查看: 899|回复: 4
音乐频谱(stc12系列)
发表于 2019-1-15 10:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
音乐频谱(stc12系列)
  |5 M; D/ y% S- `( i) @: l/ \' v; n7 h' }' b. J
( `3 g% g/ b, c% p, G, m3 q4 X
原理图是用proteus画的,所以没有Vcc和Gnd标识$ G: ~- a7 w7 i2 t4 j; C
信号输入端的电阻、电容是抗干扰用的,大小请根据电路的实际情况做改动* X, J8 }; B& `
/ Q9 _( R7 J* p& I3 m+ @程序如下:
8 f; e- z. v+ Q% s9 E9 d8 e8 P# H6 o
* W! W8 J0 ~: d0 _8 j6 W/ ]  {5 b
#include<stc12c5a.h>  z( \" O3 K  D. y
#include<intrins.h>
, \. C8 e- h& ^( J# E//#include"basic.h"
  F' k/ k  |/ O/ ?' gtypedef unsigned char uint8;
5 \5 u& `1 _7 I- C9 stypedef unsigned int uint16;, |& y8 z3 U( k; C
#define ADC_FLAG    (1<<4)    /*ADC_中断标志*/# x; V0 o6 t% ~$ A' `
/*放大128倍后的sin整数表(128)*/
7 N) A( I, G' {- qcode char SIN_TAB[128]={0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102,
* K; U9 I4 h9 z* u$ U& g                        105,108,112,114,117,119,121,123,124,125,126,126,126,126,126,
. O/ i* X9 p+ a" q) M& v* d                                                125,124,123,121,119,117,114,112,108,105,102,98,94,89,85,80,75,1 n9 N* H. F# O5 J0 y
                                                70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,-30,-36,-42,9 e- y8 n" a7 z' e
                                                -48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,-105,-108,-112,
' ]1 Q: f9 y  x8 [& U                                                -114,-117,-119,-121,-123,-124,-125,-126,-126,-126,-126,-126,-125,
: ~* V- {; o4 U. b* _5 E                                                -124,-123,-121,-119,-117,-114,-112,-108,-105,-102,-98,-94,-89,-85,
7 z1 K) _5 J. I- X- |0 T                                                -80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,-12,-6
* c+ J3 a& I8 x+ A6 B, l                                           };
) u  |, V# L4 u# B% A; I
$ M; e6 M! _5 Y; L3 L% G) ]1 z
% @6 `4 ~. ^! P' Q* m) H5 D
/*放大128倍后的cos整数表(128)*/
0 r8 D* K2 i. a7 _+ P2 X, T; D8 Tcode char COS_TAB[128]={127,126,126,125,124,123,121,119,117,114,112,108,105,102,98,94, : u" {9 o' x+ c8 i  ^( `6 S
                        89,85,80,75,70,65,59,54,48,42,36,30,24,18,12,6,0,-6,-12,-18,-24,
; F1 d: [- I, s* q                                                -30,-36,-42,-48,-54,-59,-65,-70,-75,-80,-85,-89,-94,-98,-102,3 I' _- @1 V7 j+ L; R8 [
                                                -105,-108,-112,-114,-117,-119,-121,-123,-124,-125,-126,-126,-126,6 @' M" `% l0 Q; g3 w
                                                -126,-126,-125,-124,-123,-121,-119,-117,-114,-112,-108,-105,-102,: p# V# ^" _" b8 a( F# e
                                                -98,-94,-89,-85,-80,-75,-70,-65,-59,-54,-48,-42,-36,-30,-24,-18,. S9 ~6 V# C( |8 [0 J
