查看: 3026|回复: 3
PCB专业用语中英文对照!
    2019-12-3 15:20
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2007-9-1 12:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    一、 综合词汇
      j8 f9 ]6 D5 [& ]' J' \4 M8 ^   1、 印制电路:printed circuit/ e3 @. \  b' Y
       2、 印制线路:printed wiring4 {" h  L' b1 X, [$ ?* ]
       3、 印制板:printed board* T  N% k: k& [" z
       4、 印制板电路:printed circuit board (pcb)/ ~" c, y$ S) T( L6 C$ A
       5、 印制线路板:printed wiring board(pwb)
    # }* T0 m, m2 c0 a   6、 印制元件:printed component
    : u9 T2 `: Z5 ~( Z% u   7、 印制接点:printed contact
    $ g5 W1 a; K+ A   8、 印制板装配:printed board assembly( Z  V- p( S- Z+ }6 O
       9、 板:board9 @: }/ h" P. N# ~4 }* L9 u
       10、 单面印制板:single-sided printed board(ssb)7 H) |' V( v1 O) o- T
       11、 双面印制板:double-sided printed board(dsb)
    % ?2 B8 N8 y3 z1 {   12、 多层印制板:mulitlayer printed board(mlb)0 e2 R1 V8 n5 G3 h& ?
       13、 多层印制电路板:mulitlayer printed circuit board
    1 l* v+ t8 S7 @/ ~$ H# g   14、 多层印制线路板:mulitlayer prited wiring board* \+ `% h% }9 T5 M  ~2 {8 P8 `/ e1 Q
       15、 刚性印制板:rigid printed board9 ?9 i( o3 J* H, o3 {2 d. S4 A, R7 C
       16、 刚性单面印制板:rigid single-sided printed borad9 h# W4 E- r1 L6 o2 i& J( w; a
       17、 刚性双面印制板:rigid double-sided printed borad
    6 U6 }' s1 T. W, {9 K/ F$ [1 R5 U   18、 刚性多层印制板:rigid multilayer printed board
    3 ?7 _* P/ s5 b/ G7 e" L8 Z   19、 挠性多层印制板:flexible multilayer printed board
    : ]  s" W8 Z2 Z+ _0 I6 q   20、 挠性印制板:flexible printed board
    " ?! R# L' m4 U8 @9 x) y   21、 挠性单面印制板:flexible single-sided printed board
    ; i( R- |. ]3 p: y   22、 挠性双面印制板:flexible double-sided printed board
    $ @8 I4 e1 E  I$ z$ y( B3 u; S   23、 挠性印制电路:flexible printed circuit (fpc)0 l2 k5 m% E- K% n/ f3 A
       24、 挠性印制线路:flexible printed wiring3 X6 {# E3 i# I0 I6 I6 C
       25、 刚性印制板:flex-rigid printed board, rigid-flex printed % T7 q* f  f. h0 B) }) `, u' D. n
       board- k/ H5 Z/ p% |6 c" V
       26、 刚性双面印制板:flex-rigid double-sided printed board,
    $ v6 Z+ A2 Q4 Z5 |  U8 K   rigid-flex double-sided printed
    2 b6 ?# P# f3 _4 S   27、 刚性多层印制板:flex-rigid multilayer printed board,
    0 b9 k2 h! E( a; }+ K" P. F   rigid-flex multilayer printed board
    : s& H6 x& d5 ?) @7 ?   28、 齐平印制板:flush printed board* f% c  `* {! y$ N4 H! F
       29、 金属芯印制板:metal core printed board; p  K1 U3 d% H; R& D2 M5 N7 l
       30、 金属基印制板:metal base printed board" O( s# I& Y7 W) H
       31、 多重布线印制板:mulit-wiring printed board6 Z/ F6 ]+ D, u9 W3 e7 P4 C" d
       32、 陶瓷印制板:ceramic substrate printed board
    ) j! t4 Q, W) l$ G   33、 导电胶印制板:electroconductive paste printed board
    8 o- W4 O; A0 Z   34、 模塑电路板:molded circuit board# C& T6 p7 N' q# M" V) B, k
       35、 模压印制板:stamped printed wiring board
    + h: u+ V* @9 x, i   36、 顺序层压多层印制板:sequentially-laminated mulitlayer
    4 z, i  O/ D- q* N! [# ]/ p/ ~   37、 散线印制板:discrete wiring board; @4 T5 x1 N; \8 P# w4 v2 n
       38、 微线印制板:micro wire board3 b8 p! b9 d) `
       39、 积层印制板:buile-up printed board
    2 F4 ^) t3 c, s   40、 积层多层印制板:build-up mulitlayer printed board (bum)
    . }  j8 G& C; u' v* d5 X   41、 积层挠印制板:build-up flexible printed board
    5 P/ u  c0 H0 M   42、 表面层合电路板:suRFace laminar circuit (slc)
    1 D! F% G( S* Y   43、 埋入凸块连印制板:b2it printed board1 p; v% B) x$ C9 H  d
