查看: 706|回复: 1
单片机LCD12864仿真与2402关机多种状态保存源码
发表于 2019-1-22 13:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
! m& }' C( R' J5 @4 @0 `+ P
8 ?8 P& i; a0 H# M+ Q8 s% b
/ Q; T/ }6 z, K& y/ k* ^2 }! \8 f
4 H- R) V/ e% Y% Y- c) ~  a1 g
/ y, H( f. f) J9 r! y0 ^+ Z
( _' e/ F" G, l$ ]/ Q8 U- R
#include <reg51.h>
0 X1 v; ?1 ^* G- u3 {$ x: E#define LCDoff           0x3e# @/ Z  Q) G# g6 n! }7 Y
#define LCDon           0x3f
$ o; r( n' S; f#define pageadd        0xb8  //ye/ N  u  h; F7 O4 y7 T
#define lieadd             0x40  //lie
+ |0 o5 Y! ]2 U& \! P. k#define hangadd        0xC0  //hang
% r; k/ f7 ]# R9 q6 ~#define uchar             unsigned char
9 l3 F. ]1 S7 O5 K3 c$ b#define uint                unsigned int
( D% m3 Z' e8 t* Euchar vg=1, vs=1;$ a+ v3 u- O8 b4 g
bit   ack;
+ x2 y* |' D; dsbit  sw1 = P3^2; ) ?: G& ~$ Q& j, N0 \0 R& t' R
sbit  sw2 = P3^3;
( J! O8 b" i9 Y- K7 tsbit  SDA = P1^7;
7 Y9 ~  H6 j4 @% qsbit  SCL = P1^6;
" O5 b6 m: f& Bsbit  RS  = P3^5;
# s3 Y+ q6 \5 s6 S: Wsbit  RW  = P3^6;
' n/ p$ K; D4 j7 Y0 ?; vsbit  EN  = P3^4;
( u4 k; f1 X+ E( A+ t! h' u) Jsbit  cs1 = P3^1;    N0 ?" `* q: ~- w
sbit  cs2 = P3^0;
; A) l3 n. e4 F5 G, R+ P3 O$ ]
1 A. ?) [, k% \3 s) M8 Q1 Dvoid  Us(uchar t);
: `5 E+ Q4 E* A% i5 b# b4 |void  delay(uint k);
, g7 i  |! f9 P$ x9 kvoid  busy();9 b! S. k4 O" T( b* [+ _) v' j
void  wricmd(uchar cmd);8 \* h' {' q$ H- {, ?; T3 k
void  wridat(uchar dat);  o' i$ B' C/ W
void  LCD12864init();: S8 K5 z4 M& ?
void  disply();
) @' L/ b# \, @3 e- D: ?3 ^2 Q" l. Hvoid  qiping();
4 M' V# j6 D4 j2 Nvoid  pianxuan(uchar pianxian);
/ f8 H3 J! O/ B! a( vvoid  disply();  Y% @; Z* c; M' K6 H6 |. i6 T9 F
void  key1(void);8 d" ^4 |2 d' B1 a
void  key2(void);3 w* M9 h+ b! G& a
void  Star_I2c();
4 Y: Q0 Y! z: L/ Dvoid  Stop_I2c();3 k6 T. I6 N8 r# L
void  W_B(uchar c);        ( e$ w+ E" C8 N# L' M7 j1 t
uchar R_B();
' o" G5 `; c% Gvoid  Ack_I2c(void);
2 ^6 Y$ O( l& I6 i# Avoid  NoAck_I2c(void);
+ O( x* k& G9 H9 d1 n. G' zbit Wristrs(uchar sla,uchar suba,uchar *s,uchar no);8 z% S6 R0 \* ?5 Q) o! a
bit Redstrs(uchar sla,uchar suba,uchar *s,uchar no);3 ]+ C) z8 e7 y2 h9 I: Y
void hzfdisp(uchar px, ye, sl, n, we, uchar *wc) 0 E5 }& y  X1 |2 q) y
char  code tupian1[]; //haixin0 t$ k( _' k- ?: C
uchar code SHU[];
% G4 a) j) N) X/ R7 R, c( D0 Luchar code Hzfu[];
9 K/ W' b) h$ |- S1 N6 kvoid ledoff(void)
' {  Q' V4 D) b# @{
4 q; E, E9 {2 Y        switch(vg)
# z7 z/ `7 I- V9 P4 k8 [; ?5 |( c        {
+ @! u% B0 C% d        case 1:          P1 = 0xfe;         break;
  N& C  G8 Z: B' B% A  }        case 2:          P1 = 0xfd;         break;) C9 t1 K# Z. h
        case 3:          P1 = 0xfb;         break;8 h& H( [' j$ z. z1 R: e
        case 4:          P1 = 0xf7;         break;
  W6 i" U; A6 H9 p: V* \* _        default:/ r  m: [8 \7 p* m2 \* z
                break;" y0 r4 R) |0 z, c1 M# n; P% {
& W3 G% i; c( i. e5 n3 }6 ?& f! D' b        };9 ~, U: |" Z+ o5 x% R
        switch(vs)) R2 |: W9 b9 x3 u$ g
4 o1 E. S; n5 o' _8 z4 F        case 1:          P2 = 0xfe;         break;, y+ ~' G& M' A5 T, Q
        case 2:          P2 = 0xfd;         break;
$ o; ]' E5 w5 z. S$ m        case 3:          P2 = 0xfb;         break;
. q+ O+ p! l9 H: i        case 4:          P2 = 0xf7;         break;8 d6 g1 P2 C$ b5 d; V& c
        default:
# [! o# o' R' H1 _; `7 i6 H                break;
4 I; h# J! }* T6 W0 n- s        };3 ?7 y: [( g  K, D  h5 I
}$ Q. v" m% e0 h2 x2 s# `& ]: a
0 c5 `% |8 Z# e$ s- ?void main()
) p( Z2 s$ D8 C  b& w/ K{- z. A5 R2 E, Q2 k" I. d
        LCD12864init();+ L; K* D8 A* @  S* d1 d
        qiping();
" {$ k+ D) D. e7 S        tpdisp(0, 0, tupian1);
1 q+ a4 s# L! r: x4 V6 R  O        hzfdisp(1, 6, 8,  0,   16,   Hzfu ); //-----强大的汉字与字符随意显示函数
% {, H- H7 q. @9 T6 ~. A        hzfdisp(1, 6, 24,  1,  16,  Hzfu ); 7 X/ D) p/ m  i* c; Q
        hzfdisp(1, 6, 40,  2,  16,  Hzfu );
4 u/ ]" ?9 A2 W9 p  A! I        hzfdisp(2, 0, 0,    3,   16,  Hzfu );   T4 S* T8 @2 S* t, J
        hzfdisp(2, 0, 16,  4,   16,  Hzfu );: e- \$ _8 B6 g: x7 F6 m
        hzfdisp(2, 0, 32,  1,   8,    SHU );
) d& b$ l/ N) v4 w        hzfdisp(2, 0, 40,  10, 8,    SHU );3 E9 j* W. n! _/ R# g0 s
        hzfdisp(2, 4, 0,    3,   16,  Hzfu );
( W7 n0 l) J: g+ Z, C        hzfdisp(2, 4, 16,  4,   16,  Hzfu );
2 O7 Z2 s8 _2 V5 p/ ]9 N" {! a        hzfdisp(2, 4, 32,  2,   8,    SHU );
& T- {$ U+ p. f# @' U* V        hzfdisp(2, 4, 40, 10,8,      SHU );
