查看: 477|回复: 1
51单片机驱动2.7寸tft液晶源程序
发表于 2019-1-4 08:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51单片机驱动2.7寸tft液晶源程序2 m, g  F( i. G/ N( o( k
  a* s0 [+ t! F7 p- G5 `
  G5 J) w8 l- g$ S分享一个51单片机驱动2.7寸tft液晶
! u+ |: f2 Y) I" @0 \9 q1 c
+ g. r$ g+ Q, F% ~" @2 Y) _- Y1 V
; w5 n3 H  d- \+ \0 Z8 c
( v2 M/ I6 A/ m5 \9 G* ?主程序:
) k+ ~7 V6 n$ g( V! U2 I#include <reg52.h>                                              * U/ R5 x' b' V2 P. ~% q
#define DBL P0
. c1 r* x8 B  G- Q, U#define SWITCH_TIME 4000 //默认2s
, b8 O5 Z" T2 m  n  S
* v6 C# J! k5 \8 w2 funsigned char a;
) e+ T8 L" O9 ]2 w2 Funsigned int pic;) W) I/ t$ l6 q. v& o
bit delayflag=0;2 }; d8 a7 a( a2 D6 j6 _5 i& W
$ P5 E& U, [1 X7 j/ d% w/ |void Initial(void);
. M. B  K* T+ ?void Write_Command(unsigned char RegisterName);! s8 D! |" A, R& d6 b6 Y
void Write_Data(unsigned char RegisterValue);
" i' N; Q0 S" f, A( kvoid fill(unsigned char dat1,unsigned char dat2);2 n" m/ y- \' w7 r+ E
void Delay(unsigned int count);: u! h: P4 L% F( V
void pane();+ K+ y+ T+ y$ B: J, R
void showpic();4 W% n3 t' n1 c, G, p
void pictrue();$ T' j" p' ?$ M- a4 [4 l
: v  F3 |- h# O2 j& C# q$ z9 Hsbit CS =P1^0;; E7 x  |* E* b( z3 F- `
sbit DC =P1^2;
9 W0 C8 e' k, ?sbit W_R =P3^6;
% L* Q  ?7 U* _4 g8 Gsbit R_D =P3^7;
+ e7 ~/ _  g( ?! ^sbit RES =P1^1;- B, P- u2 m/ v$ n5 k$ e# o
4 v2 X7 z8 |; k. n, V' j" b# |sbit SCLK         = P0^0;                        // Serial Clock Input4 S' T1 {  K8 H  y
sbit SDIN         = P0^1;                                // Serial Data Input
& Q: j( Q0 d1 r: |: e" z5 d2 a
/ J! {% T5 K! {6 w* \8 C) Z2 Isbit key_stop = P1^3;//按键,按下为0暂停循环,松开为1循环跑动
; h, v# S" n! f  J3 N- n8 Y3 S, Zsbit key_mod = P1^4;//并串模式切换按键,为0串行模式,为1为并行模式,仅在程序开机时判断9 r/ x( o1 [  w: s
* q( l6 I: W$ {  l2 r
bit mod_flag = 1;
2 }! N* _* B% o+ H0 Y- a$ r! w- `$ P( a( F  H& X7 Y6 i/ V( [0 k! ?7 t/ Q6 V
' d: o! H) G: i
) ?& X3 L) F9 m3 B2 @! |9 Y. fvoid Delay(unsigned int count)
" z2 R& F8 N$ S1 Y* D% v{
% Z3 K" `1 V/ A! R. U+ z" I% R, C        unsigned int i,j;: Y1 G4 i, J0 J% y# s
                for(i=0;i<count;i++)* I0 ^8 W- B1 l
        for(j=0;j<114;j++);" c/ u! V! u/ y2 E
0 ]8 c+ r& |1 J* munsigned char code show1[]=
, {5 A  M1 _0 D( k. m{
$ x  C8 U6 u, u6 _+ l% |0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,9 m" L7 I$ d' P! L& U2 k
& Y2 O5 r( }( Q2 v7 O- _0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,$ z; B! l. F2 w8 M7 d  m4 e6 ?
% [9 h) {3 c  q* e! m0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
& U6 Q* t. @: a* B: `2 U; T0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
2 \6 A6 f# D+ \# a. h0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,& L5 T* Y* J4 |
. L& N1 V# @. c6 @0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
3 a" P0 i1 R' A5 \' J0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,7 f& l" U# D- b& }, S/ j" q' U
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,) K3 ^% F* t* v  X/ ~. Z# h; F
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,: Y* w8 E- T9 B& W  q6 D+ [
" o- j% i  E9 U0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,' \2 y- c5 ^( ^% A+ h. R$ [
2 }! U# Z. p3 R+ W# V$ j0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,+ f& r% i$ S; S8 V. `$ f
/ o  [2 S( ?* V0 A; E0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,0xFC,
" [) @* @+ C* b4 T+ z0xFC,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xC0,0xF0,
- @6 x* Q2 M( P. D$ w6 z( l. y/ c0xF0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x80,0xC0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,. M" I' Y3 y2 @7 Y( e) M. y$ H
0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,( [# n# |7 g5 A
0xF0,0xF0,0xF0,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,0xF0,. V. e* K% J1 E; V, R
0xF0,0xF0,0x00,0xF0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,
1 g# Y, p, @" y0 k0 [" x. W3 x0xF0,0xF0,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF0,0xF0,0xF0,0x00,0x00,0x00,0x00,9 v1 Y# n* P0 R, w
0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,* f" ~8 a6 y9 Y
0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xFF,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,* e2 k  G/ K+ V" q, p; H
0x7F,0x7F,0x00,0x00,0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0x7F,0x3F,0x1F,0xFF,
