查看: 914|回复: 8
请教关于ADC0809转换程序
发表于 2019-4-16 09:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教关于ADC0809转换程序
0 L* H$ `2 G/ w3 W9 b8 a8 o; j2 J, S/ `8 I. d
这个是ADC0809转换及显示程序,我想问AD_DATA[0]-AD_DATA[3]是十进制的吗?7 E2 ~3 d; T9 M" D+ e1 t( s$ [6 x- Y
#include <reg52.h>
; R/ J* L& t9 T. K#define uint unsigned int! K4 L! p' {& `# x$ e/ |% ~: s
#define uchar unsigned char
9 [' B% b0 I# Z+ D' }
6 q) s% i. k' Z6 p3 {, j4 duchar code LEDData[]=% n5 o! C1 w: Z/ Q9 H9 p
/ q0 F. g9 ~+ W- [         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f9 V4 h: X  t6 z" E! c
; O4 \6 `4 |' C9 Y7 {sbit OE  = P1^4;! _" \1 e- a* e6 J3 W" {
sbit EOC = P1^5;; u  o5 }( I* @) g5 r9 L1 U
sbit ST  = P1^6;
/ J, c7 W* t' c% z1 a: P& isbit CLK = P1^3;* a" c6 o' R: I% k- ]. j( [3 w
uchar AD_DATA[5]; - Z4 @6 D$ T6 |& e/ w4 _
int i;
- q0 t% i5 e& Xvoid DelayMS(uint ms)
$ T+ `! O  o$ T{2 i1 f5 H0 ^$ @, s( G' ]
         uchar i;
3 F) r& ~; {; A1 ~( x        while(ms--)
% l- a) L  T+ a5 }1 O        {
6 ^' v/ U/ I, |2 O! h+ _( [& D                 for(i=0;i<120;i++);
# o9 V! }, n1 T) [' b, g        }" v; ]7 \( b3 W; U
}# s- d1 t( N9 ]7 e" e: Q. x+ U- c  M
1 N& ]7 p1 L6 B5 C$ U
void Display_Result(uchar d)) m9 a; a$ y5 J9 N. J
) o, L6 d( C  K  Q3 [% ~& V  for(i=0;i<100;i++)
) S& x( W, G: j  {& W6 ~2 J' f( D$ }
5 ?; ^  E: s9 C. Z5 y& a4 o
         P2 = 0xf7;8 C9 q* f+ j2 w0 c( n
        P0 = LEDData[d%10];; R3 u* L% J+ F2 W: Z3 `/ V
        DelayMS(5);. j" m) D! C; [+ c' W' ?1 t5 ^5 m
        P2 = 0xfb;
) P6 a) U9 n, h- L: u        P0 = LEDData[d%100/10];& H, U9 d- C( Z  L2 b1 Z( `
        DelayMS(5);
1 r+ l. `1 y; B8 u  o6 z( F        P2 = 0xfd;
! x( l' k) {7 s' a        P0 = LEDData[d/100];
: P# U4 x, h0 i+ f. ?3 t        DelayMS(5);
" H4 @" ^# H0 p# E6 l4 w! p- [  }  q5 m3 B, X3 H8 H. K8 n2 h
+ Y) S  X+ a2 N- P! x7 v. `9 I( n6 {1 o$ y
void main()3 z& N9 m* \; g, v# l) v) I( Q6 m' y
{2 n4 q8 z4 w* J
         TMOD = 0x02;
0 N9 E5 k* W& R        TH0  = 0x14;: v1 B: O9 a$ S4 B/ w" J  R, x% j
        TL0  = 0x00;
. i" ]* c% X, D) K) B        IE   = 0x82;5 c. P9 d' a- R; Z. h
        TR0  = 1;2 i% W7 {- V. m% V: W
          F' e. O4 [2 F, a5 F4 F
         while(1)3 Q4 N! n$ ~2 @& D2 y
2 ~) z: G. ~: G) V8 \                P1   = 0x7c;, L+ }# N3 A9 u# N: x
                 ST = 0;
& e9 s6 V# h* N) s' w3 s5 c! J                ST = 1;
$ ]4 [+ V# e# |- J                ST = 0;. H7 P& H6 O( z" l/ ^  o9 L
                while(EOC == 0);
! z. }1 L, |$ I* U5 M" S                OE = 1;% u% \2 I0 P! P/ w8 d3 K
                AD_DATA[0]=P3;4 o( j9 ]$ e! v9 y8 B3 f6 j
                Display_Result(AD_DATA[0]);& h7 t2 A% ?3 Y% Q4 S0 M
                OE = 0;