                                                -12,-6,0,6,12,18,24,30,36,42,48,54,59,65,70,75,80,85,89,94,98,102,
5 s1 [% y8 q" l3 u4 J* b, U                                                105,108,112,114,117,119,121,123,124,125,126,126* |0 v% ]# |! x5 ^
                                           };% g) J$ w* @# O& q- g
1 x  f! }- _, w. A2 w- B
' v  d2 n' j) T  s! y
/*采样存储序列表*/, W, v; b6 G2 B9 ]
code char LIST_TAB[128] = {0,64,32,96,16,80,48,112,8,72,40,104,24,88,56,120,4,68,36,100,20,84,52,116,
/ s/ a1 Y! g" e3 u. m  F                           12,76,44,108,28,92,60,124,2,66,34,98,18,82,50,114,10,74,42,106,26,90,58,
6 t! q6 z" t1 u0 f/ q                                                   122,6,70,38,102,22,86,54,118,14,78,46,110,30,94,62,126,1,65,33,97,17,81,49,
: q2 W8 ~1 m3 N3 [1 y. ~                                                   113,9,73,41,105,25,89,57,121,5,69,37,101,21,85,53,117,13,77,45,109,29,93,61,1 e# U: i0 H6 ~- m# s/ K
                                                   125,3,67,35,99,19,83,51,115,11,75,43,107,27,91,59,123,7,71,39,103,23,87,55,
+ I; E( r% I; H9 v" p3 Z6 H+ A                                                   119,15,79,47,111,31,95,63,127
- j; V' D8 M% I6 H3 e8 X. d: s                                                  };
/ c  ]7 u0 j+ _8 d+ T4 d& ?) z+ ?3 K, w$ c: C& I7 s
' l6 b/ y5 {% z, z* }
/*分级量化表*/
- L  ]1 ~. _. A0 U, fuint8 QTY_TAB[] = {0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};% c% e, o* E/ {0 E. [; `, B9 l" N9 k2 J
uint8 ADC_Count=0;
, c  x  s3 W& Huint8 i,j,k,b,p,anum;
9 K5 i) e2 C& _2 ]: D$ {uint16 xdata Fft_Real[128]; 2 i0 l6 I7 o3 Q: u( S3 n, r
uint16 xdata Fft_Image[128];               // fft的虚部 9 q- J, R& L/ z6 @& I- l
uint8 xdata LED_TAB[16];                                //记录红色柱状
; [- q0 [' `5 k; O* O* B# p+ L2 h5 `0 g$ h! L
* Q) m2 G: O; n; X/********************************************************************
) c* d/ Z8 z( _+ ~# y* 名称 : FFT( ?7 h$ I4 n7 L1 |$ A
* 功能 : 碟型运算转换
7 H9 R) P# @  @$ O* 输入 : 无$ m; Y6 b% Z- b" H6 B
* 输出 : 读出的值) u4 f/ s- C/ j* C/ Z; G6 \/ R
* s3 K5 ~: Q6 \' j. W3 I' w0 F& s. ivoid FFT()//基2fft2 z% j: G: ]1 n# b( K
{                 ! d6 e: ~% A( N
        uint16 Temp_Real,Temp_Imag,temp;                // 中间临时变量: b6 X2 s" J0 d9 {, C/ `/ \8 N
        uint16 TEMP1 = 0,max=0;
: `; G5 k7 G' ^6 D3 A        for( i=1; i<=7; i++)                            /* for(1) */: S0 W% N7 M1 I) m
        { # {- x- U7 A2 E# Q) U) F4 l2 [# |: k
                b=1;5 [& U* ]$ E+ C/ R
                b <<=(i-1);                                 //碟式运算,用于计算隔多少行计算例如 第一极 1和2行计算" y9 d) Q% [4 N  f
