Sht11湿度测量proteus仿真和单片机源代码- j% x- p! j5 J' I/ v" N9 Q$ L& M
$ _, R/ i) c; G2 F
# S4 s3 l9 d; C1 w: R1 P9 \
sht11的单片机仿真原理图和仿真效果:
+ m, B, Q& r8 F8 T- J
( F4 W0 o& u2 d% o6 w2 z. s4 @7 q; n4 C# V J
51单片机源代码:& \: A; H8 _* \/ q8 i6 j1 h5 G
#include<reg52.h> z7 x: h6 P$ @0 X
#include <intrins.h>
: u1 k& _# {; l6 J% o#include <math.h> //Keil library ( W" n1 r$ y% s& L! d
#include <stdio.h> //Keil library3 o6 w4 N5 e4 ~4 y; S7 e
; q$ ]9 P$ y' P9 U) U& w2 s R* N6 p/ @7 j# Q
#define uchar unsigned char
0 ]$ y3 ?7 ` v9 H0 }( F i. D0 h8 G/ A; ]% F p* z+ f
$ z3 L5 f- d; a, Y* Y, b6 S
typedef union //定义共同类型% J; A8 ]" _; s) a* [2 B0 a
{ unsigned int i; //i表示测量得到的温湿度数据(int 形式保存的数据) : O3 E' @! l# y
float f; //f表示测量得到的温湿度数据(float 形式保存的数据)
5 c6 ?2 |/ O' l- Q} value;
0 w, G7 i* a# j0 J7 Y, ]+ A. s( k" |+ S; F
% B* M, K/ D* q/ y
& V6 l9 }* g* J+ J
. z& w. @ G. R/ o9 x% A ^: }enum {TEMP,HUMI};
O- [( _& N W' n$ @- `8 \% X _" u0 R, A1 V; q' M" e. Y1 r- _
2 w4 E' s' ]+ v, |' c1 C' |
sbit DATA = P1^1;- O, S' Z+ R% O: r7 y% r; }
sbit SCK = P1^0;" r: O. ?- e J% r) u
3 `1 n8 A' H. V$ f( z* F/ S8 k1 q) Q, t8 f/ v) Z
sbit RS = P2^0;/ y' ^8 B& R, I$ Z8 }
sbit RW = P2^1;
; D& ^2 L/ M& N; ]4 F) _; `sbit E = P2^2;3 ~/ ]% D1 [, z; I
sfr DBPort = 0x80; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.数据端口' p4 T- {: t4 z
% B% Q4 ]& q& T8 V' M9 Z" U, v2 e( I/ i: E+ Q5 a
/******** 1602函数声明 ********/3 Y) W9 q0 _5 x* E( X
void LCD_Initial();
2 f* W0 s% ~7 d5 D- \& ?void GotoXY(unsigned char x, unsigned char y);
1 E. U' d$ `, u% L( h) Rvoid Print(unsigned char *str);% Z9 R7 L. D* n4 K/ s* H2 @& z/ y
void LCD_Write(bit style, unsigned char input);/ q6 C' ?7 W0 z/ |
3 }4 B8 b: X& i: k' x: Q3 a' O; ~; R1 @, Q% s: B$ Z O. q' X
' L" U* w# J9 \" U
4 J; @" X7 L: R2 r2 _/ ^4 {/******** SHT11函数声明 ********/; z# v0 \7 ~9 |! [( A
void s_connectionreset(void);
6 Q- R) E* s) }) ? B8 d) W. Ychar s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode);
