查看: 888|回复: 6
AD检查规则设置
发表于 2019-3-4 18:41 来自手机 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
画PCB规则设置主要要设置哪些规则?
    慵懒
    2020-3-11 15:45
  • 签到天数: 8 天
    [LV.3]偶尔看看II
    发表于 2019-3-4 20:28 | 只看该作者
    物理规则和电气规则
    + y, _) r$ w- l3 _物理规则包括:线宽、间距、过孔大小与间距、铜皮间距、器件间距等
    ' ?5 A! U$ ?  [2 x6 T: O电气规则主要是时序方面的规则设置,以及3W这样的电磁兼容规则
    那完全用AD默认的规则吗  详情 回复 发表于 2019-3-5 11:07
     楼主| 发表于 2019-3-5 11:07 来自手机 | 只看该作者
    wmz 发表于 2019-3-4 20:28
    , T4 a8 }1 u+ [物理规则和电气规则2 b1 J3 w3 Z, J  F2 p+ Z1 r
    物理规则包括:线宽、间距、过孔大小与间距、铜皮间距、器件间距等( `& ^8 t5 M9 o0 z% N
    电气规则主要是时 ...
    " N$ C$ g7 F; J3 V7 r3 W5 c3 O- F
    那完全用AD默认的规则吗
    发表于 2019-3-5 22:14 | 只看该作者
    肯定不能用默认规则啦,低速线关系不大,建议多找找别人的案例看看线宽线距这些规则
    2022-5-26 15:12
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    发表于 2019-3-11 20:35 | 只看该作者
    谢谢分享!学习学习!
    发表于 2019-3-17 13:29 | 只看该作者
    There are 2 main rules you have to take care of: Electrical Rules and Routing Rules.& _2 t" ~; K( U5 k' [0 H
    Most important rule in Electrical rules is Clearance, it means the distance of space between two object. These space depend on voltage level (high voltage level => larger space), PCB manufacture capacity (typical minimum space is 4mils), for high speed interface you have to maintain 3W (3 times trace witdh) or 5W (recommend) to reduce crosstalk.
    " X( t0 ^6 a' j; W$ f7 c$ r5 M# k) c, j: k5 T
    Most important rule in Routing rules is Trace Width, it's mainly depend on current flows in traces. You can use some PCB Toolkit to estimate trace width (I'm using Saturn PCB Toolkit, it's free). Also depend on PCB manufacture capacity (4mils), m6 v4 s7 a; c8 \5 w
    For vias, large via => more current flow. I often set Minimum via size is 8mils for hole and 15 mils for Pads.
    好的谢谢  详情 回复 发表于 2019-3-18 14:47
     楼主| 发表于 2019-3-18 14:47 来自手机 | 只看该作者
    hoantv 发表于 2019-3-17 13:29
    % O/ P) t9 M0 P* TThere are 2 main rules you have to take care of: Electrical Rules and Routing Rules.
    1 |( j* d9 X5 ?0 pMost important ...
    4 `* ^6 C3 [& u- g好的谢谢
    GMT+8, 2025-7-22 16:31 , Processed in 0.140625 second(s), 28 queries , Gzip On.