, d9 o! a4 g" s* D) D- H) {" B- \0xFF,0xFF,0xFF,0xFF,0x01,0xFE,0xFF,0xFF,0xFF,0xFF,0x07,0x43,0xE3,0xF3,0xFB,0xFF,7 q, N, C) s& @; A" R( q7 ~; R
0xFF,0xFF,0xBF,0x1F,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0x43,0xE3,0xF3,0xFB,0xFF,0xFF,
# B: u" K; v0 y+ ^  j0xFF,0xBF,0x1F,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xC3,0x83,0xC3,0xFF,0xFF,0xFF,
" N3 k) x4 f7 V" O: B; f% ^0xFF,0xFF,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFE,0xFF,0x7F,0x3F,0xFF,0xFF,0xFF,
1 C# U  Z1 J, m" Z( j0xFF,0xFF,0xFC,0xFE,0x7F,0x7F,0x3F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x00,0x00,
7 O+ B9 U% O4 ]3 P) F0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,) P. V& A' P( [- u  p
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
* J2 P5 z+ z3 P; r" j0x00,0x00,0x00,0x00,0xEF,0xEF,0xEF,0xEF,0xEF,0xE7,0xE1,0xE0,0xE0,0xE0,0xE0,0xEF,. [; h" a# J0 N( B5 `; Q) }& i
0xEF,0xEF,0xEF,0xEF,0xE0,0x0F,0x0F,0x8F,0xEF,0xEF,0xE0,0xE0,0xE0,0x01,0x83,0xC7,/ w0 i. C. ~, C( {
0xEF,0xEF,0xEF,0xEF,0x0F,0x0F,0x8F,0xCF,0xEF,0xEF,0xE0,0xE0,0xE1,0x03,0x07,0x0F,
# [# c1 R2 H) }8 z, ?! p3 V  N0x0F,0x0F,0x0F,0x00,0xEF,0xEF,0xEF,0xEF,0xEF,0x0F,0x0F,0x0F,0x0F,0xEF,0xE7,0xE3,
. X% w5 ]' s; S& e) j& h3 e0xE1,0xE0,0x00,0x0F,0x0F,0x0F,0x0F,0x07,0x03,0x01,0x00,0x00,0x00,0x0F,0x0F,0x0F,0 t5 J2 K  Y3 ]# x' d
0x0F,0x07,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
7 L6 f& D2 {, R) T/ f0x00,0x00,0x00,0x00,0xF8,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  ?* q3 r6 K2 ]) _$ y, n* r4 y* k) ?0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,6 V" s% t4 m6 \: b
0x00,0x00,0x00,0x00,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,) R; n$ ~( {6 T2 _) q. R0 T  {, b
0x03,0x03,0x03,0x03,0x01,0xFE,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xBF,0xFF,6 \3 ~0 u' |; g9 N2 c; W. G
0xEF,0xE7,0xF3,0xE1,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0x87,0x83,0x81,0xC0,0xE0,0xF0,
" T6 u0 d, \- B+ e* m0xF8,0xFC,0xFC,0x7C,0xFF,0xFF,0xFF,0xFF,0xFF,0x7C,0x7C,0x7C,0x7C,0xFF,0xFF,0xFF,) m/ c  D& @/ m" R/ b' g) z5 n. l
0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
( L2 Q: |1 K) W4 J1 ~3 o! i0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
5 p9 W% a1 I8 z. \0 Y1 Q0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x0F,0x07,0x03,0x01,0x00,0x1F,0x1F,0x1F,
0 W( s3 Z8 L5 q3 h4 U0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
+ s3 l1 o( \; l- z; g- s; C" H0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x00,. |7 m8 ]" C8 x! G  M+ V2 d
0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
4 ]7 H; D: w) B4 @5 i  }0x0F,0x07,0x03,0x01,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x0F,0x07,1 {0 I8 f/ _& n, `
0x03,0x01,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F," m; Q/ H" L  O  Y
0x1F,0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
2 q6 K: E( b9 P: F0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,. `7 u6 ?' b" }! K. j* d
* S1 b7 G! ~3 f% Y0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
% F0 y: N1 H+ N" K0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,7 g$ v% l# O- `, v. j7 f, h# ]
& B1 O3 O. ~! J* j/ c) u0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,2 O7 H/ [  X9 ]2 S$ O
0 ?2 T& t8 h6 G0 p0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
9 C  h6 I& i0 N5 y8 p1 w& J6 z0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
8 a$ A: x3 M# d/ I1 R6 v};
6 j% `8 X  `+ c: q* ^unsigned char code show[]=- F6 d) R/ \8 E6 W$ w  j  X6 T
{4 U( N- `; T0 q7 |# o, x
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x08,- m' U8 N/ Y# L( n
0xA8,0xA8,0xA8,0xE8,0xA8,0xA8,0xA8,0xA8,0x28,0x00,0x00,0x00,0xC0,0x08,0x30,0x00," C. Z8 X4 @% @
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0xF0,0x00,0x00,0x20,0x20,0x20,0x20,0x78,0x20,
8 |  Q: {5 w! E0xA0,0x20,0x78,0x20,0x20,0x20,0x20,0x00,0x00,0x60,0xA0,0xA0,0xA0,0xA0,0xA0,0xB8,: ]0 N+ Z( F2 R$ k: b3 Y' \
0xA8,0xA8,0xA8,0xA8,0xA0,0x60,0x00,0x00,0x00,0x10,0x60,0x00,0x40,0x40,0x40,0x40,
2 C. N" @- y) _( |& F2 ~0xF8,0x40,0x40,0x40,0x40,0x00,0x00,0x00,0xC0,0x40,0x40,0x40,0x40,0xF8,0x40,0x40,
* T; f* N1 p& i2 k+ x1 S# U+ }0x40,0x40,0xC0,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x88,0x48,0x28,, V- P0 P/ Q, U# ^" P* Z- {0 u( S8 `
0x18,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
