查看: 250|回复: 2
LCD1602的时钟显示
    2019-11-19 15:19
    发表于 2018-11-8 07:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    LCD1602的时钟显示
    ( p: c2 u  J7 }$ {' J//简易动态可调电子钟设计. K3 c- p1 R4 H/ m0 W4 B
    //实现时钟在1602上动态显示且可调
      n  }" z) @2 d- q
    ) g0 Z" M# J+ q% S8 ?" nmodule lcd1602(clk,rst_n,rs,wr,lcden,data,sw1,sw2,sw3,sw4);
    3 ^$ J  V8 J- a: e0 o
      g$ y; G- i& d: qinput clk ;  //输入时钟50Mhz
    0 E4 c  d  C8 T6 J# K- binput rst_n;  //复位信号
    & ]0 X/ J/ T5 G  ainput sw1,sw2,sw3,sw4; //输入四个独立按键
    + J" q- o6 x2 voutput rs;    //1602数据命令选择端& g4 @' S4 _/ e2 @% z' i, j" H
    output wr;    //读写控制端% g! c: y& n( v$ w9 E# F/ l
    output lcden;  //使能信号控制端
    + ?# F* P3 y: g. foutput [7:0]data;   //8位数据总线
    . x  [6 ?' o) ]" a/ Y
    0 ?& P7 ?% g8 g' f; Q5 U8 w
    # z6 [9 ~  I  p! ^% z5 t, X) W& `0 vreg rs,lcden;$ _' i& K/ q  R! ?$ w$ c% _
    reg [7:0]data;( x3 Z8 _/ z- a4 }
    assign wr = 0;6 @' Y  h, i% D
    //---------------------------分频模块---------------------------
      o: L) F' y/ [3 D4 ?" a; ]/ `7 E" I! P. D( ^& Z
    reg clkr;; c" D7 y0 v  _3 @* m
    reg [17:0] cnt;0 k, c6 |4 ^% K
    always @ (posedge clk or negedge rst_n) begin  //产生1602时钟
    / ^; X) E) M7 s7 t3 o    if(!rst_n)  begin
    ; \6 {6 r  W" U$ ?            cnt <= 18'd50000;
    7 D- U  X7 ?: Y2 q, o8 u8 R                 clkr <= 0;2 m7 [9 I5 p3 Y+ g8 k6 r+ v9 ^2 [
                     end
    9 ]3 d" J) r8 {9 L/ J$ T! J; \$ ~- Y         else if(cnt == 18'd50000) begin
    . e. }' W0 ]+ I) f* u              clkr <= ~clkr;
    # K6 L; Y1 R$ R5 Z                        cnt <= 18'd0;
    . c' E8 m$ Q- B* K         end ! _3 o5 a' s6 m+ S. t% W9 e, K
             else cnt<= cnt + 1'b1;: N* f6 H- I! `  ~  M$ }, T
    9 k# ]8 \! q# m- O
    end
    0 P5 n! A- `$ V  r7 E4 R! ^1 P+ c3 r, `
    //------------------------状态机控制液晶初始化模块--------------------------
    ( W8 b! z7 F- Nparameter # w9 ]+ C3 K0 l, h. \- U
             s0  = 5'd0,
    ; U' }1 }0 m; ^  h2 t                        s1  = 5'd1,
    0 ~: U  j. d3 }: z                        s2  = 5'd2,
    - t3 l$ q8 {- n# \; ]% A  R0 S                        s3  = 5'd3,5 w; w. c+ _" h0 v# D! ^6 Z- u( }! v, A+ r
                       s4  = 5'd4,* ?2 W5 }+ Z1 Z. ?8 a' t
                       s5  = 5'd5,
    . V! q4 [1 C# E5 y" w, V. B, B  u                   s6  = 5'd6,
    6 v; T& f0 x3 x1 o0 h  Y7 q& ~                   s7  = 5'd7,9 z3 [! G1 J9 c6 N! V" X* v6 D
                       s8  = 5'd8,        " E+ ]1 @6 x% E) n7 W! W, e# G7 k8 r
                            s9  = 5'd9,
    # V" z" t0 s& Q6 o/ Y. y% R4 l                        s10 = 5'd10,
    ( b8 {6 j* p. r$ D  A. \                        s11 = 5'd11,
    3 O0 u3 V# ^" S- M9 ?( F% H; U                        s12 = 5'd12,/ q) e0 l" V, M1 O
                            s13 = 5'd13,
    7 U5 \* [1 `7 p, w                        s14 = 5'd14,+ G) }5 ^+ O& y) k, V- d. t
                            s15 = 5'd15,
    # x' S3 F% ?3 k  q. p                        s16 = 5'd16,
    . r9 s; m# C, s' i& F$ L                        s17 = 5'd17,
    5 z1 w' O# y, p6 b6 ^                        s18 = 5'd18,        - j! f% G+ V1 Z+ m0 \: i# z: F7 u" o
                            s19 = 5'd19,
    . e8 g2 C  u6 A                        s20 = 5'd20,: d( W. n5 M6 ]& Y6 T+ n