1 U" D4 q1 A' M% u        Redstrs(0xae,4,&vg,1);  //调用存储数据
) Y$ W5 A) x8 V: k* Y* A        while(1)
8 P" v# K* h+ H0 M        {
' t# e! F! o0 {1 q, b' y. f                disply();
; W& t2 O7 u2 R; `" h) n/ k5 @( B                ledoff();, e. l8 @4 S: s6 O4 v( u/ A
                key();                         2 g+ Q& ?& D/ @4 Z
                Wristrs(0xae,4,&vg,1); //写入24c02 2 R( H2 A# e$ h# k  U( ?0 Q5 C. S
        }* K/ r3 V# o, U8 b
# G, W, i( j1 }( a( g; _+ D) O& V; o2 R
void  disply()0 J& P/ B. g4 E: J
{3 l* j+ x4 ~2 V& z9 R3 u
                  hzfdisp(2, 0, 48, vg, 8,   SHU );5 A( K. @9 k/ S0 d
                 hzfdisp(2, 4, 48, vs, 8,   SHU );* e2 O5 j) C8 E  z3 r0 Y6 W% T
}4 u9 ]3 i5 U, u& B+ [/ _
1 }7 t6 r# m+ u* C
void Us(uchar t)
! x' I6 V( j+ Z8 y: u3 O{
% H5 y' Q1 _' _! p+ U( R* j$ c        while(--t);, l$ u1 J( H9 v% l' B4 _/ V: \
}7 x0 T4 c; v9 o3 N; c7 X; c. Z
, z) O+ h) D9 s+ vvoid delay(uint k)( x" F6 p+ C' t7 X
{5 K* W/ ^- c# s+ R% x. p
        uint i,j ;
! P. `+ D* N" L9 |3 d: q: q- }        for(i=0;i<k;i++): o( D3 u( ~' Q+ H: ]: k9 x
                for(j=0;j<20;j++);         1 o6 @5 u" S% A/ M# T& w
5 l5 }9 c, c& v& pvoid busy()//LCD是否忙                1 e& T2 r( ]% c) `
/ K$ p. e8 M3 g: w# n; c        uchar dat,buysbit;//状态信息(判断是否忙)
: {5 ~1 e) g+ P5 x- [$ A        RS=0; * x: D' ~8 b% J, e/ t
        RW=1; + G9 E8 F2 Y6 F3 y! g5 s
        do3 g$ H5 f1 \/ q$ }: L
        {% o/ z" F/ v, F1 b
                buysbit=0x00;
" E3 N: z1 F* c9 X                EN=1;& ?+ p8 E6 V  T6 [
                dat=buysbit;4 v% e5 t0 F! l) A! V. w2 r9 @4 J
                EN=0;' G7 J6 t2 A8 h) c( O
                dat=0x80 & dat; //仅当第7位为0时才可操作(判别busy信号)
- u& Z' v3 V9 D* n7 e5 M    }
- Q1 d0 m7 I% V    while(!(dat==0x00));
2 m, B8 u9 f5 |, \) a}$ u- [0 q! r& a2 ?: J: c: L
$ b4 y/ Z) q7 y" J8 ^, i7 V
void key(void)( \( D9 x$ n8 Z3 i( a) C. w& a6 f
{0 @  c8 h" H; a" P; [- J% e" |# n$ ~
        if(sw1 == 0)  # c. l; j+ P$ }, T0 F
        {1 L1 y8 E) @6 t' W
                delay(10); 7 |5 u1 d9 l9 q7 M& ~
                if(sw1 == 0); r8 Z0 q4 i2 E. W1 }
2 v3 V; G6 m, r& S3 R; M) M                        while(sw1 == 0);
% N& L  r7 S( V% u& u8 g9 {                        if( vg==4)vg=1;
, U6 [) g- n" j                        else        vg++;
& A  q0 j0 a1 g, G8 J' p/ r                }1 }3 u& q% O' a& ]+ N; h
        };/ `' n/ i3 R9 q$ ?/ ]) G
        if(sw2 == 0)
' ?/ A; u- S! _+ [% ~        {
- Z( I6 u2 N. G3 y                delay(10);
# c9 f; g7 L$ l) {: v0 J$ T                if(sw2 == 0), G9 J( a% e# T, D. D
9 E( d. @0 |1 |9 t0 Z, h: N; S                        while(sw2 == 0);
1 m! L% ?8 [5 ]. q1 j0 l                        if( vs==4)vs=1;! A. X4 F' H8 p! D
                        else        vs++;
. Z9 Q1 [! w( N; u                }) U) A: Y2 |2 ^) W
; |4 ~( D. ?" v+ x" `! X0 n7 b' i}+ G' ~2 J) ^; l$ [0 Y
* u) m2 G( t. ^# R9 J: Uvoid wricmd(uchar cmd)//写命令& x- S3 W) e  f0 w) m1 e' f
{4 C- A2 \0 S. g* ^) Y. |
    busy();//检测LCD是否忙
0 n; f* A( v5 y        RS=0;
) _! z, z& D: F        RW=0;
+ a0 ?& m" r/ m/ c/ N2 e        P0=cmd;                ) _) O$ @; k5 V, B6 o
        EN=1;2 V' W4 e7 g- j" G7 Z2 V  T
        EN=0;) p: A% U* r( f" N
}( |  E3 d4 ?. l2 @& d
  n5 A+ E. D- u$ W
void wridat(uchar dat)        //写数据到LCD程序# t1 s! ]# x' X7 N% f
9 b: G# H' z2 g0 p6 V( z    busy();//检测LCD是否忙
, I1 B& f2 R: Q3 ~( X9 H        RS=1;1 x5 ~% `. z' \4 A  D
        RW=0;
. u( H" A4 p9 ]        P0=dat;% W/ i5 i4 r% g! a# w
        EN=1;
1 @2 ]5 C$ u- n2 D        EN=0;
5 q+ {  x; V' ~2 n}
. C; E- a$ d3 B$ m
) z" R# L5 Z; q" M: Ivoid LCD12864init()//LCD初始化程序# K- P: x/ E' H
, J& {( ?3 H* h1 K& z/ K# ?        cs1=1;//刚开始关闭两屏
$ p7 s* c# A3 U" `        cs2=1;
8 q) Z  q, ~. r" W  b5 d+ E2 B% s/ q        wricmd(LCDoff);         //写初始化命令
, P9 V" t; O4 k" y# e        wricmd(pageadd+0);8 _/ ~, S) C9 L) I- ]- o  i7 i1 o
        wricmd(hangadd+0);
* L. m7 Y- ^4 K% v1 m! K        wricmd(lieadd+0);( H8 F: B& V* b3 q$ O
        wricmd(LCDon);: g# _. n0 D2 x( L
( ]+ ?' e* {5 M* C: e
: T: s$ J" I: f5 [$ Z8 X+ kvoid qiping()        //清屏
7 _0 h$ N3 ~! W/ Z{5 {3 w& [5 a& r. z- k& ]7 A
        uchar j,k;
3 t, k5 Z3 [0 ?. k* d/ J        cs1=0; //左、右屏均开显示  e9 [- f6 s  S9 u
        cs2=0;4 x3 Q/ Q6 n$ U* ]
        wricmd(pageadd+0);
$ i% t, Z4 l9 s        wricmd(lieadd+0);