3 y7 q' K* U% C4 g/ t# A# [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0x00,( ~* {; q# ^! g( l$ W% Z  d
0x4F,0x2A,0x7A,0xAA,0xAA,0xAA,0x6A,0x2F,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,
# W/ ^3 J- e; c  s0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x10,0x10,0x9F,0x91,0x51,0x31,- H4 L6 O& A" `/ f
0x1F,0x31,0x51,0x91,0x9F,0x10,0x10,0x00,0x00,0x08,0x0A,0xFD,0x54,0x56,0x55,0x54,6 p& u! N- R# x. R
0x55,0x56,0x54,0xFD,0x0A,0x08,0x00,0x00,0x02,0x82,0x7E,0x80,0x20,0x10,0x08,0x06,2 j2 Q/ D1 V/ A: \( N% d7 {; G
0x01,0x02,0x04,0x08,0x30,0x00,0x00,0x00,0x3F,0x12,0x12,0x12,0x12,0xFF,0x12,0x12,$ i( T5 M; m# h; m8 c5 b
0x12,0x12,0x1F,0xC0,0x00,0x00,0x02,0x02,0x02,0x02,0x02,0x02,0xFF,0x02,0x02,0x02,8 }5 G( h+ l2 b+ s
0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,# i( ~. X  @9 t2 \# l, `6 r7 q
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x01,8 o5 Q! f, }# Q* ^" r- S
0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x00,0x00,0x00,
0 K, [8 q/ o( _. `6 m2 N' q. z0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,  I8 F, L* Q/ [8 W7 i. [
0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,
4 }( ]7 A9 m" s9 n0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x01,0x01,0x01,0x01,
2 O; M5 \. e, r- b5 Z) T4 D- @8 d0x01,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,
' h9 m9 A6 m6 i. Z# H# i$ F' m) P& H0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x00,0x00,0x00,
, u6 J6 I3 c0 p5 j/ C% p& Z% g4 G0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
7 j: V* U) f& Y9 b# Q0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x81,0xFF,0x81,0x03,+ {* e" L6 g& m* j8 e
0x00,0x81,0xFF,0x89,0x9D,0xC3,0x00,0x81,0xFF,0x81,0x80,0x80,0xC0,0x00,0x80,0x00,
2 j2 ~- E% y( V. p0x00,0x00,0x00,0x00,0x00,0x84,0x00,0x00,0x00,0x7E,0x81,0x81,0x81,0x7E,0x00,0x4F,. z4 l" q3 C5 c% B" ]2 I
0x89,0x89,0x89,0x71,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0xC6,0xA1,0x91,0x89,0x86,+ G; l. }& w( a; C, X* x# v
0x00,0x08,0x08,0x08,0x08,0x08,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x03,0x01,0xF9,+ K/ V% B( c; _) L
0x07,0x01,0x00,0x00,0x82,0xFF,0x80,0x00,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x00,
# |* i, t  i- i! I0x82,0xFF,0x80,0x00,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x7E,0x89,0x89,0x8B,0x70,1 O6 z0 k# H! J& t
( H7 s$ P6 K0 h1 H1 k& {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  F: B1 C0 F! m3 w4 ]$ G9 K& o
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0 C3 T2 N: F8 ~; U- n* @& z
$ c( }5 }) t+ c; Z) a% p0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  u+ A% e2 l; U0 W1 \0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- t3 {& c/ h6 i+ D5 V! D0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
, t# h5 j; g8 [/ U# Q# t9 T6 R0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
' P. J5 h3 D5 e" K. k/ J; x0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
: v# b1 E6 Q0 y0 P5 s- U0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x81,0xFF,0x89,0x1D,0x03,; U/ z7 A/ F0 a% Q3 D
0x00,0x80,0xF8,0x27,0x3C,0xE0,0x80,0x81,0xE7,0x18,0xE7,0x81,0x00,0x00,0x80,0x00,
$ O9 \4 C6 C- ]1 D0x00,0x00,0x00,0x00,0x00,0x84,0x00,0x00,0x00,0x7E,0x81,0x81,0x81,0x7E,0x00,0x4F,
' s" l" E! \+ s( H1 H4 c, a0x89,0x89,0x89,0x71,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0xC6,0xA1,0x91,0x89,0x86,3 b% ]5 D' L  Q
0x00,0x08,0x08,0x08,0x08,0x08,0x00,0x42,0x81,0x89,0x89,0x76,0x00,0x76,0x89,0x89,* ]  w. H( v; j8 V/ \
0x89,0x76,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0x4F,0x89,0x89,0x89,0x71,0x00,0x0E,
$ g9 M9 d/ y/ T5 L3 A0xD1,0x91,0x91,0x7E,0x00,0x0E,0xD1,0x91,0x91,0x7E,0x00,0x4F,0x89,0x89,0x89,0x71,
8 V+ p+ }' o9 n3 M; q0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0 D0 Z  M  r1 `3 n
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,$ Q, c' {# n/ U6 ]: ^; E: w
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,1 I; V+ B5 W& b! F: L) v* ~
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0 M9 T$ D6 w0 h% y' d' u, ^
4 y+ C; O, @! b* ^0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
* f( y! i0 ~9 ~: i6 ^$ C& a; \0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,3 w% L/ c5 M6 @
* Z  R3 \" r' z( M, [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,, Z% F9 e+ m' e) B
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,: m4 _8 _* ^% V# B+ Y- j