                            s21 = 5'd21,
    ; z9 z. d7 I6 N& K9 R. F+ }                        s22 = 5'd22,
    $ q$ u+ U5 }5 S  x5 N$ m. x% A                        s23 = 5'd23,$ X6 d+ {+ Z5 e5 o$ U
                            s24 = 5'd24,8 l$ Y: g5 b+ Z7 O4 Z) l$ A1 L
                            s25 = 5'd25,
    9 r' a3 W1 M! j# O) Z                        s26 = 5'd26;
    & v# Z( b* D" `, q
    6 V& ^' n) H" }& d" z                        , k9 x; ]3 R8 K- k' l
    reg [4:0] state;5 ~4 J+ O7 M& ]9 ~- W+ _
    reg init_over;   //液晶初始化完成标志位
    * k' E! k' U% p; A  E' s) E& H( ?5 E" `' }" k' Z
    always @ (posedge clkr or negedge rst_n)  begin
    2 k( O% T$ i: x   if(!rst_n) begin           //上电复位初始化
    2 b! q) u$ G6 Z% }- j  Z           rs <= 1'b1;2 M, Q+ L3 `, c! |3 y# J3 t
                    lcden <= 1'b0;8 g  X4 l% F8 h* V0 b& Y- N
                    data <= 8'd0;
    $ n- I/ L) p" O1 i7 B                state <=4'd0;
    + }+ l6 ^! O# ]$ v                        1 M, B% p2 s- U7 A
            end
    0 _3 h8 [6 |* I. d! z        ) |( [$ r& w7 ~* ^1 X
            else case (state)3 I6 j/ Z; v/ C1 c( }
                 s0 : begin            8 a$ j! w$ x! [( m- b3 J, x3 _
                            rs <= 0;
    " p+ K) F& Q( i4 B; K1 f/ a+ s0 x                                  lcden <= 0;
    5 L; l# D% V: f6 [- o' H3 s                                  data <= 8'h38;  //送数据,设置16 x 2显示,5 X 7点阵,8位数据接口
    / ]5 n) g  U0 q% w- z, S                                  state <= s1;
    ; g& D/ W0 G. K/ Q9 l/ h                  end                                    3 B, |/ Z: i8 u0 Q' \: s9 m
                      s1:  begin           //数据有效1 [% C! E- \. E1 D; D# p
                            lcden <= 1;
    * Y* e" `2 K1 |  r( ]7 j                                  state <= s2;) o- X/ q2 A9 p
                      end                                    8 E# s1 T6 M% T6 u- i
                      s2 : begin
    & ]) E3 p& v# l3 F9 S8 f5 T                       lcden <= 0;
    5 Z/ D/ O8 q$ j" y4 ]                                 data <= 8'h0c;  // 开显示,显示光标,光标闪烁
    " d7 S, o. s: L  _0 d, y                                 state <= s3;; x* ~- e5 N+ R/ G" S
                      end
    ! @# S! x: n. c1 m; _                  s3 : begin 2 N9 O6 C8 e8 r. ?# x" L7 g  n
                           lcden <= 1;
    9 R4 ?, B7 y3 ?5 ~: M, h                                 state <= s4;  K5 ~7 A1 l5 \$ I
                      end( S+ m# y, h* S% B' h) L
                      s4 : begin 3 Z; G6 a  w  T- u" Q5 l
                             lcden <=0;
    6 _8 q/ R) ~' F2 c: J                                        data <= 8'h06;  // 写一个字符后地址指针加1* H4 o5 u& r' ?' D0 Y9 s
                                            state <= s5;
    , U5 u/ [4 \% B5 m                  end
    * L, ^0 f. o$ s! _$ G# f, k                  s5 : begin
    / I5 ^& {. q- X7 Q                         lcden <= 1;
    6 f% G( b) }& q$ p                                        state <= s6;& T  l$ `! J0 A8 c/ _/ n
                      end
    9 q. `3 t/ ]* D/ M5 Q. w# I$ W/ v                  s6 : begin " n' M6 |6 m1 M' h4 C: H
                             lcden <= 0;
    1 m! K, B# A2 g8 |# i, R/ \# W' B                                        data <= 8'h01;   // 显示清0,数据指针清0' @( N, F6 B- \/ Q4 \1 H8 f) x