. q, g; v6 y! |$ h2 v- b3 ]4 F2 ^        for(k=0;k<8;k++)            //控制页数0-7,共8页) c* c/ Y. [" F8 k) Z
. h$ |/ L! H; `4 x) y' J& Q                wricmd(pageadd+k);     //每页每页进行写5 H0 E5 Z  [: \. g! G, G6 r* }
                for(j=0;j<64;j++)      //每页最多可写32个中文文字或64个ASCII字符( V6 w& O  d9 ~. I
                {, s7 S2 L! ~/ J
                        wricmd(lieadd+j);& q8 s) V% P% P% O9 _
                        wridat(0x00);     //控制列数0-63,共64列,写点内容,列地址自动加1% C# n7 k' i; `% ]8 d! H
                }) k$ q+ X1 ~) e
# O1 }, Q- u, o% L1 M}
( d8 p$ f* q4 A- b5 J( h: I( f% F6 _' \0 p
" Y6 _  W. x; C4 m) ]0 Z{
2 I1 n9 T5 ^& ]- A        if(pianxian==1)
4 b, @6 E# u7 C5 Y, |# B        {7 Z4 |0 k' p8 Q7 Z$ g
                cs1=0;          //开左屏' J. c- I, Y5 [
                cs2=1;
4 F9 K0 M3 V2 f* o% {6 I        }
8 p, d. {' T6 f/ j/ [        if(pianxian==2)
# r# q# U1 u6 y- `7 X$ Z# {3 v! X        {; I/ ?2 d; W8 x1 P# q$ {6 s
                cs1=1;         //开右屏) S- U. ~) g- V
                cs2=0;5 m- a/ d8 ?* E' `& Z7 s
  M' ]9 H, X5 {        if(pianxian==3)
( A0 Y5 W! x6 k3 Z0 o2 o4 v0 F        {9 Q4 p2 r0 A+ @, v) Q2 T
                cs1=0;/ q. ]2 h$ r, Z2 }2 h* U) D
                cs2=0;* Z& a1 Z( d! R% \" f2 x
2 C, f3 ]1 N# O9 C}
, n  \# V8 H$ r
1 T% j, }9 I3 ~4 D//---------------------24C02程式--------------
2 T6 t1 O- v9 c8 p% avoid Star_I2c()  //开启
/ s1 g" S1 i, v: q6 S7 K! B0 P0 V{% d4 |8 i: m& Z* F8 I$ k
        SDA=1;  Us(1);
+ @* T- M/ r' J4 U: I5 \        SCL=1;        Us(5);    4 b& z4 b& s" Z" D$ Y& T
        SDA=0;  Us(5);    + h8 r) W& f7 ]+ W
        SCL=0;  Us(2);0 A5 C6 `+ b# Z
3 O9 S" G) ^- h, `4 T/ d% k3 }; J. Z8 j7 p8 p
void Stop_I2c()//停止, X  p0 {1 T6 Q: a9 n
  n( h0 r/ F* Z8 s5 c4 ]        SDA=0;   Us(1);
5 O& ~# `/ x9 a" }' L        SCL=1;   Us(5);
' c, n7 k7 h3 b( x  \        SDA=1;   Us(4);
' i. G2 |, r1 \  L6 b1 H9 a4 ^6 ~& t+ b}
0 {* I, l) d% ~% I) b
  K' B5 a  j0 f  g  Pvoid Ack_I2c(void)//应答" H3 E: r9 Q2 F  k* g
7 O, S" y# z, }        SDA=0;     Us(3);7 s/ h. D' {" B; ?" ?" i0 `
        SCL=1;     Us(5);
, R8 ^5 k5 f2 E' R% Q5 a2 ?        SCL=0;     Us(2);
; v4 z5 H  r( f}
$ u5 ^) |* O# v+ X- U/ }
$ v5 ?! P: u& A& s* Wvoid NoAck_I2c(void)//非应答
/ d# A3 x! t' l9 w; v: W+ n- \{* e' f+ f& o. [. N
4 G  ?! K4 Y1 Q& `  n6 B        SDA=1;   Us(3);      - b' w* G/ s& E' H
        SCL=1;   Us(5);
# q. e0 r, J& g$ s( @! P0 v8 W        SCL=0;   Us(2);   ; x3 [1 m' I" U! ~6 |
4 i* A6 G7 U  \1 i, Y" t8 ?; E2 s' N3 ]5 _; d
bit Wristrs(uchar sla,uchar suba,uchar *s,uchar no)# O  }2 f6 R0 f( ]6 p* K: D
{% o6 m! S) W. {2 p  l- m
        uchar i;
, i( ]' W% e  [$ k        for(i=0;i<no;i++)
8 o% U8 r$ m6 a+ O    {
9 i2 a5 C0 ^2 O3 Y3 n9 w( s                Star_I2c();               //启动总线" ?6 r0 @4 `5 X
                W_B(sla);             //发送器件地址/ V; @3 S) N  U& }, t
                if(ack==0)return(0);6 |/ f& l% k) H0 y6 z  E
                W_B(suba);            //发送器件子地址# M0 q! O0 A. n$ ~! k1 B$ u
8 H" L1 m+ ~" l4 e6 A4 Z. d: W, z9 ]3 ]
                W_B(*s);              //发送数据
9 g5 j0 k. C$ S* s                if(ack==0)return(0);7 h* p4 G7 _+ m8 H
                Stop_I2c();                  //结束总线
# k, [3 q' C9 g" j2 ^4 J                delay(1);              //必须延时等待芯片内部自动处理数据完毕
- T8 r' D  O; W3 d6 \                s++;; ~) w! l) K: {" c
                suba++;
( q4 P9 h6 U4 X& C3 g, m/ |  G5 A    }   m$ B8 f7 y2 l/ }# V1 @
        return(1);
6 b, F) C3 {" c+ `. W, E; M8 t9 X}
7 P4 z/ u9 t& J9 k
7 F6 I& n+ K- O, T( k1 k+ W1 o* \/ pbit Redstrs(uchar sla,uchar suba,uchar *s,uchar no)
" p) Q+ f- T" Y$ b/ g( O{
) F- W* A! z5 V; Z* A2 t( D5 z        uchar i;
& b7 j2 t4 ~/ @: u8 B* \        Star_I2c();               //启动总线
: y9 ?. r# I9 U( U5 g# K  l0 _        W_B(sla);                 //发送器件地址4 \/ f7 T6 p6 _3 I
        if(ack==0)return(0);- l( u7 j  k) a: E0 U
! l& `2 d# \0 `# j4 {% a        if(ack==0)return(0);
% Q" n. t# |4 l% t( l$ K3 b7 x. N" [
6 a& g4 [- L. M8 R        Star_I2c();/ N( @& I5 b6 K3 G/ E1 X* z2 }: e
        W_B(sla+1);
% W$ D4 S# G( G: M* p1 W5 h' M        if(ack==0)return(0);0 N# E# q7 Q. ~
        for(i=0;i<no-1;i++)
3 ^; b; D/ t, \1 k  }+ @    {
. e( D8 N6 T0 D- v7 A( H+ I) d                *s=R_B();              //发送数据* c" k/ j+ b+ {4 G2 D; Q, j
                Ack_I2c();             //发送就答位 : F/ O8 y4 x$ q) A& ?2 C; E# W
                s++;) u, y, C' ~) {! J% ?
