查看: 735|回复: 2
电磁兼容(EMC)术语缩写中英文对照
发表于 2018-11-1 13:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电磁兼容EMC)术语缩写中英文对照
a.c.or AC! \' [: A; ]7 A. E5 x* x% t# s/ ]% |  f
alternating current交流电
' r- O, G* [7 s. G$ d4 e! {6 F
8 d- E) ~8 w" D* ?ACEC
  B# O' l8 r: V( I* j- q8 [& @advisory committee on electromagnetic compatibility电磁兼容顾问委员会
5 k% d2 N6 i0 u# \3 Q' L  l; d8 w9 |
ADSL% v7 j( ~8 E3 h0 Q2 E. \
asymmetric DSL非对称数字用户环路
- g: k3 ^/ V3 j
% ~4 S: i4 [7 y4 f  `* Z! E' p1 sAE
! [* U  r0 U2 W$ {, lauxiliary equipment辅助设备
5 ~6 b# ~0 ^+ E. A( \7 o( u# x# j$ r
AF . Z# y8 m& Z2 M5 e0 M8 C  j' ^
audio frequency音频9 w& Q. s+ H$ U9 b9 A! l) s- a% i
. b: H6 Q* l2 A0 U! }" T  g: HAM , {) q. q8 z! G2 W5 \
amplitude modulation调幅
& Y) @3 p/ ?  f. D/ a  V6 ]- L4 A8 O
AN
1 s3 W8 \; \2 F7 L3 kaccess network接入网
, V+ \2 |3 y; ^
  N1 C6 U9 C& d& l% O9 n% cANE
/ t6 a( b% ]- ?, I7 ~* f2 x: ^access network equipment 接入网设备
' D9 n+ Z- \5 [9 \" `! {5 m! B2 S% }$ w
+ ?+ M9 J# U$ x7 X6 b8 QCDMA % c+ G8 ^; A: A8 Q4 e1 O% k& L' @
code division multiple access码分多址9 Z( t% ~  W2 S  u: ]2 G! V4 A! N+ }
* P$ f  \' v* _/ sCDN  - R! T' l% m( I  y8 \5 E
coupling/decoupling network 耦合/去耦网络
- z2 Z! B" p0 `1 h7 z, y4 ]
8 p2 ?$ g$ N6 H  VCIGRE
4 u1 B) L" v. u9 f6 |  E: tinternational conference on large HV electric systems 国际大电网会议8 j1 y# W  I; R5 u  x8 \% `' h0 P- k
/ A6 N3 l( W2 k' K8 z+ a
CISPR
( \, G) Q* H% M3 Vinternational special committee on radio inteRFerence 国际无线电干扰特别委员会3 X! ~5 o/ v  R& i, x/ A
& ]- h. p+ s( ^$ j2 S9 k. iCPE  ( i0 o: X7 i# j3 [; z* z
customer premises equipment 用户驻地设备
9 k' s+ z5 H% b8 @9 \
( D5 P3 V# ^$ A2 ?! @7 QCRT  9 q" B' l$ W% _, i/ @7 \, Q
cathode ray tube 阴极射线管
/ ^2 o5 f6 \5 C
* D- ?# M: t' J1 Kd.c.or DC
8 \- V8 F3 U, w, c3 \direct current 直流电
( `1 g' Z# D3 h+ w. z3 t& R+ t) T* n# X! _! y0 z
dpf 5 D/ K; i: O3 |2 B
dedicated power feed 专用供(馈)电
2 z0 u% N+ I" R
" h8 d8 ^$ N* e% I5 }DSL
; y* c% ^: h, ]" q2 f. g/ I' Odigital subscriber loop 数字用户环路
4 t7 o2 X+ v1 A  Q, L0 [' c$ {; R/ C' W# Z9 z& I4 U2 i
EFT/B
  W' }" D( C" J, F+ zelectrical fast transient /burst 电气快速瞬变/突发( t0 \# `$ A" Y3 G6 Z
8 Z  P* Z' V1 l( gEIRP
: E. M+ W$ V, jequivalent isotropically radiated power 等效全向辐射功率. h9 B3 Y* M3 G1 l8 P- ^. _& c( J
4 {% @; U8 t' M$ R. `2 _7 ~
