转——ZRtech Altera CycloneIV FPGA开发板——计时时钟
3 W, |+ |: W; d
1 e3 w# r# Z* M$ i h/ S4 [5 b本实验是用数码管显示一个计时时钟,由于数码管只有4位,所以只显示秒和分,时类似,由于控制数码管的段是复用的,所以每一时间只有选中的数码管才亮,其中左边两个数码管显示分,右边两个数码管显示秒。' D% W- E8 _' _
1、同样新建工程,$ x; z: z+ o5 f( a& X
2、本实验的代码如下:
" s, k$ c6 D+ [' m6 Q//clock7 Z3 H0 a. X+ n3 R0 S
module clock(clk,DS_EN4,DS_EN3,DS_EN2,DS_EN1,DS_A,DS_B,DS_C,DS_D,DS_E,DS_F,DS_G,DS_DP);; U, ~+ ?: `- p( @, i$ _
# g7 w7 \) N: B; |+ s
input clk;& k) X m% [6 f
output wire DS_EN4,DS_EN3,DS_EN2,DS_EN1;5 m3 h6 D7 [; [# _: F% B. v
output wire DS_A,DS_B,DS_C,DS_D,DS_E,DS_F,DS_G,DS_DP;
! S2 y) m, _! i8 S( E- G5 l. `* @! Q+ W& L- _
wire [3:0]wei;4 X: N V3 B; `3 C# i4 y
wire [7:0]duan;
% {, _5 W h8 \; A; q+ kreg [3:0]wei_r; E9 V5 b* [ G. J f1 C1 a$ X
reg [7:0]duan_r;
+ S8 l! {% k% E1 g+ @
5 Q' o y# q, A4 S" ]1 treg [5:0]Hour;1 J0 _4 ]& W. ]& w; t5 P1 p5 M
reg [5:0]Minute;' U" _2 c6 d( |, \9 l' K! S
reg [5:0]Second;
8 L$ w- R6 I+ J8 O+ p9 ]2 `/ ereg [31:0]Cout;
1 H& g8 ?5 ~1 V& x% Ireg Clk_En;
* U6 e9 a% G3 w. D( E7 {2 `wire [3:0]Second_bit,Second_ten,Minute_bit,Minute_ten,Hour_bit,Hour_ten;* c9 r4 P5 T+ [: F
% ]$ Z8 g' R9 g1 @* f: Gwire clk_1k,clk_1s;9 ?& k% T2 ~0 w' U# [+ x* k
3 b q) K+ J7 i' c% J9 Iassign {DS_EN1,DS_EN2,DS_EN3,DS_EN4}=wei;
6 R7 ]- Y" z2 Fassign {DS_DP,DS_G,DS_F,DS_E,DS_D,DS_C,DS_B,DS_A}=duan; //数码管共阴极/ B g# P1 _3 k4 e
. O% {# S1 v% x2 e/ \1 y0 C
fp_k fp_1k(clk,clk_1k);
" g2 m* N- f& _fp_s fp_1s(clk_1k,clk_1s);( I( ?$ ]7 f4 P$ Z. k- ^9 y
7 |. H8 M" X j0 jinitial% @: s2 f: X! `5 A
begin
) a4 z; T" k, X! B/ S wei_r<=4'b0000;
: m5 w* c! f3 O. Y( d9 ~ duan_r<=8'b00111111;4 u- [8 _( l/ l" B$ M
Second<=5'd0;$ g5 \- E9 g! O4 n E/ x3 X f
Minute<=5'd0;
1 c2 E* t7 h" p( [- N Hour<=5'd0;: @0 P& U0 r& J! _( h. U1 ?1 }
end& J* X8 r7 o3 A
% ^% [4 g7 [7 r2 a) O) O; yalways @(posedge clk_1s)
3 w7 K6 I+ j. R2 j/ Z6 ybegin
6 M; r9 n/ }8 \8 a if(Second<59) ^0 s0 u+ ~" _- ?& z" l' A/ g- s
begin' O* ~3 w% F, a1 t8 i) H0 R
Second<=Second+1;+ K& A/ i% O! X/ z- i( q+ L
end9 b H4 E+ c% p, r% n
else if(Second==59)
A8 m$ g+ M. _0 c$ Y! l begin5 M. G5 Y4 ~( t) l2 K# O0 u4 a9 i; i) Z
Second<=0;
$ p5 \3 |5 T, w. ^4 \ if(Minute<59)
% X4 V; f0 B0 X, _2 ?& | begin
( g* v1 d' ]! u9 | Minute<=Minute+1;
: G/ t- _1 r- J- O7 ? end& V8 A6 p4 _% G7 ]+ O' a4 L
else if(Minute==59)9 v3 L. q3 |1 c1 @" q3 d
begin
0 o- D$ s; v" u9 w0 W2 A0 L. O Minute<=0;. y9 u: H# W: R% l
if(Hour<23)' Y' x( W0 \. n( h
begin
+ p% c" D/ }0 m c Hour<=Hour+1;