% [* k1 c9 L, G! p3 M3 \$ W  }0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
) W% ~* W6 D& \6 j* h; C% S1 V0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
6 \3 I) y1 |8 L0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  t3 }  N! _9 D
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,* E# M6 u3 y9 ^8 g! a
  P' I! t5 ~  v! \+ Q0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x000 w4 ~' r  q: |& z, z) M7 g" c2 Q
8 D+ P1 z% X3 ^+ Y6 u) \* \$ M1 u; I( o& F+ C" C1 |
# z  b, {' V' u5 w2 T" @0 \
                                // 8-bit 80XX Parallel+ f0 K* N$ }1 ?3 O# g
void Write_Command_Para(unsigned char RegisterName)
5 s8 b& f& q1 t1 q: t5 }* ?. g{
& |: Q& A  M: H( G) I3 ~4 {        CS=0;: T1 M7 k* o; K* o* P( a
        DC=0;
8 y2 ]* p- A8 ]4 V& H7 V& u" N        DBL=RegisterName;# r4 E5 Y. E/ o% H' y# N7 o
        W_R=0;' ]3 b; q5 r5 [$ v4 N8 S( h/ V
        W_R=1;% `1 i% N  _3 I
        CS=1;' r. p2 C0 Q$ a1 t  R3 B! ]; D
}! K: @1 T- l# e3 g' B
# q' f* c, I3 o4 e, J0 K/ qvoid Write_Data_Para(unsigned char RegisterValue)4 T. y0 O/ ^' g4 q# I5 [
, B0 X- e+ G$ }6 E) O, L        CS=0;. `, g9 E) f) a. X5 T$ ~
        DC=1;
1 y5 ?$ g6 q$ H: l5 ?! w        DBL= (unsigned char)RegisterValue;
. g/ n7 K2 r/ \, ^; b% g+ x        W_R=0;3 ~( h8 M( y7 @4 F; u" _1 p/ k
        W_R=1;6 n+ K1 Z0 V6 J' y# _6 \8 l9 b) k
        CS=1;: r; p, A. k: h. v+ Y
}8 ^& y; z; j: j& p, K( H/ Q7 M
1 f6 x: e& l8 @) t: w                                // 4-wire SPI
( \7 N: D% [; @void Write_Command_SPI(unsigned char Data)
( B( ~8 O2 `) c+ {& v{
# t0 z* I/ h( e1 Z" V: t2 S4 eunsigned char i;
, L8 o: E( r$ _1 C6 Q; X! x! @& N
4 s" o! h8 f) {        CS=0;
5 A( r8 k1 \0 f; O        DC=0;* u/ s* e  R! x  l: _: c
        for (i=0; i<8; i++)
3 c8 R" b, t2 N/ r        {7 d& U4 b! l$ T7 @# _, k4 t6 l* ~
                SCLK=0;4 y: p7 D$ P' T/ c; E; t
                SDIN=(Data&0x80)>>7;
! O8 H( y% X, @9 P7 u1 y! I                Data = Data << 1;* f4 C9 o! Z) \8 I4 ~6 n1 w
        //        uDelay(1);
  I# h- G. N3 V$ C                SCLK=1;
& i+ V8 u/ Y- l3 I! V$ H        //        uDelay(1);, f# w( C3 N% P! {3 h
1 T# M( w$ {" Z4 G; h7 J//        SCLK=0;
/ c: }7 G1 w8 v2 I        DC=1;
  m) m# ?4 e: i" x; C$ h  T2 W' t        CS=1;
: K% `+ H! X- j# T0 C& M& x% D}) j+ |- F) f- A" _/ V
: E; W: B7 I8 {; K5 [: ]- w
8 C* w, L! \& j9 Y( @void Write_Data_SPI(unsigned char Data)
/ I3 ~; ^6 D$ ]+ V9 K7 F+ _{
1 |. d( N0 [$ X' R9 Yunsigned char i;
, R" i4 F! L2 n$ H) J" `" h( V
( x$ Z; s, l* A+ p8 g, {        CS=0;
: `1 U: L/ q3 e5 Q0 J/ n' ?        DC=1;- J+ u/ i0 p0 R/ O% T/ Q
        for (i=0; i<8; i++)
* \5 m. N* C5 {" _! r; b% o' t+ j0 b        {
" F3 ]7 s& O( Y& g3 g                SCLK=0;
) N0 y( i6 C. y                SDIN=(Data&0x80)>>7;( ^' P  ]; w  H8 |6 I% i3 O6 a, T
                Data = Data << 1;9 P2 R+ w# P. ~  ?" H  U$ p( A. Q/ C
        //        uDelay(1);
1 r1 B5 |7 e9 u) m/ p6 x* k                SCLK=1;& \/ T, c% C* b# b
        //        uDelay(1);: `! G- \$ D9 J! J" H. J
        }  v; d* U) T8 I/ c9 `
//        SCLK=0;
" j5 P6 H/ W( N# n: e& Y) ^% p        DC=1;
! n  A9 r; ?# j        CS=1;: B& u" g+ J0 ?$ ?
}; [& j( l3 P; S; p8 K1 D2 c9 w& d
* q5 x: v9 c8 F+ o- x2 t- P* J
1 L, C0 e  q$ ?/ k{
$ D5 H- r5 S; ]6 i$ x        if(mod_flag == 1)9 \3 x/ V! t8 i4 Z# @/ j* H# [
2 @6 z6 i7 S0 a; l; F                Write_Command_Para(RegisterName);
5 N5 m8 N" n. n( L# ^. }        }# t  R0 O4 A) B* Q8 l/ ]4 n
        else2 s8 ]1 K3 `$ n& b
        {1 S6 V5 t$ C) ~% a' C
                Write_Command_SPI(RegisterName);4 }4 g3 T/ c  l% V  R9 S
        }) @! P" p3 l7 ~, I* |3 l. u9 p* m
5 Q/ f* p% m, n! H8 k
        //Delay(5);
1 A& k* J5 ^. i& s  h$ t# h; H3 z: e; r8 m/ _+ X: X
' P: `. \5 B* o//**************************************/ y' i/ W; D1 k" U1 b
void Write_Data(unsigned char RegisterValue)' R$ Q4 g( H" l" x" @, i
{2 G% i% h, n3 g4 O. e; m
        if(mod_flag == 1)
/ n: ]0 j8 D4 e+ d! j8 n7 s: b        {
. a  E8 N' _& h6 m& }$ @                Write_Data_Para(RegisterValue);
8 v: v: {9 Y6 {4 i# m        }( {$ o  L! A9 G
        else, o. S' P  w% H
        {# }" m; u" Y* n9 o* b0 l
                Write_Data_SPI(RegisterValue);$ S  g; K' x& p9 H+ e  ^1 _
        }& p( Q, K+ V* D6 j) x5 |
