查看: 482|回复: 2
基于FPGA板的音乐盒的设计
发表于 2019-3-13 07:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于FPGA板的音乐盒的设计
+ `2 w! j/ F! e8 W' W6 T
: r7 Y' `5 g3 x& M- Y
计数器:
+ I$ ?) w- T0 @+ C8 r( e% P/ n8 r/ H& P- }. e
module count(clk4,num,full);
( {) W' v9 r% I
4 L: z/ c6 F! K7 V8 ^: winput clk4;9 @; X7 r- D7 [4 |% m) A
0 h# _; v% ]: Y% z4 L5 f4 t
output[7:0]num;( q( H9 W* Q3 g1 z6 s
output full;
! c8 ^3 X/ W3 T0 F7 i! ~0 Sreg full;
+ p! {7 v7 {$ freg[7:0]num;
1 c* W$ N  z1 D" z1 Y8 [( I3 M( Oalways@(posedge clk4)
# R+ x+ S2 J7 ^! ebegin
6 v$ Z+ l+ v- |& d8 K        if(num==127)
) }' q' {! n1 V$ p* A                begin
, X, {6 T: N6 X* L* T                        full=1;
/ `# ^# R- a3 {- V! l                        num=0;
" R7 ]8 G9 r- o& P, z8 b# N                end- @. ~! B9 P4 I- e
        else
" b+ w$ R' X: f- y* o                begin- Q  R& f4 n, L/ O6 H: U+ c
                        num=num+1;
( }7 j! v9 }9 r7 S8 h) Y) r  N                        full=0;
) o" o/ D9 p* f                end8 R' C$ l- ^" G+ ]4 x0 e
end. R2 K+ w0 H( {" F( D
endmodule4 e9 L% e* b7 W5 M4 P- n' z  b$ S* K3 h
/ R& o8 P' I& ?
音调译码器:
; u/ C) h# {' t1 S" h7 ~: R. R% {6 {; y
module decodeA(Qin,Q2);
: o. I% r- m! x; q, s4 sinput [7:0]Qin;
- ]7 l) r+ G. T4 P( t* m. r9 Youtput [4:0]Q2;
. U- ^8 r2 ~' M, ?reg [4:0]Q2;
7 O; ]! d) \1 n5 b5 X. Walways@(Qin)
. g& B" F. \' {* l: y# S* g0 rbegin ! ]% v5 i. U7 a: K
case(Qin)( C) d% Q. k8 }* b/ T
02=13;
1 K* j' C+ D4 x7 {+ Y6 X# r, y12=13;) c2 C* {( X: V' b% }6 N- f' T) o2 j
22=13;
" Q: X: J& R) d: _. p8 |3:Q2=13;! V0 ^2 f. g5 F$ h7 ?: O! H
4:Q2=12;9 m6 ~' T# |9 ~
5:Q2=12;* @: N; U( I$ O2 ?* E) t
6:Q2=12;
% v1 P1 B3 k% ^5 F' }7:Q2=12;/ U3 u2 D0 b) Q( Z
8:Q2=10;
+ E! j, Y6 v+ ?% I1 X! ]- C9:Q2=10;
. w( J; _- x! h* [$ z- Y6 j10:Q2=10; ! M) y- I$ y" T1 U  H0 W
11:Q2=10; 4 U4 k+ n& D8 f( a; a
12:Q2=12;   2 [6 v" s3 @' |/ k5 K
13:Q2=12;
, i% p. \( ^$ ~, V( j8 b* G0 J4 U14:Q2=12;   1 p2 p. s6 e8 o8 v/ [+ Q  e
15:Q2=12; # \/ y9 x( T" \3 m+ g
16:Q2=15;& R. M2 O8 B* U
17:Q2=15;8 G! }  P: y$ C
18:Q2=15;  : E( m0 z4 p! x* c. W2 h8 W
19:Q2=15; 3 U0 |: o, E4 Q" o
20:Q2=13; 1 B3 y0 T  Q' X# _4 k# T/ d; [' U  w0 ?
