群里的朋友,EMMC芯片,我们之前使用江波龙的NCEMAD7B,没有规格书,程序是V4.0,我们是用全志的平台R16,现在芯片用的NCEMAD9D,是5.1的EMMC芯片,硬件连接上多了H6,T5接地,其他的没有变化?是不是软件也要升级?[17:52:27.355] workmode = 16
3 @) [$ Q) D' x, Z c w) Q[17:52:27.355] [ 5.115]NB1 : enter phy init. x& d) f. `- O5 s% i9 w. T
[17:52:27.355] [ 5.119]nand_physic_init
0 B$ @* X& f6 }0 v[17:52:27.355] [ 5.121]Reset NDFC start 0 0
0 R$ g% G" x: k5 L* m[17:52:27.355] [ 5.124]Reset NDFC end 0 0+ W- p9 R1 F9 A b- g0 R W% o H
[17:52:27.355] [ 5.127]nand not support! channel 0 chip 0: f0 f0 f0 f0 f0 f0 f0 f0! X) d, y1 _6 L1 Z( o6 |3 k" Z% E( V
[17:52:27.355] [ 5.134]nand not support! channel 0 chip 1: f0 f0 f0 f0 f0 f0 f0 f0) k" x5 _9 f! ]6 ?8 {
[17:52:27.355] [ 5.140]nand not support! channel 0 chip 2: f0 f0 f0 f0 f0 f0 f0 f0
8 ]1 ^+ e% s. R, Q" G( A! x[17:52:27.355] [ 5.147]nand not support! channel 0 chip 3: f0 f0 f0 f0 f0 f0 f0 f0! j9 q/ W3 ?0 H0 o g3 I3 Q; M
[17:52:27.355] [ 5.153] no nand found !
" ]/ M5 _9 Q4 x1 n) o, K3 d9 y: ^[17:52:27.355] [ 5.156]nand_physic_init nand_build_nsi error: L9 _; h4 Z8 ]7 N! @; ~' L
[17:52:27.355] [ 5.160]nand_physic_init error -1
5 f# H9 a; ]1 E" n) E* B[17:52:27.355] NB1 : nand phy init fail
% w3 x7 `8 F3 j[17:52:27.355] [ 5.166]NB1 : enter phy Exit9 r4 U* A) _. A7 H; D
[17:52:27.355] [ 5.169]nand_physic_exit' q# I. W, \9 v; Y5 V8 _
[17:52:27.355] try nand fail( P) k+ ^+ n7 y! s6 ^* n( M
[17:52:27.355] [ 5.173][mmc]: mmc driver ver 2014-11-25 17:03:00
' [+ e' |5 m& L[17:52:27.355] [ 5.178][mmc]: get sdc_phy_wipe fail.% K: w" m" W: c+ @: b
[17:52:27.355] [ 5.182][mmc]: get sdc0 sdc_erase fail.6 |8 a7 I+ R4 g6 U, {
[17:52:27.355] [ 5.186][mmc]: get sdc_2xmode ok, val = 1' `1 ]- D+ Q1 _8 G% T9 i
[17:52:27.355] [ 5.190][mmc]: get sdc_ddrmode fail used = 0
7 o9 V- l1 P6 I8 [8 H: u[17:52:27.355] [ 5.194][mmc]: get sdc_f_max fail,use default 50000000Hz
( x6 l9 V6 F3 d2 L1 {/ r4 h! Q[17:52:27.355] [ 5.200][mmc]: get card_line ok, card_line = 4
# b. R, G/ ?0 e3 f6 _" |[17:52:27.355] [ 5.204][mmc]: get sdc_ex_dly_used fail,use default
/ N# D: \7 V2 W$ L[17:52:27.355] [ 5.209][mmc]: SUNXI SD/MMC: 2
5 w H* n# |6 m- S[17:52:27.355] [ 5.223][mmc]: *Try SD card 2*( m" z; N/ |+ C. |7 u( z9 g
[17:52:27.390] [ 5.226][mmc]: mmc 2 cmd 8 err 100* N' r3 R6 a; f+ d
[17:52:27.390] [ 5.232][mmc]: mmc send if cond failed
' C* y$ V- f9 v* _% p- P" o[17:52:27.390] [ 5.236][mmc]: mmc 2 cmd 55 err 1003 Q. o1 l; n/ F; B2 ?" t2 X
