查看: 398|回复: 1
[Cadence Sigrity] 求助,speed2000 软件报错,求解答
发表于 2018-8-27 09:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Simulation Start ...
3 m& ^( R0 ]$ `. o, Z   Extracting trace/pad parameters ..." @7 V+ C8 E" E3 g
Simulation Error:
' D4 [5 z+ o( G- B$ @8 T- {8 yError 4030: Invalid data when reading line:".padstackDef 030X120_SLOT 3.810000e-001mm OblongVia"3 s9 m+ d, `, F* x& ]
Error 4030: Invalid data when reading line:".PadStackDef 030X120_SLOT 3.810000e-001mm OblongVia = (2.286mm"$ {2 j) f8 \( v9 K% C/ \$ [
Error 4030: Invalid data when reading line:".PadStackDef 040X140_SLOT 5.080000e-001mm OblongVia"! q# y* v7 c) M' M7 X
Error 4030: Invalid data when reading line:".PadStackDef 040X140_SLOT 5.080000e-001mm OblongVia = (2.54mm"% F. p( y. W  ~, n" N
Error 4030: Invalid data when reading line:".PadStackDef O059X090-035X066T 4.445000e-001mm OblongVia"
2 J( A: S; C! Y; h6 r1 }Error 4030: Invalid data when reading line:".PadStackDef O059X090-035X066T 4.445000e-001mm OblongVia = (0.786892mm"
$ q3 T' X0 B+ B; Q* VError 4030: Invalid data when reading line:".PadStackDef O096X126-071X106T 9.014460e-001mm OblongVia", r# ]+ d5 Y7 h' v, e
Error 4030: Invalid data when reading line:".PadStackDef O096X126-071X106T 9.014460e-001mm OblongVia = (0.889mm"$ O8 V7 Q0 f* u* t+ G5 ~9 x7 }: l
Error 4030: Invalid data when reading line:".PadStackDef O106X059-083X035T 4.445000e-001mm OblongVia"
. v% l5 h# _' `Error 4030: Invalid data when reading line:".PadStackDef O106X059-083X035T 4.445000e-001mm OblongVia = (1.21895mm"
+ X, |% Z' z8 L: xError 4030: Invalid data when reading line:- X* o7 `0 M, G
".PadStackDef O130X065-079X040T 5.080000e-001mm OblongVia". D/ a# n- Y8 [) M6 Z& q1 F/ j
Error 4030: Invalid data when reading line:3 G; o( }+ l7 i! `2 i) B* Z
".PadStackDef O130X065-079X040T 5.080000e-001mm OblongVia = (0.991108mm"
0 q: V+ C1 M  Q, e0 f9 _% {* NError 4030: Invalid data when reading line:# ?! h" C& y7 o- {
".PadStackDef SLOT125X35P150X60P33 4.445000e-001mm OblongVia"4 G9 i% W6 P6 J" V3 g+ {
* F+ N4 d  N7 u, G6 C5 C0 G) ^".PadStackDef SLOT125X35P150X60P33 4.445000e-001mm OblongVia = (2.286mm"
9 |" R& q* O' Z" S" T: d4 yError 4030: Invalid data when reading line:) g2 \# \9 X" s* P3 ~  K. \
".PadStackDef SLOT145X45P160X60P33 5.715000e-001mm OblongVia"8 I5 f& r1 G. E5 g' ~( u
发表于 2019-3-27 23:22 | 只看该作者
看着像是非法字符导致读取数据错误
GMT+8, 2025-7-24 09:24 , Processed in 0.125000 second(s), 24 queries , Gzip On.