       44、 多层膜基板:multi-layered film substrate(mfs); {* j5 k4 i/ k  @: w0 k7 h# t6 d3 g
       45、 层间全内导通多层印制板:alivh multilayer printed board
    ' `) _* X0 j- a. |6 B   46、 载芯片板:chip on board (cob)4 t5 f; t5 ^% Y; E% ~
       47、 埋电阻板:buried resistance board0 Y; C" t  l; u' O/ C
       48、 母板:mother board7 v; H8 V' \" _3 c2 }3 N
       49、 子板:daughter board
    & |5 S5 u  R8 J! v( Y   50、 背板:backplane9 I9 I' ]7 a9 z; ~, \9 L
       51、 裸板:bare board
    1 m4 F- Q" Y4 b, k   52、 键盘板夹心板:copper-invar-copper board7 B) |  ]9 h' ~- z
       53、 动态挠性板:dynamic flex board
      `  }& m# q" K4 @: W* }  H   54、 静态挠性板:static flex board3 c, R3 p& _6 m. z+ [  I- R
       55、 可断拼板:break-away planel- M8 M( W- z0 w$ \
       56、 电缆:cable
    - a* {9 q% E3 x% T& _  D$ _+ W' u   57、 挠性扁平电缆:flexible flat cable (ffc)' e- }9 [& G) S' W
       58、 薄膜开关:membrane switch
    ; ?8 a* C/ P/ M2 w* i   59、 混合电路:hybrid circuit/ `3 r! P- V/ x( }% f5 i2 W
       60、 厚膜:thick film: R  `: i& O+ _3 y/ \
       61、 厚膜电路:thick film circuit  a5 g9 N* C/ @% B7 O1 Q7 s
       62、 薄膜:thin film1 d0 Q% X6 w" n2 F5 @4 \$ D
       63、 薄膜混合电路:thin film hybrid circuit
    9 J4 e$ B' i! e; |' v4 L+ D" k   64、 互连:interconnection
    5 w1 J' g$ u( t: {( N. H4 j   65、 导线:conductor trace line. s: w$ T# z, |& @$ ?
       66、 齐平导线:flush conductor! ~# J, W% Q6 V" X. `
       67、 传输线:transmission line
    - L4 a( G* x* }5 L' c8 S$ F$ u; ]   68、 跨交:crossover
    6 M; B( i$ [8 d4 ]6 K( @   69、 板边插头:edge-board contact
    & P' h, i! ^) g/ P   70、 增强板:stiffener, O, S1 O6 T: b6 z) Y9 g/ w3 V
       71、 基底:substrate9 O! Z' i' r) K) k) l
       72、 基板面:real estate1 X; P. O( z1 Y7 _
       73、 导线面:conductor side ' O# ^4 k* R& R9 w$ P' o1 D) k# E
       74、 元件面:component side  _0 N, c$ V8 c$ Y% r6 N% ^
       75、 焊接面:solder side
    # M  b% ~; i) x% v& D* g& p   76、 印制:printing
    + U( X: o! N; C" V1 }4 `   77、 网格:grid9 i% D1 s, {* v7 s5 S; u1 k
       78、 图形:pattern8 p; u& b$ E; n8 n
       79、 导电图形:conductive pattern0 T5 V: H0 h; N" a" \' |
       80、 非导电图形:non-conductive pattern6 A( e9 a0 M  L" s* q- K  F
       81、 字符:legend6 v! q8 X0 H1 P; |! D$ Z% L2 C* V( A
       82、 标志:mark5 ~6 v% M% z& }. r4 T
       二、 基材:
    - I# y% O6 v! m7 j6 o& k2 W   1、 基材:base material+ z+ l1 o4 [% b. S! W; b
       2、 层压板:laminate4 y/ m2 e- E1 K% Z- d6 C
       3、 覆金属箔基材:metal-clad bade material" l  {* c( P  F0 a
       4、 覆铜箔层压板:copper-clad laminate (ccl)
    6 Z8 }  ~7 H$ Q# f& O; [   5、 单面覆铜箔层压板:single-sided copper-clad laminate# N2 x) S6 z0 Q+ e
       6、 双面覆铜箔层压板:double-sided copper-clad laminate
    ' _* e6 X, ?5 x& J4 f   7、 复合层压板:composite laminate5 {, v/ H) K5 m$ M  M/ e
       8、 薄层压板:thin laminate
    $ E4 q" _  R7 I   9、 金属芯覆铜箔层压板:metal core copper-clad laminate7 E. d( O  r0 o5 W4 ^" w! U
       10、 金属基覆铜层压板:metal base copper-clad laminate
    5 d5 @# Q/ b, D/ s   11、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
    * |" ?, @4 Y% I# W' Q$ U   12、 基体材料:basis material
    7 F& N6 n9 h7 V3 \5 V! j& o! n   13、 预浸材料:prepreg( L& V2 J% h* B; Y, k! t% T+ I* _
       14、 粘结片:bonding sheet. j% {4 n6 u4 l8 p( o+ f# _
       15、 预浸粘结片:preimpregnated bonding sheer9 z- q) R/ k6 A2 }
       16、 环氧玻璃基板:epoxy glass substrate
    * C- x$ Q( e2 E& ~! T; u; T- ]8 r   17、 加成法用层压板:laminate for additive process( K, N2 {& z! V2 q
       18、 预制内层覆箔板:mass lamination panel