21:Q2=13; . }, d: B4 |( m# \' q/ g
22:Q2=12;
4 @4 Z8 r1 ~) V* L$ M23:Q2=12;6 \: F3 @  m# ?: h6 O: M. }
24:Q2=13;
4 b% m4 \, k9 o7 y: {1 q. A25:Q2=13;3 g2 ~3 ]: v2 e- V& c- J
26:Q2=13;
) H- i, o) y0 c* C/ b6 f# J# X! w27:Q2=13;' p. c; u1 p, r0 r7 C& b
28:Q2=10;9 m! R% |4 P" b$ j! r  S4 d
29:Q2=10;
; j) W# C7 K/ v9 M30:Q2=10;
9 Q  j3 n% E4 [1 y- \: j/ U2 _/ U31:Q2=10; 4 b; L' g9 k: e9 r+ y" c3 J
32:Q2=12;$ H6 k. A) ~; ?4 y+ Y
33:Q2=12;
4 |0 d: W+ a# U34:Q2=13;4 P6 E+ r# {# b) A" A; o
35:Q2=13;
$ v, ?  t/ k% w0 r# f36:Q2=12;
" _+ t5 u4 A  i. H37:Q2=12;
9 X( h! _/ q, \% N6 i) m1 |38:Q2=12;2 F2 I9 ]+ y  y5 u& o
39:Q2=12;
0 ^( ?9 I; u$ x4 i+ w2 W40:Q2=10;
. Z/ f' @3 c4 y( E9 ]41:Q2=10;
, z2 l# h( Z5 `: M5 I" V- s42:Q2=9;' l5 O' Y/ h- \9 k/ Q" Y
43:Q2=9;8 t0 y0 |8 ]! B* E- z
44:Q2=8;& Q/ v8 ~/ n8 l5 S8 h: }( ^
45:Q2=8;
, Z8 x$ z' z+ w" g1 V2 L46:Q2=6;
, D+ I2 G7 ~  n* Y$ c* N* l9 E+ Z47:Q2=6;
- a8 x. A) d3 E2 }- }48:Q2=12; ) y( @# {& i! o. `
49:Q2=12; - k6 H- @7 j3 y
50:Q2=10;   & Y* K3 k; @$ c, }) M- c
51:Q2=10;  4 K. k& ]7 U# \9 E# C; r  }: b' M( z5 S
52:Q2=9;
+ n1 ~& U& P, v  b, n- p53:Q2=9;
0 n: g9 J+ j7 {  x$ T54:Q2=9;
& W% W  A; q! {6 ~3 K& Y. t55:Q2=9;! u1 f3 p+ Y5 t
56:Q2=9;
# w9 w: J1 y+ Y& q57:Q2=9;
; `/ w- a# e' X58:Q2=9;
& b  `, H! U) P3 H! Z2 M7 h8 d59:Q2=9; , W* V! a* F6 X$ ^& o, d* G
60:Q2=10;  1 \& R, U. I. u4 N- [3 U6 A
61:Q2=10;
1 l. A. E( @, g& K  A2 o0 d, }  G62:Q2=10; / T7 C. d1 m2 H7 Q9 a
63:Q2=10;
# H/ K8 u* u0 T# V1 ^# Q64:Q2=12; 1 s9 h9 z* ^. J3 ^0 k- u6 m
65:Q2=12;
) w* g$ V* z" b0 P  q& i1 U" G% Y66:Q2=12;
: q7 W/ M, @' |) y9 M7 C67:Q2=12;
1 V3 a+ R9 b: X3 e% T5 k7 b68:Q2=12;  0 i* a: M& N0 r8 |
69:Q2=12;  4 [8 {2 @# \7 K9 k6 ^9 j* X6 [
70:Q2=13;  $ z" k- Q  v; q  e
71:Q2=13;8 r% a# k7 i0 c7 r- c
72:Q2=10;, r8 J& s) C8 g) b) t
73:Q2=10; ; R; p# m4 u+ J5 H! \
74:Q2=10;  . n& a1 q( W. [/ c) s4 C2 I
75:Q2=10;
; K& o  @5 Y8 v$ I8 S7 Y/ {76:Q2=9;   . R# f3 s  ^, x- l8 Y- w
77:Q2=9;
1 X7 w& U9 v/ S. v; p, k1 ]78:Q2=9;
! ~, {7 I/ u4 Z  m; k! R, O79:Q2=9; : W+ l3 x, U1 N3 Y2 W
80:Q2=8;
7 A: Z8 ]" b( ?- Z2 d& \81:Q2=8;   T6 ^, i5 K* ]6 G
82:Q2=8;  4 W9 b& i, s2 }+ `0 k
83:Q2=8;
. H( k7 R# t% H  S/ H4 T84:Q2=12;
6 N/ g5 P9 B0 `' O, ^2 H85:Q2=12;  . Y- }+ l5 a3 L' W3 A  V" r