  V& ?2 \: x# ^( f3 K        *s=R_B();
, C: n, U8 n; k3 L    NoAck_I2c();                //发送非应位
" n% I* B7 E) z  Q' h5 n    Stop_I2c();                 //结束总线5 k% `! P9 d7 \% U! A" \
        return(1);7 v2 Y$ D9 v: ]* k$ H
}+ i" e* w5 O/ _  v7 p
/ ^& Q, R! t& b* euchar code Hzfu[]={          //汉字打包搞定; w/ T  {7 j; k1 ~1 e4 k  z; ]2 H
             0x08,0x08,0x08,0x88,0xBE,0x00,0x00,0x00,0x00,0xBE,0xBE,0x3E,0x88,0x88,0x08,0x08,
7 x$ `6 x( v& q+ v2 K        0x04,0x06,0x07,0x7F,0x7F,0x7F,0x00,0x00,0x00,0x00,0x7F,0x7F,0x46,0x43,0x61,0x61, //花 /---1
/ S2 B; }: |. ~* l  ?9 H                0x10,0x10,0x10,0xFE,0xFE,0xFE,0x10,0x00,0x00,0x00,0x00,0x46,0x46,0xFE,0xFE,0x00,
  O) X* l; G5 I: \$ f0 i! }  y        0x00,0x3F,0x3F,0x3F,0x13,0x13,0x3F,0x00,0x00,0x00,0x00,0x42,0x42,0x7F,0x7F,0x00, //蝴 /---2- _, }, T7 E" e/ M
                0xF0,0x10,0xFC,0xFC,0x10,0xF0,0x08,0xFE,0x88,0xBE,0xBE,0xA8,0xBE,0xBE,0x88,0x88,
- x3 _1 u5 q8 ]9 M1 E7 a8 @        0x43,0x42,0x7F,0x7F,0x22,0x73,0x60,0x62,0x1A,0x0E,0x7F,0x7F,0x0E,0x1A,0x62,0x02, //蝶 /---3
, o* G/ S3 w' Z            0x10,0x10,0x10,0xFF,0x90,0x50,0x00,0x00,0x00,0x00,0x8E,0x88,0x88,0x98,0x88,0x00,
! C+ Z4 j& }2 w- a' d* M% |        0x02,0x42,0x81,0x7F,0x00,0x40,0x40,0x00,0x00,0x00,0x00,0x08,0x16,0x31,0x20,0x00, //按 /---4
0 k$ ~2 E  \0 W9 I8 U4 M: q5 ?4 S        0x40,0x30,0xEF,0x28,0x28,0x44,0x64,0xDC,0x10,0x54,0xFF,0x54,0x54,0x7C,0x10,0x00,
# x: ~( H1 o+ C5 X7 ?) o        0x01,0x01,0x7F,0x21,0x51,0x22,0x14,0x0F,0x14,0x25,0x3F,0x45,0x45,0x45,0x44,0x00, //键 /---5
1 D) ?4 g2 \$ n2 _8 C                0x80,0x40,0xF0,0x2F,0x02,0x04,0xE4,0xA4,0xB4,0xAF,0xA6,0xA4,0xE4,0x04,0x00,0x00,* p% b0 i. ^0 B- p
        0x00,0x00,0xFF,0x00,0x40,0x40,0x7F,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x40,0x40,0x00, //值 /---6
$ O* x/ t" C3 E/ F};; w" Z* b6 i  e; N
# D; J: ^# g8 x& r. @: I: D5 [) ruchar code SHU[]={
/ ?3 S5 c/ a3 l            0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//  05 F" p: A2 X+ ~1 d9 u5 A* ~+ @
                0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//  1
8 S: q2 ?$ `; m+ v                0x00,0x70,0x08,0x08,0x00,0x00,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//  2
* j/ Z" c( [' L6 U  g9 r                0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//  32 o5 c  Y3 F! k" }5 d: L0 E
                0x00,0x00,0xC0,0x20,0x10,0x00,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//  4/ V; g. g% r* W! k4 B: n6 ^
                0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//  5
  A5 q3 S/ c, I+ q/ n* J( p5 W                0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//  6
* ^# D, F0 L+ a+ j' z  y  w, l8 [                0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//  7
2 t: I8 I& B$ J8 e                0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//        80 [/ L; l- U, C6 r& z( k* E
                0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//  9
+ Q( S8 J& e/ H9 Q# O                0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//  :  /---10
9 w2 q7 q; r  k- q- u* @                0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//  v  /---11& Z, i+ j* z- s3 P
                0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//  A  /---12% V& }6 t! N0 h4 r& r
                0x06,0x06,0xE0,0x10,0x08,0x08,0x08,0x38,0x00,0x00,0x0F,0x10,0x20,0x20,0x20,0x20,// 温度符号 /13& n/ @0 q2 K) C, `
};! v, W5 `) B) p  `+ G
char code tupian1[]={ //meiyu
1 B  Z8 T) A; c        0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,# u+ s9 B& p1 _1 k. d: B
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
3 P( |( t, a' B0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  K9 S' h( n- W1 |$ h# H
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,6 K( a+ a  @% X
4 [6 b: d4 T: N! \: V& R: k0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,; L: N8 S* A- a5 v1 K
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,. r6 B2 S2 Y+ ~5 J, j
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,# e: ]: k; K. V& G* s! d
0x00,0x00,0x00,0x03,0x07,0x1F,0x3F,0x7F,0xFF,0xFE,0xFE,0xFC,0xFC,0xF8,0xF8,0xF0,
! T/ W6 d; d# {6 @& \0xE0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
" f6 P4 a" j6 L) @! d) n0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,
3 k0 q3 ?2 T  @' c7 l- j  b! o5 e8 G
& u/ g( \7 D) A3 a1 o/ t! q% ]* T
#include <reg51.h>
. B+ S' |0 e$ o& o7 D* l#define LCDoff          0x3e
4 L/ f- a0 }; m- w( I4 S4 w#define LCDon           0x3f
& p8 r. U. q* J; V4 }#define pageadd         0xb8  //ye  ^% T$ Y! Y2 f& {7 ?
#define lieadd          0x40  //lie5 R+ ^1 g1 t- @5 y2 S
#define hangadd         0xC0  //hang* q' N1 S0 x! J- f5 n3 w# ?
