比较实用啊,对于新手来说是很好的资料。下面把文件目录列表总结下,希望对大家有帮助。
9 |4 j G0 C- P! [3 S( F) g<SCH元件库>! t1 J2 c. k7 @1 P
├555定时.SCHLIB) f2 E* p* j3 L* g5 X8 O
├8字数码管.SCHLIB: `% m( s8 }" {) J4 J
├AD转换.SCHLIB
* O) B* E, W$ b. U0 R├CMOS系列.SCHLIB# P c* U1 n. H0 [1 {% b: s: M5 h& D5 I
├SCHLIB(2003.4.23)dxp2004.lib
: ? H! p8 g* c3 G├TTL74系列.SCHLIB
" T! S T+ l i! }3 ^2 _├变压器.SCHLIB
) ]8 ~2 O; R( w. D/ i4 s% O├场效应管.SCHLIB# @: D5 E9 } j4 a
├存储器.SCHLIB: U) s, H, Z" _9 Q
├单片机.SCHLIB3 ~7 B8 K9 g& n x
├电控开关.SCHLIB/ K6 S! y- p8 E
├电子管.SCHLIB' X; u" M& x* ~3 s0 x& |9 }
├光电器件.SCHLIB
" b+ \( X5 V. I, q5 H├接口器件.SCHLIB
8 `+ r2 x1 a7 J4 Y$ w├可控硅.SCHLIB
" I, [ n5 c( r! E, j├模拟器件.SCHLIB
, {! j4 Y8 \4 k/ x) c8 @5 L├特殊元件.SCHLIB0 [5 U$ R$ N8 m* S' ]+ t' w
├稳压器件.SCHLIB% p" d: A: Y) r! i" d( ?# S. ?% l
├显示器件.SCHLIB
1 z: R' n) R% o2 [: @+ t- J" k├杂元件库.SCHLIB1 k" c1 e6 s+ l; o. N
└中央处理器.SCHLIB K1 o( D8 E( k' d0 k) I3 G
<PCB封装库>
8 e' x3 W; I& S/ Z3 U( `9 y├Axial Lead Diode.PCBLIB
- |( u, f8 k5 a/ ]" P7 _├BGA (0.6mm Pitch Square).PCBLIB
3 ]" k9 g, R9 H( D: Y0 E├BGA (1.27mm Pitch, Square).PCBLIB5 U2 j0 N1 e& W. Y! w
├BGA (1.5mm Pitch, Square).PCBLIB7 }* m1 r( a: d% x5 I+ \
├Bridge Rectifier.PCBLIB
+ ]- Z# ~$ k: T2 e% G. @# a├Bumpered QFP - Centre Index.PCBLIB, u+ u4 g. @# O; Q6 L
├Bumpered QFP - Corner Index.PCBLIB
$ x6 ~3 r$ M5 W( }9 C. s├CAN - Circle pin arrangement.PCBLIB) G2 C' A: F# N# P. t$ }( B& a
├CAN - Rectangle pin arrangement.PCBLIB
; G. \) f4 y: V4 U2 i; {, z6 p├Ceramic DFP.PCBLIB* J$ k9 t2 i& z- Z8 L7 P+ V: _ q
├Ceramic QFP (Square).PCBLIB
5 I: y, a9 a6 m. s: @├Con Rect Stag PCB.PCBLIB/ F- p- X7 n* L" x( N, m7 r3 Q( }
├Cylinder with Flat Index.PCBLIB
1 K9 d; Z8 y) C& ^5 O- N0 A├Diamond Base CAN - 2 Leads.PCBLIB
/ K' ?3 N: a( T$ ^├Diamond Base CAN - 3+ Leads.PCBLIB
* W/ F7 S$ g0 [├DIP - Peg Leads.PCBLIB
5 h% N, M1 `! A( A, H├D-PAK.PCBLIB
" K# F! q# {$ T. _├Dual-In-Line Package.PCBLIB
0 K7 M: U. X7 |+ M├Flange Mount with Rectangular Base.PCBLIB, w) f( [7 K4 m3 J
├Flange Mount with Tab horizontal.PCBLIB( C0 c/ F- [8 [4 s, o; S5 `
├FQFP - Rectangle.PCBLIB