' }! K% G/ x8 X9 Qvoid calc_sth10(float *p_humidity ,float *p_temperature);
( D5 R) Y+ ]# [& _( E! m& ^//float calc_dewpoint(float h,float t);$ N, X1 [1 z, w. m; U
/ F, X: E# m7 e& d9 ` b
& s$ n+ m* t, G4 U0 @0 {" x2 y
P, \, U+ O9 T
- E# W9 p/ `2 A- z
* f* i5 E9 F. q2 _, Y$ A* ]5 c- E( V# C t; I) i. n
/***********************************************************************************************************************************************************/* s: w2 H5 Z8 r: R' {. K# O
" d8 q. B, A- A9 `& z
* a9 k% h4 L- o4 D( h, j# Y) D//SHT11程序
% X) y3 c3 H4 F7 C7 y4 ?8 s
: _* d- |- m" W9 g9 l$ C+ m w' Q! Y4 b
+ i( `" ?, b3 h6 n3 [- ~% U% o! ]% ]- }" E: J
#define noACK 0 //继续传输数据,用于判断是否结束通讯
8 V: ^' }/ n, t#define ACK 1 //结束数据传输;
$ \$ K- r! e1 M+ P+ g# P //地址 命令 读/写
( q, v- m+ y, G6 Z#define STATUS_REG_W 0x06 //000 0011 01 G& ?" \5 s. V1 v9 u1 m
#define STATUS_REG_R 0x07 //000 0011 1; o' L' o1 O7 u" K/ h6 f5 [
#define MEASURE_TEMP 0x03 //000 0001 1$ g3 V9 { J4 ~& \* Z) }# N
#define MEASURE_HUMI 0x05 //000 0010 12 ]7 F! W0 T' ^2 Y' v
#define RESET 0x1e //000 1111 0) w4 w; @" V, g; l/ |
& G9 G. y7 K# {2 g
, D G9 O) k3 f. H2 y- J: J; C6 V4 v5 \: O8 x7 k
+ S% c, x7 s9 h' t
% |/ _" }0 _* W4 d" d+ V- S% s0 f$ M2 P4 x& a
//写字节程序 N, c' k5 X8 v" V) w- N5 V
char s_write_byte(unsigned char value) 5 f6 r! A/ W5 L6 ^5 O' U0 G
{ / ~& m2 c7 i- T( R6 _
unsigned char i,error=0;
4 `+ L% q- p3 J& G4 E' N* i: _+ ? for (i=0x80;i>0;i/=2) //shift bit for masking 高位为1,循环右移5 F' g* \* Y/ N' q+ q! Q% ^
{ ) U D+ t- o$ Q' z
if (i&value) DATA=1; //和要发送的数相与,结果为发送的位4 Z$ e9 ]/ S4 w
else DATA=0; ) j8 P2 D4 A$ _. Q- s
SCK=1;
0 R5 [. X, I1 e _nop_();_nop_();_nop_(); //延时3us 2 B: O$ D- W" C, C' @ o& k
SCK=0;
# o7 ~1 s( n" O }
! \% f% X7 n7 n x- ~ DATA=1; //释放数据线7 K. G. B' M" y. g( d
SCK=1; * W; q' r) e! l: i( x/ d! Z: d
error=DATA; //检查应答信号,确认通讯正常* _0 u1 I6 k# h) t% Q* B