    # E4 p. f) i' E   19、 内层芯板:core material+ X& y0 f0 K2 J3 X1 g6 A
       20、 催化板材:catalyzed board ,coated catalyzed laminate
    - p4 H+ q0 V$ d. M   21、 涂胶催化层压板:adhesive-coated catalyzed laminate- A/ L, M( w: c3 _- u5 P
       22、 涂胶无催层压板:adhesive-coated uncatalyzed laminate; D4 l( i$ A$ \$ \1 s# X' ^
       23、 粘结层:bonding layer
    2 v1 V  h+ `- ~% @. G   24、 粘结膜:film adhesive
    & O5 o# D2 ]8 m& J   25、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film
    : h! n: r6 R2 s0 k( V+ A! \   26、 无支撑胶粘剂膜:unsupported adhesive film
    . t& V3 o6 l/ t1 P* j. h& O   27、 覆盖层:cover layer (cover lay)7 _% U9 }" F" T8 ]/ d) g
       28、 增强板材:stiffener material
    7 w) c3 u7 i- n0 c+ Q   29、 铜箔面:copper-clad surface
    * X0 J" J. T3 g/ H" B5 B   30、 去铜箔面:foil removal surface
    / Q) O# P$ O5 k   31、 层压板面:unclad laminate surface' F7 r9 I1 f' e# E* W1 g; d
       32、 基膜面:base film surface3 F- H( Q* q* F4 ^3 g" b0 H, l  Q
       33、 胶粘剂面:adhesive faec
      G0 D' n2 @& x% |   34、 原始光洁面:plate finish* k2 \4 R; O/ R. x' z! \
       35、 粗面:matt finish
    " C; p% n/ R+ S  m. {& S6 G   36、 纵向:length wise direction
    8 i1 ~( n, R  a7 W, }   37、 模向:cross wise direction
    ( K+ h& e  D1 |- T; X   38、 剪切板:cut to size panel3 W: O# ?& Z4 r
       39、 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad
    % W. y$ _. _  K8 k* O# w   laminates(phenolic/paper ccl)
    4 E0 i6 w) K. x5 T   40、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad
    7 j: l* e/ G+ I   laminates (epoxy/paper ccl)
    - S3 }; R: T* _/ J, c3 F   41、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad   w3 p# C3 C! ^
       laminates
    ) j1 h7 |. Y7 a7 W, j   42、 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass 5 m" T! ~- W. Q5 C* `# F' [8 l
       cloth surfaces copper-clad laminates
    , }9 n/ \0 ?; `+ U3 M   43、 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass
    2 A0 |+ Q+ g" l; L, b   reinforced copper-clad laminates4 B  c! z9 _4 l7 n7 q0 U
       44、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad
    - k; x1 S) v) e; ?4 H$ X' }3 B   laminates
    & U* c2 t4 u, O8 N8 @   45、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad
    " _- B7 h* \- ~& z6 l: V: S& j$ x   laminates
    : |' ^. X# \: ?+ \1 ?1 d* z   46、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide
    9 r% R; H! j1 X. f$ o; w+ y. b9 g   woven glass fabric copper-clad lamimates
    ' k- J- q/ w3 p  S: |9 d   47、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric
    * a: C" M& V" Q$ U9 X+ i* J" w   copper-clad laminates- o* F7 p3 j$ Z# H# q
       48、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad % v" `2 D# f( J, f$ T0 f; U7 p
      laminates
    / ]/ k9 g% h! I# M7 o9 B  i4 G   49、 超薄型层压板:ultra thin laminate
    3 _. p* e3 {8 u( R" l   50、 陶瓷基覆铜箔板:ceramics base copper-clad laminates; G, _& ~4 H+ F0 ?4 M4 N4 U- N1 \7 B
       51、 紫外线阻挡型覆铜箔板:uv blocking copper-clad laminates4 `/ ?/ v  I- U# i0 u+ i
       三、 基材的材料
    4 `' A1 s9 X9 U9 C" K- f   1、 a阶树脂:a-stage resin' c0 V6 D9 V% N9 U
       2、 b阶树脂:b-stage resin. |% ]" B8 l4 v% t( B) J. C6 l* s. A
       3、 c阶树脂:c-stage resin
    1 \" N# n) N  n   4、 环氧树脂:epoxy resin3 o& }: V3 N1 g* a6 `
       5、 酚醛树脂:phenolic resin
    , f3 U% j7 J9 I1 T+ c5 n   6、 聚酯树脂:polyester resin+ n* W. s+ d4 L; ~' `* V0 ?