                                            state <= s7;
    . ^! @; k! F; x; T2 r- ~9 u                  end
    ' {2 N" I3 B6 I) u; T                  s7 : begin
    + ]8 X4 u. G$ q. n                        lcden <= 1;        # P/ Q, ?) T% `' {5 Y6 ~
                            state <= s8;
    # s' U: ]7 F- E                             init_over <=1;                //初始化结束标志位
    # M7 Q. l" q  ~6 U% C                  end
    - A1 P' z! k; H  l( Z" K3 r+ l! J//---------------------------------1602初始化结束-----------------------------                2 z1 S1 ~* u# ^, C  a  {6 y, V
                      s8 : begin
    ; K* e! p: K- `) I/ V$ g/ J                        lcden <= 0;
    ) m) E; x4 u6 |+ {4 U                                  data <= 8'h84;    ! ^) q" t% O, h" R4 n
                                      state <= s9;  Z1 M$ O+ s' D" y+ M
                      end
    9 g8 e) Q+ c( K: ]5 P$ O* @                  s9 : begin
    ' f9 y# q! o; ?% Q                        lcden <= 1;/ l0 t  `0 ^+ C2 H  ?, z
                  state <= s10;
      u+ ]& V5 C2 f- Y; w: }2 W                   9 A* Y6 B+ j3 n3 [
                      end
    ' g! L. I+ _! A% _
    0 [: k0 j# t% i% U
    * d$ a! W# ]5 y. _. {                  s10 : begin , K) z3 z7 e5 r1 Y2 Q" h
                            rs <= 1;          //改为写数据状态
    3 v1 v$ N2 C3 ]% ]% ]' ]3 [                        lcden <= 0;3 p7 p: n4 c! Q/ p2 R' o
                                      data <= shi_s+8'h30;    //写小时的十位! ?9 ?' h- B4 i' n& F0 B5 F
                                      state <= s11;+ _& Q2 C: x' U" h6 J8 y% M3 `% G
                      end
    # U0 V0 N+ u. n8 o! T; j                  s11 : begin
      [# w& H8 v( n# u                         lcden <= 1;8 ]. s( i* w' x
                                            state <= s12;" E) @, a7 c9 u3 W+ [3 l7 ?' O; j
                      end7 k+ d- {1 B- Q4 h0 Q
                      s12 : begin                                   + s  y; m4 w8 o, c
                            lcden <=0;) b5 F9 @# |" {! _4 _7 N: V
                                      data <= shi_g+8'h30;    //写小时的个位; C& E  N: i/ U( C( n" L  L
                                      state <= s13;1 Q- F4 p' Z$ i, j. u9 u
                      end# e4 T3 o* j6 t  K
                      s13 : begin
    9 Y9 }- g; D& c+ @, }+ ^                        lcden <= 1;
    2 S. D) {  V. F# Y9 {: ]                                  state <= s14;
    ' I/ M" R- @9 v7 X' G4 r                  end
    " ~, @. J, E7 G3 l' h                  s14 : begin                         7 d! s* a. h$ f3 K. g& ?2 M
                            lcden <= 0;
    . K! w/ N+ L. J& W                                  data <= ":";      //写冒号. [( E( i/ u' y2 b
                                      state <= s15;
    4 f8 z1 {# N* `9 h6 }
    : E6 I1 P3 K$ R1 _6 n! |                  end
    2 t/ ~- I% F- ]8 Q. S8 W* ^                  s15 : begin # _0 Y5 w& o! F9 u% V! T6 `; v
                            lcden <= 1;
    3 Z: E' ~1 x- J% x: {+ X                                  state <= s16;
    % ^7 W7 j# D- {5 O  P3 i6 p                  end
      X! {0 G1 h9 k/ B& B7 o
    1 Q: g5 Z( o7 G( s                  s16 : begin 7 K  v1 E& F' _
                            lcden <= 0;. w6 s+ Q3 W9 x6 I3 E  ?