3 E' J5 `1 M, O1 j f! H% P SCK=0;
8 K& E `" }' q J7 N g, @" s# G) d DATA=1;2 I. J- J' J$ a6 a, u8 O& `7 I9 O
return error; //error=1 通讯错误
! N8 g! _9 |, h4 U8 E}6 r! ~7 H' O/ c$ G) F3 N
2 F% l4 o+ Q. \% \5 k
$ x! O5 U% |5 {+ z" q9 Q//读字节程序9 c& N/ i. I! p4 M
char s_read_byte(unsigned char ack)* a; Z2 _# H9 X) q* x
//---------------------------------------------------------------------------------- X$ L/ v2 _& m/ f( F" W
{ 8 ~& R0 a* h; U% q
unsigned char i,val=0;' o" h+ |0 [$ R) j7 F/ w& _: f
DATA=1; //释放数据线
/ Z& w$ r N+ i5 s$ Y* ~ for(i=0x80;i>0;i>>=1) //高位为1,循环右移
0 t% e C2 Q$ l) K2 d { _1 y5 j d8 I8 V: Z* u/ x+ n) P4 ~
SCK=1; ( m9 I- D9 z2 L1 k# s0 V; X2 W% ~% D
if(DATA) val=(val|i); //读一位数据线的值 ) ]: T$ w Y" ^& k; S
SCK=0; * C8 @' ]! I# r& a- z+ s, D
}5 H3 g/ [' R$ V5 R: Y2 n
DATA=!ack; //如果是校验,读取完后结束通讯;7 h3 Z5 W# X: d# R0 w
SCK=1;
5 p3 E/ w! l9 s& \' R: n4 I! @, \ _nop_();_nop_();_nop_(); //延时3us 8 B: R$ N3 p, J5 _
SCK=0;
& O/ @& W3 G; R; f C) q4 N _nop_();_nop_();_nop_();
: D9 G! c7 c* S! J5 C DATA=1; //释放数据线
' F: p1 j0 o& s$ I& _1 Z return val;
1 i+ I6 ?1 t( G" A1 }$ p) Z- S) u}
/ m: l/ B1 K0 X2 B; r# y1 o+ {
+ } r' o, y7 n- h# J/ {% B: H( p1 V: ?7 v3 i+ k. P: C" [
//启动传输
# n8 w& C- t7 o0 M4 m: ~1 f+ Y& xvoid s_transstart(void)
6 e. ~; z. X& g8 c1 M. e// generates a transmission start 4 l# S" @+ F4 Y. @3 L$ y6 a% y
// _____ ________ K. x# J( T9 `5 K
// DATA: |_______|/ T9 O1 S0 K* z: i
// ___ ___
. C' p j, E$ o! M ~1 D// SCK : ___| |___| |______- o* v6 H4 ?5 }, f
{ 2 [/ y8 V c' Y' |# d
DATA=1; SCK=0; //准备- V/ S/ n7 K2 [) i
_nop_();
0 [7 K- v5 }$ {# ]" b SCK=1;
! [( J: ^9 h/ T- X0 { _nop_();& I8 ?, C. h: v
DATA=0;5 E ?$ c# J2 D$ P1 y+ \( g: P
_nop_();
" f i) @5 s( @1 e6 X SCK=0;
}. J( {( m& j' Z _nop_();_nop_();_nop_();
7 H# m& r0 V, C$ B5 ^: h SCK=1;7 U2 _5 n7 {7 ~+ `; l( E
_nop_();
$ ?7 x7 ~3 y0 r/ y% U DATA=1;
% d5 N- P, c2 w _nop_();* x7 [& y6 J: I, W! f( \8 v$ {
SCK=0;