86:Q2=12;  - K% l# C0 o9 R6 V& }0 @8 M
87:Q2=12;: R& x5 U3 R- d/ W, i
88:Q2=10;  2 Q+ u8 q) I3 J8 }* G- K6 J0 D
89:Q2=10; + B0 a+ i1 e& L7 x9 }% Q
90:Q2=10; / z2 E$ ~" s3 h! L
91:Q2=10;   7 J" b6 u' V+ p0 y/ i0 j
92:Q2=9;
$ ^# }3 R) W4 @! U/ c- S: [93:Q2=9;
/ C+ C' G) x' z, D9 c, p# u; O94:Q2=8;  + b9 M4 C% v) K, T8 C# T$ Y3 L
95:Q2=8; # z# O" I$ |# ]4 Q
96:Q2=6;
7 e9 K2 R8 b/ c" J$ w97:Q2=6;  ) h" U9 G; O7 Y/ A! s
98:Q2=8;
2 m: P; }/ q% Y# W99:Q2=8;   3 L$ S/ o% Z  v" k; R2 C+ e) u
100:Q2=5;
9 T. v0 J& H8 c8 P+ W* M0 v8 R& U101:Q2=5;  ( n. X7 D7 d9 }$ r, ]0 p% }
102:Q2=5;
4 f# ]# r5 V- f9 p# c& ~, r6 O103:Q2=5;
% n  d( w7 U* @4 r' r8 bdefault:Q2=0;
0 a! X* A* c1 u2 e, X1 [8 R) J0 ]- y6 }endcase1 J* X2 X; n" N6 v3 Q) c
end
  q6 Z- y0 M9 R9 Z+ u: X" C! M" J: e) v  ]* G( N+ E7 X( G& Y
endmodule
- g0 M: w6 J2 @( E/ F6 _% F( `2 \8 B% }8 t
4分频:module div4(clk1,clkout4);- U5 ^5 ~. D3 A  o* l- G: H# ^& v" H; L
input clk1;
, l4 c  L! W6 ]output clkout4;
8 T) _3 n4 Z2 h  G3 Ereg clkout4;
: q; w1 K. o# Dreg [31:0]q1;4 l- Q/ U9 a- r2 `- e+ E
always @(posedge clk1)3 p0 F0 }) J, Q/ Y! ^7 D
begin ; m  z) S& @" k7 c& F
        if (q1==6249999)
3 a- m' l( U$ `. E0 }        begin q1=0;+ w# P1 [& J+ J) m
                        clkout4=!clkout4;$ O) R- ~# H. K8 t: e5 A) o
        end, R( }4 V7 m2 R5 ?. S, L8 }
        else! v, R0 y$ v/ Z; D
                q1=q1+1;/ G. u* m5 G) K% F7 g7 M2 b/ S
end0 @- r9 Q) Z, z4 C
" U* L; H* e8 f( y
endmodule, `4 s8 A& f9 u' u- U, B
# n7 l# f" e" [7 s
预置数译码器:module dcodec(din,origin);
- `& ]3 H1 v& O& G7 X8 m( Dinput [4:0]din;
2 G1 {  F& z* M/ W" p' s. u3 ?output [31:0]origin;+ E) Y" P* Q& Y: {+ T
reg [31:0]origin;
3 ?& A) k0 f- @. w9 h; Qalways@(din)
5 Z8 e7 c7 U, n! N- \/ fbegin
. i# @2 l- i7 l3 B! u% L- Ocase(din)
- O! a3 a& {9 Z7 ^' H0rigin=50000000;
' H0 @, a1 H% ]0 L; w6 e1rigin=95749;
( R; `7 `9 M8 B4 D2rigin=85266;
, W3 S' l) V! a. N3:origin=75965;
- q# ?  Q: H6 ~4 Y1 x/ H+ i4:origin=71695;
( _% n8 p* V+ H5:origin=63857;  7 ]6 S9 {9 k! R: V, @
6:origin=56883;    8 R( G/ @' _/ E
7:origin=50669;   0 g( e, a; G) A( U/ P. J
8:origin=47819;
; u; ]( s/ d0 r5 [9:origin=42604;
; M# d% u& J4 n10:origin=37948; : K; l( ]" b: \8 G. ^; v( `6 ?
