查看: 675|回复: 1
普中51单片机开发板,12864和矩阵键盘源程序
发表于 2019-1-3 13:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
普中51单片机开发板,12864和矩阵键盘源程序9 z( _2 t- @0 w3 |
9 n# l3 i% R  H5 O0 }6 b
5 ~4 X2 g0 _6 K5 k4 ]! J
/ T; M) w% Z2 w. M2 O" n
$ D% N6 M- q% a0 x* }
' n9 `: ]$ ~! X : ?. k% y, z6 u$ e1 l2 q
% z, I9 z, A- ^5 q  c2 X0 K5 e% x+ `
main.c(参考了好多大神的源码,结合矩阵键盘和LCD12864,显示相应的数字)
#include<AT89X52.h>
6 r( `! I+ u. r#include"12864.h"- N" D5 \2 _2 G" Y( O: O
#define uchar unsigned char8 Y( m* \7 Y& d/ l% T
#define uint unsigned int
  ^1 r0 h) m- o; e6 w5 Luchar code dazi[9][64]=
% `6 U9 S2 M+ `* v9 _- t1 e8 y0 V) u{
/ k6 v8 C$ @3 V! K9 R( m4 o        { //1' m4 W$ H2 E, o& f1 g( O
        0x00,0x10,0x10,0x10,0x18,0x38,0xFC,0xFE,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
8 P: q! |& P: D" I$ d        0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,3 L+ q- W% w5 |" g3 L, u5 |
) d. ?* G) V' z        0x00,0x40,0x40,0x40,0x60,0x70,0x7F,0x7F,0x7F,0x70,0x60,0x40,0x40,0x40,0x00,0x00,        4 F$ |# s3 `1 ?: I6 A
5 |7 u6 w7 X' ^6 W" A2 u4 n# ~' O! ^' f, E4 O% E. s
        {//2
3 z/ o; D0 r) w9 o2 R# c  ~( E+ e9 {        0x00,0xE0,0xF8,0xFC,0x8C,0x06,0x06,0x02,0x02,0x06,0x0E,0x1E,0xFC,0xF8,0xF0,0x00,
' W8 D$ {# E4 Q6 j" e        0x00,0x07,0x07,0x07,0x07,0x00,0x00,0x00,0x00,0x00,0xC0,0xF8,0xFF,0x7F,0x1F,0x00,% {8 J+ A9 n2 b* ~: w: [9 F
        0x00,0x00,0x00,0x80,0xC0,0xE0,0x70,0x3C,0x1E,0x0F,0x03,0x01,0x00,0x00,0x80,0x80,8 S0 }2 T. i9 W" D/ u2 r  R
        0x70,0x7C,0x7E,0x77,0x73,0x70,0x70,0x70,0x70,0x70,0x70,0x70,0x78,0x7E,0x7F,0x01,9 W' m, ]  {4 [9 z( q
4 E: J7 F3 u& q, K
+ q+ o! d$ ?2 b        {//3
0 M: t" Q3 W+ Q        0x00,0xF0,0xF8,0xFC,0xCE,0x06,0x02,0x02,0x06,0x06,0x1E,0xFC,0xF8,0xF0,0xC0,0x00,
. N: R( ?7 Q7 D        0x00,0x01,0x01,0x01,0x01,0x00,0x80,0x80,0xC0,0xE0,0xF0,0x7F,0x3F,0x1F,0x03,0x00,; Z3 b8 S/ Q- m! [( r3 @
        0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x01,0x01,0x03,0x07,0xFF,0xFE,0xF8,0xE0,: X3 u% q" }9 A$ I6 T+ y
        0x00,0x0F,0x1F,0x3F,0x77,0x60,0x40,0x40,0x40,0x60,0x70,0x38,0x3F,0x1F,0x0F,0x01,
3 v) I' ^" R6 }6 p; Y        },
! q0 s- h0 [8 r' c& g5 N  y% V# N( J" ]- \2 _( [5 V! _; Z
        {//4: Z/ L9 {' I% D4 S+ W
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xF0,0xF8,0xFE,0xFF,0xFE,0x00,0x00,0x00,
2 z4 g. }* S5 K8 |/ \        0x00,0x00,0x00,0xC0,0xF0,0x7C,0x1F,0x07,0x01,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x00,
: F- \1 P% c' @8 U        0x70,0x7C,0x7F,0x77,0x71,0x70,0x70,0x70,0x70,0xFF,0xFF,0xFF,0xFF,0x70,0x70,0x70,; L+ {/ o% v: l: X! n
        0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xFF,0xFF,0xFF,0xFF,0xE0,0xC0,0xC0,
2 ~8 ^( C7 e$ l& Q) Q2 Q$ g' Z0 z6 s1 G7 k; n
        },* a" D2 `: k# m# b3 r
7 \" i: u9 e& H% y/ N: V
        {//5
