查看: 236|回复: 1
键盘扫描代码
发表于 2018-12-6 08:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
键盘扫描代码 9 \) d: c" C  ?' x+ Y
module key_board (clk, rst_n, row, col, data, valid, clk_1k);! m/ ]7 y' P& [! U# c( x
! h* e  E8 X( L9 e5 h* S) S        input clk;# Q) N+ Y# d8 B- K; `8 a
        input rst_n;
% R: _0 k' P( L  G        input [3:0] row;
6 C4 ?9 X" f- y1 J8 E          U  n7 d4 w( m7 I- r+ t# X
        output reg [3:0] col;) N/ r3 ?/ Y$ D) |8 }- }
        output reg [3:0] data;7 f8 B5 W4 i+ v% D' H2 D% X& ~
        output reg valid;( C5 \5 H0 m5 Y. Z
        output reg clk_1k;6 |; _  n- A+ u7 f% B" a: t0 D
$ w! m8 T" w8 c' i# q9 J2 F        reg [14:0] cnt;
# P" p- u# \$ p" \
' B# ^2 u) {. A$ `6 M$ y) o/ Y        parameter T1ms = 24999;
2 A1 W- J% j6 Z! b
: w0 O: K, g& T5 ?% E        always @ (posedge clk or negedge rst_n); A, `% {; D7 G& L! {8 ?* q
                begin$ E. y  M4 Z, h$ }- u
                        if (!rst_n)) j( Z: g6 T( H8 K5 C
                                begin
& j' z$ M: I9 n6 [                                        clk_1k <= 1'b1;
( t1 S2 k0 ^4 k5 p; L* w4 v2 E                                        cnt <= 15'd0;: [, W# B1 E+ Q' [( V
                                end3 c; ]; @9 u1 Y0 f, x; l' T
                        else' q  B* C7 w" C) g1 ~, q6 F0 V# \
                                begin0 |5 {0 c6 r  D$ v$ t+ H
                                        if (cnt < T1ms)
$ v% h; p' X  C& ?! P: ^                                                begin
$ y# Z. [3 X5 t+ c: T5 H. Z                                                        cnt <= cnt + 15'd1;
7 W; w7 W7 o) G4 C- g! G+ p                                                end
# m. y5 D  [3 `% U2 S2 A                                        else1 }  |% d  S, N( S
                                                begin5 U9 T$ O9 O/ R; x. q0 L4 z3 L
                                                        cnt <= 15'd0;
9 ]! y4 }; t8 }" |  U9 m3 O- K                                                        clk_1k <= ~clk_1k;
: K2 B8 z  r2 t  B& p  J9 J                                                end/ C1 b0 |  B& ?2 q5 x6 w
                                end          p. [  S. v5 C
                end) j" B7 h; G4 J
- M8 @# b3 ^8 Y2 z( Y. z
        reg [7:0] row_col;
: ^# X+ E8 F8 b5 Y$ ~7 Q, G: N        reg [1:0] state;1 `. L6 U7 g' _
        reg [4:0] count;3 ~* a! ]4 N$ i6 ?
        " Q6 c& N3 I" @0 {: C
        always @ (posedge clk_1k or negedge rst_n)0 x. G0 b4 ]* [% ~# G% V
                begin
/ A2 b7 w4 @, c0 U9 ], p                        if (!rst_n)1 Q  b+ j: H# r; A* O! i
                                begin7 D9 q( F& U! x1 w2 Y! w# n  h
                                        col <= 4'b0000;
$ T+ L+ H$ j3 P  f9 J3 t                                        row_col <= 8'd0;
1 k) v6 l* S6 h5 m                                        state <= 0;
. |$ x  H) S* v( t1 |                                        valid <= 0;
' c9 y& s/ X; A' {2 |8 m% I& g! F                                        count <= 0;
7 e0 c7 _+ j3 [# ]: i                                end
! G- ~# Y+ p5 J6 N( Y2 E                        else) I' ?1 F" k* C& ~7 U
                                begin
' O* k1 r8 x  f                                        case (state)' A4 F4 F8 b; L5 P- _  v! P: O
                                                0 : begin% ]' Z3 h% R! E" U+ k+ L- M
        if (row == 4'b1111)9 Y6 {) R% E: q; _* K
        begin
! i4 q0 @: M0 j( I# H$ }  w' e" a        col <= 4'b0000;
5 ?& \3 a9 V! a7 v3 h/ u" `        end
' `; ~: J$ G" D* b+ `        else
6 F1 g2 l( `$ h$ h- [. w4 ^0 h        begin5 C4 f; y" j  e
        state <= 1;
8 {7 l9 t2 v. C; m2 I        end
  T8 c4 Y2 T$ b  j. c* j8 W: b                                                        end
. J9 N; \6 x5 y7 z# L6 D) x" {& [
% A9 h9 U' ]9 X9 w5 O                                                1 : begin
& a# B/ c" r( G2 w        if (row == 4'b1111)
' v; }  Z) q0 d5 B( N% W/ Z8 R        begin
# ]; S, k6 A7 F        state <= 0;8 M  ?! T* Y" _! _
        count <= 0;' _+ L) m" o+ P" y
        end! I0 S# j3 ~- u: z" R
        else
. w( G6 i2 N8 G9 o        begin
( W9 V' t1 V1 B        if (count < 19)  S! Z8 }% i4 F) g. g& v
        begin4 }0 B7 b! {/ {% q' D6 t' B7 A
        count <= count + 1;