[17:52:27.390] [ 5.241][mmc]: send app cmd failed8 v8 f- }2 @/ W5 g9 o1 d
[17:52:27.390] [ 5.244][mmc]: *Try MMC card 2*
* }& v/ {2 a _$ a9 o[17:52:27.390] [ 5.268][mmc]: Invalid ext_csd revision 8
0 i1 b B4 t( p; J8 x/ i[17:52:27.406] [ 5.283][mmc]: unrecognised EXT_CSD revision 8- \/ n+ m7 Q% Z$ j
[17:52:27.434] [ 5.288][mmc]: decode ext_csd failed
3 e9 W( I$ V8 y$ i$ K7 U( @[17:52:27.434] [ 5.310][mmc]: CID 0x88010344 0x39443038 0x47246d01 0x8523a5752 n+ r+ A- u6 h. j1 }7 Z u+ s
[17:52:27.510] [ 5.315][mmc]: MMC ver 4.08 E( H% i# b- }0 ?& L( r+ P4 h
[17:52:27.510] [ 5.318][mmc]: mmc clk 50000000
1 d$ y/ q1 n# c+ J: s" `[17:52:27.510] [ 5.321][mmc]: SD/MMC Card: 4bit, capacity: 7396MB
9 a! E" p' ?; P* Q8 u: ^[17:52:27.510] [ 5.326][mmc]: boot0 capacity: 4000KB,boot1 capacity: 4000KB
' {% C8 a4 s/ O3 x[17:52:27.510] [ 5.332][mmc]: ***SD/MMC 2 init OK!!!***
% J: X7 r j9 Z- v[17:52:27.510] [ 5.337][mmc]: erase_grp_size:0x400WrBlk * 0x200 = 0x80000 Byte
( d1 r( v$ r/ n1 W( E3 C/ r[17:52:27.510] [ 5.342][mmc]: secure_feature 0x55
! n2 H8 e" s& s7 d. m8 f* _[17:52:27.510] [ 5.346][mmc]: secure_removal_type 0x9" C2 D5 h& T$ b6 e2 d0 s" j+ \: j
[17:52:27.510] read flash error
& T1 [" A" @* i[17:52:27.510] out of usb burn from boot: not boot mode
$ c! O7 z/ \5 S) U[17:52:27.510] In: serial6 J7 {) n* O6 G. c% g: N \
[17:52:27.510] Out: serial
9 a, j! R" _3 y1 b, t3 k' |% \[17:52:27.510] Err: serial
. z6 j) w: e( d) Q9 _1 n[17:52:27.510] --------fastboot partitions--------
% g) Q% P3 ?2 q8 w[17:52:27.510] mbr not exist' a/ Z! ]+ g% J5 w- \" O& O
[17:52:27.510] [ 5.364]Hit any key to stop autoboot: 0 7 n7 {* P# Z! T* r* E# H! ?
[17:52:27.510] work mode=0x10
2 E9 X" f! v G$ R5 G: _2 C[17:52:27.526] run usb efex
+ z- \$ Z, o' D3 J2 q[17:52:27.526] buf queue page size = 65536! P. d$ R2 s2 i
[17:52:27.526] delay time 2500
' H f* O* [) J. V2 ]( m[17:52:27.558] usb init ok
9 r5 b1 J* ^0 @- O, Y' r% S3 ^. ][17:52:30.089] set address 0xb
' A* d4 r Y% C b. w3 l[17:52:30.440] SUNXI_EFEX_ERASE_TAG
: y# v! `3 ~ x[17:52:30.861] erase_flag = 0x19 \4 T; p+ e p
[17:52:30.861] FEX_CMD_fes_verify_status! v" q; F z2 x" W
[17:52:30.861] FEX_CMD_fes_verify last err=0. c7 U- ], A4 q. q1 B" X9 X
[17:52:30.861] the 0 mbr table is ok$ j4 d9 T9 S7 q) o
[17:52:30.861] the 1 mbr table is ok' D+ X9 n8 O0 U/ k3 S# z+ S" Q
[17:52:30.861] the 2 mbr table is ok8 e7 S0 m8 x- f+ a9 v
[17:52:30.861] the 3 mbr table is ok' K+ a, A0 O7 @- m# h) B
