查看: 752|回复: 2
单片机99秒定时报警器proteus仿真
发表于 2018-11-30 09:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
单片机99秒定时报警器proteus仿真 0 S( a6 M, Y  g- u5 Y
: M  R6 D, a! u( P' l6 L
0 }' G: `" L4 E! G' p. G% W% K8 b
单片机源程序:
' K3 v* A! k/ q3 L; V#include<reg52.h># J+ S( ]  d; H3 U
#define uchar unsigned char$ t$ B. |, W2 J/ v8 ?
#define uint unsigned int$ C# ^( h, h9 M4 G7 _/ O7 |& W
sbit k1=P1^0;
; ~& K9 K; l" }$ U3 Ksbit k2=P1^1;
! r! F' }$ P0 k8 H; ]& @5 f4 O6 ksbit k3=P1^2;
, b. K' J7 K. S+ ?0 osbit k4=P1^3;8 E2 h% }. V3 \4 a5 a, L( F% U
sbit buz=P3^0;
# c9 P. }) `, R: ^' [& R+ k) s# auchar code duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};* W# q; {! z& T5 k
uchar count,shi,ge,dcount,dicount;
7 c8 S$ q2 g5 c+ y* ?void delay(int ms)2 Q' D4 K/ y( w& A9 ?
* u( Q& Y) t+ W6 Q, d6 q        uchar i,j;
" d6 U8 G% F  ~0 W        for(i=ms;i>0;i--)6 \) c; \- C0 h( B2 E3 N9 Y* l) r" f
                for(j=200;j>0;j--);
7 U$ e& ]  y" Q8 m1 N6 M% O0 Z}
4 T, O0 r1 H+ J% v3 k% @void init()6 E$ w( Y- e& |+ q2 M. q8 P6 S
{1 G" T, |# D7 [
        P0=0x6f;. N6 O1 b1 d6 \7 b% T! \/ N$ |2 M
        P2=0x6f;
, V0 s5 v: Q1 |5 y& \/ T9 v        P1=0xff;
0 C" o: L/ {- C$ @        buz=0;
- R  M2 ^7 ~5 f- \        TMOD=0x01;
* r. o( f! _, v3 K2 o( S        IE=0x82;
/ w* z; r9 @4 L2 j' O        TH0=(65536-50000)/256;  m" A% q7 F( p$ i, l
        TL0=(65536-50000)%256;% O6 J' {  Z! B1 d4 y
        TR0=1;8 X( [) ?) I5 P/ l
        dcount=99;
5 k9 |9 ~+ Z' ^; x. W# g4 p}
0 j4 R; N. ?! |# lvoid keyscan()
, ~9 T; g, V' G$ _( v7 P{! h4 w) p9 p: {# k: N1 ~6 i! O
        if(k1==0)
+ ^+ X) m3 d. G7 i% h9 _        {
1 C3 ^) M" a& F5 d                9 y4 M! X3 {6 M0 J' i
                delay(5);
, s, j/ d" w- B) V- ~% O- v, _                if(k1==0)
( A( i: _% N" n0 j8 {3 R2 L% ]1 B                {- k! D2 S5 s( i1 c3 A* p5 I6 u
                        TR0=0;
+ ^3 ~' E! i4 K$ I. e! Y. q4 p7 C                }
- C7 l8 E9 x& C% @" [# Q5 ?        }                ( S3 R2 {1 m7 _0 x
                if(TR0==0)
0 g, q) L$ h+ R5 v1 i/ h                {, \& ^3 Z' q, _% r  n: Y$ m5 d6 ~7 R, x
                        if(k2==0)9 a/ S( p2 t& m: `; u& f; ~
; U0 B% N& o, H) B/ g                                delay(5);& M) n' q% i6 F9 y* N. D+ Q
                                if(k2==0)6 J. M$ Y: B) z
' M! t# I0 x: R# A" G                                        - c& f% y3 c6 k% c2 }0 w- \
                                        dcount++;
$ G, i4 t: S: \                                        if(dcount==100)* p3 v) M  A5 q" G0 z1 w5 z! V2 I
                                                dcount=0;
. j6 w1 {! U' \% K                                while(!k2)
, y( v& ?# }. A                                        {        & k2 n& U3 G9 X: P
                                        shi=dcount/10;1 e$ M3 [+ s$ h& ~! Z$ d4 S
                                        ge=dcount%10;
: `6 P9 w( M+ d% i6 M- V4 @                                        P0=duan[shi];
6 m& q# o7 ]6 q# z                                        P2=duan[ge];2 \) J! Z, f; H% M
! q2 g* D& J" {; O; g                                }
% `' Z' m7 z% m# o& R8 D                        }
; ?7 C. {) I. S3 n& t: Q' W8 L1 s
- K1 O6 A) X8 s) j' P2 e; l                        if(k3==0)
. h- W$ ^" D: A+ J                        {- U; Z7 W, L+ f+ n# Y
                                delay(5);+ {2 V; [6 h7 X: B) c4 m
                                if(k3==0)  t& D  V2 R0 R" D) v1 g: H