                                      data <= fen_s+8'h30;  //写分钟的十位  ^! w$ w# H) X( }. H: I
                                      state <= s17;
    9 `9 C% k- U9 K+ |( e                  end
    0 V3 N1 Q; \* w( V# c* H                  s17 : begin " M6 Z: E* d# y+ l; E
                            lcden <= 1;
    . u' q: I$ S- @6 D2 F                                  state <= s18;
    1 |5 r0 h6 y  {$ A7 ?, s. M                  end2 v) S& `- t  `; K
                      s18 : begin
    6 P6 |* b/ V  [3 G5 k7 r                        lcden <= 0;/ |8 z  M% j, B% P( C
                                      data <= fen_g+ 8'h30;  //写分钟的个位
    . h$ `' U1 `( N: \- |                                  state <= s19;
    # X  s: O0 f/ K# c# R                  end  o% L4 R8 ~' s7 V7 u% H
                      s19 : begin
    1 F# K* `' W& e0 H, {6 O4 }" T                        lcden <= 1;
    / M4 p! j% ]4 W7 B5 \$ i3 g& p                                  state <= s20;2 `2 O1 L& }. f$ }
                      end1 i) c% R) E- r( M, F
                      s20 : begin 5 C+ C' i7 R! z5 w2 a
                            lcden <= 0;! d% `, p- S9 G/ j4 k( u
                                      data <= ":";    //写冒号! G  c2 k; X& C
                                      state <= s21;
    , Y1 T3 {  N/ X3 r                  end
    ! n5 @7 E8 K0 B* w) h3 S                  s21 : begin
    9 p9 R% ]: @) M! [6 a2 D2 \0 k                        lcden <= 1;2 S# A: o5 o& G$ F
                                      state <= s22;
    0 a) B+ ?2 Z9 ~& Y                  end
    : K$ N% W9 v8 r( D                  s22 : begin 2 v  i7 g& T$ F+ U+ ]( }1 E
                            lcden <= 0;0 A2 Q% o9 k% w8 K9 Y+ S' s( g
                                      data <= miao_s+ 8'h30;   //写秒钟的十位1 Z% B! c/ _8 }  M2 \
                                      state <= s23;  i6 b. W' x8 c4 _
                      end
    1 g, n$ T. b0 H                  s23 : begin
    ' W8 p% R; V5 L                        lcden <= 1;
    ) S0 z( c0 b, C( A# C                                  state <= s24;2 q/ @1 y( i" Y2 E6 u
                      end& F# n. `4 s2 P; A# F8 C7 y
                      s24 : begin
    6 S9 ?/ C% I  L3 R& g                        lcden <= 0;
    / |; m" S# d& T+ R8 @- N/ D                                  data<= miao_g + 8'h30;    //写秒钟的个位
    ) [! E7 d- D- G, F$ D+ G$ s                                  state <= s25;
    & u- Z) ]1 }% T0 X+ W                  end% m# W$ b: n8 G5 D7 t( T% }
                      s25 : begin
    2 v: i( A) h' K! L- I8 W; ~: a; a                        lcden <= 1;" L! a8 ?$ I2 `1 S0 i' Z
