字符串$ t# A% w9 M8 M. q' j8 r8 K
Python中字符串相关的处理都非常方便,来看例子:$ v1 K; y; N& \3 M
a = 'Life is short, you need Python'
1 _9 o: z4 o! w9 sa.lower() # 'life is short, you need Python'2 X0 d2 ? l5 e& V% T
a.upper() # 'LIFE IS SHORT, YOU NEED PYTHON'( i. S6 s4 p/ t" c& s# j; r
a.count('i') # 2
3 q# q* U: U$ q9 ~& _a.find('e') # 从左向右查找'e',3
- Z, ?1 y/ m9 R" r' Qa.RFind('need') # 从右向左查找'need',19
6 d0 e! v/ i# x y) \a.replace('you', 'I') # 'Life is short, I need Python'
$ M7 i0 O) L, ~9 b& Ctokens = a.split() # ['Life', 'is', 'short,', 'you', 'need', 'Python']
! y8 S" \8 y5 r- k0 xb = ' '.join(tokens) # 用指定分隔符按顺序把字符串列表组合成新字符串
. J3 g( A4 }$ M3 N: e2 a4 wc = a + '\n' # 加了换行符,注意+用法是字符串作为序列的用法
, D: y4 Z' q3 J2 g" g2 o Tc.rstrip() # 右侧去除换行符' t- R. b+ x6 V0 K5 Q6 {6 M
[x for x in a] # 遍历每个字符并生成由所有字符按顺序构成的列表
# \/ S, U9 v+ F& Z& d' X3 t'Python' in a # True
7 H" L9 b v0 W, p
y' ?' O! f' O- H( A$ yPython2.6中引入了format进行字符串格式化,相比在字符串中用%的类似C的方式,更加强大方便:
! Y6 q4 p4 [, F' L) e) Z! u3 Oa = 'I’m like a {} chasing {}.'; P6 `6 O u* j8 P$ e, }- o+ B
# 按顺序格式化字符串,'I’m like a dog chasing cars.'
+ o$ G/ _+ r* ], l, R& q& aa.format('dog', 'cars')+ M1 x0 U. P1 O0 j" v: ?# X% l. }- |
) z* } \4 o* H# 在大括号中指定参数所在位置8 j+ d" l7 ?, [
b = 'I prefer {1} {0} to {2} {0}'' q8 b/ V( z9 `6 i* c
b.format('food', 'Chinese', 'American')
0 J* d5 c( c2 O1 G! h
9 {; q" n- L y# >代表右对齐,>前是要填充的字符,依次输出:
4 p& v. L1 L; Z" _4 \' g2 P' j) a6 i# 000001
4 s% C+ q* P9 J! Y, b: y3 j# 000019
% G& X* B3 X. U s8 p" I% i# 000256/ |. o; U( y- M$ k
for i in [1, 19, 256]:& Z' H& T7 J p' Z- d8 D
print('The index is {:0>6d}'.format(i))
! k+ W# Q$ P" e2 |% R% b
! @& k) l* M7 N: {) I9 b# <代表左对齐,依次输出:8 u% B9 \1 M5 |5 F6 u
. w: @0 o# c, H3 o/ n1 C# ****------
7 I6 Y' n2 I: |- C/ ]8 e' p/ {! J# *******---$ `' g. M% g0 ]3 c# f7 O! r
for x in ['*', '****', '*******']:
5 p) s7 h# O y1 w- |0 Sprogress_bar = '{:-<10}'.format(x)8 o* d' J; W6 j' b0 x
print(progress_bar)
- p' A* O+ _6 F0 S! w/ u$ Q/ K3 V' D1 A) t6 k
for x in [0.0001, 1e17, 3e-18]:
1 U, i4 C( ]7 s. {4 ]% [1 o* Qprint('{:.6f}'.format(x)) # 按照小数点后6位的浮点数格式
2 f+ t+ s! `" U+ e7 rprint('{:.1e}'.format(x)) # 按照小数点后1位的科学记数法格式
" ~: J' ^7 V% Q- U( q' A6 Jprint ('{:g}'.format(x)) # 系统自动选择最合适的格式7 m' }- O {6 t4 P9 l! m. |* u
8 L9 ?6 n: A' i! w9 Itemplate = '{name} is {age} years old.'5 `7 L8 A6 j o" e( G
c = template.format(name='Tom', age=8)) # Tom is 8 years old.1 l- v5 R: z, E# A- I
d = template.format(age=7, name='Jerry')# Jerry is 7 years old. | 3 @! z' N% H5 I3 E
