matlab做图形界面——日历
1 x1 I1 X( H; N# I, x4 Mfunction CalendarTable;: c4 {$ `* g, b: ^+ K
% calendar 日历
6 a2 |$ H0 c3 X( @/ m4 L9 F1 ?% Example:
3 U2 {. m5 U0 M l; y) r6 G# @# Z3 |% CalendarTable; S=datestr(now);4 } K$ H: z, k( y* x; I/ r
[y,m,d]=datevec(S);
$ [! i* D A5 J% d is day% |; M- I( j. @, ?
% m is month; p; M& {. X& r- j
% y is year! [0 Z8 w! V2 M9 o* \8 a6 i
DD={'Sun','Mon','Tue','Wed','Thu','Fri','Sat'}; b/ m/ w- H0 A2 Z. X
close all
% C; g* T0 }1 \7 c/ F; C figure; %出现一个画图界面, t$ P" c' O$ L
for k=1:7;
5 D: ^% z+ j- s' P) f! z" n uicontrol(gcf,'style','text',...9 @" n8 q: u9 I: G- K% t
'unit','normalized','position',[0.02+k*0.1,0.55,0.08,0.06],...
* q: V) F2 k; B& \; Z% [ 'BackgroundColor',0.6*[1,1,1],'ForegroundColor','b',...' g7 c8 K) n4 H! `) B
'String',DD(k),'fontsize',16,'fontname','times new roman');3 i! e8 ?, X, B# W
end
) s$ k. {, z; T5 S9 j- Xh=1;
1 O0 o/ A$ F4 T6 K' M' }ss='b';
& _( W7 e5 Z& g! W" j/ Gqq=eomday(y,m);% 获取该月天数
5 ]9 t! f' G0 A: M$ O6 ^for k=1:qq;
5 B6 I( p. n" U% A1 Q. u1 F r7 { n=datenum(y,m,k);( v1 ~' R' |1 ?2 p. j! s
[da,w] = weekday(n);
" R* X; H; T2 N3 T" c4 ~. o if k==d;
- e& A/ ]/ L# h5 D* v$ j ss='r';- v) H7 E/ `8 |* h+ [/ G( U5 B' B
end$ A1 C7 U+ e( S2 J- q
uicontrol(gcf,'style','push',...
4 t% u- _3 W& c 'unit','normalized','position',[0.02+da*0.1,0.55-h*0.08,0.18,0.06],...
) j2 H' F3 h: b' v$ m 'BackgroundColor',0.6*[1,1,1],'ForegroundColor',ss,...0 g) S; U) a2 r5 {" K8 [- L) \
'String',num2str(k));* ~, W% m% L% l# w1 h$ p% ^0 G
ss='b';
4 j% z: l4 z: ?7 Y if da==7;
" ~1 I& j1 R6 d5 {' I h=h+1;! c" r9 j; D- P
end
5 i2 n. k/ h, G& ~end
5 [+ @2 _+ ?2 i$ N8 J& Z F6 uuicontrol(gcf,'style','push',...9 x6 Y- ^/ V5 B( ~. X+ }, A9 Z
'unit','normalized','position',[0.6,0.66,0.12,0.08],...! M# ? M6 `0 M5 ?( ^$ W" ~/ m
5 y2 m0 I9 t t' o* A) \- P0 Z 'String','clock','fontsize',18,'fontname','times new roman');
s! Z W6 f/ V7 N# s' JTq=uicontrol(gcf,'style','push',... %%%%clocck 右边的框
0 ~3 Q. |( Y6 ~ 'unit','normalized','position',[0.74,0.66,0.17,0.08],...
0 u0 x" U& U2 ?+ z 'BackgroundColor',0.6*[1,1,1],'ForegroundColor',[0.1,0.9,0.9],... V% J" h1 l7 F4 S7 B) |
9 ^7 V. h; O! T% \sq='The calendar';
" b# U) Y) y6 iuicontrol(gcf,'style','push',... i) Z/ R$ g/ [4 T" C5 ?4 r
'unit','normalized','position',[0.14,0.86,0.37,0.08],...
; {+ A, F6 H7 x; v/ i/ Q4 [& H3 G 'BackgroundColor',0.6*[1,1,1],'ForegroundColor',[0.1,0.9,0.9],...8 z6 ~6 P( i7 z2 ~
'fontsize',18,'fontname','times new roman','string',sq);
7 B9 W9 \/ q( g/ _) t5 l3 Uset(gcf,'menubar','none');; v+ ^) P9 V9 Z9 w( W" l
try
- {& L; Y1 j3 {- m9 [$ Z while 1
" O3 X8 Y; {6 R9 q9 w set(Tq,'String',datestr(now,13));
+ v# t3 y1 ^0 k# {3 e3 V5 l pause(1);- S3 ~/ Z7 U: B& q
end5 I& `; Q5 z" b' V( g! i
end 看后很有启发! mcc *.m -a function name.m 形成.EXE文件 -a 可以 便于回调函数调用别的函数 , a5 \) B: k! B" U; k |
0 `6 ~* |$ w0 Q3 O1 P# M# h