       7、 聚酰亚胺树脂:polyimide resin  n1 e& q1 o7 L; [+ {: l) \
       8、 双马来酰亚胺三嗪树脂:bismaleimide-triazine resin0 C4 _' q: p" p* a) r
       9、 丙烯酸树脂:acrylic resin
    , a; @. _3 {/ @* _/ t   10、 三聚氰胺甲醛树脂:melamine formaldehyde resin: i- e/ l! E  f" E
       11、 多官能环氧树脂:polyfunctional epoxy resin* g. S9 p% Z( B1 r) B
       12、 溴化环氧树脂:brominated epoxy resin7 r- |3 v8 @! {4 M( ~& H
       13、 环氧酚醛:epoxy novolac6 a$ Q9 |; H, k6 i/ a/ A
       14、 氟树脂:fluroresin
    " }; K# ?4 a7 Y: u; X# V   15、 硅树脂:silicone resin8 q. l# o! ]1 W2 N# H( u* `
       16、 硅烷:silane: Q% _4 Q" S4 n
       17、 聚合物:polymer
    9 ~& Y% ]4 x' D6 r   18、 无定形聚合物:amorphous polymer3 C' l  p4 Z1 B
       19、 结晶现象:crystalline polamer3 g  B3 d; G9 v8 N8 i0 R- I# q5 [3 {
       20、 双晶现象:dimorphism
    9 g/ j: m4 _, _( ^   21、 共聚物:copolymer
    + ?9 v+ k/ m2 J2 K! q* T' O& L) v   22、 合成树脂:synthetic- s3 D. Z8 X0 R0 h) L0 f% X1 C2 P
       23、 热固性树脂:thermosetting resin. o: N* e% I5 _
       24、 热塑性树脂:thermoplastic resin- X: d, r- r- d% G6 I4 u- E4 b+ r
       25、 感光性树脂:photosensitive resin
    , {8 K1 Y* H6 X1 T5 Y, l( d   26、 环氧当量:weight per epoxy equivalent (wpe)
    & p7 u( R) x! [9 I   27、 环氧值:epoxy value' H) k% o+ X7 e1 X. |. x2 U
       28、 双氰胺:dicyandiamide- L* H( V3 v) r$ z: m+ o$ l
       29、 粘结剂:binder( R0 M1 C4 z8 ~* S3 w4 m
       30、 胶粘剂:adesive
    6 N5 g9 ^2 N- l5 S0 Q; m& J   31、 固化剂:curing agent
    ; y, T4 u/ ~/ r8 C, Q   32、 阻燃剂:flame retardant; `9 i3 j  J4 v2 s7 ?2 V2 p+ y+ f: m
       33、 遮光剂:opaquer7 R6 B, X  x6 s8 v1 @
       34、 增塑剂:plasticizers+ ?- @! j' X+ z. p: T1 e4 V
       35、 不饱和聚酯:unsatuiated polyester
    , X5 s. Z, X& O6 G- b; x; c   36、 聚酯薄膜:polyester
    2 {' A3 E. v6 p3 n7 b+ f- N   37、 聚酰亚胺薄膜:polyimide film (pi)
    * P: C+ W, a. G: s$ ?   38、 聚四氟乙烯:polytetrafluoetylene (ptfe)
    - d0 y' W3 f( [  d2 ]0 A; Q8 x   39、 聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene 4 l1 u1 h$ u4 b8 K& U& e
       copolymer film (fep)( K; ]+ w. J: G6 F
       40、 增强材料:reinforcing material: b2 Q5 b$ t6 i: i6 o# t5 d
       41、 玻璃纤维:glass fiber( e4 v4 s6 q) r. h" C6 v
       42、 e玻璃纤维:e-glass fibre
    4 w" J% R4 ]8 k3 l2 N   43、 d玻璃纤维:d-glass fibre0 K! M+ G  H; {0 @4 v% N) X
       44、 s玻璃纤维:s-glass fibre7 g% F5 D6 n+ v7 R
       45、 玻璃布:glass fabric
    " \; N# x0 }: d! o* K   46、 非织布:non-woven fabric
    7 ~) y, s/ p7 U4 V: P. D   47、 玻璃纤维垫:glass mats
    6 Z0 V! j# a- v   48、 纱线:yarn# }6 Y& a9 [2 b2 r
       49、 单丝:filament1 P  s6 u# P7 j  c) `
       50、 绞股:strand( @$ |: U9 b1 Y  `
       51、 纬纱:weft yarn
    7 ]! ?2 E( w. y2 H- r2 c( Q   52、 经纱:warp yarn
    ' r/ }5 H! l6 g   53、 但尼尔:denier
    # \1 s" f: ^+ o" X, L  U   54、 经向:warp-wise
