点阵资料加程序! t: Y5 @: e3 ]7 d+ i
MAX7219点阵模块+控制模块+单片机模块+显示模块杜邦线5根
( M j( ?) f0 a7 l' F( e
) i: G& ]0 d; L) N2 V( S2 o* F }MAX7219原理图:! M* p: t4 g8 c5 c$ T7 F! Y
: u$ [3 W1 X9 x P7 ?1 j. S9 H
4 J% @6 \% q/ }2 k1 k9 O6 a4 b3 V# s/ r
9 s! S8 X: I; O5 r9 g# |1 e/ g2 k$ p单片机源程序:
/ \% d4 ~ I+ w8 d4 y, _0 e. T |
#include <reg52.h>
' n+ B- t2 r* k& x2 k#include <intrins.h>
4 C8 ?; N/ ?3 G" Q% X* c- e. o% Y#define uchar unsigned char
/ p) \6 H$ b0 ?0 v, g( F+ t( x#define uint unsigned int
+ ?9 c8 r, f ~3 H//定义Max7219端口
* O* F5 N" ]( w ?0 a# a+ }# E& z
sbit Max7219_pinCLK = P2^2;
) {* d' `! ^* a; j! D9 f* S
sbit Max7219_pinCS = P2^1;
9 v+ k1 v+ @8 F1 A( N3 H7 p8 a7 Q
sbit Max7219_pinDIN = P2^0;
" J; m1 s% l, J4 |5 P9 Euchar code disp1[38][8]={
/ Q8 X& o- J5 h9 J+ r" Y0 Y* b
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
6 U4 D& O, [; Y7 q8 L& O
{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
8 b3 j* N4 R* b. l& \& J: d, p
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
1 h- r. w% P6 t
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
/ H% `. p _* ^' z4 h
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
# b# ]2 ?2 J/ t' F{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
6 V% G0 Z$ a2 {# s( u; ?7 | p8 O8 C{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
+ F* O, Z" ]; Q: e7 B+ S; }{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
3 F/ o% {6 h( z+ ~* r( u{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
( h% v+ P7 A; Y8 t{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
; ~ p; h. k# Z% A{0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
! }& p4 @ g- \{0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
) Z$ L' x9 H. ]& G
{0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
7 ^% v5 D+ K) D7 r) I{0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
3 k! p% j' u4 E+ u+ K& ^6 P7 |{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
2 t. f' V( Z4 e* R1 C2 I' s; y- x
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
1 Y( X! t. K6 n, O# ^ a{0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
g, A2 i0 N5 g; T+ p
{0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
$ V( s5 [" t$ a8 ?{0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
% F% U- [8 ^' |. [( R2 F$ a0 B/ o3 T
{0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
+ a7 C& q+ T# \5 v) z8 B
{0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
4 ]; ?6 K( F4 B
{0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
4 Q$ C6 t6 n8 {* i- n- j{0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
1 h% B0 }7 w4 `" R4 O{0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
4 z7 \" D0 v2 U; h3 M
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
) v) a8 @0 d1 {8 Q3 j{0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
. U' A g. z# g. q9 h2 a# Q+ ]
{0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
2 i* I2 V% g; G
{0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