#define uchar           unsigned char$ Y$ Z) @, l% J: k
  }) y8 l9 P) F; t3 |% v& g8 Zuchar vg=1, vs=1;
7 P3 D/ D( v; o8 ]$ ebit   ack;
' Y" x# I3 e& W9 M  ssbit  sw1 = P3^2; 2 m% F, e8 L; V( a  o2 `+ i+ q
sbit  sw2 = P3^3;
4 n, g/ Z: Y$ Y% [. Y. jsbit  SDA = P1^7;
; P* T, i7 v5 m4 x4 ]' Q6 m% t/ H/ wsbit  SCL = P1^6;
$ v8 c) F: i& y- U0 g- U6 asbit  RS  = P3^5;
$ N, `5 u2 g1 K1 K7 i" t& Rsbit  RW  = P3^6; 7 x& B% X: v  e
sbit  EN  = P3^4;
/ B" @9 r( n  Q$ @8 vsbit  cs1 = P3^1;  ' }# r6 W, K$ ]. t
sbit  cs2 = P3^0; 5 \3 V. }6 `2 H/ a0 B% J8 V* a& \% C
. R  D* _1 \3 M9 @+ ^void  Us(uchar t);3 s. k' d- D8 S" P$ j/ S3 U
void  delay(uint k);
5 m9 S- K: Z# [( D, h1 ovoid  busy();
  G9 w; F$ |6 v: Ovoid  wricmd(uchar cmd);
; P# F# `+ w! Tvoid  wridat(uchar dat);
. K# h: c- X# jvoid  LCD12864init();
- M* B3 H, M: o7 w( L* dvoid  disply();
  c: o6 S$ H) \; B" Pvoid  qiping();
, h9 P! J. E( Q4 p- Q9 O/ ivoid  pianxuan(uchar pianxian);' y3 b7 M  D; K; ]0 B/ p2 v
void  disply();  k- ]. v+ w$ a5 J" q; x  L$ A
void  key1(void);( P! ?0 N. z. T4 w, B! {" i) e
void  key2(void);
6 \. T$ V9 N$ u6 R0 [7 bvoid  Star_I2c();# W, h7 P( [" r
void  Stop_I2c();
1 j& v) A7 J0 n# ^/ x( Yvoid  W_B(uchar c);
7 W! p! ?) v: Ruchar R_B();
/ b" J0 x. v) |5 r; k2 D/ b' J! Svoid  Ack_I2c(void);
' U6 S; `' n: G  n% |* evoid  NoAck_I2c(void);
; l3 Y+ G( ]* e& {bit Wristrs(uchar sla,uchar suba,uchar *s,uchar no);
7 b) o* L2 K+ z' B- Wbit Redstrs(uchar sla,uchar suba,uchar *s,uchar no);/ J+ u/ U1 u# ~) ~
//--------强大的汉字与字符随意显示函数
4 r' b% @. a% Uvoid hzfdisp(uchar px, ye, sl, n, we, uchar *wc) & V2 q) N; Z6 M2 @& A
char  code tupian1[]; //haixin" g/ a9 t8 I2 ]1 }- q
uchar code SHU[];# \% \3 K7 R) }9 G0 s7 k) W0 s
uchar code Hzfu[];
  u* u" ?* V$ x( g0 |) C; zvoid ledoff(void)
* p4 ^2 `# Y% O1 m0 N{
, K" ~$ l+ c4 W8 v$ |1 E        switch(vg)" M/ t+ ^) U; e2 e  ^
        {( U; ~% a' J/ Z/ a3 f
        case 1:          P1 = 0xfe;         break;9 G& o: T1 ], l0 y
        case 2:          P1 = 0xfd;         break;9 G0 }1 K* Q- A0 A' f
        case 3:          P1 = 0xfb;         break;7 b9 h& P# ~8 b6 a* }
4 V4 j' r1 A6 _, y9 E$ G, E" B. G  y        default:3 w' p7 T3 G* u: o1 C$ D# E
                break;4 K7 G3 m1 h# R( w4 u
: H# J, b4 p$ A) X- Z! r. X+ H5 M2 a
        };- ^( c+ L+ c0 q$ ^/ J' c
        switch(vs)& q- K) W% b7 x
0 W8 }9 Q7 h: J1 v; v5 L9 Y( {        case 1:          P2 = 0xfe;         break;: p0 D; V0 q" ], C0 a
        case 2:          P2 = 0xfd;         break;2 Z) ^/ O( {4 W' I% T3 H0 e& j2 x
        case 3:          P2 = 0xfb;         break;1 k9 Y: v9 ^3 n! q
* U( v" b7 v( W$ ?9 K% h* X        default:$ r, O8 A4 v% n  g9 O- ?
                break;
& ^3 q3 P8 W/ V7 v1 I; O0 W+ A$ N' Z
- M$ f# X. {) F2 z0 T) `}
3 _6 W  g* Z; e: H% v, `* c- M8 ?7 C7 I9 X
void main()
+ u0 Y5 G+ ~7 ?& c{
. u/ K: d; T  x) e: W  d, ]        LCD12864init();9 n# p! u) L$ v2 D0 x
        qiping();0 r9 e! i! d5 _3 Q; [! _* ~- v
- w4 i9 L+ ?1 J8 W' h1 f        hzfdisp(1, 6, 8,  0,  16,  Hzfu );  //1片,2页,3列,4号,5位,6字/符数组. [7 i3 X3 _+ P4 q/ ?
8 s7 v- V' n# Q2 I( i0 H) _        hzfdisp(1, 6, 40, 2,  16,  Hzfu ); 0 [; M5 w$ O% P
% ^' Y, t8 |+ o8 C. `) Q- i7 O        hzfdisp(2, 0, 16, 4,  16,  Hzfu );2 D8 h9 {4 z; H9 l# H0 [4 t
" m6 m( Z+ p3 y  k6 Y        hzfdisp(2, 0, 40, 10, 8,   SHU );. M% T9 _* C* O$ `  ~7 O
0 F" S! y* H$ X8 p; r        hzfdisp(2, 4, 16, 4,  16,  Hzfu );. h8 {+ X' A0 z) A$ v/ W
1 P' n; |4 b  J7 A- q0 H        hzfdisp(2, 4, 40, 10, 8,   SHU );        1 H, U8 t& B- Z# K. u* a4 a7 }' c
        Redstrs(0xae,4,&vg,1);  //调用存储数据        ' P% r9 d) T+ _$ k3 X4 L
        while(1)! H: T1 |" h% ~" T7 E0 ~7 a6 p  m
/ [7 s* }# I+ ^' _8 M                disply();2 {6 E1 W9 W1 K5 e. G
                ledoff();
$ v: o$ O6 J) D* J% o                key();                         - k  D  u7 D3 t
                Wristrs(0xae,4,&vg,1); //写入24c02 / I3 o; L1 I. M" m* p: h- w
1 n7 H/ w( n- c9 A}
% \( N+ w+ @( N. G
. T) ?0 v; v# X) v4 ivoid  disply()% W) s* g3 e6 b0 j5 f
5 U/ A+ P% ~% w8 @4 L* O- q* D, h                  hzfdisp(2, 0, 48, vg, 8,   SHU );5 s2 P! o& n( v0 j3 j
! s5 W1 n8 }! Z3 x6 ]4 k: [}
) L1 D, @) [- |1 |5 m4 k5 x/ I6 ?' D
) T8 `& F% |; Vvoid Us(uchar t)$ b- X- S1 \2 d! x" n% Z2 Z. \
{   : |5 k5 A) K2 q, F/ D
        while(--t);
8 o) }3 ?# }5 ^. A0 s7 e9 P# D}
- ~! s3 [2 j. x" p, ?: X2 Q. n" ^2 f% C5 y+ j
void delay(uint k); s8 a7 K! Z$ N$ X
{9 \2 D0 `0 G! t$ S8 G$ c( d$ u" Q
        uint i,j ;
" D" k) j0 Z1 W$ x  X        for(i=0;i<k;i++)