    ( V  x9 p7 ?! v   55、 纬向:weft-wise, filling-wise5 ]8 ?1 [- B) K  i8 b
       56、 织物经纬密度:thread count
    5 d- I' k  ~: `: o1 [- j1 X. A   57、 织物组织:weave structure/ f) ~3 Z( N( q! A& V5 t8 Y6 ?
       58、 平纹组织:plain structure
    1 i' n" v+ t6 M+ Y3 t- d   59、 坏布:grey fabric' B2 J$ D5 z; [
       60、 稀松织物:woven scrim4 \* F+ g. @( r1 |
       61、 弓纬:bow of weave
    ; G: I8 ]. o! C, q8 r5 O( {   62、 断经:end missing
    6 G; j' p) W' F! W   63、 缺纬:mis-picks! C4 q- ?0 N: n/ ~0 s# }' O  g
       64、 纬斜:bias" L+ D& j( h( W, A8 E3 u# j
       65、 折痕:crease
    $ A  r1 y6 o5 U  K4 B   66、 云织:waviness
      ~/ Z  C( j$ I4 i$ D0 j   67、 鱼眼:fish eye. P/ `9 O" W/ K, v. I+ n
       68、 毛圈长:feather length+ v. M( G! _) Q2 m. q. y1 E
       69、 厚薄段:mark4 T: k- v4 B6 x% C; ?; ^
       70、 裂缝:split& B6 [: c; B- a5 l4 n9 \
       71、 捻度:twist of yarn
    : I; [, L$ @" g1 r: J+ u* n   72、 浸润剂含量:size content5 b" A+ L: x2 t1 l4 _
       73、 浸润剂残留量:size residue% ]+ b) u) t) R/ s. R$ W* D! W; k
       74、 处理剂含量:finish level7 l' y/ a7 r6 J" v9 Z
       75、 浸润剂:size
    $ G/ H8 f$ z3 N0 h4 Z   76、 偶联剂:couplint agent
    0 @! Q8 p! G% \- `   77、 处理织物:finished fabric7 d' p" j9 F, @
       78、 聚酰胺纤维:polyARMide fiber1 U  ?" `- Z9 Y5 W
       79、 聚酯纤维非织布:non-woven polyester fabric. H2 @1 S. A5 y4 ?; m
       80、 浸渍绝缘纵纸:impregnating insulation paper  j" J! ^1 t. G3 g; B
       81、 聚芳酰胺纤维纸:aromatic polyamide paper
    3 n0 H" W: t( u; m: C  ~% x+ l( {' s% ?   82、 断裂长:breaking length7 m; b( J1 n: E) z8 [- T
       83、 吸水高度:height of capillary rise+ C% _$ C) T: g" ^. Q- @
       84、 湿强度保留率:wet strength retention0 O% c/ O  Z; X7 T" c
       85、 白度:whitenness( t  r8 @+ @; n# I5 Z
       86、 陶瓷:ceramics8 ]: N+ ?- }8 h7 t# p- \- Q: V
       87、 导电箔:conductive foil
    ; \/ i$ I" h7 j   88、 铜箔:copper foil
    # k2 ^- \6 A8 Q& n# x' G   89、 电解铜箔:electrodeposited copper foil (ed copper foil)5 r$ C- K4 m: n. Z0 D
       90、 压延铜箔:rolled copper foil  L, W; A9 g7 k6 v2 e' \
       91、 退火铜箔:annealed copper foil
    / o( l2 ]* O3 {0 g* t0 C' ^: ]! ~) H   92、 压延退火铜箔:rolled annealed copper foil (ra copper foil)- Q# v0 f$ `! w6 ]8 p
       93、 薄铜箔:thin copper foil - v! l# @; |+ {5 n. I, g
       94、 涂胶铜箔:adhesive coated foil
    6 x- p* L) L- ]% P# s9 W   95、 涂胶脂铜箔:resin coated copper foil (rcc)
    1 V& R- H7 W' _% M   96、 复合金属箔:composite metallic material7 U6 B* b9 i, N: S# n8 M
       97、 载体箔:carrier foil3 b! m8 M6 N8 N  B0 f  ~
       98、 殷瓦:invar& n9 V$ ]2 K) A/ {/ _
       99、 箔(剖面)轮廓:foil profile
    : X0 s! ^6 i5 s   100、 光面:shiny side
    ; [6 }- T$ T0 O0 C% K( v   101、 粗糙面:matte side
    ! x. a. a2 a0 y& Z( A; L* e  A   102、 处理面:treated side* Z6 M: M3 X# x- A8 ]6 ?