                for( j=0; j<=b-1; j++)                      /* for (2) */
8 g9 c0 Z: U7 Y/ v1 T                {
4 b6 I4 v' O$ c8 e" c                        p=1;. E' Z+ m% Y3 _; Z$ D" W' o+ Z
                        p <<= (7-i);            - t6 D+ l" D8 u: S' Z/ S) U; l
                        p = p*j;0 U0 O, |! C" L
                        for( k=j; k<128; k=k+2*b)               /* for (3)  */# _- _: G1 Q5 D+ I6 \( E
( h$ C& u- l" d, H                                Temp_Real=Fft_Real[k];
7 N2 @8 k& y- L" {  i$ ]7 W                                Temp_Imag=Fft_Image[k];
- ]' n' |) U% `( v( d* J                                temp=Fft_Real[k+b];
  ?  `* o  K$ `8 c5 x                                Fft_Real[k]=Fft_Real[k]+((Fft_Real[k+b]*COS_TAB[p])>>7)+((Fft_Image[k+b]*SIN_TAB[p])>>7);
7 W& }$ B- |) r0 [8 e                                Fft_Image[k]=Fft_Image[k]-((Fft_Real[k+b]*SIN_TAB[p])>>7)+((Fft_Image[k+b]*COS_TAB[p])>>7);; _$ O1 S+ d. H9 R5 G' {
                                Fft_Real[k+b]=Temp_Real-((Fft_Real[k+b]*COS_TAB[p])>>7)-((Fft_Image[k+b]*SIN_TAB[p])>>7);
6 }+ C& R' |+ [" j4 n& Y; @                                Fft_Image[k+b]=Temp_Imag+((temp*SIN_TAB[p])>>7)-((Fft_Image[k+b]*COS_TAB[p])>>7);          // 移位.防止溢出. 结果已经是本值的 1/64               0 z  N, b# U  ~# n
                                Fft_Real[k] >>= 1;             & m/ u* t* K$ U+ M# g+ j/ L
                                Fft_Image[k] >>= 1; 7 c# P" @) c1 x: a
                                Fft_Real[k+b] >>= 1;
9 Z4 E* A# d7 o/ \$ D2 S                                Fft_Image[k+b] >>= 1;
$ e( R; M" j" E                        }
: L# \: \' B2 k8 P1 k) O: k+ @                }
+ V1 J+ w( F5 ]! U& Q; [8 u  E8 u        } ' a! o+ P) `4 m! N8 U. t
        ! }4 w: b7 ~6 i  G
        for(j=0;j<16;j++)//16分频
6 R, I- ~" q, b8 s8 G        {
+ r5 f/ o8 M% W8 E# b                TEMP1=((((Fft_Real[j+1]* Fft_Real[j+1]))+((Fft_Image[j+1]*Fft_Image[j+1])))>>1);//求各频段幅值2 P- ?; C5 O! i' Q1 w9 S
                if(TEMP1<1)TEMP1=0; 1 h0 n) X4 x: y; i
                LED_TAB[j]=TEMP1;
3 i/ W" O  |# b$ |. ^                if(LED_TAB[j]>max)max=LED_TAB[j];
2 y: ^! ]2 ~$ I1 b# p$ k        }
2 i- O2 O  h. [        if(max > 16)//分级量化7 H( _) W! j# @% ?4 ]
+ v' [; }- h1 y6 }( Z& \3 _( F                max/=16;
+ c5 G4 L0 v: T' B* W# s                for(j=0;j<16;j++)LED_TAB[j]/=max;
+ D5 d) J! r" F: W        }
' w1 O3 z6 C9 u3 R}
% L, d$ s  S6 t) {8 _% [' Q. b: H/ p& z& e9 v
( a9 r4 `" b" q1 U& f/********************************************************************) _! ~/ K5 u8 L# Q
* 名称 : GPIO_init
/ p, f% t% F! s" @# X* 功能 : GPIO初始化