4 w' W3 B6 \( u5 i- D% ]1 V end
9 g" E4 i$ u* U. k) f else if(Hour==23)* ~- I3 S3 T' E5 W, u7 K
begin
( j9 ~* I) H* e+ ^ Hour<=0;
) f% h+ v0 G/ q+ L end
' ^2 k; E2 W- e6 t# |* n z3 I* R end+ B; F$ b/ {5 N B
end9 T% b3 L: A, _4 Q- q5 V* v
end
2 A4 a7 B/ I3 n2 k! @
% z$ ^) @7 _6 b4 t8 Tbinary_to_digit time1(clk,wei,Hour,Minute,Second,Second_bit,Second_ten,Minute_bit,Minute_ten,Hour_bit,Hour_ten,duan);+ E) m4 {; y/ r7 N' i4 c$ k: \
: i$ S5 U* N c) P
endmodule
9 G9 M8 L$ r: @: i% _) Y; X \
7 L. b% ?9 J2 d//分频1k-----1s
+ ], ~3 Z/ M1 m4 V) r8 r3 ^module fp_s(clk_1k,clk_1s);( {) p8 O5 w( i; ~2 l$ X+ q
input clk_1k;
* _9 x9 z+ x: U' q# ^output reg clk_1s;
' x% [' |2 p/ zreg [10:0]cout;2 B+ o) s" Z/ \% v
//reg clk_en;) ]7 k8 Q1 @& _; O& i0 D
initial
" N3 `3 Z9 E% o/ E" sbegin& ?. G9 X6 ?) B, z( F
cout<=10'd0;
% \0 @8 O7 `' n clk_1s<=1'd0;6 t6 Q( f( U$ v4 q, Z, K* F
end
# }6 y% F! G0 b+ N! ]$ ealways @(posedge clk_1k)- |% N ^8 Q+ [& _' `& X
begin
& s: A( `9 j: h& |1 T. U C) A9 b if(cout==10'd500)0 e% b B* p3 o. O: x8 {
begin
! I, ^3 g$ @: O9 s$ w; s cout<=10'd0;# O. a3 V5 N2 B# D# `8 ]' C
clk_1s<=~clk_1s;
5 z- R. s) ^: A! Z! U end
, X6 Y+ q, ~+ t' i else6 R; h! z ~3 n8 r# E* T! |' t
begin' {# A' L, b3 k
cout<=cout+1;
+ o5 m& d' `. W end8 U) T3 V2 k/ m. F; m
//clk_1s<=clk_en;
. J3 K# y' f3 O6 {, z8 Z% @end& B1 b$ ]* |7 m$ j
0 s" n& `) `- ^. mendmodule
% m. Q* E& L5 @//分频48M-----1k& [! P5 o; n! ]5 O( ?$ `
module fp_k(clk,clk_1k);( Y) F& Z) \" I
input clk;, X* r/ h4 }9 P
output reg clk_1k;
! v" G& E% ^9 w4 J8 z2 g4 I) {1 n' Lreg [31:0]cout;
5 |' p: W5 `$ K9 h//reg clk_en;5 f" Y1 G; W5 O6 c
initial 1 y- a- D# I, d* t
begin8 Q( z. v5 w4 L* z
cout<=32'd0;* h) ^% G, \6 n# n- {
clk_1k<=1'd0;6 p8 J9 ]+ S m* t
end& H4 L3 N3 K, J
always @(posedge clk)' p2 D+ i( p* E: l [
begin
4 t M9 N9 q* {, l( a if(cout==32'd24000)
3 Q# o" | w2 h/ {* A begin4 i9 v7 \) ]" Y' ?: ^# W
cout<=32'd0;; @) `& G& a* Y- P0 Z
clk_1k<=~clk_1k;7 N1 H+ R8 A S) d
end$ N8 q, {! l4 E, Z8 o8 S: h
else) _# I" n L4 i( ?' h; q5 t% Q) a3 ]
begin
* D% y' P/ D4 d( g7 Q; S9 {: Y cout<=cout+1;
# o* E; y) w1 ? end
" h5 |1 M. c% P( _7 [0 R8 e5 ]# n //clk_1s<=clk_en;; A0 x9 z1 D$ J& \) @$ u, f
end
: L% \4 Q% Y/ f% F/ g# C& g X; ?; I- N% y; H+ w& u+ k
endmodule
9 T1 U2 o: _( |1 W* M r4 h ~; w+ \
module binary_to_digit(clk,wei_r,Hour,Minute,Second,Second_bit,Second_ten,Minute_bit,Minute_ten,Hour_bit,Hour_ten,HEX);9 D) p* Y a' {
input clk;