EMC . H6 r) L0 O8 V8 J. @5 f% x
electromagnetic compatibility 电磁兼容性  O/ ]# Z7 O' g2 P1 I
- x8 @4 E! ~  m) u% z$ H  zemf
7 w- `- I! w2 w( ielectro-morive force 电动势
- F6 S- `5 R! y0 r+ a- K6 L
$ e6 V! D+ G5 \) `$ ]EMF
3 O1 x; w  P+ b  U- |6 aelectro-magnetic field 电磁场2 r7 x  n5 K, q, ~, x2 Q
  m9 G2 S* x- w6 i% F, Q/ G' c6 U
EPR . b) p! A7 v1 ^8 y  X' K2 Q
earth potential rise 地电位升高
& s: k  [8 M8 \! Z: A3 @9 M, Y* s- r$ M% X) x- Q. K' e
ERP
2 C2 o9 l8 a5 yeffective radiated power 有效辐射功率3 M" ^" A5 |1 t, H, }, `8 \7 y
. c0 T) B$ z7 W1 t0 w) k- m
ESD
0 }2 |/ [, g# {9 \: }! }electrostatic discharge 静电放电2 Q1 g9 C/ T* W2 O2 `% o
% N( v; C$ O! O2 X, B2 i  T0 iEUT
* e5 o3 m' H4 X+ |equipment under 受试设备/ J2 Z$ l8 a' ], m. ^0 A
$ l% j  d& K$ Q
GDT
# p) t- ?+ `. N- i' `gas discharge tube 气体放电管
* n/ l3 [$ t; A( p: g1 t
, B5 F3 V' W( H2 o; NGV % d+ `1 R  B0 k% s. w4 A% _
high voltage 高电压7 u8 w7 c3 _6 @( m4 i
) p, I" ^: S! Q- H+ E. U
ICNIRP
2 z" }5 s1 I6 \- Sinternational commission on non-ionizing radiation protection 国际非电离辐射保护委员会
9 O6 D1 ]$ A5 v3 e& |5 {4 T* x4 k% Z2 X' M
IEC 3 J9 O0 j" \1 f4 F$ a, d, w; a* u+ O
international electrotechnical commission 国际电工委员会! A+ d6 A6 Q7 B; m
1 x" H- \" D& C
ISDN 1 p' o3 l3 [5 P- D; J
integrated services digital network 综合业务数字网: I( u( T  }6 s( z' X# D4 k
) V, ^& R  [5 @9 [) [. s( W. PISM . ]/ f. ]* J% X+ B3 [
industrial, scientific and medical (equipment) 工业的,科学的和医学的(设备), o6 D5 I1 w8 o) B
) D9 N" M+ ]6 h5 ]7 }# L
ITE * c  K( w" e; x( E5 q: V% H
information technology fquipment 信息技术设备  g: O4 ]3 Q+ Q# N- Q. C! [$ s
% N; B% a9 U$ DITU-T
0 }0 V: \# g# k: @; b1 H* Xinternational telecommunication union-telecommunication standardization sector
! k* u: Y" J& s2 i" ~: S国际电信联盟电信标准局
3 K5 S3 R1 Z5 }
6 t! y5 E6 h# x" o8 W4 @& SLCL
0 S) k" Q) j9 k' W0 Glongitudinal conversion loss 纵向转换损耗
4 U0 e* f( l' o
& Z% U) _8 i& ~( kLCTL
1 b. |& e0 C& E& B1 V6 `2 A! X3 ~longitudinal conversion transfer loss 纵向转换传输损耗1 h- b0 G/ q5 A; _: ]. e& ~; `2 s" F
7 Z( v) p  u' T) K/ l; h& kLE 6 q4 m9 e6 |+ N# U
local exchange 本地交换0 M+ y; ~+ }' w' A$ K" p3 Q
! X7 D7 A; S' ^, kLEMP
; [" H' j2 V5 D5 u" Q9 Glightning electromagnetic pulse 雷电电磁脉冲& o0 ~9 F" s3 b/ i# h0 O
$ T7 a" N' Q6 I% p9 P
LI
7 j; v" C5 e  ^line interface 线路接口2 @; E' e1 }: l/ [0 f' E