4 e' e4 X+ H9 N% x3 Q" ]  V) ^                for(j=0;j<20;j++);
8 u$ T/ q/ U! J6 l9 c9 c}' w* m& c: W$ x* d
. W9 a8 i9 \5 ]7 I/ O+ }1 {; X: T- }& C
void busy()//LCD是否忙
/ x6 D2 G, E1 `6 |- U* s{
5 f! f* F" ?# S& X; c6 Q  ?9 f        uchar dat,buysbit;//状态信息(判断是否忙)
- F( d4 H2 n% u" R        RS=0; 9 t" I# J/ `! c* x+ V- s7 [% u
        RW=1; / n9 K' K! y2 X% E: Q/ q
        do! a* a+ i" B7 ?" g; z5 g+ _2 ~
        {2 B6 O$ ~9 D3 T
                buysbit=0x00;
/ q; ^+ q  Y6 A( M' E                EN=1;
2 Q! T  ]/ |0 s" b                dat=buysbit;7 O' [9 `3 W$ x' g
                EN=0;
3 ~! @+ ^+ _; ^9 N* k9 b                dat=0x80 & dat; //仅当第7位为0时才可操作(判别busy信号)$ _5 u1 q  e( ]. Z% M8 o8 S3 I
1 G$ ?: ^) D- j# A2 k- g$ f    while(!(dat==0x00));0 D1 D; T4 d+ V3 Y9 w. H
" N2 o  z, @3 B" X) y5 C
% S" m/ N* R3 u: M8 k" `void key(void)' m* P# o4 _8 M6 S
( D! r7 ?! i4 }4 G* M# H$ b& u        if(sw1 == 0)  1 p0 i6 N: ~0 A  @1 \" s; n6 R
- a6 g9 v! I% k. R$ S, `                delay(10); ) `, c' @" s4 ?* w+ }! }6 y
                if(sw1 == 0)
% o* L% V8 N, V* S9 h8 o                {
+ @$ D: K/ Y( \                        while(sw1 == 0);
+ B" f: [, _9 Q8 l% O                        if( vg==4)vg=1;: x9 J3 V+ b% Q' f0 r
                        else        vg++;
& ~( \. w! p7 Y( R# D6 T                }
9 H1 Y( n/ q. i: j' f2 m  G        };
6 z$ E9 W# ?: |: P  a' c8 U5 }3 r        if(sw2 == 0)
' g! p6 R+ j. P) q1 U" ]5 v  p3 @        {
6 \8 A5 q( f6 P; a  I3 E! I( \. }                delay(10);
( j5 R! H1 H7 ^) q. v, a0 r' E                if(sw2 == 0)
. f3 `) ]# I8 V                {* ~! r: H8 c/ p( x# G+ e0 G* p
                        while(sw2 == 0);2 J; T. d# Z) U
                        if( vs==4)vs=1;
/ Y% m( z! ^$ {, H# [" W                        else        vs++;" v. z7 b3 o6 ~
+ n- _0 O# M# J- c) B        };
3 ?0 B# }  K+ O" u. O$ f9 `7 ?# }2 M
: Y' B8 @/ g5 y( R2 ?5 i
8 g6 H' S6 X5 o5 m9 n: Jvoid wricmd(uchar cmd)//写命令. \( S' e" d" x3 l
{" J: h4 u4 G' @& G/ H3 X% |3 g
    busy();//检测LCD是否忙& q4 J+ }0 _9 U
        RS=0;2 k( m$ P$ v9 h$ B' [# a
        RW=0;, _0 D. J8 p1 X3 n9 ^0 q
        P0=cmd;
) E3 k% ]. G7 O4 j$ Y! ~        EN=1;) @- _9 s2 Z! ~! A  r# z- j& R6 Z
        EN=0;9 J$ }+ V4 E" j' K$ H
}. K* a5 f+ \* A( C7 z% n) J
0 S/ m, J4 @2 G* `0 b8 ~) ~9 C
: v3 [" E7 j. I- s* ]. S6 U8 D3 k{, F. u3 {, p9 K
    busy();//检测LCD是否忙* R8 P- b5 @. H( ?
        RS=1;
( A( i* b* x8 Q7 |0 b: U* J        RW=0;9 d: W5 s2 l1 @1 G/ d
        P0=dat;, D. T: K* B8 S
        EN=1;$ K1 Y& [* K" V8 I# _
        EN=0;8 f2 d' d! {1 F9 `3 x
4 o. Y- [2 I; d! i1 o, S* h4 L! W6 W, B
! p& k% G7 P) E* E4 {$ D! c+ bvoid LCD12864init()//LCD初始化程序
2 C3 B9 ?* N& d- t. Q{        . {! t, u+ D5 ~0 K, A
        cs1=1;//刚开始关闭两屏* V, Z1 ]) B) {4 Z
        cs2=1;! M3 o; @) o# p+ J, W, I6 {0 l2 [
        wricmd(LCDoff);         //写初始化命令% q" f( q! k2 ?2 ^* Z
        wricmd(pageadd+0);) S4 T5 W# @( t5 C: @$ {" y& v
        wricmd(hangadd+0);
3 D( ]8 f7 Q! _& J2 Y        wricmd(lieadd+0);
0 Z% J% U" w+ O        wricmd(LCDon);
3 l5 m2 b6 b5 {/ c' f* J}
- h' F) n  G: N$ `/ U) L! R+ V' w4 r
void qiping()        //清屏3 q3 r; ~2 P  N
{  n+ u! J% i* S- h; y
        uchar j,k;& A3 _% O) l5 p) z3 e3 w- r4 Y# A' ]
        cs1=0; //左、右屏均开显示
# h1 G2 M1 W5 p* Z  F2 P        cs2=0;
1 J4 k5 f3 k$ F" V6 N# X& k' U        wricmd(pageadd+0);& N& F  g# A! t: L: e
        wricmd(lieadd+0);' I* ]; ^& G, g& ?
! k7 N$ D+ [2 ]% A% S        {2 w8 b+ L6 n- p+ U* \
                wricmd(pageadd+k);     //每页每页进行写+ H9 e- a5 C& c; E1 S' I! z
                for(j=0;j<64;j++)      //每页最多可写32个中文文字或64个ASCII字符$ O; u/ p" ]. Y2 `# [6 e
                {/ e3 P, F. V- v, j( k* g
                        wricmd(lieadd+j);
6 s& U6 \" E9 E, |; E" e( n$ n                        wridat(0x00);     //控制列数0-63,共64列,写点内容,列地址自动加1( X; Z, E+ t: x
2 J  b0 E; x# e& V0 L        }
# N1 p0 \5 P4 T0 |% C' R4 A$ N}" S- R( o( n! F0 E0 r# W
, `: a# C- O) U7 F, t/ @- c1 avoid pianxuan(uchar pianxian)
; s- n' Z& k; v% d7 K8 R{ 7 H) O  ~' {3 x& L9 ^
        if(pianxian==1)
6 w: Q+ C/ ^! Y  Z+ A        {+ M% Q- Z* o  U& V6 _* a
                cs1=0;          //开左屏
! G& L# ^( T0 _% t                cs2=1;
. W- n9 G( K5 _" \8 Z        }# t4 l! L$ h. u8 S8 p  h- }
        if(pianxian==2)
7 _6 E6 {: b' E7 G8 u( C# o0 b        {  A; S6 E- n) b( ^  B: U2 W/ I
                cs1=1;         //开右屏' y7 }% x/ P. e* e3 [) p4 |' D
                cs2=0;* y& ^  F7 u6 n" R, `0 e
        }# S2 q$ Z. y# F; d  ^
        if(pianxian==3): ]  f6 X8 u! a% H0 u3 p0 }8 s% z2 ?