                                      state <= s26;
    - u- R; q6 [9 [0 W( A$ o7 S
    - g4 p4 J% X; Z                  end3 Y% w: @: m+ S( l
                      s26 : begin . C" J: A1 N' {/ s
                            lcden <= 0;" K  P0 Y$ V. B- G
                                      state <= s8;          //回到写起始地址的状态,来回刷新( ~) K9 B! Y; Q3 H0 L
                                      rs <= 0;9 R: ?( P0 Y, p1 K! g- S
                      end , \3 X! [( f, `9 L% K" ]0 b" J: d" t
                      default : begin
    5 d& U2 [1 u( J; E                            rs <= 1'b1;                                        ' x! U2 T2 `3 D* Q- g
                                                    lcden <= 1'b0;
    . c" s2 l# }  S& `                                                data <= 8'd0;  P8 o+ D; I- L
                                                    state <= 0;2 i; J$ h- t. V! a8 u
                      end8 O( L" S/ E) ]0 Z* V& t
    ' j/ d! i+ @2 o. ?' e
            endcase
    , u. J' ]5 d  J: s. K& y3 S0 z6 F2 Oend
    ' i1 c1 {7 P/ m6 c; K8 [% j
    " E5 k" a1 p! b* j# ]- V//-------------------------------时分秒产生模块---------------------------------
    8 D: P7 `# H0 m8 ]) x7 ?5 U3 K9 V* C. `) R
    reg [5:0] shi;
    4 Q2 B( J9 b5 K6 u$ E  S/ jreg [5:0] fen;
    $ Z5 F/ i- Z5 l* n  T6 c# Treg [5:0] miao;) s0 Q# l/ I' J  v# o
    reg [25:0] cntr;  // 产生1秒钟的时钟,要计数到50_000_000;8 K% _6 O2 C" j* F4 |: G( x
    always @ (posedge clk or negedge rst_n)begin
    7 G3 t3 |& b: ^8 h    if(!rst_n) begin ' k% W& N& ]8 w, W# y3 H. T( u+ M
                shi <= 6'd18;               //设置初始时间# J1 ]7 r) X9 Z0 b
                                    fen<= 6'd22;; L. c. k, ]2 N
                                    miao <= 6'd36;7 H1 b( [1 e) N+ o: H. J
                                    cntr <= 26'd0;; v% V/ R/ I8 D$ G. s" C
             end7 w$ G! Y1 h- }, I
             else  if(init_over ==1'b1 && flag ==1'b1)begin
    - }) J) p$ u( s0 s* O  }( C                          if(cntr == 26'd50000000) begin
    1 E; y! d# j2 Z                                         cntr <= 26'd0;
    7 w& `% c( O1 m1 |$ j& f8 q- I6 J/ [1 B                                         miao <= miao + 1'b1;$ P$ ]4 j5 b  N  X& A" g; I& `/ F
                                                     if(miao == 6'd59) begin
    # w7 D0 C% C+ J$ K$ |; N+ k                                                          miao <= 6'd0;2 q) u  b9 {; g. l' l
                                                              fen <= fen +1'b1;$ V  y4 G# g  k/ z# V7 z
        if(fen == 6'd59)begin $ x4 F, N7 _) ^' o; m
        fen <= 6'd0;2 l4 z* f# ]7 N1 n5 J; d( c# m5 m
        shi <= shi +1'b1;; {# b; U1 g% \* I