$ V$ d. @, t+ w' t                   DelayMS(500);  o! d2 D* S5 n& N. V+ L3 M: w
( g0 v8 U( ]" X( t3 q                P1   = 0x7b;  T$ l" D! b) N; j# Y  J
                 ST = 0;# x2 c5 k, ?/ I5 |4 `
                ST = 1;
1 t: U, @$ L8 j, Q  O' q% v3 A                ST = 0;7 f8 n5 q7 ~4 G+ n0 u9 j+ [
                while(EOC == 0);, L- J+ a* m7 H9 g' f4 j0 L
                OE = 1;: N6 j, I% ?, ~/ V
            AD_DATA[1]=P3;
5 Z% R& ]* `+ ~* M' i% [                Display_Result(AD_DATA[1]);& w) E( w% T+ V2 n, s2 u
                OE = 0;
, \9 q! G3 [0 k                   DelayMS(500);! r, b+ z2 G  d2 s" G
5 |, J; h1 ?7 ?& R( D& \
                P1   = 0x7a;5 O9 y! I; x7 e
                 ST = 0;, F% q% H% h7 h* J4 H
                ST = 1;
0 A) E/ U# t2 |" k                ST = 0;
% {, D6 b5 g% \6 E                while(EOC == 0);8 n' a# H. l" S5 z1 b3 }
                OE = 1;
' S' `6 b& ^1 B5 `' _1 r                AD_DATA[2]=P3;& `7 }, e3 U& l
                Display_Result(AD_DATA[2]);
/ j% g) Y8 G" h5 N& t5 q* d                OE = 0;- h1 O# @# o1 M2 I/ u& d
                   DelayMS(500);/ B' G) h8 U) N3 c6 K" P- g2 `
# H) m9 \. A2 ^                P1   = 0x79;
/ S! _9 g, c% R+ x                 ST = 0;
- m9 H9 f/ I* ~7 P- W' E                ST = 1;
$ ?( ?) x" A/ E                ST = 0;
. z6 w& o, \- z! c# [) t6 ~: ~5 l* r& W/ u                while(EOC == 0);6 v$ V: Y, h6 u9 Z; v
                OE = 1;
8 x0 c/ e/ v, M; S                AD_DATA[3]=P3;5 h" L* \# X9 B
                Display_Result(AD_DATA[3]);0 X% K" {* o, n. j6 G
                OE = 0;3 h3 Q3 `: E. A% B: s* \
                   DelayMS(500);3 c8 Z9 T. ?) ?% Z7 b
$ n+ O. e) Z/ c' |& i( Z
            P1 = 0x78;
* |0 l/ ?: L  z( {$ g                 ST = 0;+ O6 E: x; [3 |2 [
                ST = 1;7 `$ A) K5 ~& k# G3 z$ J" u
                ST = 0;
$ ^# j  j$ K8 ^- W- {3 S                while(EOC == 0);. `' a, }2 D3 t/ @7 x; J% G+ n
                OE = 1;
! h- J" x: \. f% Y$ a- s0 [                AD_DATA[4]=P3;
0 n- @1 r$ w  l& {- c5 P/ v0 ?                Display_Result(AD_DATA[4]);
+ s8 U, G) A/ {& {" N2 N9 A                OE = 0;
& u+ q4 q$ T7 Q4 W/ ?2 _. p2 ]                   DelayMS(500);, t" x. N8 U0 o# N
7 o* e" R- Y. g$ X1 c. m          }
3 |7 }" k& k2 o- ^
! I$ e. o- z6 G% X% X
; K$ d! n# A! |/ `( e. u- S! W+ S2 {, F; i0 W7 h) _9 F
/ w+ v8 g3 p$ {  C
: U9 G$ }) o5 y3 L2 U4 K' vvoid timer0_INT() interrupt 11 ^0 W  o/ Y' `% H6 F! s) Q! h
{7 Z9 q6 |" b6 y; T. t$ E
         CLK = !CLK;
0 ~+ N/ u- ~; I. z+ c/ ^}" q6 [; n& s. K4 ?$ Q% C9 M- N" j, u9 R
发表于 2019-4-16 09:36 | 只看该作者
我可以肯定的告诉你,肯定是16进制!