- |5 y7 _( Z0 {  s2 v! v' }7 j                cs1=0;
3 M& R% g: T# s4 z' e' W* {% J                cs2=0;0 o8 f6 p3 ~+ Y! z
        }8 a8 t, Y, K% |/ B( d% M$ l
}3 e2 D7 l6 v' I8 Z& ?. U7 Z
# G( @5 H! Q& s
$ |* a9 I0 [0 l) B3 hvoid Star_I2c()  //开启
' U: G) d+ _, V1 t6 m% G6 B{
7 ^- Y1 a9 }; c        SDA=1;  Us(1);, H8 h+ M$ p/ T
        SCL=1;        Us(5);
$ X# M' q  [; d9 s/ [. D- N. p; Y        SDA=0;  Us(5);
3 b6 M! L1 `  V5 D: m' k3 r$ H        SCL=0;  Us(2);
+ Z% J( O" {9 @' g* D. N}
6 D7 }( `& M. U$ G' E( x- X3 r8 y/ D# p! Z* T8 S+ B! `
void Stop_I2c()//停止
& T; J6 }( J0 B{
% J3 F5 o& u( ^7 J0 o/ {3 l; F        SDA=0;   Us(1);
& d, r4 ~8 {7 x$ C0 |! n        SCL=1;   Us(5);
: s% m6 Z$ D% }1 J: D% M        SDA=1;   Us(4);( Y/ m! \' N& G1 O2 A
}6 |4 F: o9 A9 {* m8 ^4 r" P2 _( q
/ o- A3 X7 \9 q+ E' p9 ivoid Ack_I2c(void)//应答9 v' t4 Z: r# s8 |0 }
6 N" I0 e+ E$ |. K5 Z        SDA=0;     Us(3);" }0 ?; V% m# o/ ?0 [5 K0 W
        SCL=1;     Us(5);  c' m' v) q0 g* h% \. B1 g" Q6 [; _
        SCL=0;     Us(2);
" Z, b4 a1 F, s}* \8 B2 e2 x! g8 |
$ f& n6 X+ j3 `$ c/ v
void NoAck_I2c(void)//非应答7 L1 p: l  B4 u- G6 Q6 p- H
  B" W2 @, Q# C' r  E
; A' o) P$ T# Q1 x" l+ S+ L# z0 R7 i        SDA=1;   Us(3);
1 Q2 W8 g0 \, D" z6 z        SCL=1;   Us(5);
! s, g7 V6 [; y5 `5 X% M0 q0 p        SCL=0;   Us(2);   " M" y, S& D" V. R8 R% z
! u3 W5 |) G1 C
" V; Q: u7 O: jbit Wristrs(uchar sla,uchar suba,uchar *s,uchar no)
5 ~, V3 q2 L4 v% w. t  n* T2 T{
( I( j& A8 s  k2 q; R6 b        uchar i;
, F6 z9 u5 Q2 I( H7 v) {        for(i=0;i<no;i++)
+ O0 O) ]1 z7 V4 n( t    {
" v! ^5 S4 x: j% m$ M. f( A* J                Star_I2c();               //启动总线
! i1 b, s; Z0 n                W_B(sla);             //发送器件地址/ i8 ?% Q" `0 q! E% E, g
                if(ack==0)return(0);  g( ]9 N( G: p
  e! b# X- i9 F                if(ack==0)return(0);
1 r8 l& Q5 d7 C' O5 R9 A; y
% L( g. x: v+ m& O! O                W_B(*s);              //发送数据3 t9 u7 J- }9 }, q" a
                if(ack==0)return(0);6 j( Q7 b# ^8 t' g& `
                Stop_I2c();                  //结束总线
8 d- ?( C( ~. S( J1 J- |                delay(1);              //必须延时等待芯片内部自动处理数据完毕
, Y) L/ i# t8 w' i$ k8 T$ s                s++;
( b3 B0 T6 {6 K# T! P: y                suba++;
7 j# S2 I1 u' {* M1 U" e) M    }
% J0 i7 x/ B0 r; X: a" v        return(1);
- N) Q* b$ {! s6 F- M, p}
: L3 {5 k2 W' n2 M% J1 K( M# M( _5 [8 M$ @& T
* {$ W  p) L; u( {/ _6 ?/ d8 x; _3 c{
, k3 S: C% `* }% D9 [        uchar i;* W8 G6 W9 ]8 n0 n2 o$ |
        Star_I2c();               //启动总线$ B* d3 J# P+ |8 b, S% U, x
        W_B(sla);                 //发送器件地址5 }- V5 ^: L( K. Q8 T4 I$ ]; Q! W
7 y; m5 J1 t0 Z3 A8 }8 W        W_B(suba);                 //发送器件子地址$ h# M% S7 E$ u! c3 a  U2 z' R
        if(ack==0)return(0);2 h& y1 v. R4 d4 V6 e- j
. ~% Q" Y, Z/ \% U5 w* {        Star_I2c();6 ?) ^: Z9 X& y3 R' c$ |9 X
        W_B(sla+1);
4 D/ U! D' d) t' U6 f* R. @8 E/ i        if(ack==0)return(0);
& B4 J7 a3 `% N        for(i=0;i<no-1;i++)
  V- h/ _4 m4 ^    {
) m' m/ h0 K: R3 Z; \7 G" }                *s=R_B();              //发送数据
$ ]* [  i% H, m7 L/ ^                Ack_I2c();             //发送就答位
! N# u0 y4 H2 B: U                s++;
+ F* g! q" B- b. @$ Z3 f, t2 v7 K    } $ ]3 b5 Y) l/ l9 A; A
        *s=R_B();. c2 `+ A' I0 e
7 ^) X: G9 ?! L' R: t    Stop_I2c();                 //结束总线) _/ p/ Y9 Y+ |. Q; n
        return(1);
) w( J. s5 K1 h. h) l2 |/ ]" B}) h! R7 M. B) k! C* ~2 w; e
9 C1 ]; n# L3 ?9 z, o
uchar code Hzfu[]={          //汉字打包搞定$ q# n6 s! B2 `1 _$ V0 s/ p6 |
             0x08,0x08,0x08,0x88,0xBE,0x00,0x00,0x00,0x00,0xBE,0xBE,0x3E,0x88,0x88,0x08,0x08,- V; B7 |& _3 l. m1 y$ J' d
3 ]6 X- b0 }) ]. `7 L7 m                0x10,0x10,0x10,0xFE,0xFE,0xFE,0x10,0x00,0x00,0x00,0x00,0x46,0x46,0xFE,0xFE,0x00,
' ?! a* C. c* O8 f4 z6 o# h        0x00,0x3F,0x3F,0x3F,0x13,0x13,0x3F,0x00,0x00,0x00,0x00,0x42,0x42,0x7F,0x7F,0x00, //蝴 /---28 b! H# W( C% b& Z
                0xF0,0x10,0xFC,0xFC,0x10,0xF0,0x08,0xFE,0x88,0xBE,0xBE,0xA8,0xBE,0xBE,0x88,0x88,* a6 x/ n2 \+ E) N) [' n7 h
        0x43,0x42,0x7F,0x7F,0x22,0x73,0x60,0x62,0x1A,0x0E,0x7F,0x7F,0x0E,0x1A,0x62,0x02, //蝶 /---3& `& S0 G" R8 i" b
$ A0 Z; T, A" B1 ?. |, ?1 p2 J        0x02,0x42,0x81,0x7F,0x00,0x40,0x40,0x00,0x00,0x00,0x00,0x08,0x16,0x31,0x20,0x00, //按 /---4" F# s1 P% h5 r1 \  f
        0x40,0x30,0xEF,0x28,0x28,0x44,0x64,0xDC,0x10,0x54,0xFF,0x54,0x54,0x7C,0x10,0x00,( J- K* u& ]; L5 W  }
        0x01,0x01,0x7F,0x21,0x51,0x22,0x14,0x0F,0x14,0x25,0x3F,0x45,0x45,0x45,0x44,0x00, //键 /---5. Z8 }0 r! |, z9 Q$ l" T0 o& U) u
                0x80,0x40,0xF0,0x2F,0x02,0x04,0xE4,0xA4,0xB4,0xAF,0xA6,0xA4,0xE4,0x04,0x00,0x00,8 {3 E6 q2 d5 f! F/ g0 P& Q
        0x00,0x00,0xFF,0x00,0x40,0x40,0x7F,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x40,0x40,0x00, //值 /---6/ B. n, I: N( i$ i% d( t
, v2 `# Z- D7 C+ x0 s; V9 |0 }$ z( k6 B$ U& f- M1 S3 |
uchar code SHU[]={8 }  h! m9 {5 I- T
            0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//  00 w5 x& z) l0 e. Z$ e3 J& j
5 Z, H8 t5 `) G2 |# K9 ~' g; z& U5 \                0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//  2 x, e$ K4 z6 z: L" v
                0x00,0x00,0xC0,0x20,0x10,0x00,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//  $ R% f8 ^' |0 v1 G; s" {