[17:52:30.861] *************MBR DUMP***************: w9 k: N+ ^ w/ s
[17:52:30.861] total mbr part 11
8 a/ h) y, p2 ^[17:52:30.861] , x4 ^; y- o6 b! ^. S
[17:52:30.861] part[0] name :bootloader2 L) M# _+ G* f
[17:52:30.861] part[0] classname ISK' u6 r, @, l% m, f( k8 ~3 r, A
[17:52:30.861] part[0] addrlo :0x80005 {6 B; i) n$ K+ q: H5 R$ u/ R
[17:52:30.861] part[0] lenlo :0x10000( n! n+ X0 V( _3 U6 f9 @
[17:52:30.861] part[0] user_type :32768
2 G, |) r$ |0 C4 \[17:52:30.861] part[0] keydata :0
8 ?9 h2 ]& D2 x3 _[17:52:30.861] part[0] ro :0
5 _1 m3 z( c6 w1 v) D[17:52:30.861]
* h* L7 n' j: F8 x$ [3 q[17:52:30.861] part[1] name :env3 w' S6 Z* r9 X: t3 m/ j& t# m$ ^
[17:52:30.861] part[1] classname ISK; F, z) A- H( ~
[17:52:30.861] part[1] addrlo :0x18000
# c; j, p S" j[17:52:30.861] part[1] lenlo :0x8000
) J; _/ t: d" b. G: s/ L[17:52:30.861] part[1] user_type :32768
4 p. D. v$ k7 h% w+ j+ ^( ~4 }+ s[17:52:30.861] part[1] keydata :0) @. c/ p/ @4 @2 [5 g K5 c
[17:52:30.861] part[1] ro :0
" P, h8 ]! B' Q! B[17:52:30.861] ) Q3 f E5 {( V& y# f& s
[17:52:30.861] part[2] name :boot
& n* b/ L- H, E7 h! g+ H[17:52:30.861] part[2] classname ISK" y; v: f* F9 Q" G9 [4 I% l2 F
[17:52:30.861] part[2] addrlo :0x20000$ B% z8 e k0 f; A: T' m. l* O# z
[17:52:30.861] part[2] lenlo :0x8000
# b7 O' F* B' d6 Z# s* c! f[17:52:30.861] part[2] user_type :32768
) P) c4 _8 x2 W1 v2 R0 D[17:52:30.861] part[2] keydata :0
! q" C* `8 |2 U. Y/ P[17:52:30.861] part[2] ro :08 F+ e9 G7 v! ?
[17:52:30.861]
& u! y+ |. V5 Y ^[17:52:30.861] part[3] name :system0 L4 n4 d1 E3 B- m3 e4 D" Q( n1 t
[17:52:30.861] part[3] classname :DISK
1 R; O, I0 F/ `[17:52:30.861] part[3] addrlo :0x280007 {& P/ V% g3 L
[17:52:30.861] part[3] lenlo :0x200000- W/ M, Y$ A, H3 b5 r
[17:52:30.861] part[3] user_type :32768, C2 }! _6 f0 F: ^) i/ p5 J- q
[17:52:30.861] part[3] keydata :0
, C5 `& q; Z8 g[17:52:30.861] part[3] ro :0; }) J6 j+ d/ r0 r- Q
[17:52:30.861]
m* r8 Z& z* f% @. I$ a6 ?[17:52:30.861] part[4] name :misc9 m' C( p" a6 J2 O$ G4 a
[17:52:30.861] part[4] classname :DISK: i3 G3 F/ y, c- ]& z6 w4 F( k
[17:52:30.861] part[4] addrlo :0x228000! r$ ~ x/ M6 i: }4 g4 C3 w5 S
[17:52:30.861] part[4] lenlo :0x80006 e5 w* O0 W! {4 ?' {# u
[17:52:30.861] part[4] user_type :32768% W2 O/ ]7 b6 z. H- ]8 a. y
[17:52:30.861] part[4] keydata :0
6 T$ F @9 \! m4 j+ H: f: b: i[17:52:30.861] part[4] ro :0
' Z2 Y% w y( Q& G+ m' \' f[17:52:30.861] ( M% \7 d8 j; g: ?
