查看: 365|回复: 1
求大神给程序注释一下...急用...,非常感谢!
发表于 2019-4-24 10:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
library IEEE;
9 Z6 O1 M$ T2 x7 Q7 @) gUSE IEEE.STD_LOGIC_1164.ALL;5 k5 G& g3 ^- E7 M) `. W
USE IEEE.STD_LOGIC_UNSIGNED.ALL ;
, I- T5 T# }+ p) E3 G/ {/ iENTITY keys_lock IS
# h4 N  |' D0 S7 a        PORT (
, L. I; u) Y% _$ p' E) \6 q4 ^2 v        clk ,clr,status  : IN   STD_LOGIC ;
" D) n1 @  R8 X' U& v4 I7 Z           selout    : OUT  STD_LOGIC_VECTOR (2 downto 0) ; ( Q0 J+ X% H" G: c6 M6 _* @. j
        key       : IN   STD_LOGIC_VECTOR (3 downto 0) ;
$ s* D( X/ K; ^0 H2 O        segout    : OUT STD_LOGIC_VECTOR (0  TO 6);- P* j' X: [( u. @4 `
    locks,unlocks: OUT STD_LOGIC
/ |3 H' Z# ^! R8 L# s# o          );$ F  W9 _4 S# ]5 G  q$ _
END keys_lock ;
' X' Q2 E) R3 ?- ~0 |: \* {0 g8 x; D: x1 T5 Q
ARCHITECTURE doit of keys_lock IS: F# v& f3 T) L$ L+ t
signal counter1 : std_logic_vector(1 downto 0);+ K, B, d& h) O3 P5 D: m3 Q
signal counter : std_logic_vector(2 downto 0);
5 _  L1 o* g. z: Ksignal counter2 : std_logic_vector(4 downto 0);4 f$ j' W0 a8 T/ }6 t
signal dc0,dc1,dc2,dc3,lock0,lock1,lock2,lock3 : std_logic_vector(3 downto 0);
7 ^, a0 y# l$ r# l& |signal dcc1 : std_logic_vector(4 downto 0);* G% n" S8 e5 H# V8 ^% F* d% x
signal dcc : std_logic_vector(6 downto 0);
- A5 e$ l; O0 B5 ^signal d0,d1,d2,d3 : std_logic_vector(0 to 6);
" q, t% B% _- isignal clk1,test,koff: std_logic;
( A2 c% U7 x5 a4 R5 icomponent decode" b- R/ P- ~+ x0 B
  PORT(, y( y/ b5 W1 y, e) j7 p
    ssin : in  std_logic_vector(3 downto 0);9 P6 x7 }/ H8 A8 D
    ssout: out std_logic_vector(0 to 6)+ O. q* q+ [# b* x" i2 I9 p4 Z
- G5 |1 y0 r% c' m+ Jend component;8 [8 C1 ?$ h2 f4 V- M) ^3 G
begin: Z4 l, ^; U' M& e  R
; {- M5 I, z5 F! s
test<=key(3) and key(2) and key(1) and key(0);
3 A$ M9 w& v5 |9 `3 ~: C9 ~( e1 A4 `# A, b6 Q- @3 I4 R: C
P1: process(clr,clk)9 c$ R1 B# P2 Y& [. Y" c3 A) U; R
begin
+ `" a: H' \9 B: r4 t   if(clr='0') then
* \, @+ f  }3 b$ {     counter1<="00";4 a% F* i3 e  M: D' x' T% s
   elsif(clk'event and clk='1') then
) O* s$ H, M6 u5 L$ }: n( _     counter1<=counter1+1;
0 n! x- @, {4 X6 I   end if;
8 p( L. H& F; k& R( N& Xend process P1;# X' H' u+ Z. B  X+ d5 R
5 {1 o7 ~2 m: `3 `7 N) y
clk1<='0' when counter1<="01" else
: F! i1 `$ ]$ \      '1';
9 J. ]  d8 v$ {" D8 `# `
2 [. g% y6 v( B# D* wP2: process(clr,clk1,test)
( I* ^- w% f6 }; O" k0 Tbegin6 S+ N* O7 ^( ?/ M$ T% n/ K
   if(clr='0') then! W0 C" {8 r- z- T' k
     counter<="000";3 X+ \, ]/ R4 B% t. B
   elsif(clk1'event and clk1='1') then
, J* N! i7 {; O     if(test='0') or (koff='0') then
* ~/ V* v5 p  v' o       counter<=counter;
1 a8 [  a+ M- O# z* ^" w     else& g# z# D" h! o$ |! A+ g
       counter<=counter+1;
( [9 r' B2 h! o" P     end if;7 ~6 f6 E; a4 [% ~" J