                                {; k; N5 ?8 u6 s* A2 v
                                        dcount--;
: k. n6 O6 h8 w+ |" m* Q                                        if(dcount==-1)
8 {1 S. c" k% j4 U5 k, F                                                dcount=99;
( u$ g* c3 [; c' f! H                                while(!k3)# i' H4 k# S& j0 I2 ]
                                        {" {5 L& z6 J: x% V
                                        shi=dcount/10;
8 E8 {5 B+ w* v* Z$ d5 l, C                                        ge=dcount%10;
% H8 w. R' o$ d4 D) w  A  x$ g; Y                                        P0=duan[shi];
6 [, D: m. Y5 h) T                                        P2=duan[ge];
9 Y8 _' \% P# u$ r% N                                        }# j/ r% `% @8 E, q7 y! c4 a$ i
                                }/ ~; c$ U( _* t' O8 L
                                0 U+ |7 z9 h, m. ?" Q/ N
# s/ R4 I* W9 O6 W, o& G" o                }
+ D2 m/ y' N: Q9 N; m                        & {1 W9 M# t% \4 K5 {
                        if(k4==0)
8 Z2 p/ F8 I  H( T                        {' h. ~4 n; o6 S5 U
                                delay(5);0 @. Z8 \5 P, E2 m$ @
                                if(k4==0)
8 u/ T( x+ y% L7 y: y: `                                {
( g; O' R+ i7 k( d                                TR0=1;% D# r6 [. }' d- K6 P
. a  ]1 m& \6 ]5 k                                }
, r5 v# B& W; A" F. t' V% \                        }
  m- a' N. x0 z, t5 p- B
5 ?% f: d& m$ w: O" a3 f        $ m' ^/ U! i8 l7 p/ a5 T7 R
3 L- j# n. R! g5 ^0 n* w) Vvoid timer0() interrupt 1$ o# s+ ?% z6 y' V8 g! T' g+ B+ z$ j
{+ q9 q3 z, ^' F' `9 i: S
        TH0=(65536-50000)/256;  }# I8 I! h$ g% w9 f
" n, b- A4 O' D7 t2 Q2 V        if(++count==20)
" Z8 t0 r9 _  }1 f        {% }+ F) H3 k* R; [
        count=0;
5 N$ \4 E* h, D3 [' V" M1 C+ K8 M        dcount--;
# i! l0 q, k& x        if(dcount==-1)
$ [8 D5 w/ ~# a+ }        {6 m; F. r! F3 K3 B
        TR0=0;+ e4 r! P. l+ ]# j# `
        while(k1!=0)
, L; ^" B( i8 u1 C, r6 n                {
! t8 F5 ~" B5 i5 w4 A                P0=0x00;* [% e4 J6 s% p
                P2=0x00;
' X& O- }& q! n                buz=1;& ^' R7 C, z9 I8 l0 z* R! U" e; D3 O
                delay(1000);
) @5 J9 B* [4 _) y                P0=0xff;
& S8 t' U- F" W& l5 t" g$ S6 K                P2=0xff;
9 g1 t5 t2 Q8 |' z                buz=0;
7 d& r" w- F6 b$ P7 i* V% l                delay(1000);3 n9 _5 f3 @3 s; R
                }  ?* R# s( G" q9 S
        dcount=99;! h; ?, W' }, J: n
8 M4 x' E4 T1 K+ w  S$ F0 j  V, f        shi=dcount/10;$ R/ ~- Z5 F8 T
        ge=dcount%10;& R9 k9 o& |8 [1 R) p- e
        P0=duan[shi];3 L1 Q; D. v& P# w- `* `
        P2=duan[ge];3 L/ y7 K  F& |
        }* l& f8 Y2 a- I8 B5 K
                ( b  z" g, F/ K2 ^
}+ ~3 Q# O9 E. J& |8 g) ]# X
void main()
. H6 ^. G" c9 B! i1 v6 a& r{
- l4 [5 ?9 O5 g2 S        , H9 y" R& b! O6 k
        init();
. F: G& J9 v+ Y6 f7 \  i) j        while(1)1 [0 \- `  L$ r9 z5 ~& Q' {5 {. d% r8 i
        {  |3 L/ i8 p9 j  m; C
                keyscan();" d' e. Y8 N& I  |/ n0 G
+ y# K6 F- }, M$ ~0 V& C$ a- y1 k
+ _  R- C. P- w( V" a. h2 N" S6 G}) ?$ l( _: a- k1 k
游客,如果您要查看本帖隐藏内容请回复
; x1 c9 D4 o) F$ l* J) D7 K
' g+ e1 _2 X7 U) l" u) J
发表于 2018-11-30 09:48 | 只看该作者
谢谢楼主分享
发表于 2019-2-25 17:12 | 只看该作者
不错,谢谢楼主分享
GMT+8, 2025-11-1 21:27 , Processed in 0.156250 second(s), 26 queries , Gzip On.