$ E& Y! G4 z$ w; z+ O}
- l+ C0 V n n# _0 }) @" D/ ^$ @
3 O$ @7 v# _) p7 H j7 U G- c `/ W7 e& `8 ]# ?
1 T7 q5 E8 k' T* L( H
6 C, o, S3 ]& }: W/ C; L5 c//连接复位
. J$ n3 q' r. r" c1 R4 P" {5 Qvoid s_connectionreset(void)2 j9 A" ]; J+ h' Y+ f; n
// communication reset: DATA-line=1 and at least 9 SCK cycles followed by transstart
6 ^# Y# P& F. {// _____________________________________________________ ________
& L1 v C: S2 S- T9 {' ]+ F, Q// DATA: |_______|
4 }3 w7 P. N: t! B% r3 r+ b// _ _ _ _ _ _ _ _ _ ___ ___1 W# {, t; }2 \( E
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
1 L) U1 \8 Q$ |9 Z5 G{
4 v9 N) V. @6 b0 t. ~5 X2 z) b, M unsigned char i;
2 M/ j" S$ n' D DATA=1; SCK=0; //准备4 m3 Z1 a0 F% s6 [* H
for(i=0;i<9;i++) //DATA保持高,SCK时钟触发9次,发送启动传输,通迅即复位
$ J) C8 p2 _# V4 [ {
0 B$ y0 [( V+ F x& A# O: s( _ SCK=1;
! O) V9 p! T) c. c- _4 ]7 g SCK=0;; T5 J+ } i- n1 [8 ?& G
+ l; _7 N ~' V8 `4 a1 P s_transstart(); //启动传输
/ C- K. ^' x$ {; i" {}& u5 ]0 \, g% y$ H+ D, N8 @
. j8 ^+ j$ u% a G4 e
/ p, l7 @" F' n! g
1 C3 d; P3 @7 ]( i% E' i* V3 Q3 Z {1 G$ X/ w* j# r
//软复位程序
2 y: d4 @( p' h- b9 B8 ichar s_softreset(void)) ]) ^7 `, q( ]+ Z+ p
// resets the sensor by a softreset
: \. _4 `6 K" k; G6 z! @4 B' _{
, `8 U+ K$ ~" S; j1 ~ unsigned char error=0;
" p5 E/ ^/ }8 F7 Z& n6 e; Y% q- x s_connectionreset(); //启动连接复位4 W7 }; e9 v3 J
error+=s_write_byte(RESET); //发送复位命令
5 `: _. `* x l0 D: ] return error; //error=1 通讯错误 y+ y1 z- L% b
* B1 M9 m2 c- t6 f) v1 B F
$ j- S& g# ~! B% {" K" V3 J& [4 I/ X- I% p3 N1 C7 K* a' n" B# K
5 b7 B- x& P8 A+ K
8 s' W' ~ B6 J3 i: q/*2 J) v0 B% t5 [& v0 Z
//读状态寄存器! i0 E% L) p2 e: [# x: W$ y
char s_read_statusreg(unsigned char *p_value, unsigned char *p_checksum)
0 ?$ z- q# g# I# U+ A4 l2 S9 m//----------------------------------------------------------------------------------% N/ U& x8 I& Y2 D. q9 ~- J
// reads the status register with checksum (8-bit): ~) X# ^) z" q
, g: H7 z5 H; F( A3 W2 [ unsigned char error=0;
( {2 M$ s; j4 k s_transstart(); //transmission start% {' c* v R! L1 I& O3 O
error=s_write_byte(STATUS_REG_R); //send command to sensor
. s8 o1 |* }! t; ]; e# I *p_value=s_read_byte(ACK); //read status register (8-bit)
/ X u$ k) w5 r' m6 Z *p_checksum=s_read_byte(noACK); //read checksum (8-bit)
: p4 Y: \* w4 u9 s return error; //error=1 in case of no response form the sensor( [0 | \: z3 n% v1 B5 Y9 L* f