) D& g  l  o4 x& G. ]5 T* 输入 : 无
7 a# A! I' y% a1 h8 ^2 o/ m* 输出 : 读出的值$ a; J$ u& t0 u6 ]. _& B
***********************************************************************/1 b) X( \: V6 W# H6 u
void GPIO_init()
5 _! Y6 F; T/ U( A" O: z{
& i3 [8 o% ^! e- u7 r# c' ^        P0M0 = 1; P0M1 = 0; P0 = 0XFF;    /*列*/
. v3 Z8 M8 _& ~/ x        P2M0 = 1; P2M1 = 0; P2 = 0XFF;- d) Q' R1 E$ W4 I2 o2 k
        P3M0 = 1; P3M1 = 0; P3 = 0XFF;          /*行*/: T+ ^6 i! k/ N
}1 \; y8 j6 V9 n+ w$ ]1 v9 P" c
/********************************************************************* T0 P- N- \$ y* b% c  X
* 名称 : timer_Init7 U# j5 O( e' H/ [+ V1 `+ H( w
* 功能 : 内部寄存器初始化; W0 y8 ^8 ?6 |, `6 `9 C
* 输入 : 无+ J* E  o3 p8 l8 Z
* 输出 : 无
# r( ~- W1 q- v' p***********************************************************************/
0 ?7 q! `  Z1 p' ]7 gvoid timer_Init()) y  l0 ~% K& ~7 b3 u7 J: [5 x3 G1 f
{9 k% R- \$ l* [
        TMOD = 0X12;( V) C8 Q0 E& f; i/ J9 V
        TH0 = 0xb0;        , o5 g8 d2 j5 ?- k) D. i
        TL0 = 0xb0;
$ Y& d/ O2 l8 `+ d6 G+ M. J" }        ET0 = 1;                                               //定时器0 打开1 d- T/ Z: z* |9 c
        TR0 = 0;                                                      //关闭定时器4 Z: w! ~3 v7 x6 T* e
        TH1 = 0xfd;        ) p' A  A# x7 O' b& K, g
        TL1 = 0Xa8;! n: S# n& X3 J+ A3 ^$ b
        ET1  = 1;1 ~& g: z; C3 t& z) J2 C' R" p( ~
        TR1  = 1;        , }1 s( N  x, ^& h" x
        EA   = 1;        ' z2 I$ E% X4 A9 n
}$ c0 {0 n$ |! I, v
/********************************************************************/ `9 }5 P8 C: X, \- b' p
* 名称 : adc_Init
$ W% Y$ e  D" l$ \! {* 功能 : 内部寄存器初始化7 A; l# o9 C% Y
* 输入 : 无( v6 R1 ]8 U2 ?( t/ f( P
* 输出 : 无6 m% s6 o1 O4 ~9 n2 O
***********************************************************************/4 ]' B! A9 j0 U7 s$ I* o5 N
void adc_Init(): ?4 T& q& r9 F2 @0 E$ d7 o% E
{          7 S. n# h" r0 O1 [3 K3 Q# S5 a* v/ x
        ADC_CONTR = 0x80;             //ADC电源打开
& k+ a6 f$ q4 T# q) q        _nop_();_nop_();_nop_();_nop_();
$ c: G! W3 P+ L9 s        P1ASF = 0x01;                 //0000,0001, 将 P1.0 置成模拟口
- B' ?, F) m1 H  c2 E8 p5 m        AUXR1 &=0xFB;                 //1111,1011, 令 ADRJ=0
' f1 U# j# S: L% G* ]0 P        ADC_RES = 0x00;               //清零寄存器
9 ^6 Z# t3 j0 e! \- H        ADC_RESL = 0x00;: g) ~! c/ F9 Y
        EADC  = 1;                                          //AD中断打开5 z$ ]1 H$ L# S9 s- [& b
        EA = 1;                                                  //总中断打开8 a3 Y; F7 @& \% Q4 \9 l
0 _5 v: M" }7 {" t
- H6 |- J* U, {  L8 K1 `/ c
- u. {# F, r7 O/********************************************************************