# q5 m$ }  a+ y+ B/ U3 k
        //Delay(5);
( v$ V" h  p) m( e2 A}0 Y/ {( \0 Z3 F% F# \8 f  S& r
5 p+ I; h* c: [: p  R) `" I% \' zvoid Initial(void)
% b+ i1 d2 z1 \+ `! P  v+ w{! j2 R8 \  B# C1 }
Write_Command(0xAE); /* display off */
% j4 `" a& g) w' E( r4 W9 SWrite_Command(0xB3); /* set osc division */5 x4 G! q, r9 {; f
Write_Command(0x91); /*100 */
% o, W' ^- {9 S0 U: nWrite_Command(0xA8); /* multiplex ratio */
3 j3 `: Z! V+ z( v1 U# Z& bWrite_Command(0x3f); /* duty = 1/64 */
$ a; `" Q: X: r1 a3 E1 tWrite_Command(0xA2); /* set display offset --- */
$ K$ |  I8 }$ EWrite_Command(0x44); /* 72 */
3 {8 @. a9 g" l1 MWrite_Command(0xa1); /*set start line */7 m$ @& h1 a1 A! G
Write_Command(0x00); /* ------ */
9 _6 v; d/ h# Q1 l' W  ~0 Y$ IWrite_Command(0xA0); /* set segment remap------ */0 @5 P' X5 c& ]; A6 n" T
Write_Command(0x63); /* disable Nibble Remap */
0 i% o/ ^$ v. M5 v" N/ z8 t4 r/* Horizontal Address Incremen */, _3 D0 K  z0 `2 A1 f
/* Scan from COM[N-1] to COM0 */
3 e1 k+ J4 ^' s5 ~/* Enable COM Split Odd Even */
( p$ a- y. `# S! f: J( KWrite_Command(0xAD); /*Set Master Config DC/DC Converter*/4 T3 Q+ w, w8 C
Write_Command(0x02);. j1 y" s- F" b) b
Write_Command(0x81); /* set contract current *// h) d* U6 |, @$ e* T0 Z7 x0 Q& `6 P
Write_Command(0x40);, v) H2 e- n. t, ~& T
Write_Command(0x86); /* Set Full Current Range */+ D* T1 v4 K0 {
Write_Command(0xBE); /* Set High Voltage Level of COM Pin */
/ G4 f& y0 G" [. Y# s2 EWrite_Command(0x02); /* 0.53Vref */3 {1 w. m9 \( e; ?: Q$ M) R9 A' q$ l
Write_Command(0xBF); /*set Low Voltage Level of SEG Pin */
0 e8 e: L( B; b' S9 N+ \# J2 eWrite_Command(0x0e);
" m! v4 w  _9 X7 o: F$ DWrite_Command(0xA4); /* set display mode */; R1 X+ ?$ y8 X( q! g6 q5 `
/* Clear Screen */
5 g9 z- ^1 n, ]. d% O- d2 PWrite_Command(0x23); /*set graphic acceleration commmand */
+ c5 L3 ]% @2 }, j' }) `Write_Command(0x01);& k# q( K0 c. C! h) @: O
Write_Command(0x24); /* draw rectangle */& l! O* a% w5 ?& Q
Write_Command(0x00); /* Gray Scale Level 1 */
: h2 y2 C5 ^& E4 m8 U- bWrite_Command(0x00); /* Gray Scale Level 3 & 2 */
% }- j2 e% |0 k0 p, o+ g6 rWrite_Command(0x3f); /* Gray Scale Level 3 & 2 */- T: u' h4 W: l  A$ u# X, c* S
( p. n+ q, {8 sWrite_Command(0x3f); /* Gray Scale Level 3 & 2 0x00*/
  O" ]' [6 o/ s" U+ r% @* J, lWrite_Command(0xAF); /* display ON */
, w) c* l3 [- I# m+ A. Z; l% C: f  ?}5 z  F" P+ l! m" B& {2 {9 u
$ p# \" U4 A8 \0 h8 J7 a0 ?7 B7 V//void fill(unsigned char dat1,unsigned char dat2)
* c" V' V! A+ |//{
8 Z, |* z) Q1 Y" p- e) V1 i5 v//unsigned char x,y;
: p8 C5 {* ~+ D% t1 h* G4 x7 s; v7 V//Write_Command(0x15); /* set column address */* g3 Y; W6 r7 B& t2 F
//Write_Command(0x00); /* set column start address */0 d' K* j9 @: I: q
//Write_Command(0x3f); /* set column end address */* V$ `, r# m+ D4 d! E+ Y, Q% B
//Write_Command(0x75); /* set row address */0 Z  ~8 z- w3 }- [% m4 s
//Write_Command(0x00); /* set row start address */
: }/ R0 K6 V7 H* }6 M" W* v0 o//Write_Command(0x3f); /* set row end address */5 |- W$ a' m; r2 S* w
//for(y=0;y<64;y++)
: o. w# \+ Q" p) G. D//{( [1 T- v# y( T3 k+ ~- r) W* T
//for(x=0;x<32;x++)
2 V( ^& `2 x% p- [5 i; q2 P( W//{
; k: H! d) v  C& j, N. [//Write_Data(dat1);3 ^% G% a' V, Y! E
//Write_Data(dat2);  ~7 E/ s3 G  F2 J6 x0 l, D# n7 B6 x
5 U5 K9 d8 \2 e# b6 R//}
* e" Z: X! O6 h6 _//Delay(2);
' A% d1 |/ w/ _* h! F7 N( q//}' `' x) j5 V" X) U6 o9 V
6 Q8 v" t: v% L" B  \void Clear()6 A! }: o$ G* J$ q$ Q
1 h. P4 n* b) _# `) n( e7 O( x% nunsigned char x,y;' V& Z4 u. r7 `7 ~
Write_Command(0x15); /* set column address */" D7 q, s2 J! w% `7 q  B* e
Write_Command(0x00); /* set column start address */5 b" U/ _1 B' W; N! [! d
Write_Command(0x3f); /* set column end address */% q4 n' w8 ^4 p0 }
7 I* H" g% W# K# r$ r! ^# O# \; _Write_Command(0x00); /* set row start address */( \1 L4 `  L& o* x# a' _$ J8 p* ~. @
Write_Command(0x4f); /* set row end address */
' x% B' F9 v6 s/ T$ {# e1 I% q* Hfor(y=0;y<64;y++)5 O% E+ c9 c) a7 Q# F  F
{0 Z' S* o& v- f3 b
for(x=0;x<80;x++)% r8 n7 W9 a) G* Z" s; r( I8 H* B  I$ D
{! a; ]! O( p1 G% q" f
Write_Data(0x00);
2 I+ |; [3 i% }, h4 B  i9 G9 ]& r}
, i- M, B8 q! ~, L! x, \* i& q, w9 I}
* \1 G; G3 B& p4 X6 `}) K" j9 g# r$ U' J; o  X
" z2 I/ w1 Q) F+ w0 N8 t1 L
. Q" w4 [4 d& V( Y# @
//方框  w* l) A: }  }- x
void pane()
4 i3 e7 ~8 a# V- ~9 Y{, c* {. H8 i8 g' Q- D