* f6 n) y' ~, ?$ W, y9 M5 T0 z
& M+ A2 e9 q3 O
+ u2 Y; V; j) p//写状态寄存器7 m. Q5 Q0 G! S. Z/ c8 m
char s_write_statusreg(unsigned char *p_value)4 d" G2 ^9 j# W' J8 Q- Z1 w5 N
// writes the status register with checksum (8-bit)$ ^* A1 n' B% m* Y% Y
( x' x, _" x+ L( I7 P5 Q unsigned char error=0;
/ r1 @% j3 I/ C) s& _* x s_transstart(); //transmission start
5 r; |8 L$ D3 h error+=s_write_byte(STATUS_REG_W);//send command to sensor, E7 V, T! s2 P: d
error+=s_write_byte(*p_value); //send value of status register e$ [. R( o5 n: Y0 j3 ~
return error; //error>=1 in case of no response form the sensor, x- y3 U# j6 Z3 }! }! v
} */ . S: P% f S+ L5 h
% G: ?, e! e& p! K6 {
. `* Q1 P6 D6 |7 e2 ?/ ~# n' I
8 {* d- H4 ~# N. I. f1 W& q [
//温湿度测量
. P. U- Y4 J5 }char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode)$ u2 j- o2 A* I1 R
// 进行温度或者湿度转换,由参数mode决定转换内容;$ Y$ u/ u. O- a; }- ~1 g
{ + \) _5 ]' T, J- o# M
// enum {TEMP,HUMI}; //已经在头文件中定义# y& G* z5 E$ z( X: b" K2 J
unsigned error=0;6 q. y8 n8 U0 i( @! F+ ^/ n) z
unsigned int i;
, `+ C1 U7 }# y0 P- I% z5 `. `9 Q1 P0 ^3 s& v2 @8 ~0 F
( a& S9 ?& w; H; _" f
$ y+ a( \3 l2 G. c switch(mode) //选择发送命令
5 Z- |8 E& w7 p4 w {
. z4 t+ o/ j3 Q8 ?6 c& i2 _' ^, C. J case TEMP : error+=s_write_byte(MEASURE_TEMP); break; //测量温度
$ @: s3 ]3 s" K case HUMI : error+=s_write_byte(MEASURE_HUMI); break; //测量湿度* T, u' _6 P0 [
default : break; 3 n5 T- U- N2 {+ I6 v
}/ ^+ h% { U* g- v
for (i=0;i<65535;i++) if(DATA==0) break; //等待测量结束6 w+ y$ x9 N+ d% R# \ Z7 N
if(DATA) error+=1; // 如果长时间数据线没有拉低,说明测量错误 8 k6 Y) ^0 v2 x+ g e
*(p_value) =s_read_byte(ACK); //读第一个字节,高字节 (MSB)
4 f) N% D# h# j1 [' | *(p_value+1)=s_read_byte(ACK); //读第二个字节,低字节 (LSB)
" W4 z/ o& [" `- N *p_checksum =s_read_byte(noACK); //read CRC校验码
# X! q1 p! k) i R f, f' c% b/ Q return error; // error=1 通讯错误
2 K: x8 G% v8 H4 h ]3 W5 Y' ]' r}
: Y9 B2 W7 n' Z+ \' j; Q: r& H
. h5 i; e4 U. O& ?
{) ~! q% U* V//温湿度值标度变换及温度补偿' w( t! N$ S) }+ K! G* m, |" \4 k' N
4 P1 s( b. S. v6 U$ U; H2 c+ E{
4 Y/ }! I6 }# n0 U- K4 X8 x$ j4 q const float C1=-4.0; // 12位湿度精度 修正公式1 X% e5 g% b: Z+ _
const float C2=+0.0405; // 12位湿度精度 修正公式
/ T. k" n% D" c/ o5 `0 r$ W. n const float C3=-0.0000028; // 12位湿度精度 修正公式
( |. [" L. N `( m) [5 { const float T1=+0.01; // 14位温度精度 5V条件 修正公式
6 _. g- I$ {& V0 r$ V! p1 ` const float T2=+0.00008; // 14位温度精度 5V条件 修正公式
