时序分析教你怎么看singaltap逻辑分析
/ v+ O3 e& t) M, b/ [- R, h' |+ ]7 f% L- Q9 e I7 m
module dyn_seg( input clk ,//clk_200hz input reset_l , input [13:0] data , output reg [3:0] seg_s ,//用于片选的寄存器 output reg [7:0] seg //用于段选的寄存器 ); // ************************* // SIGNALS // ************************* reg [1:0] cnt_show ; wire [3:0] data0 ;// 定义四个功能寄存器 wire [3:0] data1 ; wire [3:0] data2 ; wire [3:0] data3 ; reg [3:0] hex ; // ************************* // CODE // ************************* assign data0 = data/1000;最高位 assign data1 = data%1000/100;次位 assign data2 = data%100/10;倒数第二位 assign data3 = data%10;最低位 always @ (negedge reset_l or posedge clk) begin if (!reset_l) begin cnt_show <= 2'b0; end else begin cnt_show <= cnt_show+2'b1; end end always @ (negedge reset_l or posedge clk) begin if(!reset_l) begin seg_s <= 4'b0; end else begin case(cnt_show[1:0]) 2'b00 : seg_s <= 4'b0001; 2'b01 : seg_s <= 4'b0010; 2'b10 : seg_s <= 4'b0100; 2'b11 : seg_s <= 4'b1000; default: ; endcase end end always @ (*) begin case(cnt_show[1:0]) 2'b00 : hex <= data0; 2'b01 : hex <= data1; 2'b10 : hex <= data2; 2'b11 : hex <= data3; default:hex <= 4'b0; endcase end always @ (negedge reset_l or posedge clk) begin if (!reset_l) begin seg <= 8'b0; end else begin case(hex) 4'h0: seg <= 8'b11000000; 4'h1: seg <= 8'b11111001; 4'h2: seg <= 8'b10100100; 4'h3: seg <= 8'b10110000; 4'h4: seg <= 8'b10011001; 4'h5: seg <= 8'b10010010; 4'h6: seg <= 8'b10000010; 4'h7: seg <= 8'b11111000; 4'h8: seg <= 8'b10000000; 4'h9: seg <= 8'b10010000; 4'hA: seg <= 8'b01110111; 4'hB: seg <= 8'b01111100; 4'hC: seg <= 8'b00111001; 4'hD: seg <= 8'b01011110; 4'hE: seg <= 8'b01111001; 4'hF: seg <= 8'b01110001; default: ; endcase end end //// ************************* //// SUBMODULE //// ************************* Endmodule 大家看到我用singaltap抓到的波形有时钟 计数器 片选寄存器 段选寄存器 每个寄存器的波形以及在某一段的区间内 的关系 从图上我们可以看到我抓到的波形例如2813
- J" t q8 K% L) ~% D; [ |