11:origin=35817;( i) o+ t( H0 K/ a1 w" M
12:origin=31908;' ^! F- G) |1 |; N+ h9 Y+ v- G" b
13:origin=28425;
4 x6 v+ x+ C2 U# H( S3 [4 P14:origin=25332; " m/ v" w7 }6 A
15:origin=23901;. T3 [" o5 E! Q! o( f- U- j, i( u; z
16:origin=21291; + F5 ?! o% F) j1 t5 C
17:origin=18962;
6 |4 B7 Y: ?+ |18:origin=17903;
, _) U+ H) a$ d' c7 y/ j0 y19:origin=15949;
1 ^2 s. L' J. X9 A20:origin=14209;  / C1 K: ^1 w3 Z
21:origin=12658;   l$ k, [9 g6 c3 c/ w
default :origin=50000000;
+ W' C; B( k8 v4 tendcase
; D" X. y( i  _  v9 rend0 x; ^( V; M- v; u  p
# J& Z: Z. j, @+ X# x  @* Aendmodule4 v$ z) k/ s' Y5 }+ A
* _; b6 s- X$ z) p/ Z任意分频器:module divb(clk2,clkoutb,origin);6 r5 p9 b0 o+ E3 W
input clk2;& r$ l& |0 i" s& f+ T) ]! @& X
input[31:0]origin;
6 q# K0 B$ ]; ]output clkoutb;# b# O" E- q% I
reg clkoutb;
8 \+ V6 e# [* b% x4 x( qreg [31:0]q2;
  O* A. r$ ^. Nalways @(posedge clk2)
& \6 R0 o7 Q- [begin
- I$ x6 g- M/ }        if (q2==origin)
" a# k" u; j' z                begin q2=0;; m9 l- H0 Y# R4 x& m% u/ f
                                clkoutb=!clkoutb;
0 j; j3 v& S0 _( [( _                end. q# ?; }* _  f# Q
        else
. ]8 ?" e( ~/ a0 Q- o% `1 F; R9 c                q2<=q2+1;) d0 B5 |8 H5 B3 {' ?- S& C9 z" h: R
end
5 `# p, u# \9 J/ J3 ~. x- i& R% p- |4 f  U2 V
endmodule$ v4 o5 [; ^$ c. |
5 x. T/ c9 _! c- l; C) L8 s
顶层模块:module song(clk,speaker);# U; r; }! ^. o
input clk;
1 H; P3 P2 T% k. }% D9 soutput speaker;+ m- r. m& A( }; J0 T* M4 v% N8 d
wire A1,A2,A3;
9 ]0 Z% U$ i  p% ~; @# A  k: ewire[7:0]B1;3 o1 v3 K( O* z: b! ]' P7 Z$ x
wire[4:0]B2;+ |3 ^" ^5 b% e- r" m  t, T
wire[31:0]C3;
$ H- r* D) z$ p, _" b! W* \reg speaker;# ?6 b. V) z: ~! v
div4 u1(.clk1(clk),.clkout4(A1));- f2 @" Z+ G+ F) T& J
count u2(.clk4(A1),.num(B1),.full(A2));
8 ]( O  A9 e& a' L% L5 O) I! |! UdecodeA u3(.Qin(B1),.Q2(B2));
, X# j) H; }( p( c6 U4 edcodec u4(.din(B2),.origin(C3));) }% @# J! x+ [; L9 K8 j# A  E
divb u5(.clk2(clk),.clkoutb(A3),.origin(C3));( u; ?) p; R( L' \: P: C! L
always@(posedge A3)
8 a+ [( \* b/ {2 p6 Q8 nbegin- x  x3 ~* V6 Q
        speaker=!speaker;
/ q0 Y! j/ q" @4 j5 {end6 v- v1 d( t; P2 j" H& O7 y
endmodule
9 f( t; C$ \$ m- ]: p( P) @
发表于 2019-3-13 14:48 | 只看该作者
谢谢楼主 我这就去试试
GMT+8, 2025-10-12 16:51 , Processed in 0.125000 second(s), 23 queries , Gzip On.