0 c( I) g7 Z& y: j, E! GLPS
* L6 r4 Y+ v  _" w7 I8 wlightning protection system 雷电保护系统3 }( \7 A  S( `9 C# @
) w  `! Q; k$ {$ c% y, m2 l6 QLPZS
. @# p1 v! E* t& Flightning protection zone 雷电保护区
' [0 j  v% x$ ]8 \( G9 P
4 I# z: T1 Z0 A' Y0 A$ pLT 5 i6 v' D* ]+ U: S% N3 w2 }
line termination 线路终端! U1 O& z  r( n- K
' z' H2 \" U  Y$ c
MDF : a% e) A  J* T5 T- h/ C# T: L
main distribution frame 总配线架) h" M+ @; C- A( H: i* C/ ?9 B
2 M6 ]& G) Z8 J2 g% J% r2 j1 `MOV
2 a( ]/ x8 X3 m& N5 l. Mmetal-oxide varistor 金属氧化压敏电阻 . C  z- r7 y& D. `" N0 ?) ]" h
+ ^5 Y. ~* x' P: ]n.a.
% U0 `( h& u2 m( `not applicable 不可用
: i/ b/ v! q& m1 p! O+ L( _) ~# D2 v- a- w, I
NT 9 R" @$ w$ z: |
network termination 网络终端
3 d) d& C% N/ ^( r8 Y, i1 c% Q. p$ d
OATS " d" Y3 v# f! n
open area test site 开阔试验场  w$ M! \( L3 k2 G/ m: H% ~
/ \- ]! m! c; p: go/c
# q. [. t; \* `open circuit 开放电路) @9 S. k, C$ N& C) y2 e& A! C
2 E/ E( Z* K0 d$ l7 x
pfv % O# _* z6 K  E' p9 m
power feeding voltage 供电电压1 c  U( E# ?) n
+ h4 e# S2 Y4 f% Y
PNI 4 y7 v. V. d3 \& N
public network interface 公用网接口- N6 i  L) f1 B9 J- |2 S
1 F( P. K3 H/ R" o3 u5 q* E4 MPRBS 6 N, _+ ^+ K& a$ `9 N% f1 J
pseudo random bit sequence 伪随机比特序列& _- q, a; q: @- V
4 d9 f- V: d2 Y9 l) w* F4 oPSTN , J; `; h4 k& G
public switched telephone network 公用交换电话网
+ |3 b% M' U* P! J* @( U9 K, E% @: H
PTC 9 a! K  e7 a4 U3 b, ^5 r, ?
positive temperature coefficient(resistor) 正温度系数; @# v# N2 s. P0 s5 l9 n7 G
" J" @/ v% `$ g: ~RF
9 y# a$ j1 L9 h: ~4 C: G9 Kradio frequency 无线电频率
3 t! u3 {$ W! S, L. i3 ]
2 d- k- t- q2 E# I5 z- G5 TRFI & Y2 h/ D# G/ n
radio frequency interference 射频接口7 c: c# H8 Y2 X2 a
2 @5 D9 r# o& T8 K8 C+ `  H, [- mRFT
' ^) i. p1 {- }2 v% Eremote feeding telecommunications circuit 远供通信电路
5 v4 E8 h* F; ^8 t5 Q. c
7 `3 t7 ]  l4 T" o" pRFT-G
2 q  b/ B% S# F7 H7 [remote feeding telecommunications circuit-current limited 远供通信电路-限电流
5 ?7 P/ z6 r: P" a
& e9 F0 d: Z/ p4 f; d2 u, zRFT-V
/ u) D8 u, u; Z+ y: ~remote feeding telecommunications circuit-voltage limited 远供通信电路-限电压3 S& l6 D! j7 S8 E5 v
0 U0 M1 y. T) Q
RSE ) C; m5 j! E5 Y
remote switching fquipment 远端交换设备
! p2 P5 ]1 Y) T, C3 F$ R
5 d; J7 ]  o# J! D$ @+ a* LSA
8 b* c# B6 t% J6 J8 C; ospecific absorption 比吸收能
( Q! ^/ v9 f) ]) G5 v0 A: l$ I  r" Z  }( ~) U0 J6 Y) s8 g0 n& l" k# ?