) g' w/ l& d3 j3 ~: l% Z        0x00,0x00,0xFE,0xFE,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x06,0x00,2 r- e/ r0 {( f) c* ]
        0x00,0x00,0xFF,0xFF,0xE0,0x70,0x70,0x30,0x30,0x70,0x70,0xF0,0xE0,0xC0,0x80,0x00,# \* o: S" r5 [8 p
        0x00,0xC0,0xC3,0xC3,0xC1,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFC,
. b' k) i$ F$ j- A. m0 |        0x00,0x0F,0x1F,0x3F,0x73,0x60,0x60,0x40,0x40,0x60,0x70,0x78,0x3F,0x1F,0x07,0x00,
2 ~; w* V% X8 y" x  m! h" s        },
: k2 u$ c7 c& Q% C( j1 ~1 c5 j5 K  Z: a+ k, w: ~
        {//6' y8 _. R$ Z1 u9 q
        0x00,0x00,0xE0,0xF0,0xF8,0x1C,0x0E,0x06,0x02,0x02,0x06,0x7E,0x7E,0x7C,0x70,0x00,
; s2 [; _* s2 G! K3 B        0xF0,0xFF,0xFF,0xFF,0xC1,0xE0,0x70,0x70,0x30,0x30,0x70,0xF0,0xF0,0xE0,0xC0,0x00,& e5 E& J% `1 Z  e$ P2 O) n& S
        0x3F,0xFF,0xFF,0xFF,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFE,
4 t  f, [: t* a, q: B& e        0x00,0x03,0x0F,0x1F,0x3F,0x78,0x70,0x60,0x40,0x40,0x60,0x70,0x3F,0x1F,0x0F,0x03,7 K; o( g5 a4 M" `9 L" x$ v
        },$ m. o' p; }! Q6 ^. v
( }4 {# v" T" f% q- i5 d
        {//75 S, g* w; y+ ~  m/ x
        0x00,0xF8,0xFE,0x1E,0x0E,0x06,0x06,0x06,0x06,0x06,0x06,0xC6,0xF6,0x7E,0x1E,0x06,
! m: E! J- R- t        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xF8,0x7F,0x0F,0x03,0x00,0x00,0x00,( j$ Q8 }& F' ]" h. [5 @
        0x00,0x00,0x00,0x00,0x00,0x80,0xF8,0xFF,0xFF,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,! a, ?2 M% o; D4 N+ M; M
        0x00,0x00,0x00,0x00,0x00,0x7F,0x7F,0x7F,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- |% @. Q( @6 M! g) A1 k. A; }        },& I6 _$ ^0 x% u& L
+ x7 c1 a; }* K' }. e
        {//8: a2 {5 h$ q3 N# u1 e  b
        /*--  ¿í¶èx¸ß¶è=16x32  --*/. n2 {- V" B" M, L  P6 Y- L' X
        0x00,0xF0,0xF8,0xFC,0x0E,0x06,0x06,0x02,0x02,0x06,0x06,0x0E,0xFC,0xF8,0xF0,0x80,
/ F# n+ a. ]/ N! t% ]: s        0x00,0x0F,0x1F,0x3F,0xFC,0xF8,0xF0,0xE0,0xE0,0xC0,0xE0,0xF0,0x3F,0x1F,0x0F,0x01,2 D. b3 G/ @* V4 ^9 p$ x! K
        0xE0,0xFC,0xFE,0x1F,0x03,0x01,0x00,0x01,0x03,0x03,0x07,0x0F,0x7F,0xFE,0xFC,0xE0,
: C1 X2 k2 M1 r# Z* @, W( `: q        0x03,0x0F,0x1F,0x3C,0x70,0x60,0x60,0x40,0x40,0x60,0x60,0x70,0x3C,0x1F,0x0F,0x03,
, P* l: r* {% v  [* ^        },
# o% [; d( d8 A& x' ?
& b& X6 g7 [( Z- d! a* X        {//9
5 ~0 a$ E/ D' ]; }5 X7 P# z        0x80,0xF0,0xF8,0xFC,0x1E,0x06,0x06,0x02,0x02,0x06,0x0E,0x3C,0xFC,0xF0,0xE0,0x00,
% B7 W6 ?4 {4 X& y        0x7F,0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xFF,0xFF,0xFF,0xFE,/ {) T8 T( S" y" _" h
        0x00,0x03,0x07,0x07,0x0F,0x0E,0x0E,0x0C,0x0E,0x0E,0x07,0x83,0xFF,0xFF,0xFF,0x0F,
: f: b# ?; t$ p% p% @6 G# \        0x00,0x0C,0x3E,0x7E,0x7E,0x70,0x40,0x40,0x60,0x70,0x3C,0x1F,0x0F,0x07,0x00,0x00,9 J" \& B& \, a/ T
3 ]3 H2 ^& R3 h! I) I};
# \; j9 Z# t. t- F/ {! d# Evoid delay1ms(uchar x)
( ?9 x" a) Z/ H* c0 J{  _( h9 c( w+ O! ?
