设计简单的计数器 6 k1 T1 z5 f o x( O
1、计数器源代码 `timescale 1ns / 1ps
+ W) H1 g$ s, V( Q7 \# [0 x //////////////////////////////////////////////////////////////////////////////////
: }2 I* ?0 W% G" i9 C9 L // Company:. I* ]8 m8 [+ b" ~9 G" s. u
// Engineer:; ~# f; u3 @# X; L% Q
6 ^! d; b$ T2 d" x/ ^3 _ // Create Date: 2017/10/22 15:16:21( J& G' s" p: S1 k0 J3 T
// Design Name:" f5 }" _4 |9 z E
// Module Name: counter1 ]9 l; p. m) `
// Project Name:
1 ]+ v8 e3 T4 M+ n" t2 R // Target Devices:
( z6 ^0 I3 V" I5 a+ N // Tool Versions:
4 L- H4 [2 T! v. |* H: e* A* W& m // Description:) [' S4 B! G, G$ ` s
//# k. }: I1 j6 h2 U5 _- ^
// Dependencies:* b: z3 v- I0 i P
//2 q5 O# D6 y" @& O
// Revision:6 w6 k; q J, C6 Z7 X6 B
// Revision 0.01 - File Created
1 h( f1 e9 X3 t3 V ]4 {5 p" h // Additional Comments:
- s4 }4 y b3 w //, P0 B4 @' C6 l" C- y1 b
* F p1 `2 q2 Q; L1 B2 b
% x4 k, B) [+ e% }& d* F) b" [( T0 P: Q8 H8 c% i+ H) ^
module counter(
! b# F. z) C: h6 J4 F7 L input reset,
: K- n# f' e) O7 R1 W2 I9 y' ^ input clk,( n- Q4 z4 e. t( R+ m4 x3 i
output [3:0] out+ W5 U" q) a8 @" K( z' D
);$ m5 d: W1 h9 e$ u& T" p/ Q' x
reg [3:0] out;
7 C# q' T! a( c3 K& q2 r4 b' K' d* b: G1 z# a
always @(posedge clk)begin' Y! U! m: ]( ~7 J1 b6 F
if(reset)
" |2 s# O$ R. {0 q B- j. g. O- Z5 [ out <= 0;
4 G( J5 g- L$ M, g& n: c3 B else
- H! `" N, O7 W7 E, \. Y+ `0 X out <= out + 1;; [& }4 q0 K! ~+ g! k4 {
end
# h3 {9 {. ~8 q$ G
/ o. n, l- B. P. T+ E endmodule RTL模型 RTL技术原理图 仿真源代码 `timescale 1ns / 1ps //1ns的仿真刻度,1ps的仿真精度6 X4 u5 w4 ]) e+ g) C0 i0 j! h+ _
//////////////////////////////////////////////////////////////////////////////////$ t7 S/ ^# [% j3 {& x
// Company:. j2 E- }& e4 H. \% x
// Engineer:
: F0 ~, `! J* ~ //
' t8 K# ^0 Y/ C9 x9 w // Create Date: 2017/10/22 15:28:44! m- U$ c" r6 ^+ Y$ Z! @0 [
// Design Name:+ D: {+ z/ j, ~1 ^) v! T8 ?
// Module Name: simu
! ~# J2 W- K, Y0 M# f // Project Name:, D) ]; c' \4 m- O# A9 H
// Target Devices:9 N5 m' s; E9 M+ V3 V" L
// Tool Versions:
7 |+ M& W3 s& q# C$ k // Description:
4 e) `; p9 H1 x1 F1 o& [' E //
2 [( m2 z4 M- t% H) Q // Dependencies:
+ X+ T. y* v9 j7 a& X$ U/ W/ c+ x //, J- r b% D; F2 ?+ N8 u
// Revision:
7 N" l& v$ ~5 H9 l$ [3 ~' K: Z // Revision 0.01 - File Created
2 p) h. y/ v' n! k. x6 Q // Additional Comments:8 C, s' f+ ~3 w8 ~2 [5 _! D: z
" @, o3 U. |. n% W3 { //////////////////////////////////////////////////////////////////////////////////# P- @4 K+ N! U. E
+ R' C/ I8 I) k3 R. n/ f" |9 P+ G$ K+ ?
module simu(
2 p! ~: `, q, p3 H Q9 q) M. b" \( v7 v3 K7 I, B. a" G
);5 j Q2 B* ]4 ?9 ]/ z, J
: j, n4 |. o& |+ o, D2 x reg reset;
8 d {& f# p6 B* J1 a+ O reg clk;
- B* V/ s3 R% |! ~9 }7 Y/ X( H0 `, y7 v) R, y1 e
wire [3:0] out;" R. d# i% ? Y/ Y; k' ?
8 h- K6 W4 z: Z, |: S0 {5 D; r
parameter DELAY = 100;2 @* n$ D3 ]5 Y5 x4 ?1 [
, O: P% r# `+ L3 \' k0 b9 _( @
counter inst(
% ]# w* I4 t7 i6 k- ?- Q2 V .reset(reset),, F' @, y) ~$ j+ Q* f; I
.clk(clk),
% G$ y0 i; w$ @6 a; z3 Q: N .out(out)7 l$ G9 b2 T$ g* H
, R2 X" t# ?/ D* H( O, V+ s+ N# S0 }( V( k
always #(DELAY / 2) clk = ~clk;- J0 n% v5 w1 x4 a+ T: z3 ~: e
8 t4 ^3 f& L; x8 B9 u4 Z$ a! } initial begin
! m9 O7 V7 A; l4 X% V7 r clk = 0; //输入信号必须初始化. Y. e% X' b" ]! g
reset = 0;, m$ ?, B$ x2 ^. p
#DELAY reset = 1;
( q; A: a$ [; ?2 X3 {; K3 j& T2 D #DELAY reset = 0;8 d1 z. L3 L+ y
#(DELAY*20) $finish;3 N8 d" `' t2 x* Y8 D) U! n
# C9 ~; \* @/ S! [ o
end
; K( k$ K$ M9 z* G
& @; J' \9 f5 E; [0 M initial $monitor($time,,,"clk = %d reset = %d out = %d",clk,reset,out);7 S8 z5 g9 j5 t j% A
( l, {. Q: d& J$ [6 ^; S ?0 |3 m
endmodule 仿真波形输出 打印输出结果 7 d0 M& B- }" @- M5 D
