查看: 1091|回复: 3
[Ansys仿真] HFSS 仿真问题AdpCombiner found a different tet order across frequencies
发表于 2018-6-20 17:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问路过的大神知道下面的问题是什么原因吗?& Y4 d+ S, D, m* c7 w6 u( Y, D: {
在线急等,感谢!!!!!+ ]& B& \& [* E6 X: C9 `
AdpCombiner found a different tet order across frequencies in at least one frequency group : Ongoing R&D task
/ N" S+ g1 A; g1 P, [. [( o/ @: I6 }* u  u* X/ q
 楼主| 发表于 2018-6-20 17:34 | 只看该作者
路过的大神帮忙指点一二!!!感谢!!!
 楼主| 发表于 2018-7-5 10:44 | 只看该作者
l Order of Basis Functions: the order of the basis functions HFSS uses to interpolate field values from nodal values. The Zero order option is useful when a model requires a mesh that produces more than 100,000 tetrahedra, but the model size is small compared to wavelength. The higher order options solve progressively more unknowns for each tetrahedra. Mixed order uses higher order where more accuracy is required, and lower order where fields are weaker.
GMT+8, 2025-7-25 22:05 , Processed in 0.109375 second(s), 24 queries , Gzip On.
