查看: 469|回复: 1
16×16点阵 上下滚动显示LOVE
发表于 2019-1-16 10:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
16×16点阵 上下滚动显示LOVE ' K0 c2 B" B3 `& H0 a5 d% Z
4 b/ Z+ O4 Y  G. A7 D; b* j( I
! ^) _8 p0 w# w6 w/ y+ [8 `1 `4 x( M
1602液晶显示LOVE的C51程序
! M- T: C0 J* y) \! T- P$ I- }2 A: C4 m完整资料下载:
# I* F+ ?6 c5 |0 e' K
游客,如果您要查看本帖隐藏内容请回复
( r4 O/ ~2 `& l- p
" x0 q, F& c8 B( f3 V! z
$ N- ^" I, r. z& h
源程序:
: x) z- a$ m5 k% \" a6 H9 `4 D9 c#include<reg52.h>/ y( P- B: G( h- h
#define uint unsigned int0 W) ?4 T+ ^* V  X! u
#define uchar unsigned char) i" [, N- ~# ~$ w) v( ]& l  w
#define  xh  P1           //P1口选择行
$ r" _* `' O/ Y7 Q( G8 K+ }/ B1 `#define led2 P2                 //列数据口* _9 x# D& G8 m9 k: {/ w$ A) F
#define led0 P0                        //列数据口
, f4 O& N  s& c3 A5 Y/ l8 b/***************************************************************  e; W5 c+ T7 C; a$ \* z
        这是love表的注释   P2口  P0口 P2口 P0口 P2口 P0口 P2口 P0口
0 m# e% n* L; f+ j- Z*****************************************************************/
% {; [. g/ v6 Nuchar code love[128]={0xff,0xff,0xff,0xff,0xff,0xff,0xf7,0xff,            //L
3 B* D+ v" \9 b; a* F' h        0xf7,0xff,0xf7,0xff,0xf7,0xff,0xf7,0xff,, d: @2 O' f6 `, c
3 |) Q' d  i* C) h        0xf0,0x0f,0xff,0xff,0xff,0xff,0xff,0xff,/ |+ Q0 U+ _/ p( Y
        0xff,0xff,0xff,0xff,0xf8,0x1f,0xf7,0xef,                        //O( R: \; N0 X7 M' G5 I  Q
        0xf7,0xef,0xf7,0xef,0xf7,0xef,0xf7,0xef,' [4 t4 @/ M% t9 L0 v# \, F; V7 S
        0xf7,0xef,0xf7,0xef,0xf7,0xef,0xf7,0xef,8 u8 u+ ^/ I, B8 T. \& W
        0xf8,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,7 y  U: R7 `- t% @. w* h
        0xff,0xff,0xff,0xff,0xf7,0xef,0xf7,0xef,                        //V3 s) B; ~# g6 i9 b3 X
        0xf7,0xef,0xf7,0xef,0xf7,0xef,0xf7,0xef," a* Q9 J1 T" x# u
        0xf7,0xef,0xf7,0xef,0xf7,0xef,0xfb,0xdf,+ r; K9 j( X  o1 z& R# ~/ x
        0xfd,0xbf,0xfe,0x7f,0xff,0xff,0xff,0xff,5 x1 i6 h5 ?% i# q( }
        0xff,0xff,0xff,0xff,0xf0,0x0f,0xf7,0xff,                        //E
2 y4 t$ P1 m8 s8 _/ X        0xf7,0xff,0xf7,0xff,0xf7,0xff,0xf7,0xff,' N* a) ^- I5 ]' C! J$ r) V
        0xf0,0x0f,0xf7,0xff,0xf7,0xff,0xf7,0xff,; S7 G& E$ _7 n3 _1 T& }2 ~
        0xf7,0xff,0xf7,0xff,0xf0,0x0f,0xff,0xff};  H3 P0 ^+ j1 D! b! I8 x
6 P- L# F% f. i+ e
void ysms();                //延时1ms# W# I( \2 N( V: d0 ^, j5 \9 z
uchar m,x,y,h=0,i;
' `$ d% ?0 n; ]: D" _6 b3 b0 i! m+ w+ d, ~# S( R! ?! a
void ysms(uint p)                        //延时1ms- u: p5 `- ?! q. Y4 d
{                7 x( y) G. k& C: L; U! q
        uchar q;4 p2 C. r+ \2 V- w0 Y1 }
        while(p--)
4 D9 m# [0 P! o# U; g  [9 j        {% m+ V" l$ s8 ]! b4 B
                for(q=0;q<120;q++);7 P! r6 c8 o/ i( |
/ o$ W. ^, a3 O% _! w}$ @( A* t6 O! ^( I6 B
* [- m* ?+ }/ d9 Y% Q
void main()
7 n! s; ?- c/ v) k( B{                        2 D! p2 E+ {# K4 i+ H9 t
                        while(1)
* G3 K  L0 h/ e% a9 ?                        {
  a  z1 ]( h1 h9 v* n& {' p                                for(m=0;m<5;m++)                        //使得每个字停留0.16秒   10*16ms=0.16s
! P: T! G9 @8 m2 m                                {
0 d7 R9 |' e. [                                                for(i=0;i<16;i++)
% v: |" D  F: T6 Q- ]                                                {
& i: @$ P# x, b6 d7 P& y2 w                                                        xh=i;                                                //选行& C' F+ |: @7 I% k; ]
                                                        x=2*i+2*h;                        //第一列屏列数据
  N0 r: }# Q- d8 n0 Y4 R                                                        y=x+1;                                //第二列屏列数据
$ ?% \3 h$ p$ o1 U                                                        if(x>128)                        //若x超过数组个数  则从头开始0 ], @, j* u% G( }* U" B7 w- j
/ C( O( V! p- q0 T' Q* P  R/ I        x=x-128;                6 o3 J* X5 P, J( {1 s! ]- }
        y=y-128;* T- H# @& t) l) f9 Y6 {
                                                        }* a9 p# `) ~9 k6 b% [
                                                        led2=love[x];                        //送出数据
1 ~; D4 n4 h1 k, Q                                                        led0=love[y];                        //送出数据. J  P! k' t. P0 J
                                                        ysms(1);
$ `& Y8 z; N8 {7 K                                                        if(h==128) h=0;                //滚动完后 从头开始
" o* m* ?% `( q0 i8 D                                                }/ ~7 M% A& o  E) ]" O/ h  r- I
% L, f/ M" _" z. @9 }  R( i* S                                h++;                        //使文字滚动' t# R$ w# N$ A: |, e
                        }5 Z4 m. L5 e& ^/ F
}  \: w, L5 Q4 P- q$ D& j
( X* B# T; S8 b2 j' s( t9 h) y
GMT+8, 2025-10-9 02:02 , Processed in 0.156250 second(s), 26 queries , Gzip On.
