查看: 666|回复: 1
写的心形灯程序
发表于 2019-1-17 10:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
写的心形灯程序
; r" O& A$ N: ^# k+ m. y. S! v
) _) n6 c, ^8 n+ [4 E$ ]$ W+ P1 H5 x% E; F' n4 E8 x
这个心形灯,希望对你们有用' f! |6 B, P/ ^
2 y, d5 |3 x& d+ d" q# |6 T2 j9 S4 Z8 Q
#include<reg52.h>! Y2 `) k2 O% v4 H6 {4 \9 l/ b
#include<intrins.h>
( [* r9 ~" D2 p! r3 W8 ?: F#define        uint        unsigned int
6 Y% h/ N( \* L+ x+ ]#define        uchar        unsigned char& M: b4 P* X  @) x* D. r9 p2 E
uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//LED从低位往高位移% e$ l- n- O" N9 y" q& @
uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//LED从高位往低位移) O" W' i4 y! z8 ?# k+ b
uchar code table2[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};//LED从1个亮到8个都点亮(从低位往高位)8 }  c! \5 L% S4 c( o  j
uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//LED从1个亮到8个都点亮(从高位往低位)0 c: Y. O& y; e" R2 F+ A0 k. f0 Y
uchar code table4[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//LED从8个全亮到一个都不亮(从低位往高位)8 p; J; `5 q% ^# L2 }" c1 y1 b
uchar code table5[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//LED从8个全亮到一个都不亮(从高位往低位)' h2 f; C) s% v3 l9 c
uchar code table6[]={0xfe,0xfc,0xfa,0xf6,0xee,0xde,0xbe,0x7e};//LED从低位往高位移(最低位始终为0)/ l# q0 x# }" u9 a7 k
uchar code table7[]={0x7f,0x3f,0x5f,0x6f,0x77,0x7b,0x7d,0x7e};//LED从高位往低位移(最高位始终为0)/ i6 [" ^- C/ z) U1 \
void delayms(int z);
3 b% U8 E# O) u4 n+ n4 Ivoid main(void)
, V2 O6 \% b) U& s, E) S{
7 A; Y: p/ B6 O! P1 p9 \+ R, `        int n,i;" ]1 h! n1 N7 L- W
        P0=0XFF;" b, G5 ]5 ^! E# o- p4 I
        P1=0XFF;
" m! E' _1 i5 T8 \) C        P2=0XFF;' |% q% b% g, s6 o0 j
        P3=0XFF;
: Z- u9 `6 ]/ a /*******************        单个灯循环亮,间隔0.4s**********************/
. k3 t+ V' i. L" X2 P1 \        for(i=0;i<8;i++)
* [& C4 [! P  S5 u        {" a  H- P$ Y/ s! ~7 P
         P0=table1;' m5 c6 ?: p! I' o* Z0 }* r5 c
         delayms(100);
& M' A/ d- p: C; q) E        }3 P- |* H' q0 A+ l
        P0=0XFF;! R# l+ K8 L# p, I3 s
        for(i=0;i<8;i++)/ T0 l6 R7 H8 q1 ^' t) G
        {/ l- D7 X1 A' Y6 T
         P1=table0;' z# i8 l( d3 e
         delayms(100);! r, p( A, Z) J5 l7 x+ Z
        }+ W+ h5 e+ R- |$ x' H& y* n9 v# k
    P1=0XFF;& u0 [6 S3 n; R/ A
        for(i=0;i<8;i++)
4 h) O: i3 x* H' o1 W; h+ b6 Y        {
6 n  u( J  [. ?! Q, w  F. H         P3=table0;
0 J& D$ S5 f' F  i9 a  _; z         delayms(100);0 I$ I; H2 f# s% _8 N+ ]
        }8 ]- O. s6 f. Y& P
         P3=0XFF;: Y, y. ?* I% t: b) H
         for(i=0;i<8;i++)
; f8 P$ w1 Y, e2 W        {, V% c: x2 @- l+ W" [
         P2=table0;6 n8 L1 ]% j2 ^9 U5 S4 Z+ H( O$ i
         delayms(100);; C: v9 J6 C4 i; S9 F; t9 f& e
