自己DIY的摇摇棒0 t, q2 X7 Y) A$ R1 S, e# G
) f# C2 I) f7 h' h1 A4 {
% i8 t/ t) q7 F9 _7 i4 y; K/ ~- bdiy资料下载:4 D/ p$ g; ]) A% v/ C
9 |" [2 W1 \( ], v4 D6 F& k
% c7 n" e; w/ c6 E% N8 N
7 ~3 F! C3 A0 C( O5 v
空板
+ O( k' ]7 X. q, `4 N7 E! O, r
, S4 E8 ~/ ]" U, ^8 h, p+ B示例
( K1 m. l3 J# T, B
& A. a' j: q0 Z' `/ [0 C4 t
; I% v0 B3 o8 o* t* p7 d
) o: o3 O2 p' ?2 ]8 S1 }2 o
3 z# s# G* b$ d最终成型的样子
: Y3 x1 x5 N9 P' K& l# f; t- m& P0 H
2 l2 Q4 k C! ~' P7 ^: y源程序:. |2 [/ o2 {9 l) m {2 ^6 G
#include 7 H" ^3 c7 o# f4 F
#define uchar unsigned char2 @+ R+ |: w8 c9 ]6 o. [/ C$ i
#define uint unsigned int
9 l9 `* d4 q e* q: ~
! B* U8 D( b7 s8 d" S; n1 v9 ^9 ~ c4 M
sbit KEY = P3^7;
. a/ ]$ f! c/ }" w1 ^uchar KY=0,_NO=0;* a& v: O9 q5 T$ R4 _# J
5 b9 p ]9 L5 i/ l7 O
; U, Y$ {# s; x! j& Euchar code display1[]={//我爱你!- c% [5 O5 F3 q- s* N' _
0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0xFF,0x20,0x22,0xAC,0x20,0x30,0x20,0x00,. ^) |1 _- r2 h4 |" |6 X
0x40,0xB0,0x92,0x96,0x9A,0x92,0xF2,0x9E,0x92,0x91,0x99,0x95,0x91,0x50,0x30,0x00,* v9 e5 H3 K8 w. y
0x40,0x20,0xF8,0x07,0x40,0x20,0x18,0x0F,0x08,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,9 b$ x( m! m4 \
0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0xFE,0xFE,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0 L2 @% y) W; q5 h
0x00,0x08,0x48,0x84,0x7F,0x02,0x21,0x10,0x09,0x06,0x1A,0x61,0x80,0xE0,0x00,0x00,8 b, f& t0 v( q/ ~' H) \' x* c
0x00,0x00,0x40,0x30,0x8C,0x83,0x46,0x2A,0x12,0x2A,0x26,0x42,0xC0,0x40,0x00,0x00,% A6 Y9 P% F8 `/ t4 v
0x00,0x00,0xFF,0x00,0x00,0x08,0x04,0x43,0x80,0x7F,0x00,0x01,0x06,0x0C,0x00,0x00,
3 _% t; h4 _: B# D) u 0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x3B,0x3B,0x10,0x00,0x00,0x00,0x00,0x00,0x00,};
1 o, J9 @% w6 I7 B/ t
+ m7 H1 z1 l. L/ @! B% a& l( C3 V$ g
uchar code display2[]={//生日快乐
: q% L$ o% w/ B. R+ }6 R# z 0x00,0xC0,0x30,0x1E,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0x18,0x10,0x00,0x00,
" w2 p% c- i8 h0 m' V8 [ 0x00,0x00,0x00,0xFE,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xFF,0x02,0x00,0x00,0x00,
8 E+ n8 e( R- b! W 0x80,0x70,0x00,0xFF,0x10,0x20,0x10,0x10,0xFF,0x10,0x10,0x10,0xF8,0x10,0x00,0x00,1 I- U) u) c. k
