TA的每日心情 | 开心 2019-11-19 15:19 |
签到天数: 1 天 [LV.1]初来乍到
转——三路PWM 8 A* |& o0 [# C& E! }( ~
; F" S' a+ \' G2 w
--三个通道的PWM,d1,d2,d3分别显示出不同的亮度
$ _9 \/ E2 A$ jlibrary ieee;3 B4 }3 G3 m8 B; A; i9 q
USE ieee.std_logic_1164.ALL;
8 K' W, w1 T" t/ z) X) W: p% FUSE ieee.std_logic_arith.ALL;
5 D8 e3 h" R% c$ bUSE ieee.std_logic_unsigned.ALL;
, K }2 h& u9 S0 p5 F
- U9 V, H& D' @: N9 | s1 p# _ENTITY MyPWM IS
/ {7 y, T8 Y: t3 O/ p GENERIC(n:integer:=256);
& |/ L/ P+ }: d* K PORT
# u9 A, E- e3 V& M( ^ (: B5 J. d6 W( o ?% l' u7 K
clk:IN std_logic; --系统时钟
- k" N# w% Z' | B' `7 ^0 b d1,d2,d3:OUT std_logic --发光二极管% G/ ?2 q7 N! Q
8 J: Q) F& l/ _END ENTITY;
7 p5 `, [) y" p& i/ @* L
0 r0 ^0 @/ [) B4 q% U/ \& CARCHITECTURE behave OF MyPWM IS' t! z9 ?( W+ S& V" ?
SIGNAL tmp1,tmp2,tmp3:std_logic;
! K+ Y! h# D. JSIGNAL cnt:INteger RANGE 0 to n;! K% k+ b1 s. U8 l
BEGIN/ ~0 o7 `' {2 c/ @* e- U# a1 r) r3 x
PROCESS(clk)9 p7 w0 D; ~9 [1 l: {0 s
BEGIN" X- E" {; `, @! q) G# I, t
IF rising_edge(clk) THEN
( d! M5 D @9 W w" | cnt<=cnt + 1;
6 I. p6 l! |4 @( t. N: n! i IF cnt>=n THEN -- 一个周期开始时全部输出1
7 T' h! I& F& Z cnt<=0;
+ z' F2 l7 f, O& }0 w tmp1<='1';2 ^1 L. b( F C, |
tmp2<='1';
4 `" a+ j+ P- s. a( q6 B tmp3<='1';8 x3 P; Z0 p+ X, A
ELSE3 a D, t8 U5 \5 Q$ T0 z
-- PWM1% h. h- n* B7 Q t: J: y4 J
IF cnt>=n/200 THEN -- 到pwm值后输出05 i X# H6 g; }4 C
tmp1<='0';
+ B, g' x0 S1 H2 U3 `, S1 [- X END IF;
# g2 N3 e- N1 q- W6 ^ -- PWM2
$ v3 i/ |9 \; [7 o) @+ X; X- Y IF cnt>=n/20 THEN
" ~) A' |; [1 f) s: A tmp2<='0';
1 _; D- [: m1 P. Y END IF;
9 {; _1 [7 p& Y8 h --PMW3# p# O0 C8 O2 G) d. q Y
IF cnt>=n/2 THEN
1 o( q7 @9 u9 o! @ tmp3<='0';! \, T1 S* c+ v' I7 ^
END IF;
/ O, y/ y$ ^( U4 a T- l1 [$ s END IF; A: ~% z' e; d. C* I
--把信号连接到发光二极管
: U+ g) l$ Y9 L$ g d1<=tmp1;, k" k# Z7 Y# o+ G' O- w
d2<=tmp2;: N4 J m6 K' I1 z6 y
d3<=tmp3;- B. \3 O9 M$ }
END IF; 7 O6 e! o) \: H, M" j
END PROCESS;
$ D+ l% P, R. E) l! A+ J% gEND ARCHITECTURE;: S7 @ g; V) z! L$ J9 w3 J
/ @, u6 x/ y" {1 N3 {6 V