        unsigned char x,y;8 c: p7 t( @9 r/ `) W
        // row06 k# o4 l" ]( h8 V8 ^) [
        Write_Command(0x15); /* set column address */# o, \# P8 r1 [9 s/ K
        Write_Command(0x00); /* set column start address */1 {" S% ?+ P! w, c  ^& ?1 I* p
' w; |) W$ l  X# O8 X5 v5 ]        Write_Command(0x75); /* set row address */7 X' P' d( m' T% \4 A
        Write_Command(0); /* set row start address */
$ I! i+ o# X0 n8 q% ^. ^        Write_Command(0); /* set row end address */
3 [" \' J7 o' O        for(x=0;x<64;x++)
8 ~0 _' U$ h" J, A( x        {) D, e# M& U% H2 F' Z3 \* s4 s) A
        Write_Data(0xff);/ y  O+ N2 ~4 T0 x  i6 n, M
        }7 p) C; H. Y' |' e
        Delay(2);
; E& ]% G& S. A# c- V( ?5 b( B        //row 1 - 62
) {' Z! [- {/ m, h4 P: X5 Y9 ]        for(y=1;y<63;y++): k9 k5 w2 W3 I+ h
$ Q: e6 Q5 G9 T" O. ^                Write_Command(0x15); /* set column address */) F6 k/ O/ [5 C
                Write_Command(0x00); /* set column start address */, q9 X. g+ H9 E8 u  u5 X- `+ T
                Write_Command(0x3f); /* set column end address */! M6 s0 e! V: n
                Write_Command(0x75); /* set row address */5 @8 H& {( f0 X* d' u% G* [
                Write_Command(y); /* set row start address */. h2 t, W5 }4 p& f# J( @
                Write_Command(y); /* set row end address */" a7 @) D$ [' [5 `
                Write_Data(0x0f);//低位在前
, O8 `* D' S" Q# b% K  [                for(x=1;x<63;x++): I( t0 B- `1 V$ n
                {7 v( g  D; [0 D/ N5 \- o
                Write_Data(0x00);
! X6 j& b' l3 l                }! N& s( m9 X& S
                Write_Data(0xf0);//低位在前
6 O. ^, d1 l- y3 ^. l( \                Delay(2);. A0 s2 Q% q+ v- b
        }9 X. u( v* u6 [+ f+ b) z
9 q' O' u7 q& i8 {" r8 V% ^
        //row 63
3 |/ T, M! X8 L% p. v! z        Write_Command(0x15); /* set column address *// W6 m: h" P7 V: k; L5 g
        Write_Command(0x00); /* set column start address *// M- _4 r3 y  s, l3 D3 j
        Write_Command(0x3f); /* set column end address */& z% ~7 J6 e+ u9 a, s
+ W5 ]- q/ q6 j5 @1 i0 X% k+ L        Write_Command(63); /* set row start address */
* ?4 Y' c/ k4 x$ [        Write_Command(63); /* set row end address *// [. c, L  h; Z& M5 c+ Y7 u7 l
        for(x=0;x<64;x++)
; W9 A' k$ G4 L3 `        {5 J( F+ q2 s( C+ R2 E: n
        Write_Data(0xff);# K" E3 _* @% e9 w+ J. `* @0 T
/ v1 t$ b( ?' J" y6 S* \        Delay(2);0 r- @! q+ U0 u7 D( H
4 ?! d- [% o( N( Z* u* C5 T/ k& V
% F, y, s5 C+ k! p+ W" f8 h7 [void pictrue()
( d4 [, h1 U1 m3 T* e0 y3 g{
" m' r8 n- f) {9 }$ C) u" E/ x        unsigned char x,y,z;
' J  n( x* q- a; Q4 s8 T; F; `        unsigned char value,temp_h,temp_l;1 [; ?7 N# g  a/ v& X0 K: x6 \& D* Q
5 n0 o) G  f1 y; i% E' IWrite_Command(0x00); /* set column start address */
: F! c# L' q* q  {5 Y2 k% zWrite_Command(0x3f); /* set column end address */3 m6 }) y0 r) K) @9 y
% w  K  A& T' k# c2 f2 EWrite_Command(0x00); /* set row start address */
, Y. {# [* b: f6 y7 M% o" wWrite_Command(0x3f); /* set row end address */
  [+ z7 t9 y' M0 }  a- b: d7 k6 {) W/ U
        //x,y确定数组的位置,z确定数组的bit位数; }* U" J/ W5 T4 }2 @* `, N$ [* v
        for(y=0;y<8;y++)
- ~1 f* |9 j/ B0 d        {
  u+ ^( m- l7 y$ c1 h% a                for(z=0;z<8;z++)
6 t" a' C3 r0 X% C  t) S/ w1 L9 q                {: `* c! v) w% v7 j) @+ A
                        for(x=0;x<64;x++)+ A4 M. m. G  V* Q, n8 h* i# w
                        {3 ]# E* y- x3 d$ X5 }6 [
                                //value = ((show[y*128 + x*2] & (0x01<<z))>>z)*0x0f + ((show[y*128 + x*2+1] & (0x01<<z))>>z)*0xf0;
+ ~( k( S6 T1 @                                temp_l = show1[y*128 + x*2] & (0x01<<z);" N4 N6 C0 V' I  }3 ~0 U
                                temp_h = show1[y*128 + x*2+1] & (0x01<<z);8 L3 X) o# ]& d7 i9 A; ?; Q7 M% H
                                if(temp_l > 0) value = 0x0f;
' ~3 Q- o: `- Y" \: `                                else value = 0x00;9 \; g% z/ p( g; w7 U3 a
                                if(temp_h > 0) value |= 0xf0;
5 {& P7 P5 }  V! {/ Z
( o6 d8 V+ a: `: h  U                                Write_Data(value);; E$ H# T5 S/ F& f: O4 A
                        }+ c) G( i+ A. O( c  G2 h: J8 U) Y
1 G% o  G% A  R8 B# t- m2 x( ]* j        }
6 {8 |" S1 L0 i2 @# V2 l}
, j; a# I* D/ u% ^+ [ void pictrue1()