$ V" D" c4 H: Y. A2 R0 [                0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//  7 e& F* P3 e4 m; y& R3 l, v2 l
" w- A7 \2 c# U2 Z' t                0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//
" W* m0 |1 S- W3 c# D& O                0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//
; W! r  s$ o# ?                0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,// 7 {7 D/ m. {. R) n1 K8 V% p& H
                0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,// ! N! p3 Y, _8 f, L. P/ s/ X
                0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,// 1 u' {  @4 k4 _  O, z
                0x06,0x06,0xE0,0x10,0x08,0x08,0x08,0x38,0x00,0x00,0x0F,0x10,0x20,0x20,0x20,0x20,, a# s7 p7 u, @% v+ B, T, I' `# ?
& G/ I* E- F- Y/ ichar code tupian1[]={ //meiyu
2 c( x& \1 v% n& g1 D0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,8 p, r2 h/ M2 O# W* W  f
0 A# r- Y# E5 V( A9 v, G0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,7 Q* L  c, F, [& h$ E
  J% R7 o; M7 Z7 Y0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,, a  W; V8 G' a5 e9 Y7 f
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00," N4 j; A9 f6 D5 }
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,5 V% I* C7 h. A. v# `" B
" H. b3 r3 b$ z6 j0xE0,0xC0,0xC0,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,* l) N; Y) P$ V" E# _- }
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,' f  J3 O( q3 P4 r; T, |8 n
" D+ u" y/ ]0 V8 f0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
, W# Z$ M; J1 R$ n0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
; Y. p2 @+ S' D( W  r0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
2 G3 B2 N2 n7 Q/ x" ]0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x07,0x0F,0x3F,
$ g, u$ T, x% y. Z( _0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,% n! @7 T8 O, j4 G
: `6 C* U% N6 `- x! X: S0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
8 z3 Z, P# z4 U. ^0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,9 i. I4 F7 @5 A6 d  Z* |& r) E
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,% H# {2 K' H! Q3 H
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,9 [' a- i9 L; ~4 n' @0 N9 _
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,+ S1 |2 {- _7 G' g8 f4 t' y- B
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,+ o" ]* s+ }2 A/ x5 ]8 K! h
# j) ]+ g5 d8 B2 I0 U* j1 G0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
7 u' |; d1 ^- G: U, L) Y0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
7 m8 l5 x, p0 x. {6 D* J0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,! M# v) k3 G3 l+ O$ P" c4 a
( H% v) Z% P! k! e3 L! F% j0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  u% `8 x) h5 v' r
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,1 v! t9 u; e- W. W9 U
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,- O2 m& @$ n% s. \4 B+ [* J1 x2 ?0 u7 |" }
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,* U* e# i1 w; k6 Y5 g) e  s! L
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,2 c3 w9 C+ @$ l
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,. o1 I' N( f, Z3 b  E
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00," a1 n7 _3 ~3 N: L. ]
};. g+ Y" y3 m% R8 V% S
5 J5 j$ T: m8 Z. T
4 s2 z) T2 L/ h6 K9 P* b0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,% g0 N1 g9 O3 }7 t4 p$ i
7 Y  J) F* P: _0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
# s& l9 B# B. W' l5 w  k0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
, n1 f  g/ N( `. q0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x07,0x0F,0x3F,7 [3 Q2 ?; B& ?
/ Q7 ?0 p! l* d4 \" {+ |+ v# A0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
6 c" ^9 p% J) [4 a8 H/ n0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
4 u/ g7 o- C! I9 R; I( i7 k# n0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
% l) ^  Z. v& j7 H; G0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,- h8 L( X3 c1 R1 c
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,+ E" V! h' j% k
  E) j  t! H8 h3 w0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
" k0 l% V# c: P/ c0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,8 f: T* \' x8 R* \$ ^
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,9 s3 f2 U: q4 b
8 C& E, z) u- H/ h: B% ?8 B0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,$ m3 h; X+ A2 u7 T* L8 k2 [
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,, T. K5 n; k/ g- ?  H  C* ?
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,7 k; u7 U' V" R: Q- {
4 q! l% V1 E+ e0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
8 L5 S' Y; l7 D! [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,# @0 t, q8 \5 D3 w: T0 s
( I% e4 k+ R! J) a5 {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- W. ?" u7 e' [( B, u5 e0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/ j# Q( j1 {6 y0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
9 T# d* G; t' H& b& e; |0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,) ?6 o# ]$ H0 B. C" C
8 y) Z" I, y& B2 |; P5 s};
3 \& A, g: ~# s- z
" }, C# c3 ]- d* Q6 J下载:
8 p+ o( Q, g( b: v/ ?% |6 ]' x
游客,如果您要查看本帖隐藏内容请回复
, ]# x0 i0 k7 y( {/ U) ~
* S' q+ Y2 ?/ D$ Q' k8 \. L" t$ E
发表于 2019-1-22 18:24 | 只看该作者
看看楼主的代码
GMT+8, 2025-10-9 14:10 , Processed in 0.171875 second(s), 26 queries , Gzip On.