        uint i,j;& t( [5 c% o1 m! L% @2 r, M
        for(i = x;i > 0;i --)6 M0 A) r, `9 G+ I
                for(j = 110;j > 0;j --);! H0 ^* _1 g3 N6 M  `9 a1 k
}" |! v0 D) a! L5 s: k/ K
/**************Ö¸¶¨μú¼¸oáÅÅÏÔê¾ÄúèY 16*32********************/. d# W6 l1 [# X7 N6 ]% `
void WRITE_STRING1632(uchar plat,uchar column,uchar p)5 U: }: A3 ]8 q
{! Y7 F4 m7 Y' G) {8 ~: u% p& \, w, z
        uchar page,page1,col,col_h,col_l;
& v, f+ R- Z5 F: y' t        uchar i,a,jj=0;
9 u7 t$ c% e. k0 ?/ b7 Y        page1= plat*2;
9 J# z- D3 n# k* }' m        page=page1+Page0;' h6 w/ m+ d- J2 M
        col=column*16;
; m, e( `/ G- S4 L        col_h=((col>>4)|0xf0)&0x1f;4 Y7 W$ g; }" D: I5 l8 h/ p& ]1 Q: ~
        col_l=col&0x0f;5 W( Z0 r4 I3 ^8 `. C3 a2 N
        for(a = 0; a < 4; a++)4 @6 E2 X* ]& G
        {' T" S! T$ a! G) L& Y
                LCD_WRITE_COM(col_h);6 ~  [9 {0 K$ C/ v, g0 X
                LCD_WRITE_COM(col_l);+ v; O7 w$ o9 S$ e5 A! b
                LCD_WRITE_COM(page+a);0 C0 H3 b: x- T- K
                for(i = 0;  i < 16; i ++ )
" a& L, x% R  j8 V                 {
. V& v, N" ^, m                        LCD_WRITE_DATA(dazi[p][jj++]);        # S$ i; X8 L. C1 u; [' }1 z! s
                }; P7 j. f* q( u) J: ?2 K8 e; A2 B
        }         3 m; P% [4 ~$ _; x4 C" p
}, B9 w! `. \2 C: X! }2 ~% Q
void keyscanf()
% `4 A' n4 ~# M{
5 T* s/ e8 w! z! {        uchar temp, key;/ h; T6 U+ o7 d# D; C# O) U
        P2 = 0Xef;' g, n9 r1 z/ {7 }: Y2 Q9 C; r+ _
        temp = P2;
& E6 L) T& J) B7 K+ A3 O        temp = temp & 0x0f;. L: t7 s0 u: t% ~
        if(temp != 0x0f)
( G- X/ \5 c, [8 z# K        {( P. [1 x9 `; m4 h* j! _
                delay1ms(5);//襶¶¶ˉ% {. G. |4 u- _
                temp=P2;  P+ b- o; z( `
                temp = temp & 0x0f;) P' {0 ]& B4 Y+ w" F( a5 S' L1 h0 z
                if(temp != 0x0f)2 [) x1 o; Y9 Y; M* d5 l% r, j; j- Y
                {; b; m# s" O5 q$ u2 M
                        temp = P2;
1 D! E  P3 \6 {                        switch(temp)//′Ëê±°′¼üòѾ-¶¨Î»μ½μúò»DDáË
5 M: L5 H/ I- |" ^* w+ p4 U                        {
7 Q  c9 A% w; c9 e. j, \                                case 0xe7: key = 1; break;//′Ëê±′ú±íμúò»DDμÄμúò»¸ö°′¼ü°′Ï£¬¼′11100111
+ q* N. e0 ?% J' `' v3 R. r$ u* b                                case 0xeb: key = 2; break;
  ?2 F3 f: r, A9 H  |2 ]                                case 0xed: key = 3; break;
5 g; W) Y0 N  N4 C! w6 h                        }+ n! E  V" O* a6 j# L8 l6 ]
                        while(temp != 0x0f)//°′¼üËé¿a
: P& ~+ Y9 d4 c5 D  z                        {- C) u, W. T* D* E, t& [
                                temp = P2;! Y+ V% K: p& o* h5 n3 _
                                temp = temp & 0x0f;
7 d( [' ^  |) l  T% I- w7 ]0 p: d                        }6 X& X7 K/ X- i9 F  }* N2 O
                        WRITE_STRING1632(1,3,key-1);1 A4 j9 t4 }! `1 G' f& }- a7 a, \
6 t+ J3 ^& i* K- m! v) L        }
; {& [0 a" j; ?% I) W, k% q5 v! V3 Y2 V        P2 = 0Xdf;