       103、 防锈处理:stain proofing8 t+ [! F/ m. T& J
       104、 双面处理铜箔:double treated foil
    ' s9 Q" a3 F! J; x* O, G   四、 设计- U  [. v  d/ R  U! ^4 i
       1、 原理图:shematic diagram$ R- y) o  ]0 J& Q# ]
       2、 逻辑图:logic diagram, M5 Q% |& J* h5 q
       3、 印制线路布设:printed wire layout% {) Z/ \% \$ N) o, A. M
       4、 布设总图:master drawing! h6 l) L' c4 z( E6 W
       5、 可制造性设计:design-for-manufacturability
    . F1 S8 c. y/ w" k$ X% p   6、 计算机辅助设计:computer-aided design.(cad)
    ; T  H2 {- h6 M$ I2 j" @# d   7、 计算机辅助制造:computer-aided manufacturing.(cam)
    & `; j3 j9 P7 d. b* ?- i0 g   8、 计算机集成制造:computer integrat manufacturing.(cim)
    0 K$ O" C; z7 H+ T9 G$ \   9、 计算机辅助工程:computer-aided engineering.(cae)0 L( E2 m6 N- u5 H% K0 e" _
       10、 计算机辅助测试:computer-aided test.(cat)
    2 D8 f0 E# z  F* c* o   11、 电子设计自动化:electric design automation .(eda)5 s3 l+ f8 Y" V& ]
       12、 工程设计自动化:engineering design automaton .(eda2)
    5 B8 n, u7 O& o0 D( f9 y$ Y0 {$ }   13、 组装设计自动化:assembly aided architectural design. (aaad)4 O( N- K% E, e+ m( }
       14、 计算机辅助制图:computer aided drawing
    - S: l# W% {$ e- \   15、 计算机控制显示:computer controlled display .(ccd)
    5 D. T: W+ Z- k1 N) ]* r5 B   16、 布局:placement
    ; i  A) v. M8 t( ^4 z/ f4 D5 e   17、 布线:routing3 ?* {; C* P# t4 h! Z
       18、 布图设计:layout
      ^1 O) g/ V, v& A) |   19、 重布:rerouting! n2 a" \4 N+ h0 K8 ^" g
       20、 模拟:simulation2 A" E1 @: u9 v* D& {
       21、 逻辑模拟:logic simulation9 n# k8 g- X" t6 O  |
       22、 电路模拟:circit simulation
    4 M2 R0 C1 ], p   23、 时序模拟:timing simulation
    9 v' ^+ R* t, a) P   24、 模块化:modularization
    " N1 H" b4 B! E& A7 P9 j  }* E$ ?   25、 布线完成率:layout effeciency4 I( V' e# O  u% a  j1 W; N
       26、 机器描述格式:machine descriptionm format .(mdf)/ l1 z, V) {, t1 L" M
       27、 机器描述格式数据库:mdf databse
    ; D: o2 S9 F8 j  Z% k0 L   28、 设计数据库:design database+ |* L6 G/ K- t# [7 I" ~
       29、 设计原点:design origin- J6 k  i# U) s5 z; Y! E  C) Q7 o
       30、 优化(设计):optimization (design)3 p3 z4 P/ l" S' \* m
       31、 供设计优化坐标轴:predominant axis
    3 y) s+ a1 @& P! j4 N: j   32、 表格原点:table origin
    3 g- _% Q+ s& a/ f8 R0 P) Y1 d/ g   33、 镜像:mirroring
    0 C' F0 {$ ?/ ~: Q) y& D  T   34、 驱动文件:drive file: t" B& M! L9 s, g8 i
       35、 中间文件:intermediate file3 _- z$ O! k% h! V" d
       36、 制造文件:manufacturing documentation
    7 `4 V, @' B6 S6 j7 P   37、 队列支撑数据库:queue support database
    1 t4 o# t( L* O% r% E   38、 元件安置:component positioning1 E- b5 ^) t" I  G/ U. x
       39、 图形显示:graphics dispaly1 B2 F: {9 j. ^9 t1 G9 B1 R/ Q
       40、 比例因子:scaling factor7 y% [+ A3 l0 M0 n