   end if;
1 J5 T0 r8 d# y% q4 r9 oend process P2;
! @3 K: X& [9 E) N2 ?6 e6 ]' ~4 G3 ]5 x& H: z
selout<=counter;7 g1 p. P' J- I5 `! T# t
dcc<=counter & key;7 a% M# Q; v9 h+ h6 w% d: D
3 K. _; N$ d, Q. W- l7 D; j
P3: process(clk,test)
0 t1 A- x' D9 {( ubegin+ A% w: ~2 h0 S5 ~
   if(clk'event and clk='0') then
1 K, l0 n8 _) e4 {     if(dcc="0001110") then
+ c) l; z' i( a+ o        dcc1<="00000";9 I% A( u* ~3 X' z; N
     elsif(dcc="0011110") then( e/ y/ ~8 p; G
        dcc1<="00001";
! g( L$ \+ y2 P6 B6 k# W  I     elsif(dcc="0101110") then$ t+ l- U7 ]' p
        dcc1<="00010";) c+ w3 b/ b: }0 ^- a- W
     elsif(dcc="0111110") then
1 q# B/ a+ d/ Z% i        dcc1<="00011";
) |  F" u9 A0 K, G     elsif(dcc="1101110") then
+ ]9 O/ V9 m$ |9 T        dcc1<="00100";
6 V1 Y& O8 t8 u( u/ a     elsif(dcc="1111110") then" w7 I; R5 ]  o8 f( i. I! W
        dcc1<="00101";" N: k# a' I# w* G
     elsif(dcc="0001101") then$ {9 }6 r% W* G+ Q, f) i
        dcc1<="00110";1 m# p" s# P. |0 v+ o/ O
     elsif(dcc="0011101") then6 y% V& N" W# F& q# v
        dcc1<="00111";
0 \; Y7 h9 X( Q, F- U- f6 m     elsif(dcc="1001101") then
; l% Q) T0 W1 s  q7 X) |( Y        dcc1<="01000";
  {5 f4 @6 Q: H7 V0 a     elsif(dcc="1011101") then5 G4 O- n+ X) {7 l1 M
        dcc1<="01001";
/ S' j/ ?% O! z: P9 r# P     elsif(dcc="1101101") then
5 T2 O: C0 L4 w6 P2 V1 B2 C+ g        dcc1<="01010";
; z0 K. ]% }3 [5 H. Z, t; z     elsif(dcc="1111101") then
( H# F/ W; c$ h! w! K$ {- B        dcc1<="01011";
6 K' k3 N. v: w, b8 t     elsif(dcc="0101011") then! O  n& a" x$ P+ s5 m1 d) \6 ]- O
        dcc1<="01100";
6 A* x/ h8 I/ d5 A. {9 X. ?6 K     elsif(dcc="0111011") then: Y3 Q$ G) |; a9 i9 M- c
        dcc1<="01101";" D1 q' ]% {9 C( a. }4 h/ l
     elsif(dcc="1001011") then  w/ n7 s  ]. f6 Y' a5 T
        dcc1<="01110";
5 m7 @  u& S) Z& P: i  s     elsif(dcc="1011011") then6 @& N3 V  ]4 E0 v) d
        dcc1<="01111";( E3 O; r8 b0 O
     elsif(dcc="1001110") then% d/ C+ d9 @/ j" ]$ Z! R
        dcc1<="10000";
7 R( s9 J) N9 B     elsif(dcc="1011110") then
2 Z( c6 O, d! u3 b        dcc1<="10001";+ `: Z# \* h6 ^
     elsif(test='0') then
8 j0 b0 Y& G( S) A0 R        dcc1<="01111";. Z& A, W  R+ H2 g  {, ?, L' b
     end if;  q* ?( E& ?9 b
   end if;- S% i: I$ G! L
end process P3;
6 U- v6 E7 y0 ?# ]8 z$ I6 _3 E: j% |
--dcc1<="0000" when (dcc="0001110") else6 M9 K9 V/ I+ i! g. `9 p
--      "0001" when (dcc="0011110") else
2 d- P7 v4 ^0 G: Z+ \! S( O--      "0010" when (dcc="0101110") else  a& ?* b8 d, U! @' C! s
--      "0011" when (dcc="0111110") else
7 {2 q: L: O7 O! r$ K3 @--      "0100" when (dcc="1101110") else7 f; [6 l' t/ y" h9 M- u2 n
--      "0101" when (dcc="1111110") else3 m7 w* ~0 M1 w7 \; H+ m8 j9 ?0 c
--      "0110" when (dcc="0001101") else
