void init_timer(void)
8 D$ c8 [$ B4 U' _ Q8 a+ B{: h) u0 Z+ r# J8 X- ?
//AUXR &= 0xBF; //定时器时钟12T模式) Z, ~: |* N; g& R" E: H
TMOD = 0x11; //设置0定时器模式1
( a' w c/ k/ i) j TH0 = 0xFF; //设置定时初值5 C- y3 @! ^5 M' O1 `* q; G
TL0 = 0xF6; //设置定时初值 10US) m% _' V' X& u
TF0 = 0;% ^$ G7 h1 Y9 D$ P) Q; l# l- C
TH1 = 0xFC; //设置定时初值
0 w8 ` Z7 k4 F TL1 = 0x66; //设置定时初值 1mS
8 g6 D( u( a5 H TF1 = 0;7 w! m) y2 ^3 b
ET1 = 1;# L; X2 a- ]+ d/ @. y4 q6 [3 K
ET0 = 1;5 Y/ G7 l. d9 t+ B9 f
EA = 1;
1 R6 L9 G" A, U! o TR0 = 1; g7 h! k& |! y0 h6 b2 Y9 H
TR1 = 1;
7 x3 |3 s( `* D}
2 ^6 P9 y: z7 a! {2 Y7 Nvoid key_scan(void)//按键扫描2 a5 x" x, j, R+ L l
2 e, F" k" S& k! N key=1;
' L# O2 A" ^ u( i" @if(key==0)8 _. Y: _" U; a9 E% L% T' B/ A, {
; l: Z0 K, n5 M) D4 G Q# B- P$ e delay_nms(15);3 n( @9 e$ |3 C7 I4 V+ M' V* R7 t; i
if(key==0) p( Y% w1 }+ C7 D" M8 d4 C w
{7 ]8 o, |6 V1 j, Z0 G* U
key_flag=1;7 S9 N% [# |" Y3 ?: \
}- a( @5 N, g5 ^0 R8 X7 S& J) H" E# g
}4 e1 G4 H4 ^2 i: f- K$ W
; A }' M% L6 ]7 w3 K. }/ l2 R7 h9 [void main(void)4 Y) M; G% b1 b1 r# r4 I6 q3 ?
{ ( U( ]5 B# Z, B8 y8 N
init_timer(); //初始化定时器
" d6 v1 T& b7 R Init_BH1750(); //初始化BH1750) A( T5 c+ L, t3 R
Delay10ms(2);
7 @2 V" W; B# C0 V Single_Write_BH1750(0x42);" z& r. h, F, x x. L* u5 t9 F
Single_Write_BH1750(0x65); //设置透光率100%
+ ?; N$ l- J7 z# d; A8 k/ ^///////////////////////////////////////////////////////////////
0 Z- \! T* O7 E. C$ i1 U; @- X/ j7 h while(1)
/ S: w2 }, F @8 b1 Y7 S; f {
( h: I3 z4 B' x# c) O1 j6 q3 b key_scan();* u2 w* D9 G6 c- j! ~
if(flag_BH==1)6 W; H K: r) z; _ U
{9 R- Y" _1 S5 s, \* w) D0 Y* K3 c
flag_BH=0;& Q9 j7 v" a. d1 E, n. Z
Single_Write_BH1750(0x01); // power on8 K$ Z" x% y8 @2 C
Single_Write_BH1750(0x10); // H- resolution mode& C7 _# m, H0 x7 C
BH_flag=1;
@- `' p& _* G% {}
2 R& r$ [& k* ?+ n if(flag_key==1)( J3 h( u' z1 u' H' Y( H" D: B1 A' [
{5 [. e8 r/ Q/ |: p# S: L6 K
PWM=0;& h; a6 a/ P3 n) P. d9 ~( n+ {
bh1750_con=1;
3 d; s2 R( u4 s, e1 q* p }. y2 P; I `# F
else
: m8 ^' |& u o8 w! d {1 u+ M8 A1 t# t
bh1750_con=0;' K& U- f$ {: }5 }2 I
}+ [( i1 b8 w7 s; `& l* Z
}6 h5 X5 z. E5 N* c5 j! P! {: Q! C
6 j1 O* @6 G4 T/ S, D# H///////////////////////////////////////////////////////////
9 x6 Y- S! P" N! j3 R# hvoid timer0()interrupt 1. V0 R8 W, W3 u