& I3 x: ^6 i9 `. O- q, C' K        temp = P2;
* b0 D8 Y6 j8 f  V        temp = temp & 0x0f;% Z( ~" D. V$ C# E* P& r5 e/ ~1 J- P$ ]
        if(temp != 0x0f)
8 }( y. \) p0 i# D$ k; u9 z7 s& g        {
5 e) T4 {7 S7 ^) t                delay1ms(5);//襶¶¶ˉ
2 j: v% o- B0 h5 S                temp = P2;
" [8 O7 q& _" @. b6 W; [                temp = temp & 0x0f;  ~; b$ ?) j7 [1 p0 B3 T
                if(temp != 0x0f)
$ V6 M) l- ^, e1 ?/ P2 K5 G) w( M                {) O4 S7 M/ ~- e
                        temp = P2;1 i* ]5 p1 @, X- E# v
                        switch(temp)) m4 p- B5 Z$ ?2 u2 w7 ~' [
9 z  V6 w& T4 }; _  V                                case 0xd7: key = 4; break;
9 g* R# `' g+ Y; C' J; T                                case 0xdb: key = 5; break;* B% K4 A8 O) R( o9 B; o( i9 Z/ L! ]
                                case 0xdd: key = 6; break;4 f0 b; r8 n$ k% f3 H
9 d# O# B( t  ~
3 j1 ?3 U' f5 b' R! h& T2 T6 t' V                        while(temp != 0x0f)//°′¼üËé¿a( F3 l2 R# m2 i
% F5 V. `/ o8 J/ \1 Z                                temp = P2;
0 c4 n  u) r% K- F5 T                                temp = temp & 0x0f;" W/ b) V3 H; r% w9 r, y+ V
                        }) ^6 [6 o3 V$ a. Z0 H! K' ~
                        WRITE_STRING1632(1,3,key-1);/ h: v, h: @3 ?2 j0 Q
                }* x3 n; |; U) Y: q1 w! X2 b; V
        }& U7 [- c# P6 O8 V/ Z
        P2 = 0Xbf;4 z3 Z  O( [0 X, F6 E$ H, c. z
        temp = P2;
, ~, Q. g0 X+ p5 [6 u7 y, r        temp = temp & 0x0f;2 K' `: ^' i: q
        if(temp != 0x0f)
; T/ A, n( ^% F        {
0 V1 \' Z4 l: s+ k4 A; e7 F0 V                delay1ms(5);//襶¶¶ˉ
$ Y  \4 O( b" |9 c                temp=P2;
8 _3 i( _; ~, d& b: I( ^                temp = temp & 0x0f;9 A8 h2 T4 K% _/ T( i
                if(temp != 0x0f)
7 E( }1 D- C6 n: Y/ S% U  H                {
1 G! t) L& T- [; }7 S                        temp = P2;4 t8 i) |, k  A( L8 x7 h" R
                        switch(temp)) a/ L5 L* l( u3 F8 f8 m
                        {0 ]( ?$ L& v8 `1 o
                                case 0xb7: key = 7; break;
& l$ e. w7 V% H+ z/ |                                case 0xbb: key = 8; break;
8 b& [" {# n0 @' R                                case 0xbd: key = 9; break;8 k! h! T" Y8 g3 m2 B
$ v/ E' N# X4 S2 y8 |8 D; t3 i5 ?                        }
  X3 F) Q" S- [+ c9 I2 Q9 b) }                        while(temp != 0x0f)//°′¼üËé¿a+ I" ]. O- Q5 s
                        {6 c" K( `% ]* ^$ L, L, X* b
                                temp = P2;
2 c9 y% s% \: p                                temp = temp & 0x0f;5 l$ m* R. [7 X- {; o
" H3 V0 _! X  P1 n" \# [' P" V/ L
9 g+ q& D6 p' O& j6 K" L0 i- |) ^, N. S. }
…………限于本文篇幅 余下代码请从论坛下载附件…………% ]  c9 j; n/ E) o3 t* w2 q
游客,如果您要查看本帖隐藏内容请回复
0 q! w0 i' S8 b* @; S: S; p: G% A
( a& t0 j" @  o+ Y5 ]6 S
发表于 2019-1-3 15:31 | 只看该作者
看看楼主的代码
GMT+8, 2025-10-9 02:12 , Processed in 0.140625 second(s), 27 queries , Gzip On.
