查看: 744|回复: 2
如果请教大神,用Rogers5880压制多层板,板之间用什么材料粘在一起?
发表于 2019-4-16 10:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教大神,
# j) E6 f9 I- a9 V  T' [如果用Rogers5880压制多层板,板之间用什么材料粘在一起?
2 D1 G1 ?/ k6 P. ^! j6 N  _材料是什么属性,介电常数等,如果再中间某层金属板刻缝隙,那缝隙的材料是空气、5880还是其它材料,与缝隙大小有关系吗?非常感谢!
% s: U/ r  ^/ `* Y/ n
发表于 2019-4-16 11:22 | 只看该作者
Two categories of adhesive systems, thermoplastic and thermoset, have been used when bonding
# d) B5 H, u9 P. ]* T' s( ?. nRT/duroid 5870/5880 multilayers. Thermoplastics, such as DuPont’s FEP film or Rogers’ 3001 film, are typically selected when
8 ^" J  I3 B( y: Kelectrical properties of the adhesive layers are critical. The dielectric constant and dissipation factor of FEP is 2.1 and 0.0003.
, k9 U0 b5 H( `) ]The dielectric constant and dissipation factor of 3001 film is 2.28 and 0.003. Thermosets, such as FR-4 prepreg can be chosen
/ j- l) K+ C# Mwhen electrical properties are less critical.
发表于 2019-4-16 20:32 | 只看该作者
是用半固化片粘在一起的。比如RO3001、或者Taconic的HT1.5材料。+ q' Q# C1 c* g8 h' t
缝隙的材料是仍然是半固化片。因为在高温高压下,熔化状态的半固化片被挤进缝隙。
GMT+8, 2025-10-29 06:44 , Processed in 0.156250 second(s), 24 queries , Gzip On.