8 v- S: W9 Y) H; v: l, I. o+ b8 l, w P$ ? f9 l5 i
! @* n! e+ R/ F) f+ y: f* W) w) w float rh=*p_humidity; // rh: 12位 湿度 ; \1 x Z. }% I8 }( }
float t=*p_temperature; // t: 14位 温度8 F o) {, s9 t8 \8 E! {0 G1 m
float rh_lin; // rh_lin: 湿度 linear值& l) ^* c' P7 y! Z8 i+ P
float rh_true; // rh_true: 湿度 ture值
; E' ]. _7 q ]- s8 s float t_C; // t_C : 温度 ℃; H3 S1 H! W2 x) e0 |' i; ?0 M
# P) Z" }3 A% I% R: U: B. U$ t
: ^; m8 v% J& k. c t_C=t*0.01 - 40; //补偿温度
# F! J n8 |9 s rh_lin=C3*rh*rh + C2*rh + C1; //相对湿度非线性补偿
; g2 G9 G1 ^. K! e W; r rh_true=(t_C-25)*(T1+T2*rh)+rh_lin; //相对湿度对于温度依赖性补偿
! x: w: Y" Q: J3 o* B% z if(rh_true>100)rh_true=100; //湿度最大修正( H2 s ^$ f5 x2 t5 I
if(rh_true<0.1)rh_true=0.1; //湿度最小修正$ D2 U- y; G e: h
) r+ ], q3 ?% k: ?/ x+ n U
) ^1 a4 y" c4 [3 w# |5 }" c& Q *p_temperature=t_C; //返回温度结果, |9 R7 I y9 d. ^' u
*p_humidity=rh_true; //返回湿度结果
$ @7 X2 O4 c1 |; B/ |) i}
3 d# K7 O4 S& z& T$ t
" s' \% |: t E0 A% j6 g" T4 h7 n/ x2 w x
//从相对温度和湿度计算露点/ L+ q& k I4 ]& _
/*float calc_dewpoint(float h,float t)
& h4 t# g; o* \* N3 b{
% a) v/ m' i ] float logEx,dew_point;
3 \5 W+ Z8 {& q" n3 [' Y0 z# f% m logEx=0.66077+7.5*t/(237.3+t)+(log10(h)-2);& Q( {, L' Q8 C2 g0 v" D
dew_point = (logEx - 0.66077)*237.3/(0.66077+7.5-logEx);
E5 Q* M9 S, M3 q return dew_point;
+ C4 v4 P' {! M/ e0 g} */2 t# y9 \! M" U% U8 M w
9 b% C. t2 j3 t+ G, H
, V4 ]/ X; v+ y+ p/ o7 W/***********************************************************************************************************************************************************/
! O/ Z3 n% y6 v+ B+ o, A/ b/ u! L//1602程序
5 W* b) U$ f5 m* V- q3 [; t, C
9 t# T1 L; r# ?3 z- s; q# s# g# b: z5 H) X' {4 S: V
3 L$ k) ^0 Q) q5 ?5 }9 k# p2 K7 |
# G* [- w0 W @//内部等待函数**************************************************************
& M7 U5 Q9 S6 Y* x; C8 |unsigned char LCD_Wait(void)+ T" l* I# Q# l; } x+ [
1 b( w+ w+ ] A# `& f2 q RS=0;# S, t f8 |9 A
RW=1; _nop_();
% Q8 Y3 y% {. x" j$ g- }& S& v E=1; _nop_(); - t0 r( a* s: l. l0 i7 d
E=0;
% k7 U3 ^0 m+ m1 B7 u/ W+ W1 O+ j return DBPort;
% n$ Y8 C" y7 U8 o# }0 f}; D W0 K$ {) g+ Y* U/ L. _
//向LCD写入命令或数据********************************************************
- _) f: M& @$ w) d Q) d#define LCD_COMMAND 0 // Command" C A0 y5 Y9 A& d& [ b
#define LCD_DATA 1 // Data
8 w5 g* n7 d7 i1 ] p, \) C3 Y2 |+ o#define LCD_CLEAR_SCREEN 0x01 // 清屏
) `+ z' V h5 E, @# L: d#define LCD_HOMING 0x02 // 光标返回原点