' @3 F# C$ b7 x: K1 C  t        end/ k  K! h, s0 K2 M% z
        else6 K4 i! x( F) Z1 z
        begin
0 l1 w5 I, d5 R4 S* H) w6 K! ~        count <= 0;3 W+ b- h# f$ G, D- \
        state <= 2;
1 X' d$ F; \& ~# q        col <= 4'b0111;
# q& {9 }9 c8 `        end
$ h$ }+ T8 W8 y4 t        end
& [" n+ u9 i- W3 x5 F# t' v, k                                                        end
& c0 r% g2 J/ ]7 x) S& D
9 N$ \7 Y( X* ]* ?5 Y' T* T                                                2 : begin# P( F1 g6 D: F' t4 H2 L
        if (row == 4'b1111)" @( ^3 ]0 }( w/ e
        begin: @5 L; e5 r# ]) u* X" k4 K
        col <= {col[2:0],col[3]};5 _' L! ~1 I; I9 {
        state <= 2;# j9 |2 y( y- }0 w* \
        end- z/ X9 W% D% h6 {
        else
* b7 S/ x! _; S9 w" T5 h& \2 y( P+ X        begin
, ?3 t$ t' c6 X% J$ J        row_col <= {row,col};7 W0 f2 b2 w2 B
        state <= 3;/ k8 \9 ~: Q! @6 P1 ^
        valid <= 1;; Q! V1 U5 |9 p; E& H- a5 z; V
        end1 f3 J7 C- {/ F- q, K' }( a- X
                                                        end( I; z& w' n% Z" l4 E
8 S7 N/ }; F0 c  J. M( N                                                3 : begin8 b9 O& m! K/ d$ y  \9 X
        if (row == 4'b1111)" v9 Z( M% S: K7 ~- t- b
        begin! C* n/ c: f% e7 k/ s3 w
        state <= 0;8 a6 ?, z" ~* l# X" {
        valid <= 0;
9 O1 ]: q7 g/ m        end
) e9 H# f. x$ `7 H+ A0 i4 \3 |        else/ j% Q" l8 b) Q' ]" q3 \& l6 X) Z
        begin
5 X) @4 g  a% K2 P6 B! l        valid <= 0;
9 ~  ]$ G$ i! q% N        state <= 3;2 E. z8 C: n, X  @) u
        end2 }" `% c  @) x3 ~3 u
                                                        end, F7 `/ u/ f  ^$ e5 i
                                                , V( M+ ^' U; K9 Y0 i5 G' Z- L: k
                                                        . }1 }5 `3 e( {
                                                default : state <= 0;
4 ~9 S3 G/ P5 r1 a
/ g  }5 C) V$ q6 _1 a+ b. D                                        endcase
7 c# x* `3 a5 ^  _  B, J. t0 g                                end2 M" y" o$ p7 Y( D4 P
                end        2 S; o7 f) ^- q
4 s; l$ C/ x, J1 l( e
        always @ (*)
' B% f! ^5 R/ G# {7 G2 |+ m9 S7 H                begin& [6 g# {8 }! I" `0 n2 C4 r
                        case (row_col)
9 T: K: r+ c2 {5 m                                8'b0111_0111 : data = 4'hf;: ?  r" N" \% n3 {1 ?; A
                                8'b0111_1011 : data = 4'he;! C/ Y9 b, y' [( }% y
                                8'b0111_1101 : data = 4'hd;
0 p* a0 ?6 b4 F  r! |6 g                                8'b0111_1110 : data = 4'hc;9 R2 L5 I3 `& l! T/ a
6 Z- f# K$ L" ~! V1 f                                8'b1011_0111 : data = 4'hb;
: k7 l% F" ], b& d* ^                                8'b1011_1011 : data = 4'ha;& X. a/ X0 {2 U# U% v# D
                                8'b1011_1101 : data = 4'h9;
7 D* p! l) ~  G6 I  h" r, ?% Q                                8'b1011_1110 : data = 4'h8;
$ F$ O4 q# g5 M( S( h% {6 S/ ^                                , N! L8 S' O4 g; r& d1 [" L& [
                                8'b1101_0111 : data = 4'h7;: B* B% C  K4 p6 l9 L8 x+ q
                                8'b1101_1011 : data = 4'h6;% w9 D4 U9 @9 \! Z, c+ y3 R- P
                                8'b1101_1101 : data = 4'h5;
; e7 B8 F) e" g# ?3 d                                8'b1101_1110 : data = 4'h4;7 M/ k1 g' ~& l
                                3 Q; R  D, w7 l
                                8'b1110_0111 : data = 4'h3;
% E2 d4 I' q6 h" W                                8'b1110_1011 : data = 4'h2;
7 z5 M. a6 a. c( z                                8'b1110_1101 : data = 4'h1;
* u' `! @1 s  o/ J5 O                                8'b1110_1110 : data = 4'h0;
) P; b2 N. R1 Q: i                                6 q) W' p8 M. Q5 u3 }) K% ^
                                default : data = 4'h0;# |- I' _& ~. |& G
                        endcase5 F" R! T! i  K
                end
1 C2 ]5 b7 D7 P
( ~# T, Z+ J" w1 b0 y; Z+ d! N7 m5 D
endmodule
- P3 T& U: a, B! Y. N4 z/ z* t/ ?
! [/ d' T  X$ |; k+ g7 [5 J5 {8 d. M8 ~3 j1 c( Z) j
# O% S% B; `5 a. ^/ Y+ _! W8 J3 D8 s8 [  q9 R" Q
2 J; Y. r# t6 u4 b+ s- @9 r
) N3 \* y( [: ^' N
GMT+8, 2025-10-6 21:05 , Processed in 0.125000 second(s), 24 queries , Gzip On.