[17:52:30.861] part[5] name :recovery
8 |7 w# ]4 G- t( i) n[17:52:30.861] part[5] classname :DISK! u6 a, M) B& Y! p8 J2 U
[17:52:30.861] part[5] addrlo :0x2300007 |5 C8 W4 s% m6 s
[17:52:30.861] part[5] lenlo :0x10000% L* z$ c1 R' Q: N
[17:52:30.861] part[5] user_type :32768
' `! N0 l5 D9 ~' y[17:52:30.861] part[5] keydata :0
9 s; q, b7 n9 f3 k[17:52:30.861] part[5] ro :0
/ o, H" a4 M! r: N' t( |[17:52:30.861]
% I; ~* n- u1 g& e4 p0 @[17:52:30.861] part[6] name :cache- W: B, Y2 D. [ O* `4 Y# o
[17:52:30.861] part[6] classname :DISK
" P8 R" ?' r2 w" v; P. m, b[17:52:30.861] part[6] addrlo :0x240000
2 e R: C3 v$ ?( t2 p5 Y[17:52:30.861] part[6] lenlo :0x180000
# E% Y% d9 i w$ z( n2 b) i[17:52:30.861] part[6] user_type :32768
+ c% J! `& F. F$ R6 F& T[17:52:30.861] part[6] keydata :0
Y3 a, o! ?( a3 z& t[17:52:30.861] part[6] ro :0
# c+ G1 D6 D9 m4 i' G. b' o% v, s8 R[17:52:30.861]
4 P: j0 a' h; K; ?9 |/ R, O[17:52:30.861] part[7] name :metadata
w$ {8 z/ d# m1 a[17:52:30.861] part[7] classname :DISK
+ n- A9 z( e; |[17:52:30.861] part[7] addrlo :0x3c0000
) r6 L6 |* G e1 _5 \[17:52:30.861] part[7] lenlo :0x8000! g% U* z# Y+ ` ^
[17:52:30.861] part[7] user_type :32768+ \, |, {* \' ^! M( M: p0 H
[17:52:30.861] part[7] keydata :0
/ ^# V3 H9 ]2 p$ z, \8 V[17:52:30.861] part[7] ro :0* b- i, |" P$ ]- K: B1 K( ^
[17:52:30.861]
, F" O. R8 e( k3 B+ H[17:52:30.861] part[8] name :private
, i9 D, [3 E, n" d _$ s[17:52:30.861] part[8] classname :DISK
$ ~1 n7 k, \2 f0 t[17:52:30.861] part[8] addrlo :0x3c8000
0 A9 b0 ?. e) D' s1 A3 G) M( a( a[17:52:30.861] part[8] lenlo :0x8000: m, i4 Z1 M E+ Y
[17:52:30.861] part[8] user_type :32768/ C; E( Y9 z$ _2 j( {& E
[17:52:30.861] part[8] keydata :1: _. v6 H. W9 ]+ b( B, a
[17:52:30.861] part[8] ro :04 I5 r1 q2 b5 w
[17:52:30.861] 6 \1 v7 O1 k, k) G( T
[17:52:30.861] part[9] name :alog
, d* k% x$ ~: r0 c. s[17:52:30.861] part[9] classname :DISK
+ K/ l: J: M. c8 v- S+ ~[17:52:30.861] part[9] addrlo :0x3d00005 a! w/ T1 [) B9 h, c
[17:52:30.861] part[9] lenlo :0x280001 h" n9 @. V& O% ~7 {
[17:52:30.861] part[9] user_type :32768% L1 E2 a% C0 ]1 N A f
[17:52:30.861] part[9] keydata :0
- O8 |" ?. e# q9 E$ Q/ I8 T[17:52:30.861] part[9] ro :06 z# D7 b+ L/ h
[17:52:30.861]
; \3 K, [7 `5 p' u[17:52:30.861] part[10] name :UDISK
. H+ t- [ n! l# H$ G& q0 G9 k[17:52:30.861] part[10] classname :DISK
4 Y2 ?: {+ D( f- n$ j# L[17:52:30.861] part[10] addrlo :0x3f8000
: D7 @0 u" N2 f2 _6 k# n[17:52:30.861] part[10] lenlo :0x0
M- O) E$ A0 e7 d[17:52:30.861] part[10] user_type :33024
7 W2 V* C& w2 y' s1 \) ^. ][17:52:30.861] part[10] keydata :0
+ q' w7 V! U4 I6 b[17:52:30.861] part[10] ro :0
/ D) V/ [/ {4 s0 O[17:52:30.861] 0 d: y; k; X3 \8 }( E8 Z
[17:52:30.861] total part: 12# G/ o- J) y$ `2 h) Z
[17:52:30.861] mbr 0, 8000, 8000
! D$ `5 G/ z2 R2 ?: S3 L6 K9 ^ P) c[17:52:30.861] bootloader 1, 10000, 8000