       41、 扫描填充:scan filling- v; |# A8 j1 {" b/ Q
       42、 矩形填充:rectangle filling% L. O6 Q" w7 J$ h4 f
       43、 填充域:region filling
    8 n7 Y% A+ W# K: p( x$ w   44、 实体设计:physical design
    / R# k/ k, u# i# D3 O+ L) L4 T/ k0 n   45、 逻辑设计:logic design
    2 e% O8 d7 K8 j   46、 逻辑电路:logic circuit
    9 g8 `; F+ p. F9 k   47、 层次设计:hierarchical design
    9 ~4 Q1 ]7 ?9 n( h6 N& l; O   48、 自顶向下设计:top-down design
    2 ~8 t" L0 z7 E# O* v  A   49、 自底向上设计:bottom-up design
    7 m: h; r2 s) Z( z0 D   50、 线网:net* c) Z" {  z9 P3 [- z! Q! s7 E
       51、 数字化:digitzing
    ' f5 p2 F. ]7 K/ j* L! e, D   52、 设计规则检查:design rule checking+ u1 {7 o. f- o3 i" B( ]. E. u; r
       53、 走(布)线器:router (cad)
    & R+ O5 P( K( @6 D7 }: |   54、 网络表:net list  @. D8 ]2 k, }9 D6 J
       55、 计算机辅助电路分析:computer-aided circuit analysis
    3 V+ T9 o; A1 q0 _, d7 Z2 D- w0 H   56、 子线网:subnet7 a% I/ I8 }1 d
       57、 目标函数:objective function
    ; h. f# S% T  F( |   58、 设计后处理:post design processing (pdp)
    2 l4 T; v4 ?) Q) G6 g: x   59、 交互式制图设计:interactive drawing design
    1 }- r8 m' t6 `1 w1 d4 [   60、 费用矩阵:cost metrix
    ( }7 K% m7 w; |1 X   61、 工程图:engineering drawing
    0 X4 q- y, ^9 _   62、 方块框图:block diagram
    3 S; U/ u8 l: g7 v: b& T3 y   63、 迷宫:moze
    ( O* R; N4 B- B( P& M   64、 元件密度:component density
    5 g! d& K! p' G# a8 X5 y2 G/ D  j   65、 巡回售货员问题:traveling salesman problem
      Y+ S! c( N4 B1 N   66、 自由度:degrees freedom
    5 A' S# H, Q5 ^, {* \( q$ T   67、 入度:out going degree
    7 }: X! s) U2 @6 e8 k* u   68、 出度:incoming degree
    ' ^6 H8 n4 F6 T9 P  Q# q# S; ^) g   69、 曼哈顿距离:manhatton distance# `8 B1 \7 \( d+ g- r) M+ Q
       70、 欧几里德距离:euclidean distance
    + Y* c* T& z! f* H7 R1 W7 \   71、 网络:network
      B8 A! n5 Z- t, p6 U+ B# ^   72、 阵列:array
    7 y( h' Q% I( ?3 e% X3 I   73、 段:segment
    & Y6 F" v' s  J' ~8 d% ~   74、 逻辑:logic
    0 p) p9 e3 t5 I2 K   75、 逻辑设计自动化:logic design automation
    ! X5 Z/ Q0 E8 W4 ]6 X6 v   76、 分线:separated time
    $ i" J+ q- Q4 p9 S. W, _   77、 分层:separated layer
    2 T) B, J. D  c8 ]" b   78、 定顺序:definite sequence& M4 F0 K. k/ {% g2 l
       五、 形状与尺寸:" u& Q6 j5 K/ |6 v' e; ~
       1、 导线(通道):conduction (track)1 D5 X5 A, z8 r( v$ B
       2、 导线(体)宽度:conductor width
    8 `" {( O$ g2 N6 c$ e   3、 导线距离:conductor spacing
    9 U" L8 e8 T$ \7 o   4、 导线层:conductor layer
    ' n! C2 F9 k- |+ X' ]   5、 导线宽度/间距:conductor line/space
    * N+ }9 ~- ^$ z" W- w: K  s7 B- L   6、 第一导线层:conductor layer no.1
    % l6 z; C, i; N8 J# x& k, u   7、 圆形盘:round pad. t) I1 n0 h2 X  @
       8、 方形盘:square pad2 ]% I" {+ J. m9 p4 g
       9、 菱形盘:diamond pad