7 N6 \2 }0 b! e' V         P2=0XFF;" `( d7 ^# V3 {7 ^: f
/*****************四个分开转圈亮*************************/* W- L7 X+ |( u3 Y: M& q1 R
   for(n=3;n>0;n--)
6 l/ v8 L& z2 e6 ^   {$ \& I. V, N: g' \1 `9 [
        for(i=0;i<8;i++)! B/ X4 }* e2 k5 E0 E* M% @
        {' }3 e9 G8 v/ v
         P0=table0;- G( {- S0 ]$ l+ q- b
         P1=table1;
- S. g0 ]: [& \& S: h         P2=table1;; B. ?6 }" h% e2 e0 }0 {
         P3=table1;+ c& W, x( o* ~
         delayms(200);
" [- u- W1 L% _, z7 G3 ~! c) g        }
9 `" A5 Z! t" j- e% {  `& a/ i   }
7 t7 T' D% @/ }/ [( y        P0=0xff1=0xff2=0xff3=0xff;5 R! g8 ~" R. h
/*四个循环转圈////////////////////////////////////////////////////////四个循环转圈//////////////////////////////////////*/
+ o* Q  {$ O# e( o9 g- z% O        for(i=0;i<3;i++)/ r% D6 L6 T8 L' t
! v1 m* R, y8 [4 J: |. p! ^1 T                P0=0X0F; delayms(50);7 o3 ~7 K8 Z- `& B6 M/ e
                P0=0X87; delayms(50);" j, Q$ b8 ?0 v) F4 m  y
                P0=0XC3; delayms(50);- S* `& h" ]( q2 c* n; z
                P0=0XE1; delayms(50);. W) u% t1 Y; W8 v1 S* ]
                P0=0XF0; delayms(50);* Q/ Z+ E& w8 q8 ^5 b
                P0=0xf8;P1=0xfe;delayms(50);
) ]0 U* J& j5 B+ }7 i1 G) Y; P" P                P0=0xfc;P1=0xfc;delayms(50);0 G) _) P  ~* X
                P0=0xfe;P1=0xf8;delayms(50);
1 F4 X* J- h" E2 b0 r                P0=0xff;P1=0xf0;
0 c/ U* N5 d  _- r5 {                for(n=0;n<4;n++)
- j3 X6 V  i, K. y( e# ]7 `                {( ~( N4 i# x/ G$ X5 @
                delayms(50);' P- w' H1 l; z$ X& z: K) e$ |, }
                P1=_crol_(P1,1);8 t" N! Q: H+ S( x) K
                }& d$ l$ w+ P2 g9 V
                delayms(50);5 }8 ~4 Z. f# y) o/ ?2 Q% @
                P1=0x1f;P3=0xfe;delayms(50);
4 T- S, C5 w6 Y0 O8 O$ R                P1=0x3f;P3=0xfc;delayms(50);
8 h) X/ x' m* B1 I- L" c5 h" I                P1=0x7f;P3=0xf8;delayms(50);
3 U( c8 B7 g* Y8 Y5 b                P1=0xff;P3=0xf0;delayms(50);, w' ^% e! X- q( ~2 N8 W( [
                for(n=0;n<4;n++)
# s& H; q( ~! T% R9 ]8 ^: A                {" `1 q" U  w+ z1 F) e
                delayms(50);& g4 H0 ^# G( g1 P
                P3=_crol_(P3,1);
6 Q! S' ^( [% \/ z                }
2 I# B# ?3 p$ n: m- \& P                delayms(50);
5 x4 j, F: A# J                P3=0x1f;P2=0xfe;delayms(50);" @) E" Z7 L( \  `
                P3=0x3f;P2=0xfc;delayms(50);4 U; m! @; _9 m9 ~
                P3=0x7f;P2=0xf8;delayms(50);# }8 z1 a& i& G8 B
                P3=0xff;P2=0xf0;delayms(50);* D! K# p: v7 y0 c& t; l7 }
                for(n=0;n<4;n++)* j- W3 ^3 ^) V) ~& L$ P