  V9 k9 K1 Y2 U, D3 T--      "0111" when (dcc="0011101") else" A! G. w' W! `* r
--      "1000" when (dcc="1001101") else
" O" Y( h& b! [6 @# }--      "1001" when (dcc="1011101") else7 B* {, p8 q/ }
--     "1010" when (dcc="1101101") else2 Z7 h, }& B% S8 y8 [
--      "1011" when (dcc="1111101") else, `( c3 C+ U  e2 s0 w
--      "1100" when (dcc="0101011") else1 A: e# O4 S; J* s9 R- M& ]
--      "1101" when (dcc="0111011") else
* I" ]6 x+ F6 \8 G8 l--      "1110" when (dcc="1001011") else
/ @- O' r9 H7 M--      "1111" when (dcc="1011011") else
+ x$ l% ]/ D! ~, U5 v0 h4 l) ^--      "0000";
: h" |0 b3 W- `$ K. y' A2 d" O% n. U. `8 _$ r2 ^1 w( r  U
P4: process(test,clk,clr)
0 M: a' L( Z! a( h2 U7 \begin
8 j9 ]6 r- ~6 s+ n2 G   if(clr='0') then+ V3 K  `8 o  ^" V5 U$ P  [
     counter2<="00000";1 g7 ]- J4 O$ @! A
     koff<='1';& T' b2 c4 ]/ c. V* Y* T4 z
   elsif(clk'event and clk='1') then- o' Q0 I/ n; ~/ C3 ^0 x! b
     if(test='0') then
1 q+ W0 n& P: D; v' p        counter2<="00000";
1 M3 ^* B( f9 E* [+ u; x3 G        koff<='0';# y$ v6 V/ @& c) n' {
     elsif(counter2<"11110") then
2 O9 t. {0 i; C* R. f        counter2<=counter2+1;; W* {! S3 f  [4 r; ]. g, D
    -- end if;3 N! m. f, w) u. v; v
     elsif(counter2="11110") then
) O8 X3 W( P' s) d4 z$ n       koff<='1';- G' H5 g0 }  `' d# p, k/ r
     end if;
( p1 J2 j0 I4 D# [$ \    end if;5 A2 G0 u7 |# k* [9 B) n
end process P4;( ^7 v7 f) K' y5 f8 x6 B
--koff<='0' when counter2<="01110"  else$ |5 h5 K! c- |  ]! p
--      '1';
' g3 s$ u! {2 J8 B6 f2 T! y/ p1 U* s6 Q
P5: process(koff,clr)
  [3 t  R- j9 Z, A4 V, u8 abegin: s. ~3 j( N. u* i, r# H4 q
   if(clr='0') then6 ^" X& ^0 z( c, C5 U
      dc0<="0000";+ _5 l) o6 I7 d5 t
      dc1<="0000";
9 n, \8 l; d6 B! v* L, _      dc2<="0000";
8 E% E$ b' L7 \; Y, U( [0 N      dc3<="0000";
/ \3 f2 N  D4 B" S      locks<='0';
: Y4 W& i) L! C% D. U      unlocks<='0';
+ ]. ^- O0 M* k& a   elsif(koff'event and koff='1') then
* M: Z) j* ]5 Z; J2 \0 @" |" r    if(dcc1="10000" and status='0') then5 V  C/ {; ^% G/ m8 d1 S
      lock0<=dc0;5 j. w2 ^# m* E# r- w% H- \2 X
      lock1<=dc1;
7 Z# g% K7 M2 ^) w9 ]      lock2<=dc2;
& i% u" t* f9 v7 n( d; t# t      lock3<=dc3;
/ m  b! @' n+ u, s( \* o1 U; U2 e      locks<='1';
, l& D( h' e' V& j7 Z- u# d! x      unlocks<='0';/ w6 j# m  Q6 @9 [4 q$ H# T
    elsif(dcc1="10001" and status='1') then- ^% u3 h& {* D( P5 v
      if(dc0=lock0 and dc1=lock1 and dc2=lock2 and dc3=lock3) then" b8 G6 t/ c. H1 [4 R1 X: E) j
        locks<='0';
3 q, c1 U( t( E! f! s- y/ w$ R        unlocks<='1';7 K% c. R: ?7 a
      end if;
( Y* F0 A4 F3 _, R    else
& n  `; w2 ?+ d& Y) g      dc0<=dcc1(3 downto 0);6 C( W; [' U! Q' r* r  @
      dc1<=dc0;
4 F& A0 f) U7 o      dc2<=dc1;+ j6 _6 R! n% j' ~/ c' E' u