! @- j- k* _! L3 ^( u' d, m{  T0 |" e6 [& e9 [8 f2 S
/ P& B5 N9 v1 _. K0 b$ w        unsigned char value,temp_h,temp_l;7 ]7 e9 m& x/ j3 ]' S# F
        Write_Command(0x15); /* set column address */6 K0 n5 X3 Z! t3 a; B$ b" A
% b; v0 F6 D, p* Z% G* YWrite_Command(0x3f); /* set column end address */
1 v  k6 g* F! i* W2 g: Z' l9 h; jWrite_Command(0x75); /* set row address */4 F$ V/ ^" H5 g% y. z
- |  y8 k. c* r: Q) xWrite_Command(0x3f); /* set row end address */
; Z$ e7 f& L% i) G: E& D/ c3 @0 a' w  Z
8 p9 c, T3 L' [6 {' i# [        for(y=0;y<8;y++)
5 k! f4 R7 h+ u& g9 l0 F# _; C        {
0 N- F' l- ^7 r4 L4 a                for(z=0;z<8;z++)+ N# H" n8 p5 V$ q# `$ s
7 C1 R! O4 }6 ^5 }                        for(x=0;x<64;x++)
, v( K! B. \" ^; M4 e6 e                        {% w2 ]7 @: f* ~# g
7 J, z" I& S8 w9 Z& x1 K                                temp_l = show[y*128 + x*2] & (0x01<<z);
& L: _! `% x7 A$ N8 C  n5 Z- F" {                                temp_h = show[y*128 + x*2+1] & (0x01<<z);0 |  L/ r/ J. z5 n  i
+ B, f8 Y: A, ?5 \- @5 Z                                else value = 0x00;
- _/ ~5 ~% z7 @, a% R) a9 n                                if(temp_h > 0) value |= 0xf0;        7 n9 o. I5 ^7 n7 K0 ?- [" a  n
2 z+ I7 J3 b+ Z: \* e                                Write_Data(value);
$ T) f+ W) k6 m' O, t3 Q* h                        }
2 U( U- R* @0 d4 n/ q4 _# c( Q                }5 O! O& P) `. W# L: Y
        }. b: l. S) _( U- L( Z3 R2 ?6 Z
; h: E0 D& @2 Y. R% j/ k  o& f( z//竖条纹
7 @+ e$ \) D' Xvoid pane2()+ V' f( K& [$ S
{. U9 C7 G) r; j3 @) k7 b
unsigned char x,y;
/ u2 G& u/ r7 X: xWrite_Command(0x15); /* set column address */; q# f- k# r6 }
Write_Command(0x00); /* set column start address */+ z, C5 V6 n. L0 u
Write_Command(0x3f); /* set column end address */. c9 e8 D9 E" G( O$ r6 G$ L
Write_Command(0x75); /* set row address */& a0 i2 E* M" T. ~  s
Write_Command(0x00); /* set row start address */9 ?  q, I( h+ Z: |: ~" Q
Write_Command(0x3f); /* set row end address */2 ^1 f+ z/ a5 ^( w, R# e; b$ B/ Q7 }
for(y=0;y<64;y++)6 [. W; F) S. f; E
{1 W3 l0 l( L/ M9 l& S: a2 k
for(x=0;x<64;x++)
+ L; M$ u$ @" g* e. r, p' k{5 _1 J! l! f8 Z- K! f2 o7 m+ p
Write_Data(0x0f);
5 N6 v, U& y, D2 N}
7 ]8 b. D/ E* C- X3 L; s}
9 a$ d! I/ ]5 lDelay(2);
; N! D) ^  d1 L3 c0 S9 S& r  J. S}! Z; b: ?3 p% J1 \) T- I
  K! U4 v; N" k//横条纹
" v$ `* e8 ^" w. P! |9 Z5 Q/ e9 Hvoid pane1()
# S) J) A$ \, n{1 Z/ O1 E# a( m/ a* [1 i
unsigned char x,y;9 H. m9 x& ~/ t, R5 R
Write_Command(0x15); /* set column address */3 U) O3 k) ~0 h) {$ a" h' U
Write_Command(0x00); /* set column start address */2 w  R# y9 H% u5 w
- p- @" ~" I  nWrite_Command(0x75); /* set row address */
( j+ [3 [) L; F7 u/ hWrite_Command(0x00); /* set row start address */  u7 m3 ]8 R! {
Write_Command(0x3f); /* set row end address */+ `* h& C) E3 F  z
7 f1 P; P# C% P- k  ?
for(y=0;y<64;y++)
3 X! O+ p5 w7 h. d- I9 C; L{4 L+ ]- |/ b/ D+ P* g
for(x=0;x<64;x++)2 j0 ?% w' Y  m( r+ f) z) s
1 B0 ^, a* M9 E2 d' Z0 TWrite_Data(0xff);/ J  [! }6 v! [1 j
7 J& g2 W/ n' Y. \% a, p+ W9 W/ @' X7 ?7 I! y
for(x=0;x<64;x++)
3 k1 s( g, A4 B4 I% E9 E{2 X+ }2 ], m/ p
Write_Data(0x00);
  I9 t+ z1 W6 Y. m$ D8 @6 ^" G) [}
- K, s8 J$ y0 M& r}$ V5 H: ^5 z; {9 Y9 t
Delay(1);) P1 H( O' P+ M$ S* U8 c  ?
" f& h  ]; g2 J% }8 H5 g1 }* @+ o6 f5 |- m9 b9 A+ y
void snow()/ q& i2 V$ X& ~/ S4 C
{) y; V4 [2 a, Q+ m' ?8 c- J
unsigned char x,y;7 S# s) j& D# J& Z$ c
2 x; W4 O) X0 O+ L4 ]Write_Command(0x00); /* set column start address */+ |" t" F6 F# o0 H7 a6 Q/ b
: B( I" v7 P# n1 t! KWrite_Command(0x75); /* set row address */- N5 W* r! T. `, t3 z7 |2 x% q
6 t1 A1 R4 c: d* D) u9 z' GWrite_Command(0x3f); /* set row end address */' c/ U9 n  N8 X1 {" K  }
for(y=0;y<32;y++)
0 R0 m; T( P8 O+ T% @{$ e: n8 t2 E+ C! q2 \
        for(x=0;x<64;x++)
/ H: c8 {& Y5 f$ i. v: u  K3 V        {: y6 N/ A* |9 V' P5 t
        Write_Data(0x0f);* _2 k* l% t! o- G
! J" l, J$ x9 _$ J! a! G$ t" Z        for(x=0;x<64;x++)1 L# F% T% ^6 {
        {7 p4 s2 y$ [; c6 Y0 F7 o# n
        Write_Data(0xf0);
# `# v7 k( M' d, b0 D! e        }
5 r( _5 q0 f1 g) b3 n. Z}
0 Z7 b: [& a7 f- N; lDelay(1);
; p0 w0 J, K& l) A/ {  O}
$ e9 G) ]; U$ e- U- c9 {% b" h1 f& t* v5 M  q6 _( w1 D& V; ^' R
void Fill_Block(unsigned char Data, unsigned char a, unsigned char b, unsigned char c,unsigned char d)+ _& X- W+ O) {. r