" `1 x( \2 Q; K6 R; f9 s为什么呢?首先,单片机是以二进制形式才能识别才能运行的,其内部数据如RAM,ROM都是以十六进制进行存储的。编译器会把我们编写的所有程序都以十六进制形式存在ROM中,包括你问的问题。
- R' u* u  M. Y% ~) b# I0 \这时你可能有疑惑了,举个例子:P0 = LEDData[d/100];这里的100是十进制,为什么d(十六进制)/100(十进制),这样除能行的通?为什么能行的通呢?3 l. F* C7 J$ [/ E1 J4 R
编译程序的时候编译器会自动把100变为十六进制,这里d/100就变为十六进制除以十六进制,而不是十六进制除以十进制。所以我们不需要把100变为十六进制再相除!!
: n) m+ j6 y6 P( r: E明白不?
大神,那我想要把它和一个十进制的数进行比较怎么办?  详情 回复 发表于 2019-4-16 09:43
 楼主| 发表于 2019-4-16 09:43 | 只看该作者
helendcany 发表于 2019-4-16 09:368 Y7 b0 j" }% X% x2 m7 t' h7 T
我可以肯定的告诉你,肯定是16进制!0 S+ \' K8 @" R. S& u; P
为什么呢?首先,单片机是以二进制形式才能识别才能运行的,其内部数 ...
( y" {# T% K) w1 _- j7 a大神,那我想要把它和一个十进制的数进行比较怎么办?
* a" f8 b! M  y+ O
一样的,比如if(AD_DATA[0]==60)和(AD_DATA[0]==0x3c)这2种写法都是一样的  详情 回复 发表于 2019-4-16 09:59
发表于 2019-4-16 09:59 | 只看该作者
罗斯 发表于 2019-4-16 09:43: H) Z- Z$ s3 ~) a
# M; v, x+ E- }: w! v一样的,比如if(AD_DATA[0]==60)和(AD_DATA[0]==0x3c)这2种写法都是一样的$ m: \' {/ V. A; g& J+ t# ^
不对呀,我下面的程序不论e是什么值,都只执行 motor_forever(); e=0x96; //150 if(AD_DATA[0]>e) motor_appoint(); else mo  详情 回复 发表于 2019-4-16 10:14
 楼主| 发表于 2019-4-16 10:14 | 只看该作者
helendcany 发表于 2019-4-16 09:59
+ @4 e( Y7 X9 H6 N) e一样的,比如if(AD_DATA[0]==60)和(AD_DATA[0]==0x3c)这2种写法都是一样的
# S9 ~" D# Y$ S& _. x不对呀,我下面的程序不论e是什么值,都只执行 motor_forever();
- S: S0 H5 ~% D( T- s# o/ X5 he=0x96; //150
1 W* `) }- B! R& ?0 d/ e9 {if(AD_DATA[0]>e) 7 j' @1 X* U9 a- F
                    motor_appoint();
$ m& }# D- Y& }9 F; j7 k        else                                          motor_forever();
, i* d5 K6 E9 {; C& C4 i
# l& y  }- W/ c' P
你把AD_DATA[0]=0x97;试试  详情 回复 发表于 2019-4-16 10:22
发表于 2019-4-16 10:22 | 只看该作者
罗斯 发表于 2019-4-16 10:147 P7 H! B0 x4 x. K9 r/ X
4 U+ Q( C9 _; p& i8 z3 r% {e=0x96; //1504 t' p$ E  Z# Q, c
if(AD_DATA[0]>e)
! Q0 r6 z4 E: @* `+ S" H1 ~你把AD_DATA[0]=0x97;试试, t- Z1 o* R5 r2 e* M8 j- e
果然可以了,为什么呢?  详情 回复 发表于 2019-4-16 10:37
 楼主| 发表于 2019-4-16 10:37 | 只看该作者
helendcany 发表于 2019-4-16 10:22! x# f- [7 O6 i1 g
; t: s2 C- k  c0 M+ A果然可以了,为什么呢?
) I2 S1 D) l: N: R
AD_DATA[0]有可能为0  详情 回复 发表于 2019-4-16 10:44
发表于 2019-4-16 10:44 | 只看该作者
罗斯 发表于 2019-4-16 10:37
, Z- S# _' R/ R% {果然可以了,为什么呢?
, C% O! Q4 H: Q( i  N
AD_DATA[0]有可能为0
8 D+ r% {% X0 h' g. s* f
GMT+8, 2025-7-24 01:35 , Processed in 0.125000 second(s), 24 queries , Gzip On.