0 H% A; T% f! X{0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
3 ]0 o4 l. e8 h$ r; I+ r6 ?: I' k7 i {6 s{0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
6 A& S4 K8 [ h; N( }
{0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
1 u* }! q$ J$ H! O# @* ?+ ~6 Q- ^{0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
& S! }+ j" x8 n# G# f{0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
2 b ~9 \+ ~8 s1 f4 o/ M7 i{0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
$ {0 K# }6 _! n& l- ~5 [4 h4 P
{0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
5 l3 e+ {4 O' t! \5 W6 i{0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
. _. m/ N4 S0 o, K' w8 A* @& I{0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//中
! ]7 U, T- w& L% W{0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//国
4 p. t9 r/ ?6 w( c) l};
3 E3 [7 y* _7 z: Ovoid Delay_xms(uint x)
R! G# Q7 z8 V1 d% `/ I! Y{
" |0 I: {/ M& ]0 @& |
uint i,j;
0 o# }: i/ [* [$ ? for(i=0;i<x;i++)
# J0 s% F/ M8 ]/ g, _5 R, b% z" @. c for(j=0;j<112;j++);
e& w8 Y0 m f1 \0 ?}
$ l) m/ w5 F$ ^2 ^4 Y0 y W
. A1 ^2 Z! v) w' ]
//功能:向MAX7219(U3)写入字节
7 q' h$ ?% [/ ~, Q
//入口参数:DATA
+ R1 t, b$ t: }4 j
//出口参数:无
+ t1 k6 ~- z3 t0 m6 e' N) l//说明:
, m+ p: J! g' K5 ^# B
void Write_Max7219_byte(uchar DATA)
/ W+ ^2 Z8 E8 U" l. H( m7 W
C! j8 G; |' [- n: t1 |
uchar i;
) @& y' R6 V: i4 b2 s: P Max7219_pinCS=0;
9 a3 g4 o# V( n0 f
for(i=8;i>=1;i--)
& s6 U: i% W' p2 j8 w. v! [0 e! u) _% r8 R {
- U! |2 f9 c8 B) D3 l" I Max7219_pinCLK=0;
9 D8 k1 ^% G7 b% ~* s, h Max7219_pinDIN=DATA&0x80;
6 a- V! u* N/ J+ p5 S
DATA=DATA<<1;
9 Z$ J2 v0 T; q$ ~* E Max7219_pinCLK=1;
3 _9 G0 z, z7 f# E& W5 |' ]9 a! D }
( A4 X- h# A4 f% \$ I5 r" P \
8 k3 a/ o* }1 h7 h; ^0 R//-------------------------------------------
$ f- Y: n4 e! L//功能:向MAX7219写入数据
; `$ |0 l6 |8 N {; W( n/ `
//入口参数:address、dat
/ C0 W R- {$ Q8 ^# \: [3 p
//出口参数:无
3 r5 L+ E) U, W% ?& g# ?1 v
//说明:
8 u' H7 {9 b. J9 G- w4 x4 L
void Write_Max7219(uchar address,uchar dat)
0 y; y! h* q/ I( Q4 T{
9 |* v( L6 h6 K ?7 p" J Max7219_pinCS=0;
: R+ R) g2 \/ G- x. J1 U _/ g Write_Max7219_byte(address); //写入地址,即数码管编号
+ ]- i- \# J& Y5 g
Write_Max7219_byte(dat); //写入数据,即数码管显示数字
+ F1 ~4 r& y& y* V8 I y
Max7219_pinCS=1;
4 D8 z2 A" A& |/ F: {% Y
8 M: z( q7 R ?+ j3 `! Y0 T7 B4 e& ?+ Q# `4 g* w5 A C7 F
" v" ~3 f- e/ S8 U/ i& d; dvoid Init_MAX7219(void)
, |! X; P' N9 f! f, q{
5 f3 t9 N* F ~$ S! p6 j% S
Write_Max7219(0x09, 0x00); //译码方式:BCD码
% ?5 ^& C0 f% R5 D, K8 r) v6 R
Write_Max7219(0x0a, 0x03); //亮度
K0 \* V) H* I& @
Write_Max7219(0x0b, 0x07); //扫描界限;8个数码管显示
& q! {0 H$ n6 ]. ]0 K0 e& A8 E2 B. ? Write_Max7219(0x0c, 0x01); //掉电模式:0,普通模式:1
2 l! t- ^( {) {4 t3 n; [$ K% g& A Write_Max7219(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0
/ o0 o" Y- N7 _
/ P4 ]: h& d& D6 o. j0 L
$ C3 ~! D# h3 I/ g
. u3 f5 T9 t& p( w. G L; {
8 g9 E. D1 @7 B# b6 G2 p7 V+ J; K/ N! I4 s; z& N# o
…………限于本文篇幅 余下代码请从论坛下载附件…………
( s# Q4 t' w) ~1 ]3 s9 J% S) u5 X: i0 M