# g+ p, {2 Y" T9 J* 名称 : main
9 k. m% m$ h! Q6 z6 B; D* 功能 : 主程序
' E% C5 t9 [( x! K5 ^6 I* 输入 : 无
5 E8 U4 \! L# }6 z% j+ u& f" [7 `* 输出 : 无, ?; d0 ~8 j) ~. n1 _. d5 _* m
% D9 o$ V" p7 m8 d; g. u* K- Kvoid main()- ?: q0 w: ]5 T. }
$ C$ N: u; N1 n* Y8 }& l        uint8 i = 0;
! i7 [7 j# N9 e) U: x* M: S$ }2 P        GPIO_init();
/ T# }6 U' u/ L/ O+ U" f        timer_Init();; Z7 Z# y/ h% a$ _1 j% D
        adc_Init();4 S! C6 O: Z. D0 c- }" c
        while(1)
3 o3 V. A; d3 x- B        {
  A- a4 z0 ]+ O" v8 M                ADC_Count = 0;* v4 o6 y) _$ K+ X
                EADC = 1;
9 O* E' {( H  o& [0 v                TR0  = 1;
$ o% w8 w' q! X$ x2 ?                while(ADC_Count < 128);       //满足128点: h8 Q* n) y$ A# P( Z+ k6 g8 N6 H2 ~
                for(i=0; i<128; i++)                  //清除虚部. S1 _3 B3 O1 Y5 y$ K
                {$ }4 h% h0 J$ w) @
                        Fft_Image = 0;+ g# V! c# j. r/ s
7 C( I+ d& k; Q" m5 v. z; a                FFT();                        //FFT运算并转换为各频段幅值/ w# ]1 a& p1 Y' N; l
+ I7 m# ]* J: E0 W" l1 t: V: _
2 C, \# |. A& G4 f8 Y: E        }2 F) I+ h: v) Q5 |
$ ^: K* z7 x. Z3 ]( l, a/********************************************************************
% }4 P: n  w! g1 a* 名称 : ADC_Finish
  {9 j/ h$ B( }, h* 功能 : ADC转换完成中断服务1 L5 D- q& N& E# ]/ b9 s! Q
* 输入 : 无6 d( \& M" b! d7 y. x1 p/ b+ e
* 输出 : 无8 R- B+ s' q1 y/ R5 T
***********************************************************************/, q2 F+ @& @. X' B5 M: a7 f
void ADC_Finish() interrupt 5$ |) ^+ Z+ g7 j1 Q  ^6 w- R
{( ~5 P0 H* k8 Y9 x
        Fft_Real[LIST_TAB[ADC_Count]] = (int)(((ADC_RES)<<1)+(ADC_RESL>>1)*2)>>3;    /*按LIST_TAB表顺序,进行存储采样值*/* B% u) y) C9 p, Q. H8 q
        if(ADC_Count <= 127). s! T" b8 S7 w4 _
- y% r& C" }1 Z! P3 `$ z                ADC_Count++;           /*自动增量控制*/
/ G- t; ]" k; N* K                ADC_CONTR &= !ADC_FLAG;- Z: N# |% Y" f) Y, X! \; n
  X  C' e1 I) v        else. y9 n: h7 Y$ U# j0 G
; K; T! L5 M) U! v                EADC = 0;# z  R( N, g  J4 x! z! p9 q4 L! p
                TR0  = 0;        6 v! Q8 g0 D  ~8 m. J! p8 `
        }                        : g; ]$ x( J) X6 l
}- d, m+ X- I2 v3 L
/********************************************************************+ k- d, d" f- `6 O8 Z# R
* 名称 : interrupt_timer11 ~! ]: i% `5 d+ k$ B7 U
* 功能 : 显示屏幕刷新中断服务5 r- |! ^, T' r( v( Y
* 输入 : 无# Y! [: `2 a9 N
* 输出 : 无1 [0 g3 `; }, q- Z( ?3 U
& P. x: r* J# w  l$ kvoid interrupt_timer1() interrupt 34 a- x) C2 u+ B# O
, _5 P# J" ?" l4 _: x        static uint8 rec = 0;
) L; n- x: r# f$ H/ Q        TH1 = 0xfd;        ) N0 s' ~" p% N0 `4 g" {
        TL1 = 0Xa8;! G+ Z' ]) `; O$ E% F, q
( x1 \& w& Y4 T* w' I" q