6 s3 r" s4 u3 t8 ~ {[17:52:30.861] env 2, 8000, 8000
/ N* B5 e1 y/ \: ~[17:52:30.861] boot 3, 8000, 8000
, ^- z0 `% m* W9 w1 \3 b[17:52:30.861] system 4, 200000, 8000' u3 d! l$ z$ y/ I
[17:52:30.861] misc 5, 8000, 80004 J+ L: o; \: L! A. I$ c
[17:52:30.861] recovery 6, 10000, 8000/ F, C: e; u5 ^: E% l
[17:52:30.861] cache 7, 180000, 8000; X& H' B# W" Y) B- C0 P
[17:52:30.861] metadata 8, 8000, 80006 J! H. g/ ?+ i% D
[17:52:30.861] private 9, 8000, 8000
/ ^- y( Y% E/ Q4 \9 T) }[17:52:30.861] alog 10, 28000, 8000
& m6 v: f7 s# G! H( S[17:52:30.861] UDISK 11, 0, 8100( v& S5 |2 m/ P! R0 s l
[17:52:30.861] do need erase flash$ U" i v* v2 H
[17:52:30.861] private part exist
* |& D q4 a9 j8 g[17:52:30.861] the 0 mbr table is ok
% u; F$ G+ {% R) |[17:52:30.861] the 1 mbr table is ok
' r: e$ S, k P+ f9 z7 v, Q[17:52:30.861] the 2 mbr table is ok2 Z2 s: s1 j4 i+ B8 I; N3 p7 M4 s, T
* ^6 s4 o0 Y3 Q# ]( e/ h3 w. B! f[17:52:30.861] *************MBR DUMP***************
) h- t. t% X6 y& b[17:52:30.861] total mbr part 114 y' ?. n& _9 }! T
[17:52:30.861] + ] Z3 e3 X* C, _: F! j
[17:52:30.861] part[0] name :bootloader+ y/ i0 ?% F& Y' o, w# C
[17:52:30.861] part[0] classname :DISK
# h3 t# L" B$ z p! Z( v[17:52:30.861] part[0] addrlo :0x8000
6 b8 h" k7 j9 Z3 C5 F0 {7 w[17:52:30.861] part[0] lenlo :0x10000# S; l: E3 O: f: @1 Q
: i* p: J+ c% q! o) b* R# X[17:52:30.861] part[0] keydata :0
' G( ~, b' A X3 l* G7 i[17:52:30.861] part[0] ro :0% N! C, P" O f' U7 g, X( Z- N4 `
[17:52:30.861] + c: ~1 Z6 f6 n2 b$ T7 p# l
[17:52:30.861] part[1] name :env- k, y7 V* b' Z4 k, d
[17:52:30.861] part[1] classname :DISK$ X/ E$ J6 |' L
# m `3 q8 X. q; V$ ~6 d1 N[17:52:30.861] part[1] lenlo :0x8000" T. Y: L1 w5 f/ ?1 v/ s
7 \, ^/ l; ~- }; b0 P' ^ j[17:52:30.861] part[1] keydata :0# t* N* ?2 g. e4 Y. ?0 c/ f
' b }/ F" g( I+ w$ ]9 g+ m4 L% _[17:52:30.861] : o2 w% y5 |! W4 e8 r
9 p- h8 M! g; D* H# v[17:52:30.861] part[2] classname :DISK1 [. G& M9 Q0 T
5 ~: n8 E0 Z' y/ Q* W4 Y[17:52:30.861] part[2] lenlo :0x8000: b' Q$ x5 B6 {: c
[17:52:30.861] part[2] user_type :32768' P9 M" x8 V$ u) H
[17:52:30.861] part[2] keydata :0) s9 A3 ~6 d2 R+ f) r: K
[17:52:30.861] part[2] ro :0, L' {1 q! y% u2 O, m6 ^: n
[17:52:30.861] , ^. ^+ i4 | a5 Y7 R
[17:52:30.861] part[3] name :system4 |! z! g. X B% A, [) L
) L4 B2 M3 N0 M% X- a, G0 w3 y[17:52:30.861] part[3] addrlo :0x28000
1 P$ k: ~7 A, G! P' W[17:52:30.861] part[3] lenlo :0x200000 w) [3 W1 c7 P; m, ^. {
[17:52:30.861] part[3] user_type :327687 R2 X8 s+ C! j, n. u% _8 k
- i1 \# N: \8 Y[17:52:30.861] part[3] ro :0
3 y' y0 e, o0 U6 p% W, }7 w, R( u[17:52:30.861] 6 a0 t1 s/ ?) v* X) g' x: Q
; U+ Q6 s" R, ?! ^6 p[17:52:30.861] part[4] classname :DISK& U4 _1 V4 D( I4 }: l
" \% D0 `' m+ \; }) E* X9 a9 m[17:52:30.861] part[4] lenlo :0x8000