0x00,0x80,0xC0,0xBC,0x84,0x84,0x84,0xF4,0x82,0x82,0x83,0x82,0x80,0xC0,0x80,0x00,5 h- t; S9 T+ N2 V, n
0x41,0x40,0x42,0x42,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x43,0x42,0x60,0x40,0x00,9 G$ I# v/ h9 W0 ]+ }5 J8 T
0x00,0x00,0x00,0x7F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,0x00,0x00,
1 k, J& w4 w2 ]0 G 0x00,0x00,0x00,0xFF,0x82,0x42,0x22,0x1A,0x07,0x0A,0x12,0x22,0x43,0xC2,0x42,0x00,6 `( V) V0 u5 @5 g; d
0x00,0x40,0x20,0x10,0x0C,0x40,0x80,0x7F,0x00,0x00,0x04,0x08,0x30,0x60,0x00,0x00,};
9 {- [- ^6 u* g1 |5 R# H* E3 {. `0 A
* H6 s- e+ e, T( ?+ I; F3 S$ g& z
uchar code display3[]={//我想你了
) U$ Z4 ^& B0 P% y: f. G 0x20,0x24,0x24,0x24,0xFE,0x23,0x22,0x20,0xFF,0x20,0x22,0xAC,0x20,0x30,0x20,0x00,
% A3 n; y N& p% t4 U 0x08,0x88,0x68,0xFF,0x48,0x88,0x08,0xFE,0x52,0x52,0x52,0x52,0xFF,0x02,0x00,0x00,
5 }$ F" {1 M) u& k3 C: ` 0x40,0x20,0xF8,0x07,0x40,0x20,0x18,0x0F,0x08,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,% J& K# f. S* B5 g/ q2 c. I* d
0x00,0x02,0x02,0x02,0x02,0x02,0x02,0xE2,0x22,0x12,0x0A,0x06,0x02,0x00,0x00,0x00,
6 E: u/ _ F. L7 e3 v, S% C 0x00,0x08,0x48,0x84,0x7F,0x02,0x21,0x10,0x09,0x06,0x1A,0x61,0x80,0xE0,0x00,0x00,/ U' P# }8 [6 Q8 J' h
0x41,0x30,0x00,0x7B,0x80,0x80,0x88,0x93,0xB2,0x82,0x82,0xE2,0x03,0x10,0x60,0x00,- R: l: C3 F# x
) t% ?" a6 P4 r8 ^# M0 f( P 0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,};
2 z* Z4 h2 G/ n; g6 E H2 d! X7 E6 L7 D5 q
- S; V& E! o$ _/ M& U+ m$ O4 ?% n
4 Z3 y, {4 L7 B7 Lvoid delay(uint i)& p- Y4 f7 ?5 d
1 m8 S9 R! Q3 |, p. x, D$ I while(i)
% @! |' d0 r$ d& U. E# `5 y$ J {
/ B2 U- \& }2 O3 N* e* W i--;
+ h) j' W7 o3 z G- e }
( d, f9 k2 u' k: B. @- x$ N7 ]}
8 }# q) Y: L4 Y3 M9 `+ }. k; @7 H& V* w. x' L2 y. ^# u. i. a' Y
" E ^" @0 P& ?+ r( P: S$ j9 cvoid desplay1()( P- {* [7 t- G. P4 J4 b
{) i9 U' y) v0 D1 _) P" a- S
uchar i;- z4 x) Z1 y- Y6 ]3 \1 B ?2 z/ _1 Y
delay(6500);
# V4 f5 l. I9 T7 ?5 ]1 t for(i=0;i<64;i++)
4 q% ]2 d3 S; b# W6 e, ] {
F( z' r2 o3 _' X/ C P0=~display1;
3 C5 a! f8 W0 `) r P2=~display1[i+63];
( r9 K$ o7 Q' c4 N3 W7 b) ?6 r delay(150);) ^" Z" V7 O2 f0 Y+ |: b4 r7 |+ ~
}& o# S% }8 | W9 \! b& h3 }4 D
- a" e$ y9 b" z. v" {1 @
, [, P+ @ l) D" J; X% u. b: |8 A6 l8 e9 N( R; w2 Y
void desplay2(): C* z4 R2 M" h% ?# z! F4 k