        if(shi == 6'd23)
    ) N+ d% N, }5 X, `0 p+ B: i% h# }& W        shi <= 6'd0;3 ^, a6 H: X1 d  S
        end% e- T- Z0 s: [( F) B
                                                     end5 b: T5 i) @7 w3 Q2 U& k( v$ c5 k  l0 \
                                     ! G3 C4 }6 s4 {5 I" o
                             end: P9 X0 c( S. F4 w* O1 b# M
                        else cntr <= cntr+1'b1;
    " d; p) t2 ]7 W% h0 _         end# L, T8 U% f8 @1 h+ ]
    , W* t4 e7 ?9 \( F7 V         else if(key_state == 4'b1000)  begin
    " ?. {( U* a7 c' t8 ~, J              miao <= miao + 1'b1;  //如果键1按下,那么调整秒针, g. w- F( p9 k, @& s- a
                            if(miao == 6'd59) miao <= 6'd0;
    ' N( Q8 \* A, b3 M                        end
    % o% q# t" J: d         else if(key_state == 4'b0100)  begin 8 `% q* W2 q! X( f6 i
                   fen <= fen +1'b1;         //如果键2按下,那么调整分针 ! ^( B0 T4 ?& a3 E% d
                             if(fen == 6'd59) fen <= 6'd0;: |+ K6 x4 B6 [$ K' B$ X" ]; h3 a
                             end4 j2 E# b5 M7 |6 Z) e0 o
             else if(key_state == 4'b0010)   begin
    . I: }4 D/ ?; E0 T; d+ {               shi <= shi +1'b1;   //如果键3按下,那么调整时针: y, M7 `( j- U0 b) z+ @4 m
                             if(shi == 6'd23) shi <= 6'd0;
    " \$ ^- X4 |  d9 F; `                         end
    9 k4 F3 W/ {, z* Z/ l% \" o
    1 A7 o  Y2 |+ ^; _6 j+ I* J# _
    6 r0 h1 S9 T$ f+ e0 `7 ]end5 W; X0 n, @8 g0 j& `' E  W# g
    % V- c- u* Q# z: Q6 ?
    //--------------------------------时分秒处理模块----------------------------
    2 l2 f& o3 r# W1 y. _- _5 O! u1 M+ u
    wire [3:0]miao_s;    " d7 D) Q: v2 S% n9 N; I
    wire [3:0]miao_g;
    1 ?$ H! f9 H# Q* L/ j0 i4 |+ l0 Z) Y8 N
    wire [3:0]fen_s;
    " g3 G9 X9 S; ^/ g0 f2 I/ d0 gwire [3:0]fen_g;
    & T8 R6 y- T' E* m9 Q; d3 A4 |+ S) C" ^7 V
    wire [3:0] shi_s;
    3 \- {1 h9 n2 j* d/ qwire [3:0] shi_g;! r* d3 F9 }) D
    ' K( X8 Q8 \% H7 }2 F' a
    //对时分秒进行求模求余运算
    ! y( X" l' E' m2 ]! L) Oassign miao_s = miao /10;
    " k+ _8 \- {4 P1 rassign miao_g = miao %10;2 d: b; s. [3 O7 g, c, _$ _
    assign fen_s = fen /10;1 K0 {7 A" x. H4 R( d2 v
    assign fen_g = fen %10;
    % B1 ?1 X: Z: m0 C' M) `6 Vassign shi_s = shi /10;2 H4 J' D7 P0 r0 o# S
    assign shi_g = shi %10;
    6 m/ B4 |7 F$ E8 g0 u. k3 C) e" l( Z* F; c7 O0 l/ _
    //-----------------------------按键消抖部分----------------------------------; B) D! w2 N/ [$ D+ Y) g& A5 K! U2 E
    reg [3:0]key_rst;
    % H. Y3 _5 I3 C6 ]4 J1 d* g: d% `: B' O" K) l
    always @ (posedge clk or negedge rst_n)  begin / d* u& C' d) D" C6 Q
        if(!rst_n) key_rst <= 4'b1111;. I3 U' t* @1 ~1 \. Q