& w* p: o. L P& z! A( nTH0=FF;
0 Y( d) N3 L8 J9 I- M0 `/ pTL0=F6;! I9 u5 ]8 w# ]/ Q+ u
n++;
0 ]4 ?5 S8 e4 s; ?. ^8 ^# ?if(n==100)# V( e0 ^4 n! n8 z/ }2 h' U
) r" f9 s' t5 f X7 B2 L n=0; ;
3 Q# f( i3 k& i/ Q5 l- w led=0;9 M# h6 b9 [$ y7 N/ j' _/ V; ]
j++;
- ], }9 E- Z, {/ E}
& `3 F9 ^: L" R! dif(j==200)
& a. |9 u- b P" D{4 V4 Z2 _/ f4 ^1 U; t2 N
j=0;
* L; g( y: ], L2 z4 e if(flag_key==0)
5 O5 v; n9 N, c$ Q {
+ A- p2 K& ^; O1 q0 v if(Data>15&&PWM<100)/ d6 V! i E5 a. E
; @* Y6 |# n+ }& U4 | PWM=PWM+1;
- Y8 [6 B! c$ l9 w$ ~5 h5 \ }
: u# O; N! s, _3 Q Y4 p else if(Data<5&&PWM>0)) Y6 C4 ^) y4 q& K( V: m
# { N# A3 H3 D; f1 k- o PWM=PWM-1;5 R; T) T! z- G1 H t9 {, q
}4 H; i. L( a0 E% Z3 X# {
3 j4 `: H' t3 p/ N6 b}
5 f3 e% h5 `( {4 u//if(PWM==0) con_l=1; 1 x# H4 Z! J! W4 c+ t
if(PWM==n)
1 h/ R$ I, O5 t* s0 x+ }: ]% W U {
, f# T$ A2 Z$ q2 ~8 V" P& ~led=1; //输出高
) f2 [/ y8 y: _* u. T! J6 N }+ P5 }- {6 U! x. ?; T
} //PWM越大,占空比越小
4 b; y0 N0 ^) q1 h( t///////////////////////////////////////////////////////////////9 Q$ e3 w$ m+ E
void timer1()interrupt 3$ A6 I, h c8 N$ W
{, o9 j- l, k g2 j2 q, \
TH1=FC;2 {( U5 s# T4 ]# J! h* w: H1 k
TL1=66;
, {1 Y( \3 @$ V* P0 x1 q2 Zif(key_flag==1)
3 J* C9 [5 J+ n+ N4 ~{5 c1 z5 t# U4 R% w
i++;
) [8 ^' X% y7 y8 Q- H if(key==1)' S! w) K7 O3 _& }. s" @( v+ Z! j
) r2 X* ~+ { Q0 m( [ delay_nms(5);% ^1 m S+ Y: ~ A: Q# k2 V3 k, K
if(key==1)
7 p* g* p. E! @/ ?( w# u {/ M* v' q3 e' ?/ U- F, Z& A
if(i<=100)
$ n% D0 O; s [ flag_key=1;1 s8 {( t: p! Y3 |( H7 w# A% o
else if(i>100) flag_key=0;- _" W% d9 h, s' X
i=0;
+ P1 f) Q* C8 ~4 v* ]6 skey_flag=0;
+ u# e& H$ {# W* v. v, b }
+ R0 U& _$ a: |; q$ l9 a }
3 `: v3 p4 G# l. y1 d}
* Y2 R) g) r! @3 S6 Kif(BH_flag==1)* i$ L; ]" \6 ]- [5 g) @+ o
{# V/ z3 |! |% s: m
BH_c++;8 w7 W& A g4 b. ^* Q/ G
if(BH_c==180)
$ z1 g T% g6 D8 q {
, _ b5 e8 M% \9 O6 q" H( J! F BH_c=0;
. U/ r7 N4 w: O6 Y" c" X Multiple_Read_BH1750(); //连续读出数据,存储在BUF中
) f2 f" |" ]# n" q" |$ V Data=BUF[0];
2 A9 e, k$ t/ `7 S, I Data=(Data<<8)+BUF[1];//合成数据,即光照数据
% v K! F! ~1 E1 Q$ K2 i5 u/ ? Data=(uint)(Data/1.2);" w l, x) `8 z. w
dif=abs(Data-10);5 u" [3 v' i; X1 [. z2 h
BH_flag=0;. F6 E1 x: B% E/ s" S4 s; { F
flag_BH=1;
& J" h) W& x/ p& g }
4 a9 z. o1 D! O}
) S, A$ \. C7 X} |