% F3 _" K/ ~5 ^├FQFP (0.5mm Pitch, Square) - Corner Index.PCBLIB N* j4 ~& h) e: F
├Leaded Chip Carrier - Rectangle.PCBLIB
& C m' y- R. {/ i! x( K; A├Leaded Chip Carrier (Square) - Centre Index.PCBLIB6 I" O, @5 u4 C( L, |# R
├Leaded Chip Carrier (Square) - Corner Index.PCBLIB
% y% I; c( T1 e3 G `6 V" S├Leadless Chip Carrier - Rectangle.PCBLIB
. B+ C( y5 a/ i0 b; Y% `7 L├Leadless Chip Carrier - Square.PCBLIB7 x( {5 B: b) U4 R ~% R
├Low Profile Module (LPM).PCBLIB
3 n# Z4 w7 C9 P/ Q3 c- B├Metal Electrode Face (MELF).PCBLIB* s9 k8 Z$ h6 D, b/ {
├Miscellaneous.PCBLIB( O4 x4 K& u; M. k/ ]
├PCB Footprints.lib
# q+ a0 |% i0 v) s: k+ T1 {├Pin Grid Array Package (PGA).PCBLIB
% V$ r6 b2 }/ r: m) w( M├QFP - Rectangle.PCBLIB
. v# t# e9 D5 [0 ^2 Q; [1 c├Quad In-Line Package (QUIP).PCBLIB
1 Z9 E: z# g' ]$ g├Single In-Line with Mounting Hole.PCBLIB
7 p8 M( ^4 u; d/ u3 X├Single In-Line with no Mounting Hole.PCBLIB$ s3 b4 `( T' `; ] I) z; A* z
├Single-In-Line Package - 5+ Leads.PCBLIB
9 ^: v1 ^* D( A├Small Outline Diode - 2 C-Bend Leads.PCBLIB7 y' a3 g( Y$ J( M5 g+ k
├Small Outline Diode - 2 Gullwing Leads.PCBLIB- P2 Z5 w" ]0 E$ e" V2 ?
├Small Outline with C-Bend Leads.PCBLIB7 D2 t$ l! G( v, x8 V- y
├Small Outline with J Leads.PCBLIB
" q, \6 B) n) L2 Y& N! J" O├SOT 143.PCBLIB2 a; @* u: N4 m1 E$ ?* ^
├SOT 223.PCBLIB& \: e- a: F i1 L
├SOT 23 - 5 and 6 Leads.PCBLIB
' n) m$ P! C# i├SOT 23.PCBLIB
1 M) M- M' f- E( p5 e9 A├SOT 89.PCBLIB; |. k6 M" ?' t6 T
├Surface Mount DIP.PCBLIB
z) J' u8 U2 ]1 k3 _ {9 E6 s9 W7 t$ i├TSOP (0.4mm Pitch).PCBLIB* b" q9 x3 T O
├TSOP (0.5mm Pitch).PCBLIB* q+ C" Z& J/ V' p1 H8 ]
├Vertical, Dual-Row, Flange Mount with Tab.PCBLIB" P' h/ N' Z7 f& M
├Vertical, Single-Row, Flange Mount with Tab.PCBLIB
k& Z! D2 }# I: H) v4 E* ]: L├Zig-Zag-In-Line Package Odd Lead Number.PCBLIB7 i/ l4 W/ `) v6 \" }
├Zig-Zag-In-line Package, Even Lead Number.PCBLIB
: G4 |) m6 V+ Z4 s├单面PCBLIB(2003.11.13)dxp2004.lib
, {# R1 p( [. ]$ c& I8 @2 B9 C5 k& C& D├封装.PcbLib$ @) g' F, p% v. M! s6 c: ~9 r/ c
├回流焊SMT(2003.5.18)dxp2004.LIB& q) S+ ~. W" X
└双面 PCBLIB(2003.5.18)dxp2004.lib |