{+ O$ {6 }$ o. [: ^* M6 c5 X2 G
        unsigned char i,j;
, {& }+ ]- w% X5 ]' Y6 O1 [        Write_Command(0x15); /* set column address */. N7 ~" c% H; Y- _8 s
        Write_Command(a); /* set column start address */
, c' e* A6 Q- \4 j        Write_Command(b); /* set column end address */$ I+ |8 l, P: C& N! P3 {- H1 s
. U' o: l; ~: L  W, f( X+ I        Write_Command(c); /* set row start address */
% q- L, a7 @: }1 F        Write_Command(d); /* set row end address */, {  d9 a* g" t( z& N! P( X
                for(i=0;i<(d-c+1);i++)
$ o3 S& a( |( x  y        {/ b7 _; }1 Z& l1 g. {# Q: D
                for(j=0;j<(b-a+1);j++)/ S) F4 a  y9 s2 r
                {5 _0 a# S5 @* @5 n/ ]
                        Write_Data(Data);
3 M  o: [$ U  R; A! [7 u( H/ }  E/ M                        Write_Data(Data);0 `$ K6 K1 x$ z! r3 I) c
                }+ u1 v8 N" ]5 j/ v# L
        }         7 ?, H' O( L$ c: j* P7 u
        Delay(2);$ A" X/ Y% G; L# N
* y& y/ }) f9 x0 _7 |
9 p, c+ e( s& K0 R/ X5 Dvoid Grayscale()4 _6 P- f6 E5 ?- Y6 l& X7 ^. ]# Q
& a! y6 q  F, \  {- J             Fill_Block(0x11,0x00,0x3f,0x00,0x3f);  c; Q3 |4 ~( y* R7 ~% @
                        /* Level 16 => Column 1~8 */
, R( Z7 S( l$ q9 V. G4 d2 g  m1 k  //      Fill_Block(0xCF,0x00,0x03,0x00,0x3f);6 O& o9 I; J. n+ E
        /* Level 15 => Column 9~16*/
' J; W8 U# O( M7 y3 ^//        Fill_Block(0xEE,0x04,0x07,0x00,0x3f);- L! O# l1 P; `6 J
        /* Level 14 => Column 17~24*/
& H, M3 M" w  O# G//        Fill_Block(0xDD,0x08,0x0B,0x00,0x3f);3 d1 |# B6 f3 R  F; c
        /* Level 13 => Column 25~32*/4 r7 c# T  c+ |) u0 w8 N5 j
//       Fill_Block(0xCC,0x0C,0x0F,0x00,0x3f);( w8 S) d" G3 Z+ j0 l3 [6 a
        /* Level 12 => Column 33~40*/" f7 S0 F* v+ B% t6 t+ z
  //      Fill_Block(0xBB,0x10,0x13,0x00,0x3f);
/ B; L( {& a. {* O        /* Level 11 => Column 41~48*/9 N6 f% y8 g) b) G
//        Fill_Block(0xAA,0x14,0x17,0x00,0x3f);
( X0 D2 {3 s/ D5 ]0 B$ n        /* Level 10 => Column 48~56*/( s: J. N: e6 p2 q" X
//        Fill_Block(0x99,0x18,0x1B,0x00,0x3f);& j  f9 f, ^+ y7 ~; J  g. d
        /* Level 9 => Column 57~64*/
* m& T6 E2 c, b5 S4 S //       Fill_Block(0x88,0x1C,0x1F,0x00,0x3f);
- H$ h# b7 T/ A: T  a6 G        /* Level 8 => Column 65~72*/
* |9 s6 X3 g. R+ g2 ^% q6 g //       Fill_Block(0x77,0x20,0x23,0x00,0x3f);5 \: g* `2 a( i
        /* Level 7 => Column 73~80*/
/ Y0 r. g( |8 G- ^0 Z' K //       Fill_Block(0x66,0x24,0x27,0x00,0x3f);
9 V) y8 M! K1 ~3 E  c        /* Level 6 => Column 81~86*/
: T1 `& A1 I  m& W- X3 Q//        Fill_Block(0x55,0x28,0x2B,0x00,0x3f);/ ]0 I( V, o/ S; X
        /* Level 5 => Column 87~94*/
3 t+ r! D" o6 X# `//        Fill_Block(0x44,0x2C,0x2F,0x00,0x3f);2 b' C/ e5 X2 \
        /* Level 4 => Column 95~104*/! V) v/ ?2 o7 q  G& Y( c3 J
//        Fill_Block(0x33,0x30,0x33,0x00,0x3f);
; L5 b4 }7 ^2 X$ E1 ^, c0 Z' _        /* Level 3 => Column 105~112*/1 i- n' V+ r7 y. W7 J0 w* Y
  //      Fill_Block(0x22,0x34,0x37,0x00,0x3f);
- Z/ x+ V' G/ [$ M8 s1 Y6 W        /* Level 2 => Column 113~120*/
) l3 w4 l( A; F3 h" s //       Fill_Block(0x11,0x38,0x3B,0x00,0x3f);
$ c; y# t" c) N4 ]# |        /* Level 1 => Column 121~128*/" W. V( Z& ]  c/ }
//       Fill_Block(0x00,0x3C,0x3f,0x00,0x3f);
; E) S$ _4 d- f
/ w6 m! B# M- N, N( s7 K: i}
6 ?5 c* l% Q3 m8 H2 ? void Grayscale2()+ A2 M  c' ^3 Y* e6 |
{# V5 x% Y3 c8 }
             Fill_Block(0x88,0x00,0x3f,0x00,0x3f);7 L% H( m+ L1 b0 I' ^
}" C* L8 w' Z' ^$ K3 h
  void Grayscale3()" z( R, G# r; A* k( p, O# {3 ?
{' V- ^1 n9 L# V* t9 e8 D
             Fill_Block(0xff,0x00,0x3f,0x00,0x3f);
* t) V) i' m' M" F3 `5 |) |# m5 i }) d0 g, A$ n* p# v: n
0 K/ W, Q  f0 Q7 W. Avoid main(void). `# d. h" v9 h5 r
, @& T: d2 V6 _        key_stop = 1;% e3 F9 E# S& h5 i% z2 ?
        key_mod = 1;
( A3 u7 o+ e9 j* S) \        Delay(5);
) |* Y6 y8 N+ k0 J: ?        RES=0;
: B" X, S* S; v        Delay(10);
9 E) c' U2 l' B' f        RES=1;, C7 E! m6 ~5 O
3 a0 v- w1 F" s7 w/ M  ^: b& {
0 k2 f3 q- A) Z…………限于本文篇幅 余下代码请从论坛下载附件…………& W, b9 T8 z* X1 Q* P; _! k
  i" n1 o4 X. L
游客,如果您要查看本帖隐藏内容请回复
: {* {- B( s- T/ J. ~0 q$ ]0 R* ]. R
) c" i  P9 s' R9 x% g4 m7 ]
发表于 2019-1-4 18:17 | 只看该作者
想看看楼主是怎么弄的
GMT+8, 2025-10-9 06:04 , Processed in 0.156250 second(s), 27 queries , Gzip On.
