 22                =>        SID<='0';bit_cnt<=bit_cnt+1;
    0 t$ i6 a5 }5 Q$ Y- s2 Y, z$ i1 ^; Z! D                                when 23                =>        SID<='0';bit_cnt<=bit_cnt+1;
    3 |& Q' B7 ]" k0 _7 h; E                                when 24                =>        SID<='0';bit_cnt<=bit_cnt+1;( k8 ~2 g5 o2 U  R! O6 {
                                    when 25                =>        SID<='0';bit_cnt<=bit_cnt;" s* e. V) K5 d7 J
                                    when others        =>        SID<='0';bit_cnt<=0;
    & P: q+ Q4 f- o* H4 g% Y8 ~# q8 v                        end case;# w: d% _( U. C3 R
                    end if;2 ~3 N4 S: Y: {( U/ H
            end if;1 X$ r! H4 F! m  Z; d( B# g3 i
            end process;- H6 L! `; {- a1 s! r
    + i( j7 p2 }! ?end rtl;+ W- \" s+ x, b. A. t  v6 `$ `4 d" l
    & @- r" i+ l& M/ q/ x8 j3 S
    --str2vector函数
    & Y7 A/ X( A7 d" dlibrary ieee;
    % Q8 }: E- k. j  w9 y5 Euse ieee.std_logic_1164.all;1 C4 j) C) g8 a. ?2 W
    package lcdchar is% k0 b( V* O5 n  g2 q* Y0 t
            function char2vector (char:in character)
    # K6 h4 Q. H) y3 D7 p9 U        return std_logic_vector;( V0 J* t5 G) \$ C
            function str2vector (str:in string;i:in integer)
    ' g3 c( g5 {: h0 Z        return std_logic_vector;
    + t! h9 P7 u5 S) Hend lcdchar;$ m& w/ T. M+ \1 Y8 w
    package body lcdchar is  }( ?" H" p; _
    . v" N  k% s9 d" q        return std_logic_vector is
    ; k: U% w8 q# W& P" l4 j! `  z        begin
    1 S& q% w# T# r9 g9 L! T                case char is
    * R/ `7 z" I& E, w$ V                when ' ' => return x"20";# j4 c9 d4 @, B7 M# I& s. ]" a( s
                    when '!' => return x"21";
    - l9 B9 l. Q$ e3 ~" K                when '"' => return x"22";7 A1 W1 i( _: _+ m- \) H- E
                    when '#' => return x"23";
    2 X& L$ [$ P; q3 |                when '$' => return x"24";$ [4 E. ?8 F( V: t
                    when '%' => return x"25";) i2 T9 H- j2 E7 X  [+ H* r) J0 n' x
                    when '&' => return x"26";0 _  T: {1 [- _: W- l& Z
                    when ''' => return x"27";( g9 {# h, @/ Y7 `9 ~8 i) q
                    when '(' => return x"28";
    , U# l! P- Q5 D; i, t; V9 Y                when ')' => return x"29";
    $ [# f& b# O; R7 U7 n                when '*' => return x"2a";5 c, z4 b' y, n# a4 h
                    when '+' => return x"2b";
    : j  \( W( L# V1 v                when ',' => return x"2c";: M. ]# j  X$ z' F3 C! P
                    when '-' => return x"2d";1 b8 u7 D! m/ B+ h' E# v: o. Q
                    when '.' => return x"2e";
    7 `$ b: f0 D( T. s" K                when '/' => return x"2f";# b% `- |5 X& x( Q, w
                    when '0' => return x"30";
    3 g) G% F1 e( A) Z                when '1' => return x"31";# v  G1 ?# `# c* h
                    when '2' => return x"32";
    & V! F  h( A8 s0 b4 Z, G                when '3' => return x"33";; a) N. a; A+ s9 F7 s* g, I
                    when '4' => return x"34";