0 ?* Q, ]3 i1 ^& J) ~* ?* h5 O[17:52:30.861] part[4] user_type :32768
8 R, \2 }5 [! n) e[17:52:30.861] part[4] keydata :0, E) j2 U! g4 y- l
[17:52:30.861] part[4] ro :0, i% ]! Y9 h$ P& b; M b2 I
[17:52:30.861]
! V: d: `$ V# ?+ ]" z[17:52:30.861] part[5] name :recovery
/ I( R' |/ a& ?& [( a[17:52:30.861] part[5] classname :DISK9 }7 U0 b3 q' s, ?$ _, {+ Z- r- v* @
8 P' r) \. t, t, y. Z& j- t[17:52:30.861] part[5] lenlo :0x10000# R+ |5 R2 y5 D! F; l1 G& ^
+ m. x% i9 d# b7 M8 D) S$ Q8 G[17:52:30.861] part[5] keydata :0
3 c5 H: N4 e0 v; B& u[17:52:30.861] part[5] ro :0
6 P' D( G6 O9 I% S+ _+ B9 j[17:52:30.861] # M5 C* Z: S1 L- z9 e: ^& |
1 X1 N0 X( I: ^' |1 L2 E[17:52:30.861] part[6] classname :DISK
* M2 Z7 ~9 N0 U[17:52:30.861] part[6] addrlo :0x2400009 M) |3 W9 G4 V4 k# M5 J* P
; f6 ?, L4 T5 m% c[17:52:30.861] part[6] user_type :327687 O1 C4 n2 b' x5 e& L
% H4 W; C: y( k& S0 u2 J; d+ P/ t[17:52:30.861] part[6] ro :0" S1 j; y9 d0 A7 A, \2 j' j% C
[17:52:30.861] 8 v) e* W6 T3 ~# [. K
" V1 Y+ J& s6 E9 w[17:52:30.967] part[7] classname :DISK
3 N! {8 _# y3 l, t& Y0 C7 h[17:52:30.967] part[7] addrlo :0x3c00004 y L5 r4 [( \% M! y e& k$ P3 m
[17:52:30.967] part[7] lenlo :0x8000+ ] |1 G4 g3 B! w" u8 ?
[17:52:30.967] part[7] user_type :327680 m3 Y4 ]2 J7 R' a
[17:52:30.967] part[7] keydata :0) L8 }/ c* y) ~& Q/ J. j! b
[17:52:30.967] part[7] ro :0; l5 ]3 N' q* c; Q
[17:52:30.967]
3 G5 h0 L# m) ~[17:52:30.967] part[8] name :private5 O3 m) Q8 u* \% ?; G
[17:52:30.967] part[8] classname :DISK- a( H" T7 ~! c8 I
[17:52:30.967] part[8] addrlo :0x3c8000
$ e# h3 A# q5 B Y2 }. D( w# W: ^' y[17:52:30.967] part[8] lenlo :0x8000 t9 i. \& M0 A+ u$ n
[17:52:30.967] part[8] user_type :327688 C, I; \6 X( j$ Y
[17:52:30.967] part[8] keydata :1
, X" E% A" _5 f/ M[17:52:30.967] part[8] ro :0
2 u) U- s6 X" L! P- S[17:52:30.967]
, j4 B1 l/ ^) b3 R# F5 W( e: n[17:52:30.967] part[9] name :alog
; G. P7 V6 q( u8 E[17:52:30.967] part[9] classname :DISK/ S4 O, u, b" z: |' F' l1 [
[17:52:30.967] part[9] addrlo :0x3d0000
9 c+ p6 l# K3 L[17:52:30.967] part[9] lenlo :0x28000
- p y$ g( V3 g/ [: e[17:52:30.967] part[9] user_type :32768
. t- e6 _. w3 ]9 A9 \- [4 x[17:52:30.967] part[9] keydata :0; v0 `: M+ [. t9 A: ^& I
[17:52:30.967] part[9] ro :0
* O- J: a( `& Y+ K[17:52:30.967]
- F5 F. `; _. _/ y7 R) R2 R" o( p[17:52:30.967] part[10] name :UDISK* ^# n2 E' A- j2 @
[17:52:30.967] part[10] classname :DISK
7 b: q0 c$ S( J0 V! S& u[17:52:30.967] part[10] addrlo :0x3f8000
* W2 d4 X$ q& X[17:52:30.967] part[10] lenlo :0x0
& B( ^2 l8 u& H[17:52:30.967] part[10] user_type :330248 M. r) @. z9 J9 m( w
[17:52:30.967] part[10] keydata :0
) e2 G# b, ?5 T2 a# x/ n[17:52:30.967] part[10] ro :0
3 R6 v9 `. c4 w" P; P) T8 k. Z5 \6 P1 X[17:52:30.967]
* T5 o- L/ s) |% N$ x- Z[17:52:30.967] begin to store data5 o, X, y5 h# m: I
[17:52:30.967] part name bootloader