      dc3<=dc2;
: y6 s- y. K& {1 T( o1 _   end if;1 j9 u. S5 T5 {
  end if;) F! L7 N  \( E) W; v+ C3 w" |
end process P5;
7 U+ e7 A6 X/ |* t4 Y
+ x; \  c/ C- p8 K& g7 B& G. PU1: decode port map(ssin=>dc0, ssout=>d0);( H5 ?+ q+ q/ l
U2: decode port map(ssin=>dc1, ssout=>d1);
* b* c( s2 O/ ]. f$ G4 JU3: decode port map(ssin=>dc2, ssout=>d2);3 `& {) k' U5 i4 i
U4: decode port map(ssin=>dc3, ssout=>d3);
& J6 U: i6 O0 Z7 {5 V4 c1 G4 ]7 z* _6 R+ T+ H0 ^$ `
segout<=d0 when counter="000" else. k' j2 P# B) `! _( }( M8 h9 B
        d1 when counter="001" else
3 A. `3 E5 v/ m, V. d1 S        d2 when counter="010" else
/ |3 L- p' n% m. T3 S# M7 y        d3 when counter="011" else
* j- t2 J& m4 M+ h3 ~6 U3 Z        "0000000";2 e/ H5 t3 L" W0 l
" \, C; J# g! A4 l  N! @
$ L1 t+ x$ E; o! g9 V6 v- |end doit;. e, b# h/ P$ A" [8 h% N$ [
* v7 u, S& b0 a; f
. x- F1 _! J7 XLIBRARY IEEE;) G6 Z! c8 r% j5 }, e0 S
1 F7 ~( m5 ^9 P/ D, ^2 C9 G! R! Q% hUSE IEEE.STD_LOGIC_UNSIGNED.ALL ;
- v8 l7 [# Y, o0 cENTITY decode IS
  |  A  E' q( n+ xPORT(
4 k# }+ u& ?+ Y8 z  ssin : in  std_logic_vector(3 downto 0);0 @& K3 q' r+ S
  ssout: out std_logic_vector(0 to 6)) g: ]8 j" ?& f) b" N) y
+ z/ X) e  g% \end decode;
/ S- {: d0 M$ ^$ I+ V3 A% x* {
' n7 Y. f4 W+ f! U# rARCHITECTURE a of decode IS; }: I6 V( d& I# F5 z
begin
* q3 u% v4 V7 n  ssout<="1111110" when ssin="0000" else
2 @$ {% g/ s# m( @  X; o  _# q4 B             "0110000" when ssin="0001" else
1 F' h( Y3 o2 V, |                    "1101101" when ssin="0010" else# z  v0 V. n/ Y( I' j" J1 t5 n
             "1111001" when ssin="0011" else
: _' A0 Q. n/ \             "0110011" when ssin="0100" else- V8 x. a6 B1 u  {. K; C9 Y
             "1011011" when ssin="0101" else
! F- k9 Z# j1 X- c- W0 n0 N5 i             "1011111" when ssin="0110" else
# `, L9 x6 Z  [3 Y" D; S             "1110000" when ssin="0111" else& g: ]# U6 ^) `7 \. ^
             "1111111" when ssin="1000" else& W$ |% o5 t0 d/ u: T7 F
             "1111011" when ssin="1001" else1 Y' U0 e- B  S" x
             "1110111" when ssin="1010" else* R( O8 t. S2 ?) B
             "0011111" when ssin="1011" else
  E0 J7 i6 ^0 M8 C; T# R) B$ z             "1001110" when ssin="1100" else
+ S( U- E1 z/ [$ b/ E9 _/ i5 ^             "0111101" when ssin="1101" else! R9 C# L) t5 c0 ~! K$ h% T
             "1001111" when ssin="1110" else
$ G8 h1 f$ n! \% L" i6 f             "1000111" when ssin="1111" else! _% w; V9 `5 b# H& p
                 "0000000";& `% ^) a! b, b: Z4 X. k1 Z- b" n& Y* j
end a;
2 s; b9 d- e# p
( ^7 b2 s0 R) C[url=]更多操作[/url]
4 }- C9 B' Z" B( }
+ i7 V# W7 K" S8 [$ P3 F* @8 Z  f, Y6 v7 _- q0 H% t
0 V' a: o6 S6 U6 J& y' S
6 n9 U) P2 ~  l2 E5 o5 U
GMT+8, 2025-10-9 07:40 , Processed in 0.140625 second(s), 23 queries , Gzip On.