    % E7 B5 l+ F5 d: z- D4 u                when '5' => return x"35";0 F3 X8 Y  t9 K' }) c# p6 U0 d  ]
                    when '6' => return x"36";
    1 ^( f3 |$ _( |3 |5 T                when '7' => return x"37";% }; q: |8 B& b- ^  Y5 \) q
                    when '8' => return x"38";1 ?. _" C1 L6 s+ @$ @. T
                    when '9' => return x"39";, V' w! q# \! z0 @5 O! L8 Y, K  L8 A
                    when ':' => return x"3a";
    " ]9 h( R. Y8 A  o  V                when ';' => return x"3b";
    ' A* A8 l5 t6 w                when '<' => return x"3c";
    $ c9 f7 i/ l5 \% r  ?2 `                when '=' => return x"3d";2 O! C/ T7 ~- \; _6 y+ D; ], M
                    when '>' => return x"3e";
    / O; d9 U2 {. v9 I  V; G+ T; Q                when '?' => return x"3f";6 B) l9 i6 u* j6 n" L3 ^6 B' }
                    when '@' => return x"40";' h5 V4 F% Y. M# Q4 P
                    when 'A' => return x"41";
    2 u. A5 N9 h2 k                when 'B' => return x"42";1 _( n# [5 ~+ h( _3 I
                    when 'C' => return x"43";$ {" `; H; `4 n3 v' d" |
                    when 'D' => return x"44";" V: \9 \* ?$ k& k  z+ [; G, O8 Q
                    when 'E' => return x"45";
    ' Q+ n' o1 \5 Q                when 'F' => return x"46";5 ], R: @& Y) k) |* W# N' b7 T
                    when 'G' => return x"47";; e' F& d9 |( B
                    when 'H' => return x"48";- s8 l9 m! f# `6 Y+ m
                    when 'I' => return x"49";
    ' ~6 t0 B- x: k$ O+ }+ ~. e                when 'J' => return x"4a";$ z- o0 o: A' S. h
                    when 'K' => return x"4b";
      n1 m* g2 n  B6 k( e; Y6 {; M                when 'L' => return x"4c";
    & T( H1 x" @0 i                when 'M' => return x"4d";5 v9 b& \: E) {. d; b( N3 Z
                    when 'N' => return x"4e";
    3 m) ?% o, L2 u. m; ]5 C                when 'O' => return x"4f";
    ) [7 t# j$ X; g9 |8 O% Z                when 'P' => return x"50";6 R* I' ~6 u6 Y1 a7 G4 P
                    when 'Q' => return x"51";0 Y5 B$ p+ R3 G7 ^2 w2 p& Y" |, N! I
                    when 'R' => return x"52";
    : C7 m$ i- U( B* f7 m4 o( V                when 'S' => return x"53";: L1 L% k+ z" v( J
                    when 'T' => return x"54";! F8 W" Q" ?/ X+ ?- B8 W! g
                    when 'U' => return x"55";) }3 K/ `- J, N2 s9 j
                    when 'V' => return x"56";
    # e: Y( T, w9 S' b& A7 N+ S                when 'W' => return x"57";
    $ {/ p. h- R2 @8 `' {; y                when 'X' => return x"58";; I% N  `0 N! v! i# c
                    when 'Y' => return x"59";
    + B# }2 G/ _2 V, ?# Q1 r9 v% u                when 'Z' => return x"5a";" \( b" p- L  O6 ^+ l  c, z' z
                    when '[' => return x"5b";
    7 H0 j' Q; ]9 s3 _8 Y+ o" u                when '\' => return x"5c";
    * }0 b# {; Q2 ?9 j+ s( \- S$ \                when ']' => return x"5d";% |5 N4 F' |9 R5 N$ ]
                    when '^' => return x"5e";