) N+ M9 ~; Z- u9 F: X                delayms(50);2 r3 g6 J4 S. B' [0 I- e& z* i% H
                P2=_crol_(P2,1);+ B4 x/ v$ d% o! A
                }& U: i7 L5 n$ s
                delayms(50);
$ f, \% |( o0 e                P2=0X1F;delayms(50);
2 @& x' s/ e. A$ g2 C5 V                P2=0X3F;delayms(50);0 C& v5 D- H& U2 K
                P2=0X7F;delayms(50);
7 [. o, q8 Q! c  \3 [& K& U) `) J                P2=0XFF;delayms(50);
8 B! P% I5 W5 c: @! A        }
( h9 H1 W1 W7 ]7 X9 H3 }/****************左右两边的灯轮流亮//////////////////////////////////左右两边的灯轮流亮/////////////*************/
. ^# o1 `% W9 p) T3 g        for(i=0;i<2;i++)* P) G" Q; a9 c- B) J
% u, n' P6 H1 ~% ~2 ^                P0=0x00;P1=0x00;delayms(500);$ `7 B- K4 z; O) @; h, A
                P0=0xff;P1=0xff;delayms(500);% `; B, c$ X* N
                P3=0X00;P2=0X00;delayms(500);+ f2 d- s6 i# B9 V# z' H7 k9 M
                P3=0XFF;P2=0XFF;delayms(500);8 ]) C' ^; x& L" f  T% b: Z
# ?/ N+ s) p. K" |- m. L7 \& l/******************************间隔亮,相邻的灯轮流亮/////////////////////////////////        间隔亮,相邻的灯轮流亮/////*************/
- W. Z4 S2 U- D+ ?' K2 S2 z    for(i=0;i<3;i++)
6 B: i5 T4 F) B    {( ?7 J3 `8 r$ {$ R' o9 i. R
            P0=0X55;* S2 s% F8 \1 O7 {8 E! P4 `2 o
                P1=0XAA;
- a9 o$ U6 ?" b/ |- c% y                P2=0XAA;
) i! F8 K) I6 A' V! J                P3=0XAA;delayms(500);5 ^* L, D: _: Y+ c6 l' t( P5 l% q
                P0=0XAA;0 t) J9 }1 S" _# J! p; F
                P1=0X55;+ A' ?5 }: u7 C: f  Q, C* _
            P2=0X55;# M' ]' h- }7 l# J* i/ k
            P3=0X55;delayms(500);
/ M- l" q) Q# x+ V. B8 N" z% {: m; R        } & h- ]# U( `$ I6 n% A; B
        P0=0XFF;P3=0XFF;P2=0XFF;P1=0XFF;delayms(50);
0 n+ t+ J7 M9 h1 o' I4 X# i1 v8 d/***************************上下闪,左上右下闪,全闪***************************************/  m3 |' \) Z; e7 G% \: z4 B( O# @6 p+ h
        P0=0X00;P3=0X00;delayms(500);. [( e- a* Z+ z3 d8 @% M/ v
        P0=0XFF;P3=0XFF;
: Z6 M. o7 C. Y        P1=0X00;P2=0X00;delayms(500);8 Z3 o$ z0 x! b  o6 A$ b% V
        P1=0XFF;P2=0XFF;delayms(500);+ b% k; g! a: B8 R, J8 O8 T" i
        P0=0X00;P2=0X00;delayms(500);
6 S- v7 F2 c$ j2 i( x7 J        P0=0XFF;P2=0XFF;1 m0 s/ K! M$ g! G
        P1=0X00;P3=0X00;delayms(500);- w1 N) Q$ g1 s2 G8 s& X) R
        P1=0XFF;P3=0XFF;delayms(500);
  y5 a. S1 c6 V! ?        P0=0X00;P1=0X00;P2=0X00;P3=0X00; delayms(5000);
( h  _& M6 i' _! G- |/ Z/****************************上下相碰撞,返回***************************************************/
" v+ l8 T, Y3 {' G        for(i=0;i<8;i++)3 ]: ~) B3 r7 S9 D' [
* d# f* n, G6 O* ~+ a5 K/ ~         P0=table1;
. A1 J# S6 }$ Z" t, K         P1=table1;0 ?! j% |0 I* ?