SA   J3 j) A6 Z$ A  `
semi-conductor arrester 半导体避雷器
+ a1 S2 r/ T. _" G6 O) P% |2 E! p1 `% E& ^
SAA 6 i- R5 B- g8 F7 ^2 n/ _% `& o
semi-conductor arrester assembly 半导体避雷器组件1 x1 n7 n5 i6 X1 [  D
# Y7 n9 I# C: @. [
SAR 0 @  [' _& l* K) v) y' U7 r' K
specific absorption rate 吸收率
( M/ H. N* z; E5 C" O6 H0 i' f( O
SAP
8 Q) C! W: J# k8 ^0 |# ^; b/ Zspecific absorption power 吸收功率+ N+ d6 T6 p# v$ _
. [% ~: h8 Q/ Y( ASELV 0 C/ D4 b: E$ L  W$ ]2 l
safety extra low voltage 安全超低电压6 `5 z8 N: l+ x5 r  T
0 [+ r7 k! l8 S0 p- a/ f
SLIC * r- P) |! @5 w4 `. h* U7 g
subscriber line interface circuit 用户线路接口电路3 y, A. u- u" I5 t+ v) F7 H  M
; e4 K8 j, v- j8 J4 M3 S
SPD # a/ R* ~1 _4 j% Z
surge protective device 浪涌保护元件  _+ H( x5 e2 ]- ^& e' g
5 r, R# L) ^1 E' \& P! H" G0 @
SPL 8 j% e+ ?" J$ j& c) e
sound pressure level 声压级  J* F8 l8 k, y# |  @
  n) r0 A4 k' r0 }* n
SSA , e" v3 U: x6 A9 G# y
solid state arrester 固体避雷器  S2 E+ v; r# t$ N
7 e4 O: S& L7 QTCE
, L7 H% [- _9 K3 J' \telecommunication centre equip电信中心设备2 w( t3 c4 g" o
3 D7 L3 P+ O& E" I, _; PTDMA
8 j2 E8 Q1 d/ O7 r7 {time division multiple access 时分多址
7 j4 x* ?! v% d. W- E" d- l5 ?8 R) j- o6 {7 z% r" m- @4 j
TN
# Z; G/ i. `! K) v$ w1 `) vtrunk network 干线网
+ f9 \' ^5 ]/ C! k; ~% p$ f, P4 b8 x; M& H& n7 a' j4 Z
TNV
. B, t8 `0 t- U7 j9 Q# O4 e! Ltelecommunication network voltage 电信网电压
4 X7 ?& t' \# x/ M( |* |* ~3 \6 T9 O6 m" r/ w2 D- i& A! k. }
RSD 1 r- R. \8 h8 P
universal serial bus 通用串联总线2 o& q9 |+ F1 ]* m
2 k' @" w3 N8 G! pRPS 4 V  H% `1 u/ e/ o
uninterruptible power supply 不间断电源9 l) d  @& h6 B: W. Q
+ g. l8 P" R6 _
VDSL ) P# e* c# B9 D
very high speed DSL 调整用户数字环路. y# D! y) A( P, ?
% [: D8 B  l+ r9 G
VDU * \7 t* k) R* x' T% n3 T
visual display unit 视频显示单元
  z1 s- s) y: i* `2 x3 X" ^: B' B7 ?7 b. C
UIC
& E/ B) y/ P# X/ ^5 vinternational union of railway 国际铁路联盟
2 b. @2 a0 D6 g
( F% R: `- [: J* r4 d- `% xxDSL
* {/ |9 C% r) R6 g+ L& _/ g3 ydigital subscriber loop x数字用户环路
  d- Q  G  h. k# Y& J
GMT+8, 2025-10-25 18:23 , Processed in 0.156250 second(s), 23 queries , Gzip On.