    6 a; S$ u0 H9 j' ]% W3 b   10、 长方形焊盘:oblong pad6 o6 f5 k1 V. ~9 z' N& V
       11、 子弹形盘:bullet pad
    ' g" b3 s) m$ e5 p, q0 u+ n* e   12、 泪滴盘:teardrop pad) t7 n6 y6 M, {" }3 o) O* X
       13、 雪人盘:snowman pad
    7 M' a+ [! Q3 Z+ t   14、 v形盘:v-shaped pad
    - ]% y% V  x  [7 K! |& [5 i   15、 环形盘:annular pad8 E+ y, j. ]4 l8 B
       16、 非圆形盘:non-circular pad2 l$ @. y' t: T3 O* A- q0 x
       17、 隔离盘:isolation pad/ y4 B* C& u& I$ Q( y$ [- ?0 V
       18、 非功能连接盘:monfunctional pad
    & F: x$ v% K  f  k   19、 偏置连接盘:offset land$ k. m( |4 V7 u4 g
       20、 腹(背)裸盘:back-bard land! Z; X  {  Q9 n) R# e
       21、 盘址:anchoring spaur
    # b. p- M1 h  W# c9 u& Q+ ~  \   22、 连接盘图形:land pattern
    0 H5 f  t) s" p" `   23、 连接盘网格阵列:land grid array
    2 n+ t& ^5 R+ d3 Y, `1 i   24、 孔环:annular ring) B' F  x  m# Y
       25、 元件孔:component hole
    ( {* f- y/ {# K7 e8 K3 A! {% u   26、 安装孔:mounting hole
    6 }3 i- n! m4 T- x   27、 支撑孔:supported hole- n; \& w( V# ^, _
       28、 非支撑孔:unsupported hole
    8 G8 ^/ o% R: L   29、 导通孔:via
    & U; n- J) O4 _" D! Q   30、 镀通孔:plated through hole (pth)
    ' r, h0 f5 }# p# p6 i   31、 余隙孔:access hole
    - v/ X/ Z6 I+ \1 k9 o! u   32、 盲孔:blind via (hole)
    % H6 P1 ]# h' @% ^8 e5 {   33、 埋孔:buried via hole
    ! r6 S" N" w3 y0 ~3 I( j' |! n+ @; B   34、 埋/盲孔:buried /blind via
    - G9 b4 R, x) g6 v" Y   35、 任意层内部导通孔:any layer inner via hole (alivh)
    + d$ j% A4 o7 H6 [' K9 }& c   36、 全部钻孔:all drilled hole1 c: ~) Q* v: ]
       37、 定位孔:toaling hole" n4 g5 n1 r) v- j: D" C
       38、 无连接盘孔:landless hole
    / ^' k) N6 T2 T. E4 s( W) o6 \   39、 中间孔:interstitial hole
    ! y( s; M* u0 B1 L4 x: k   40、 无连接盘导通孔:landless via hole4 h2 u" }2 _% n: \
       41、 引导孔:pilot hole2 m3 h& Q/ N. R
       42、 端接全隙孔:terminal clearomee hole1 M, B$ g; R( @6 T" T( E$ P
       43、 准表面间镀覆孔:quasi-interfacing plated-through hole
    ( G  M& L9 B, T1 u, t   44、 准尺寸孔:dimensioned hole) x1 w9 {8 a  w, k9 j
       45、 在连接盘中导通孔:via-in-pad
    2 m" W) D: T$ q* Q   46、 孔位:hole location, r7 q- B. s0 O* E& p
       47、 孔密度:hole density/ t+ `- ^- U) T, Z9 m6 x  v
       48、 孔图:hole pattern: v, q, }! V/ Q- v# o9 B
       49、 钻孔图:drill drawing5 u7 {0 S! V; B9 s) D8 S
       50、 装配图:assembly drawing( c% s" Y5 e! x
       51、 印制板组装图:printed board assembly drawing' d$ L  }! n, D7 }
       52、 参考基准:datum referance
    liujie123 该用户已被删除
    发表于 2007-9-17 16:32 | 只看该作者
    提示: 作者被禁止或删除 内容自动屏蔽
    发表于 2008-4-8 10:57 | 只看该作者
    谢谢楼主
    发表于 2022-11-22 14:45 | 只看该作者
    谢谢分享。估计很难记住
    GMT+8, 2025-11-6 17:09 , Processed in 0.171875 second(s), 24 queries , Gzip On.
