查看: 556|回复: 1
转——HPS_LED_HEX代码解读
发表于 2019-4-12 13:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
转——HPS_LED_HEX代码解读
: t1 o1 ~5 B+ o  U7 f+ Z; m$ }/ h
: x: k7 S0 ~0 j! ^* Y8 Y" a  Q7 c刚刚学习SOC不久。这几天在DE1-SoC上编译和运行了友晶提供的一些sample,初步学习了一些相关代码,把自己的理解写下来,希望各位大侠不吝赐教。4 I) a) f, m' c
) c' w: ^3 X' g( W% e- M1 [/ h  ]$ {4 i
) q7 s% B9 i, C# I3 L' x3 G2 c" Y1.    硬件(HPS-FPGA)架构
Qsys中连接h2f_lw_axi_master led_pio
# t: Z8 j! l5 Y" j
把信号输出到10FPGA 引脚:
soc_system_led_pio.v
always @(posedge clk or negedge reset_n)
   begin
     if (reset_n == 0)
         data_out <= 1023;
     else if (chipselect && ~write_n && (address == 0))
         data_out <= writedata[9 : 0];
end
2.    HPS侧软件
打开内存设备
main.c
         if(( fd = open( "/dev/mem", ( O_RDWR | O_SYNC ) ) ) == -1 ) {
                  printf("ERROR: could not open \"/dev/mem\"...\n" );
                  return(1 );
& f/ z+ T% x! P' `! M7 v- R$ s
进行地址映射
virtual_base =mmap( NULL, HW_REGS_SPAN, ( PROT_READ | PROT_WRITE ), MAP_SHARED, fd,HW_REGS_BASE );
9 r. J) H6 C0 g$ Y+ R% c
通过LWH2F bridge 映射到连接LEDPIO端口
         h2p_lw_led_addr=virtual_base+ ((unsigned long)(ALT_LWFPGASLVS_OFST + LED_PIO_BASE ) & ( unsigned long)(HW_REGS_MASK ) );
其中LED_PIO_BASE 对应于Qsys中定义的地址
hps_0.h(87):#define LED_PIO_BASE 0x10040
# _9 z7 Q: A2 x- f
创建点灯线程
ret=pthread_create(&id,NULL,(void*)led_blink,NULL);
- s4 p+ e5 s6 Q) w$ J) v
点灯函数中调用LEDR_LightCount
void led_blink(void)
LEDR_LightCount(i);
8 g! j' |5 A7 \* m( ^+ x
LEDR_LightCount函数中调用alt_write_word
led.c
void LEDR_LightCount(unsigned char LightCount)
{ // 1: light, 0:unlight
   alt_write_word(h2p_lw_led_addr, Mask ); //0:ligh, 1:unlight
9 @5 |! E+ o% x$ j
alt_write_word实际上就是指针操作,把src地址的内容拷贝到dest
C:\altera\14.0\embedded\ip\altera\hps\altera_hps\hwlib\include\socal\socal.h
#define alt_write_word(dest, src)       (*ALT_CAST(volatile uint32_t *, (dest))= (src))
3 `' x" x0 B1 m  y; R
发表于 2019-4-12 15:45 | 只看该作者
发帖是心得 回帖是美德
GMT+8, 2025-10-8 23:03 , Processed in 0.156250 second(s), 23 queries , Gzip On.