* A5 H) }" H, g- U8 a) t" o. ?& Z6 I[17:52:30.967] keydata = 0x0
9 A: Q2 j, \8 z+ S. I[17:52:30.967] part name env5 t2 c, R$ W3 w; C
[17:52:30.967] keydata = 0x0, S) g* Y1 B0 t" L" w- m% D+ Q* V
7 g8 S1 p. d( T% w/ W* y[17:52:30.967] keydata = 0x0/ I6 ~! @* t+ A0 E" Y$ p+ w
[17:52:30.967] part name system- K' o) E' o2 g. v# T: Y
[17:52:30.967] keydata = 0x09 j- {! c ~, }" T, c; o# p8 m
[17:52:30.967] part name misc
6 K6 ~( A+ C+ K4 Y2 ?, M' h: i[17:52:30.967] keydata = 0x0 j* q0 ]$ z T. O& H1 C& a
[17:52:30.967] part name recovery
8 j3 C3 v& N- H/ q4 G[17:52:30.967] keydata = 0x0' u! D% v) k# V: h6 _* m# A
[17:52:30.967] part name cache
( w, o5 O( }" e" ?9 x5 o[17:52:30.967] keydata = 0x0$ |% p8 B# K# A( @9 @9 V
[17:52:30.967] part name metadata& C4 D) b5 p: k3 R: A+ C
" |/ M/ Z1 J4 A& C& d* _% }$ J/ w[17:52:30.967] part name private5 k" {3 |8 R% c* R& Y) f
[17:52:30.967] keydata = 0x17 J0 h$ c2 N0 D0 h
[17:52:30.967] find keypart private9 X+ i' r J% o# e; n. ?0 r* U
[17:52:30.967] keypart read start: 0x3c8000, sectors 0x8000
- ~1 j. p& Q8 T: E2 {' g$ @8 Q; C! E[17:52:30.967] keypart part private read end: 0x3c8000, sectors 0x8000
1 m5 X4 ^8 h' w6 q% O9 T* \[17:52:31.683] part name alog* H4 Z4 `8 _, B7 _- Q `
[17:52:31.683] keydata = 0x0
/ v I4 t: T" O( {! w- O% b6 W[17:52:31.683] part name UDISK
1 U2 }3 T6 m/ F, T M; s0 P2 n0 E[17:52:31.683] keydata = 0x0
. n0 Q0 t% k" U4 Q+ i/ _6 t5 r9 u[17:52:31.683] need_erase_flag = 1
4 @, J( ?& u4 L" |, w' |[17:52:31.683] begin to erase
2 y0 O* z P8 K# x[17:52:31.683] [ 9.537][mmc]: mmc start mass pro boot part...
& T1 | i9 S3 Q( x a: I" L# E[17:52:31.683] [ 9.584][mmc]: mmc start write user part after write boot part... _2 [& Z2 I; G+ v$ b8 W
[17:52:31.756] erase boot0, size:32k, write 0x00& I; }, v6 x5 a" u; s( J
[17:52:31.756] erase env part! `4 W3 e; r2 H: Q5 G
[17:52:31.756] [ 9.598][mmc]: erase from: 139264, to: 172031, cnt: 32768, erase_group: 1024' Y$ Z- }, p/ D# G) G! [+ J
[17:52:31.756] [ 9.606][mmc]: unrecognised EXT_CSD revision 8
8 d, d6 K" y1 u8 A6 x[17:52:31.756] [ 9.610][mmc]: decode ext_csd failed
- d3 F: c) C0 g p6 d& k c- u[17:52:31.756] [ 9.633][mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x1c52 us 8 e: l! Z& z! W) r
[17:52:31.823] [ 9.639][mmc]: calculate timeout failed/ A0 X: [6 y4 I3 w: Y$ {
[17:52:31.823] [ 9.643][mmc]: Do erase failed!! c1 R% z/ a1 x- X
[17:52:31.823] [ 9.646][mmc]: erase failed, range 139264 - 172032 4 T# n! ^# N: H; H
[17:52:31.823] [ 9.651][mmc]: mmc_mmc_erase: erase emmc fail!% o7 B; x) K! g( u+ r
[17:52:31.823] [ 9.656][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!, Z9 `$ H; U; l+ C. J
[17:52:31.823] [ 9.662][mmc]: --0: from139264 nr32768
; _0 \% w- ~+ v$ P! g% B( s[17:52:31.823] write zeros-0: from 0x22000 to 0x29fff, K2 o* q0 g! X
[17:52:31.823] [ 9.670][mmc]: mmc start mass pro boot part...