         P3=table0;5 m6 g3 P+ ~; D2 t2 a
         P2=table1;
# J2 Q. @7 A, q; n4 L         delayms(100);
, S0 u1 B8 @/ J+ c5 B) {7 ^- v        }0 K+ c- b+ n( }% r3 Z! _! U: C
        for(i=0;i<8;i++): d' D1 v3 Y& s$ q
        {& n/ M: _) _. S7 @# l) E) ~$ C
         P0=table0;0 r* c: a6 X: Q3 m- T! z
         P1=table0;
9 `  \& p' ^' p  G2 u( O* n         P3=table1;
# g: a0 J# {3 _: U* d         P2=table0;
( g1 B/ J- b4 R) s- b         delayms(100);
7 `* u; h5 g: c7 T7 U8 G* t: I        }
0 K  s2 I& ~7 B! v; k2 `/**************************逐渐全亮,逐渐全灭**********************************/8 F* c& w( }. x  W1 L. ~6 C
        for(i=0;i<8;i++)+ M) x4 q' i  o
        {) r/ B! K: q9 @/ Q2 N' P' ?
          P0=table3;P2=table3;delayms(100);% }: Y5 r5 U% ~2 I0 Z9 ]! P/ K) d
$ ]* c4 e# E: x# L7 \' A9 L, U        for(i=0;i<8;i++)
3 m  g6 d6 X: P9 @% o* G        {$ j. J1 m5 v) r% y+ m; Q7 g% P; i
         P1=table2;P3=table3;delayms(100);: w8 M7 c" j7 Y) Y  i) E; a
. L0 d* g" d/ x" w5 a+ p, w- P: r        for(i=0;i<8;i++)% B; q# O" g1 n% }# j, y  A* o5 i
        {7 w6 z( R) `: J& t  E) `  \1 ]
         P0=table5;P2=table5;delayms(100);
% g: E6 x; w5 F. {/ A4 \3 S        }' R9 m8 w, x. I5 U. D
        for(i=0;i<8;i++)* z- S# r2 A( ?5 U' r. c% y/ w6 a
+ S7 x, N4 O  r$ x; O         P1=table4;P3=table5;delayms(100);
% _  ?# [$ q* q; y  l        }7 R6 x' R1 k5 J$ D$ C8 [' u1 f8 {$ p5 h, S5 Q
/*从两边开始逐渐全亮到逐渐全灭************************************************************************/4 A  @/ E9 n' N4 U- i" X' G
        for(i=0;i<8;i++)9 W8 A3 B. U5 g0 M
        {& a6 h- @/ {" e& Z6 T% S# u. Q
- h: g7 b3 P1 f: @  J' |, b        }
- }% p+ a: ^  k! d  _8 F3 X! F        for(i=0;i<8;i++)2 D! Z* J8 l( k1 _4 x' j+ u* p
        {6 f$ J; g: X* t
         P1=table2;P3=table3;delayms(100);7 i# @0 b( O* H* T
        }  o* E; e. w+ k
        for(i=0;i<8;i++)
% V! y  r9 T. }& b' ~4 [  h( t6 |! U        {" y9 t8 R6 z# i: v
         P0=table5;P2=table5;delayms(100);3 C' h7 r  ?5 N+ h+ Y
! Q! Z$ w. J1 V* o% j+ h         for(i=0;i<8;i++): Q7 t0 D% p' t# B5 g* W2 J
         {; {2 |1 g! t$ Q
          P1=table4;P3=table5;delayms(100);% |+ A! F3 [* J4 v) L0 M
         }0 l: u( Q  s4 Z) @) P( q, E7 X
7 h/ o, j( y' y+ K6 `: n# n* R
! c- W9 u  m6 L' o, v# ~2 A; S/******************************延时函数/////////////////////////////延时函数//////////////////////////////*/' X' y3 T# P; C" D3 a
void delayms(int z)7 }# x$ w5 A, N
1 ^- ?, j& M% j, g- L8 ?int m,q;
% w6 n) R$ I4 Sfor(q=0;q<z;q++)
- u6 ?4 M/ l# j4 c+ P0 Gfor(m=110;m>0;m--);
+ T9 m( B, C9 R3 m}
: t  U' U; T8 @' _5 H7 ?
% l! T: f- X$ |; f  e下载:4 M; q' T# u) f$ j% \# ^
游客,如果您要查看本帖隐藏内容请回复
. ?7 ?0 W$ o* C  _
发表于 2019-1-17 18:05 | 只看该作者
看看楼主的代码
GMT+8, 2025-10-9 04:16 , Processed in 0.140625 second(s), 26 queries , Gzip On.