$ D( V0 C9 P, K$ I7 G9 pvoid LCD_Write(bit style, unsigned char input), \7 Z, n& {+ g8 D3 i
{. y. \( H4 `6 {, V! J% K& n
E=0;6 C1 U- r; e# ?' K7 d
RS=style;3 K9 [$ d7 _/ C
RW=0; _nop_();% k& n$ g6 m- j& z, X
DBPort=input; _nop_();//注意顺序
! U( y" J; J$ X% l3 P E=1; _nop_();//注意顺序
* v2 M- W1 G0 h* [ E=0; _nop_();
+ C" c' b0 A2 u; B LCD_Wait();
- D" y# j+ {; c5 y+ @8 y5 ?7 y& g}
, t3 o& @; {& d1 g) F# o7 }& T- q- Q- L
" X ?* J: E" ~ m4 v5 t% z
//设置显示模式************************************************************4 |& P" s, B, ^" [7 F/ G% g
#define LCD_SHOW 0x04 //显示开% m4 Q: c- l& r3 r* C
#define LCD_HIDE 0x00 //显示关
. H$ G; K9 Q% e9 O6 w; M) }
" U' s0 | f/ O0 v J! R
/ W* y! _9 O+ K2 T$ h: [- m% q' \#define LCD_CURSOR 0x02 //显示光标% L, J" T9 ?4 E9 b
#define LCD_NO_CURSOR 0x00 //无光标 . z+ e1 H8 G. F: J4 R* a- O% `
" b$ S4 }" X8 N
6 K' V$ J' W4 D7 I' K
#define LCD_FLASH 0x01 //光标闪动7 ^- [/ H1 a3 b y0 `; g' C
#define LCD_NO_FLASH 0x00 //光标不闪动
* g) ?8 y$ E+ O* _5 d9 J
0 j2 j' Y t6 W* U3 P
W, n( o6 e' c- u9 mvoid LCD_SetDisplay(unsigned char DisplayMode)& N$ C" a4 `# |! ]
{, q0 z7 d3 t! R( r
LCD_Write(LCD_COMMAND, 0x08|DisplayMode); 8 ?* t; b4 i6 j1 A6 [$ B. L
}: f6 z9 S* m+ @4 y( `' G& g6 Q
2 P) M' k7 f; t9 k. F
* e! O- O; H4 k0 c1 ?//设置输入模式************************************************************# J2 N$ b8 v! }2 h
#define LCD_AC_UP 0x023 C6 j8 H: d* C! q, ]5 \! y' r
#define LCD_AC_DOWN 0x00 // default
1 J4 O/ y& W5 B3 Q1 J
0 X- z4 D" Z: }: L O5 \* c* r
7 F8 R2 t( r8 U3 D: ^- F) r#define LCD_MOVE 0x01 // 画面可平移 u2 d& `+ f2 a' _" E8 X7 v
#define LCD_NO_MOVE 0x00 //default9 m4 a- O* Z' y R
& [. J5 T# |( }! j3 U
/ z) w/ g! A5 ^2 O- Y! g; t5 rvoid LCD_SetInput(unsigned char InputMode)6 t( m1 h( Q2 g' A$ C: ]
{5 N/ V! @8 B8 \% {
LCD_Write(LCD_COMMAND, 0x04|InputMode); |4 T0 C. R3 D4 n) o+ R( y
}" P, r6 G" R! h. m- q ^; R
# W- [& E y5 j( ]$ J. {) l& W. }4 n5 H2 D* x) H- Z6 E2 T- c) a
//初始化LCD************************************************************
3 n U- C6 u# P* {4 Bvoid LCD_Initial()! b9 b( M; I3 l: G
{" ~' e3 }. U6 k# z4 A
E=0;( W2 y! O1 e; E" U$ e4 Q) O' f. L
LCD_Write(LCD_COMMAND,0x38); //8位数据端口,2行显示,5*7点阵
: g A% M6 I4 L. l LCD_Write(LCD_COMMAND,0x38);
w& ]& z' A; J! W) ^ LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //开启显示, 无光标
/ I8 P9 s( A9 ?' F/ z LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏
; b) h: H& d$ V' X) s4 ~; W' g LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //AC递增, 画面不动8 `- K- {+ {1 A+ K! F1 K- _# n( I
7 \1 t% j% H3 K' \5 j2 M& Y4 m' R8 ^, r, w4 d
$ _! ^0 A8 U& S5 P. T
//液晶字符输入的位置************************
e+ }( {! Y6 D: j1 r0 T1 Bvoid GotoXY(unsigned char x, unsigned char y)4 t$ e0 N$ Z; O. z
{7 e( K% I- ]+ h$ K
if(y==0)* j! F+ f% B4 _2 u
LCD_Write(LCD_COMMAND,0x80|x);
# Q M' C7 k: M# n5 _! T if(y==1)# @+ r5 r5 y2 }9 S0 t" w
LCD_Write(LCD_COMMAND,0x80|(x-0x40));
) w2 F% e8 N! C2 N}
2 P2 \3 z! N1 t& M6 I0 A7 C' R- Q# D0 T5 ^3 N: n1 k9 d5 X9 s ~6 l
8 r/ C6 S5 N2 G3 V! k
//将字符输出到液晶显示7 N2 q ]5 r# h5 j$ y, E, n0 m
void Print(unsigned char *str). V# |$ N' [) a8 Q
+ T0 H5 `# T; S7 E1 Y0 ]$ ^ while(*str!='\0')
% {, ~. P) \+ V8 [! W+ t {
- h5 P4 _& w: t% U; I# b9 y: o% b LCD_Write(LCD_DATA,*str);
6 ~' \3 g: g$ D3 t str++;
3 A6 K. U! }7 J: @; } }
3 N$ M# Q S8 [9 I% `+ i+ q}$ w* W0 j$ k+ k0 w" P! t9 ~3 w' C( j
) N3 f6 O, P1 @& {8 R$ ?1 Z2 l' R9 E4 v: X
* t1 C6 z4 |$ Z& y$ H
+ j' \9 q- e7 ?* I$ p& x1 @
( j- {! w. V- d0 D1 w* K1 I, ~+ N/ ^
- z1 Z4 ]; r3 E1 C
//延时函数
" j6 P4 D( g, rvoid delay(int z) //z为毫秒数
: T1 A7 J! R; e W8 d% j{, ^; K& t4 E, O/ o" g& d; |
int x,y;/ |2 A; f E9 Q
for(x=z;x>0;x--)
5 [& J0 y( v$ w6 w7 L2 L for(y=125;y>0;y--);9 ~! N8 o) h6 {) D f
/ c. P- ?; W1 ^5 [0 A' S z
2 G9 r' ~ z* @4 g
' Q8 t5 V, C7 C6 F/***********************************************************************************************************************************************************/9 h! {* @+ Z$ e( w+ k
//主函数3 l8 M' y9 O8 |/ S; B
7 L/ l, P$ U2 q4 }% Q6 [ l* ]! n. f1 i
void main()4 p/ Y( T' R [; b- X% S/ M2 ]
{ : J, F: P9 r* A. @+ U5 O7 p; r
unsigned int temp,humi;
3 N- S& \% ~. h( u7 i& G value humi_val,temp_val; //定义两个共同体,一个用于湿度,一个用于温度
' E' J( b5 I0 {/ q// float dew_point; //用于记录露点值 l3 R+ v6 a+ i3 X! q
unsigned char error; //用于检验是否出现错误
, k9 P9 p: ]. R& s unsigned char checksum; //CRC : I [. {8 o: k# p9 v
uchar TEMP1[7]; //用于记录温度# [& Q4 K" y. @
uchar HUMI1[6]; //用于记录湿度7 t- G4 Y4 N7 J9 g, ]$ M- V0 s
& r% `; U5 e6 W* [; R
$ c2 I: C$ ^; P+ g; E P* J' Q8 [$ d) a/ \: E5 k
7 F$ b5 M; R3 ~# d" ~9 Z4 Q7 t+ Z
. a6 N- [' S, y# z" a3 b8 R& L…………限于本文篇幅 余下代码请从论坛下载附件…………
5 o. q; Y+ S; F, q8 b ) v4 B- P" V; a2 F$ }2 W
下载:
0 X7 k7 H: F7 w6 n( U; p! {+ I
7 X( d6 ^- J* q9 ]; Z
( s8 M9 v' k, y& P# n |
