这是最新版 v7.10
# W, B e; }. T2 C9 a" i4 x相比较于之前版本的特点如下:至于使用方法,使用过老版本都很熟悉的啊,没用过就下载6.0版本的手册,有中文的。本版的帖子里就有!8 u9 V3 t! T) j/ U, _4 X
1. Export W-Element HSPICE Format
2 n* O$ \5 n2 ^2 ?4 |2. Increase 3 decimal point precision on scientific notation for Copy to Clipboard functions
! t/ W' ?8 A* p$ M3. Change default S-Parameter Steps to 200- A* ^ H) C: U! \% E) \/ Q0 N ]
4. Add Glossary to Help menu; f& O' }' S! C# `5 S; m* e
5. Append /line to column headers, graph axis and Copy to Clipboard format when Result Presentation is /Length of Line* W& T, @/ A7 G- ]
6. Following feedback regarding our Kf / FEXT result, make code changes to calculation function/ ~. Z B0 Z4 u' T& I! B" `/ q$ r
7. Add units to Kf on Crosstalk tab' r- l5 C B5 \. u/ g
8. FEXT has a maximum limit value Vf=0.5Vin
2 A$ s9 M' l: G+ W7 h* S* k) V1 y9. Correct Copy to Clipboard functions: to work correctly with Singled Ended SPICE RLGC and Differential Even Mode tabs. I M" e. y# T7 }! B
10. Correct Touchstone output format
8 f3 P- x+ g5 b11. Alter graph source data when using Differential mode for Inductance, Resistance, Capacitance and Conductance
3 J% k- ?2 O: p% m# ?- B" }; b% f12. Suppress differential mode graph option when plotting S-Parameter data
$ X, l: ~' B% ], X+ r( t3 ?9 ]5 c13. Correct Edge Coupled Embedded Microstrip 1E1B2A structure6 n. F# Q& J3 I$ x. u
14. Correct Goal Seeker for W1 / W2 (etch factor orientation) when using 1E structures( C/ U2 A3 r4 C4 `* g
15. Er==1 sometimes results in infinity errors. Alter Calc Engine error handler |