             else key_rst <= {sw4,sw3,sw2,sw1};                     //将按键状态送给第一级锁存器锁存
    8 U8 y5 M' a' \end" a$ ]% I* C6 {5 x& k' V8 e
    6 m8 L  T3 t4 }) ereg [3:0] key_rst_r;   //定义二级锁存器
    & ]. G4 ~2 r- E: t
    4 k( i4 ~6 l1 F* valways @(posedge clk or negedge rst_n) begin # j, D$ m; x2 q$ p$ Y
        if(!rst_n) key_rst_r <= 4'b1111;# h6 T5 J1 k5 t! V  y! |
             else key_rst_r <= key_rst;    //送第二级锁存器6 g, M0 U8 \2 b! u' n4 I
    end
    9 U" G: v1 H6 ~8 l/ x- ^
      g8 y" x) g) H, [+ \2 K4 S6 Owire key_an;   //抖动标志位
    & X$ y7 }9 d3 u  Z; s0 z! G6 i$ tassign key_an = key_rst_r & (~key_rst);  //边沿检测算法
    % }4 ?5 M8 D% I7 y! U6 S! g3 a
    . |, A% G! f; R* C8 B7 W1 ureg [17:0] cnt_k;
    " a* M, V, }5 i/ x2 Y
    7 U6 }* Y3 h: M" valways @ (posedge clk or negedge rst_n) begin   {+ X: ?( w6 y" Z  R1 ?: P
       if(!rst_n) cnt_k <= 18'd0;1 ~0 P$ p1 c8 Y- [+ C
            else if(key_an)  cnt_k <= 18'd0;    //一旦有抖动,计数器马上清零( @( M( K- v+ m" R
            else cnt_k <= cnt_k +1'b1;
    0 `" ^- N& I+ ]& y' uend
    6 N+ Y  E2 j% h% A  E/ e2 y7 {; M
    7 j" j: h' ]$ R0 ]7 S4 oreg [3:0] key;
    3 M, J% w+ S: B1 S3 |/ L; t7 L0 \8 Malways @ (posedge clk or negedge rst_n) begin
    " N' x% g4 a6 G7 n0 R3 o3 Z   if(!rst_n) key <= 4'b1111;
    # W! f# d1 A+ C, O# G( t$ }        else if(cnt_k == 18'd250000) // 等待5ms,再记录按键状态0 q0 s0 n! V) F0 X; ~+ h" d
              key <= {sw4,sw3,sw2,sw1};
    ! ], l9 Y% o. x! O& Fend, V7 O6 @; j0 p0 z
    3 R1 r' I* b" o( F9 n' B+ z, ~
    reg [3:0]key_r;; o* x7 Q. y3 l# g1 a( f
    3 z( ?/ d% z: b& }$ f5 d* N9 S; \
    always @ (posedge clk or negedge rst_n) begin 4 e( k9 v. a2 t. N
       if(!rst_n) key_r <= 4'b1111;8 L! c  Z% f* `# J  V+ X
            else key_r <= key;   //送到二级锁存器
    / t2 O/ G8 W8 Y' m3 F4 B5 |end' T  t; B+ a# b4 h9 y1 o
    9 ]7 `3 v- F6 T: X$ J1 L- [) H! Z
    wire [3:0] key_state = key_r& (~key); //边沿检测算法
    # a" d4 V; H3 L/ t' u( z+ k9 r  k) w- S5 F! |, V0 V
    //--------------------------时钟暂停----------------------------
    / @0 S# Y! c$ L' q5 u; yreg  flag;* @/ J' E) r$ r' N% R$ c- S& I+ M
    " I" C3 Q. E3 o* |+ ]$ u6 r
    always @ (posedge clk or negedge rst_n) begin % R9 k2 c. x6 ?2 {
       if(!rst_n) flag <= 1'b1;! \2 U8 c5 L( Z7 x4 X
            else if(key_state == 3'b0001)   //  如果键4按下,那么时钟暂停
    ! [6 D* p9 I5 U- U9 `/ z1 q0 v           flag <= ~flag;0 U" E: b# o8 Y# D
    3 f  q0 \% ^! i8 A4 a0 K" qend3 V  }' w5 F: J: g7 {
    3 b6 q" Y, J9 i
    endmodule3 ]) K8 l* Y: B  s
    发表于 2019-7-30 16:28 | 只看该作者
    看看楼主的代码
    . E3 x" k3 j  E4 x
    GMT+8, 2025-10-12 18:51 , Processed in 0.171875 second(s), 23 queries , Gzip On.