" P9 _2 F" G9 q8 v& Z2 X/ ^% koutput reg [3:0]wei_r;8 }* a6 C/ z. B" e. z7 T- T& x" X: b
input [5:0]Hour,Minute,Second;
* `! r/ p2 y7 b+ X8 r) X Joutput reg [3:0]Second_bit,Second_ten,Minute_bit,Minute_ten,Hour_bit,Hour_ten;
5 j: D. u8 P; [" ?output reg [7:0]HEX;
( O Q& s4 M& }+ b, uwire clk_1k;
4 [: J: X" O* W0 N& n' ~fp_s fp_1s(clk,clk_1k);3 z. h. i% Z$ f2 f
) Z# N) R: o& W! Ybegin! A6 J5 @, o+ c3 w+ @7 q
Second_bit<=Second%10;
1 V# K, c1 b% D( k Second_ten<=Second/10;' i1 j: K4 J/ w+ B7 ]
Minute_bit<=Minute%10;
) }0 C$ i) {- }1 o Minute_ten<=Minute/10;& O3 ]% ^8 h5 n' U' G
Hour_bit<=Hour%10;" Y( r' f6 j* k1 X
Hour_ten<=Hour/10;4 b. W% z! g7 Q# A H
if((Second_bit==4'd0)&&(Second_ten!=4'd0))
' x5 Y9 [ K2 L7 n' y2 M6 D begin
" C \/ Y3 w4 B wei_r<=4'b1101;/ C& H$ j; g1 |2 s- |9 d% L2 D
case(Second_ten), e/ K4 ~6 D& {5 Z: V3 ]
0: HEX=7'b00111111;+ X* u( Q% }6 M+ E0 p
1: HEX=7'b00000110;
, g; g, s, l: U7 f3 t! m 2: HEX=7'b01011011;& C/ S' t. _0 W4 K7 Y8 F
3: HEX=7'b01001111;
* l; p/ S+ `/ Q' s l/ w 4: HEX=7'b01100110;# p1 F1 d4 U$ @) Q/ ~0 d8 n
5: HEX=7'b01101101;6 N: F. q9 o: j0 w! y
6: HEX=7'b01111101;
9 O) P$ l4 r2 W9 N7 i+ F 7: HEX=7'b00000111;$ `& T; l) y* d0 F9 d; d }: `8 {9 X
8: HEX=7'b01111111;
+ j* ^% m# m3 K, m- i8 J 9: HEX=7'b01101111;
$ W* y2 [4 k4 G' m1 G4 s/ } //a: HEX=7'b01110111;; T2 L* Y. E1 t$ _+ V' F0 O
//b: HEX=7'b01111100;7 t. b, \9 g8 S4 {
//c: HEX=7'b00111001;
& S& H, N* C/ o //d: HEX=7'b01011110;8 F) m6 T- f& s# v! i& L
//e: HEX=7'b01111001;
/ W. C6 h% x5 @5 T" G+ K6 Y1 ^1 r //f: HEX=7'b01110001;% j1 }4 W1 Y; ^
//default: HEX=7'b00000000;
$ h: u# H! d& r% f: u. O' M( P endcase d3 R5 z9 W4 c8 e( ~
end7 Z+ m4 d# }2 ^" D6 S l
else if((Second_bit==4'd0)&&(Second_ten==4'd0)&&(Minute_bit!=4'd0))1 D6 {5 `2 K, V+ z1 q0 X" f
begin4 D. P+ m N% o0 A
wei_r<=4'b1011;3 c5 a5 _7 r% v# i5 k3 F2 q# ~
case(Minute_bit)
3 J3 `1 R+ |$ O6 i+ [! Q 0: HEX=7'b00111111;1 B' `9 P6 @' [
1: HEX=7'b00000110;
4 C) G2 j2 L& N 2: HEX=7'b01011011;3 S3 T" W- Q' v
3: HEX=7'b01001111;) C3 _6 V0 f# Q5 G2 V' s, |
4: HEX=7'b01100110;4 ]$ ^* h% y' N4 c
5: HEX=7'b01101101;% U. L) `0 ?5 e0 ~/ z' k
6: HEX=7'b01111101;2 P( s4 T, _/ Y/ S& d, q
7: HEX=7'b00000111;" U0 G a4 q, ?& v
8: HEX=7'b01111111;
" U5 l+ Y5 ]" o! t8 H 9: HEX=7'b01101111;+ Y# W) W9 v: V" S9 U
//a: HEX=7'b01110111;. h5 r/ f3 H7 R
//b: HEX=7'b01111100;8 }# I! o! X- R7 T1 ~3 L( c8 x
//c: HEX=7'b00111001;. i" O/ x9 Q/ k0 @, x& J4 G