    - t/ M! J! _# y# J0 W                when '_' => return x"5f";; s2 Y+ W% _  ^
                    when '`' => return x"60";" g, t8 Y6 s' u
                    when 'a' => return x"61";
    . o( g' `( [6 y: ^5 _                when 'b' => return x"62";3 S% f  ?7 ~" i9 E/ j0 A
                    when 'c' => return x"63";  F3 x/ t7 l. K
                    when 'd' => return x"64";
    # u% b2 r2 K/ J1 X2 R) L                when 'e' => return x"65";
    ! L' x, [$ E+ V% Y2 ~# G: m9 T: ?                when 'f' => return x"66";* g" j1 u8 ^! Z' Z. h! y) `
                    when 'g' => return x"67";
    ; ]& D1 M6 u" J0 x) |- u# x                when 'h' => return x"68";4 C5 v3 E: x1 h7 J8 G
                    when 'i' => return x"69";% _( S1 |% V4 D3 |+ E/ O9 t
                    when 'j' => return x"6a";
    : ~3 p7 c4 s" C; `, `+ [5 o                when 'k' => return x"6b";5 \8 p- C  T' z9 y4 V( s/ H
                    when 'l' => return x"6c";
    ; x3 Q$ ^9 }6 o- z- }                when 'm' => return x"6d";9 `# w( d  ^0 R% R0 T; @
                    when 'n' => return x"6e";3 S8 \! y2 H2 Q* J6 F
                    when 'o' => return x"6f";+ d+ q) C) x# V: p1 m' w2 l1 y
                    when 'p' => return x"70";
    # K2 j! {4 t0 v4 z                when 'q' => return x"71";
    2 Z3 e8 W7 X& l+ M4 o                when 'r' => return x"72";! V( c$ I" t- O. T& F7 F* `" \
                    when 's' => return x"73";0 `7 p7 R& J" N% c, \" n7 [2 A* w+ }0 f
                    when 't' => return x"74";
    5 W# r  s2 @4 ]- C8 a                when 'u' => return x"75";
    1 y( Q# H# o/ r* v, L' g                when 'v' => return x"76";7 |0 L6 b0 ]  J+ `8 _9 M; X" F
                    when 'w' => return x"77";/ z3 Q" b4 ?+ L3 E) Z
                    when 'x' => return x"78";
    5 k" m' b( ^: r; ~% |& e                when 'y' => return x"79";
    7 E0 K7 }9 P/ \" f8 V2 I3 Z4 K                when 'z' => return x"7a";/ N" A8 B, Q; ~, {/ m
                    when '{' => return x"7b";# J' u- d  }4 b, T
                    when '|' => return x"7c";: o7 P% Y/ S% B% a
                    when '}' => return x"7d";
    3 o* Q. k- Y# ^7 O8 {/ ]- o                when '~' => return x"7e";
    1 ~# H: q. [4 Q# w% f                when others =>null;3 O. X+ E2 V: L1 b5 }
                    end case;
    # O# q6 M/ e$ m% k; p" ~        end function char2vector;' D6 J2 }) L/ }$ V" `; q
    - Y3 R1 I( y+ q1 T' j& R( l        function str2vector (str:in string;i:in integer)
    $ X5 Q" m7 Y5 k+ u2 X        return std_logic_vector is
    - q7 ~7 w' z) r. o. t        begin0 M% ]$ q4 s- k- k9 k( X! I8 }$ Z5 d
                    return char2vector(str(i));
    * a( O/ j' Z. P( J        end function str2vector;0 n6 f$ K" j. ]9 X
    end package body;
    9 I) u. d& W  l  U: z1 F/ @
    , Z' o# T. S; }2 K( k# ]: H! J; M: Q--代码已验证过,相当好用
    & T2 w4 ]$ F4 y& V" t$ R8 V6 V
    发表于 2019-4-28 17:28 | 只看该作者
    非常完整的代码 谢谢楼主分享
    GMT+8, 2025-10-9 11:20 , Processed in 0.187500 second(s), 23 queries , Gzip On.