7 g5 e9 Z$ |1 W9 K# ?        switch(rec)        //往点阵屏填充一列的数据$ [3 I' G# q/ r+ o( _
        {" S$ }# T% d8 i( x% W2 G
                case 0: P0 = QTY_TAB[LED_TAB[0]]; P2 = 0;break;
2 V0 _. V1 E6 R                case 1: P0 = QTY_TAB[LED_TAB[1]]; P2 = 1;break;
( k6 Y6 w+ U- m" U. }2 d                case 2: P0 = QTY_TAB[LED_TAB[2]]; P2 = 2;break;        - D% Q& u  ?$ u
                case 3: P0 = QTY_TAB[LED_TAB[3]]; P2 = 3;break;
( z9 u( R3 U! f% Y0 u                case 4: P0 = QTY_TAB[LED_TAB[4]]; P2 = 4;break;        ) ]/ `2 y& ?8 a: z. p5 G1 V8 I
                case 5: P0 = QTY_TAB[LED_TAB[5]]; P2 = 5;break;
. c! E' y8 A1 e9 P0 B: G                case 6: P0 = QTY_TAB[LED_TAB[6]]; P2 = 6;break;
: Z, ?# l- O& x, L7 }  g' [( x( p1 `9 w; d                case 7: P0 = QTY_TAB[LED_TAB[7]]; P2 = 7;break;  a8 Z% f5 I: ?/ J* q* J
                case 8: P0 = QTY_TAB[LED_TAB[8]]; P2 = 8;break;
* [7 f1 t- A4 Q                case 9: P0 = QTY_TAB[LED_TAB[9]]; P2 = 9;break;
! o( U6 V2 V; ^. U                case 10: P0 = QTY_TAB[LED_TAB[10]]; P2 = 10;break;
' X/ m" c5 W0 s' K; C1 A6 }                case 11: P0 = QTY_TAB[LED_TAB[11]]; P2 = 11;break;
/ n. D, E. l" X$ u                case 12: P0 = QTY_TAB[LED_TAB[12]]; P2 = 12;break;        # X$ l3 v# ^* E2 b5 M$ k* E
                case 13: P0 = QTY_TAB[LED_TAB[13]]; P2 = 13;break;                % F  q2 q6 P3 ?; I  w- X2 ?6 b
                case 14: P0 = QTY_TAB[LED_TAB[14]]; P2 = 14;break;
) _  p& R; q5 }; p                case 15: P0 = QTY_TAB[LED_TAB[15]]; P2 = 15;break;
. V. c7 ?9 W* A! y$ ~                default:break;: U0 F9 M3 S' v: z
        }# \/ f" r4 h5 E+ F; G9 E9 Z
        rec++;
1 Y$ c" w1 J. u+ m" z9 L        if(rec > 15)
' Y! P" m! y- X, i        {
$ k. r( C7 t! U( q; ]5 \2 i                rec = 0;+ _/ C0 J* D7 Y: t5 l  E# u( R) ]2 m& Y
        }- G: U- s: y# h
}( W! {8 N2 X9 ]
0 h6 z- \; m' @* 名称 : Ad_Control
& X  S& D" [# o% J! m, E) K6 t* 功能 : 控制采样率& W( [- g5 b: ^
* 输入 : 无5 ]8 v& N( q1 D/ N5 {' T
* 输出 : 无& W+ s5 v4 Z2 N5 o8 Q
6 S) V2 ]* }9 Hvoid Ad_Control() interrupt 1
3 y' r( b' D5 P{2 H- C$ t0 N6 A  F
        ADC_CONTR = 0xe8;                     //开始AD采集
, d: p0 ~5 s$ X+ C9 d: O        _nop_();_nop_();_nop_();_nop_();         3 |" L8 y; B  ~3 ?6 Z' ?' D0 B
} & w2 }" ~4 r, W
  R3 i9 a- h  `% O: D  x+ p) R/ ^
+ X+ v6 d$ k; A5 s- r下载:( N4 ~; x% I8 \
游客,如果您要查看本帖隐藏内容请回复
( J9 t8 H5 g+ U4 z$ M, }* Q, g9 i
. v4 X( j2 S: t7 m3 K4 B/ ^( ~9 B
发表于 2020-5-26 13:35 | 只看该作者
发表于 2020-8-10 23:57 | 只看该作者
多谢分享
$ `7 R1 R3 _  _5 D% D
发表于 2022-3-7 18:22 | 只看该作者
谢谢分享,楼主辛苦了
GMT+8, 2025-10-6 07:13 , Processed in 0.156250 second(s), 26 queries , Gzip On.
