查看: 635|回复: 5
Library Services 中的Import from功能灰色的,怎样激活
发表于 2018-5-7 12:45 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
我用的EE版本为7.93,不知为何Library Services 中的Import from功能灰色的,怎样激活?请高手指点,先谢了。
) c6 Y0 c, N; i  d, ?( r
+ a! ]8 l8 |* v* {7 x" p
发表于 2018-5-7 13:43 | 只看该作者
无解,应该只有Symbol这个选项是灰色的!
 楼主| 发表于 2018-5-7 14:02 | 只看该作者
UltraLibrarian中关于导入库数据是这样描述的:
 楼主| 发表于 2018-5-7 14:03 | 只看该作者
+ T6 d+ t8 K, iTo import your new library part to Expedition:' H5 Q2 O9 p' C& x- v
1. Start the Expedition Library Manager.. M. h( H" d0 P( X7 J8 z: b
2. Select File/New or File/Open from the menu (depending on whether you wish to start a new library or add to an existing program)., B) L( m8 l6 p9 Q2 f# D2 e
3. Select the library services icon." O- i& W* p, ^3 b7 i- u5 n, V
4. Select Padstacks, Ascii and Import.
( {' K3 [8 @5 }/ o5. Browse for the file we sent.  By default some versions look for a *.txt extension, however we are providing the *.hkp extension which will need to be changed at the bottom of the screen.  You will be looking for the Pads.hkp file.: G: g3 o5 V9 [+ D
6. Select the double arrow for moving all of the padstacks from the left side of the screen to the right.  Now say apply./ e# [  O6 [. D+ ]7 D3 T( W
7. Repeat steps 4-6 for symbols, cells and part, if these are included in your exported files.
9 L3 D0 {/ l6 E3 W) P4 e' t# q- u* O( X- I& ~0 I0 O
WARNING! Mentor now requires an encryption license to import any data into# d$ [: n2 z, P. T+ Z! P& a/ a
thier library system.  Therefore we are providing the normal ASCII formatted library files and special files indicating they are encrypted.  In most cases you shoudl ne importing the encrypted files.
0 S8 @0 B7 y0 z% ^& y  e0 }
发表于 2018-5-7 15:34 | 只看该作者
VX 系列截图
 楼主| 发表于 2018-5-8 14:35 | 只看该作者
哦,VX系列的ASCII file也灰了。
GMT+8, 2025-9-13 09:43 , Processed in 0.125000 second(s), 26 queries , Gzip On.