//d: HEX=7'b01011110;' M: Z. [) Q! k* R8 a2 K
( y2 y8 P- `* E$ X& [ //f: HEX=7'b01110001;
7 z M3 U/ _4 ]8 [; L+ s5 w* Q2 H //default: HEX=7'b00000000;
. l7 G- I+ V4 L. e endcase1 u0 y% |+ X; Z8 q* q
end
/ ]( _! u: t/ D) L else if((Second_bit==4'd0)&&(Second_ten==4'd0)&&(Minute_bit==4'd0)&&(Minute_ten!=4'd0))5 \2 P- m' d$ V- v9 f" d
begin, M& v$ H' ]5 {( G
wei_r<=4'b0111;
% Y0 Z. y3 H6 ^( l9 L+ y* @& b6 U7 U case(Minute_ten)& a! B# b% N! ?" p! C
0: HEX=7'b00111111;1 y8 E" `3 Z# I( K0 R! h
1: HEX=7'b00000110;
2 o* h: a7 v L5 S/ ?5 W 2: HEX=7'b01011011;
( d8 O1 v1 f9 |4 H( N- z- I8 J$ F c6 Z 3: HEX=7'b01001111;5 _) O6 A# W9 f. E0 q* ^; H! e; h
4: HEX=7'b01100110;
( s( R, _! r% z) X. H$ V 5: HEX=7'b01101101;
& z- ?1 n3 S' F& v1 v3 u 6: HEX=7'b01111101;
0 t8 F7 ]3 Q i1 M" m w 7: HEX=7'b00000111;5 q7 u+ R4 e% R5 n
8: HEX=7'b01111111;
- z7 u( p2 H& p: B- T$ F 9: HEX=7'b01101111;
$ g) d" s$ N* j //a: HEX=7'b01110111;
7 o& ?0 i$ {& n1 I //b: HEX=7'b01111100;2 q, i7 O; }# f! K( L/ c0 h
[ m( ^6 a; w //d: HEX=7'b01011110;
) ?- x h# }( `$ z5 o //e: HEX=7'b01111001;( |% G1 T) y8 Z: o0 i2 T8 E3 m
//f: HEX=7'b01110001;. A3 b4 p1 b) V5 Z! e
& J1 V" \2 \/ F- { endcase4 U5 h N2 T: Z, {5 C( I
end, ^ V( ~- M' V+ N) z( s* z
else
0 m. U/ Z+ o8 B8 a begin) U7 j2 ]% y/ e) v3 O k5 E
wei_r<=4'b1110;+ X. N# M* @" S: d
case(Second_bit)4 e4 R' f8 u' ~( x6 }. |. B
0: HEX=7'b00111111;) y; Q5 V. \: I9 a+ K
1: HEX=7'b00000110;
4 E- H- V( ~% ~6 O6 B 2: HEX=7'b01011011;
) S8 @1 `: X1 i+ x0 U! R 3: HEX=7'b01001111;; i' O& |: Y, U9 A2 r
4: HEX=7'b01100110;5 o5 Z* B2 I4 k. o g R3 w5 |
5: HEX=7'b01101101;, Y, b! M# g* y9 F0 }9 Z+ H
6: HEX=7'b01111101;
4 a* a& M4 R$ i3 D2 g8 M& C" M7 T3 ^ 7: HEX=7'b00000111;
8 Z- y5 `. }# W" | O4 L( j 8: HEX=7'b01111111;, j- r' N" f9 L3 {0 G
9: HEX=7'b01101111;
1 w. O2 O6 q0 }/ k( |( J //a: HEX=7'b01110111;
! B4 u8 Z: s+ M4 L7 [4 W# I2 e //b: HEX=7'b01111100;
4 l: H) H3 m3 Y //c: HEX=7'b00111001;3 s+ c, a5 e; g; I3 L2 a
//d: HEX=7'b01011110;! Z, o: W) G+ T' t
//e: HEX=7'b01111001;: x+ r! B. G! m: P2 j
* L3 f& e1 N. O$ Y //default: HEX=7'b00000000;
) l3 b U& L$ V endcase2 m( m( F. h; z9 y1 g5 F
end0 i- x$ w4 j" L) j7 L/ C6 A) e
end# k! o/ [8 N: Q% L N
endmodule
! V6 c# d: p, ]& Y1 c3 g( H* ^; z2 x6 W. i
3、实验结果如下:
, D# }% w: H i$ ]
# k) m+ \+ j# a1 T0 [7 Z: \此图对应第8秒0 v$ a" F. ?' K( {$ s
4 q1 w1 r. x2 z; J; f. S' ?
此图对应第40秒& y" i+ J3 I1 r; i5 {
/ d3 t8 _: U6 g0 M. P此图对应第1分钟 |
# |) \; |) p3 i4 b6 a+ i$ R |