" s7 {* i/ {5 m1 a9 n* ] Y$ j+ z uchar i;9 I: r d& m) n: t3 T) X: M7 T0 d
delay(6500);
! N. d k1 k) P. b8 v) r for(i=0;i<64;i++)( L- L4 c! ^+ @3 ]* K
0 D% K$ ~* n& {$ G0 w, M P0=~display2;
! w5 F. F* m% h/ _; _ P2=~display2[i+63];
. f+ J/ k- R- Y7 j) `0 t) z6 W delay(150);
1 m* \ d! [) b3 [# x* O; h }8 G& \7 U0 D- `
+ T- F8 e+ u: p+ u0 t0 |
1 {* ~, s, r* X4 X0 O2 e" z
) N7 Y; a6 r* S1 N1 X* K, \void desplay3()
& l+ V* M$ V: H2 c/ s: i{
) g8 |! `- U% a3 N* q- P uchar i;
+ i# W: j( V% a+ R% u* u1 t( m delay(6500);
6 u: E: x! ~" w& C for(i=0;i<64;i++)' I% ]: s/ b7 ]% I+ M+ o. U
% C* ~+ k+ h0 B" d5 N P0=~display3; W3 @1 r: y$ Q
P2=~display3[i+63];- {5 g; b2 ^1 {3 |
delay(150);
/ r+ |9 a4 u! {( @: X% [. u" d0 } }8 ~/ `! J s9 L% v/ J
' l K$ {4 j2 e
& Y) p- a2 Q- Q% X) p* j
( k/ O. d6 w1 E. V$ G+ ~void main()
3 M/ `0 h! b5 l) L. v' A) a$ G& _{' z6 M9 h2 K# a- t2 r& @1 X* D2 u
IT0=1;
% e( x2 v5 r( G8 U% i EX0=1;9 O* H. c C9 J# V8 I s- ^! {
EA=1;
0 \( x6 O- _' d$ ?' W& T* n: n/ @& c2 h 5 r( V7 Y) C: }* p) W/ n4 w3 B
KEY=1;% ?, ? |4 l+ A" X$ B6 \
" q; d8 O7 U1 Q4 C while(1)# K3 t4 V- }1 D7 o( |9 `$ B: I
{5 [) x/ L9 [" x. `- s/ H, q
if(KEY==0)
9 B) u/ ?$ r. M! K {
- ^* {! }5 p5 s: f7 u delay(200);
0 h' }& a1 p/ b2 k if(KEY==0); k" A; d/ W9 t
{& `! ?6 n$ B+ z0 }
_NO++;6 a* V8 C' [! v# z' i/ ^, ^
if(_NO>2)
3 }7 k+ f0 `8 d* H' T _NO=0;
% Y+ m h; R1 a( c3 }" `) ~9 D& i: c while(!KEY);
9 I' o8 W% E _ u }
* j. T4 O& u* a" K& Q9 s }
' ` h6 r+ P- g: u& m0 L- Y& Q } 6 f9 U# K* p/ V( ^3 p" ~0 a" s
7 Q: F% L! y' r: p/ {( W7 x5 x8 R( M5 V! T# a3 ^- C" l
, ?3 ?1 `, W: A8 R+ F* m! p& Avoid inttime() interrupt 0
: [) Q( E+ G0 T. `{
K5 \) F: T% o2 I KY=~KY;4 T. N5 @6 y& [; S9 D% Y6 P0 v
if(KY==0)9 P% H! @* e, A B
{* F/ e* y t+ h) \
switch(_NO)
$ _- {5 g/ z, R* \: h4 v( @ {
7 ]. X, D) z5 d ~ case 0:; _1 Z% `/ v6 e' }, }" y* u
desplay1();
, V5 ]3 B* m, i break;
3 g2 P( C/ \4 G9 Q5 u' `" t 5 a2 }$ H6 n6 x$ E5 b+ J6 l' _) W
case 1:1 v; I6 a4 s$ E0 b
desplay2(); i0 k+ R2 z. ?# n
break;
3 [( P+ H; q; R ]! b 2 r/ R. H( f) o6 u% e9 ?
case 2:
7 b7 X! Q$ [) O desplay3();
' A* p6 p) S: V break;; E% D i: R' G- r: u
} 7 q3 U- ]9 r0 a$ k5 J
: Z3 `$ V7 e2 Y% Y: S# s4 T) _}- A7 w f6 t$ Z* R
( ]: h0 t% `' |( ]* L2 w5 J. q3 e' u8 x$ x