0 J7 ]' l+ W4 |* s# x$ H[17:52:31.823] [ 9.674][mmc]: boot0 start address 139264# d* O6 w% b! J8 L" @
[17:52:31.823] erase boot part9 _ L, L+ z6 H0 t
[17:52:32.539] [ 10.407][mmc]: erase from: 172032, to: 204799, cnt: 32768, erase_group: 1024
# n8 m+ c. K( J9 X[17:52:32.566] [ 10.415][mmc]: unrecognised EXT_CSD revision 8
: H, h; u1 t% f u+ ?" T; H[17:52:32.566] [ 10.420][mmc]: decode ext_csd failed# V' f' ]- }+ v, B1 f" \
[17:52:32.566] [ 10.443][mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x1c50 us 4 Y# N/ J/ |/ i/ O. }2 P ~2 b$ i
[17:52:32.633] [ 10.449][mmc]: calculate timeout failed# n0 Q- _) O* {! [2 G
[17:52:32.633] [ 10.453][mmc]: Do erase failed!) j. u9 d! j7 R# `9 H
[17:52:32.633] [ 10.456][mmc]: erase failed, range 172032 - 204800
) F" f/ X# j- N3 e2 Z7 s& W0 @( H. \[17:52:32.633] [ 10.461][mmc]: mmc_mmc_erase: erase emmc fail!+ E8 Q5 X5 Y! Y. I# q ~5 C2 |& E
[17:52:32.633] [ 10.466][mmc]: mmc_mmc_erase: some sectors in emmc are ignored! a% ^' |( c. D! b
[17:52:32.633] [ 10.472][mmc]: --0: from172032 nr32768 ) g _2 R5 [6 n7 j/ f
[17:52:32.633] write zeros-0: from 0x2a000 to 0x31fff
) z+ W: G& l; j4 t) g[17:52:32.633] [ 10.479][mmc]: mmc start mass pro boot part...
0 U" }, c. g8 _. i( ~[17:52:32.633] [ 10.484][mmc]: boot0 start address 172032
, B( d/ r, F! P# }[17:52:32.633] erase system part" d5 L; L; F" V( \4 S& c' j; U5 g
[17:52:33.349] [ 11.218][mmc]: erase from: 204800, to: 2301951, cnt: 2097152, erase_group: 1024
8 Z0 y; A2 U! G0 K, Y( V7 G[17:52:33.376] [ 11.226][mmc]: unrecognised EXT_CSD revision 8
s/ b ~/ a/ Z( r. i[17:52:33.376] [ 11.230][mmc]: decode ext_csd failed! O) ]" y* h( d; A5 a& S
[17:52:33.376] [ 12.360][mmc]: mmc_send_cmd: cmd 38 wait rsp busy 0x65809 us
( u: f7 ]9 p" h L[17:52:34.549] [ 12.366][mmc]: calculate timeout failed! ]/ p! ]9 ?1 g+ u/ N. q: B
[17:52:34.549] [ 12.370][mmc]: Do erase failed!
- ?; G1 i3 C$ v* r% x( n[17:52:34.549] [ 12.373][mmc]: erase failed, range 204800 - 2301952
% }3 E- `3 p' Q; w4 X[17:52:34.549] [ 12.378][mmc]: mmc_mmc_erase: erase emmc fail!. _7 }, e# {: X- l r5 d0 b% h
[17:52:34.549] [ 12.383][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!0 y$ U( u3 X1 q+ S/ ~9 C" G
[17:52:34.549] [ 12.389][mmc]: --0: from204800 nr2097152 " t" V7 n) U$ R+ Q
[17:52:34.549] write zeros-0: from 0x32000 to 0x231fff0 \: p3 r5 v& [5 c; @: A) j( J9 I
[17:52:34.549] [ 12.396][mmc]: mmc start mass pro boot part...
" |3 ^: Q/ Z( `[17:52:34.549] [ 12.401][mmc]: boot0 start address 204800& y4 [( ^' ~' I' M( U9 K
[17:52:34.549]
5 t0 W, n3 x% S3 ?2 |8 {# v+ s
