查看: 495|回复: 1
想找人看看这个程序是哪里有问题
发表于 2018-4-15 23:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg51.h"
+ k* u, x4 \! r8 p, x* Y6 b6 ^#include"intrins.h": o9 `0 E0 \+ _
typedef unsigned char u8;1 I" D8 j; E. e. s" H3 P
typedef unsigned char u16;
& Y# U) E. N# }
3 @7 X; N& F1 x; zsbit SRCLK=P3^6;% F, J; j3 K7 Z! J- W! r( p8 [
sbit RCLK=P3^5;
5 i! `# ~# a' z$ V9 R3 U! r# }sbit SER=P3^4;" z/ I+ F. V7 k" J) r! Z5 y8 Q- J
u8 code ledwei1[]=$ I, K- H* _7 {3 y( I0 q4 E
0 W, r' W$ x- }8 U5 ^; W   0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,6 U9 R; x# h  @: m$ O
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80
% @/ K' Z( L( o, N" Q };5 N, w5 K, {. z1 m. P  p' V
u8 code ledduan1[]=3 n* s& Q5 I+ j  j2 v# [. V( m' u
. t6 _! e* l, e: b, b /*--  文字:  普  --*/
/ y' ~# [7 b. t" x) Y+ ~% \- ^$ d/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/4 Z* w9 t5 t+ V; {3 l4 j2 k
0x40,0x44,0x54,0x64,0x45,0x7E,0x44,0x44,0x44,0x7E,0x45,0x64,0x54,0x44,0x40,0x00,/ d; i  R8 ~* U7 T4 ]- `, |! i6 T
0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,0x00% N& @& ]0 Q8 @* D: t: J7 H
# I  s8 e+ t" x5 e% [- d9 R& J6 i; ^' p2 s: `) K  H1 J* g5 T
: v) B7 o$ k+ E3 A; ~3 V; a* ~2 z3 b
9 w( t0 M0 R- i, r% C0 i9 g6 C
% ]4 E% k- x3 x
         void delay(u16 i )
6 p- `* p7 }1 R+ B; {$ {4 s         {8 c& Q' F0 d$ E( d* t; d0 D# C
            while(i--);( _6 C" E! P. F/ e  d: g# I) P6 ]# X6 T
4 V# G, o3 m' }2 N. C+ E
, \- T4 s( {$ z9 Z( \* r5 h         }
8 O8 @/ o5 \  \0 t! K: T. i& t. C6 e1 Q0 E' o5 m. f
( U- k1 o2 k$ S4 v void Hc595sendByte(u8 dat1,u8 dat2,u8 dat3,u8 dat4)9 s% A5 z+ d6 o7 t' d5 g% ]
# z: k/ `1 U3 ~5 v0 ~# e
{+ V" Q5 c2 Q) w; T* F6 u
   u8 a ;" G- L5 ~& g6 }5 N  u: Q
   SRCLK=1;$ g4 G- K) M' O  _
   RCLK=1;
9 s- V; d  {9 p( E1 i, [   for(a=0;a<8;a++)        //传递四个参数分别移位四次在移位寄存器当中去
; P4 z% z6 e! b6 V' u   {
& M0 V: a6 z: z: ^0 p- X        SER =dat1>>7;# H4 i" E) _1 q! e4 N
        dat1<<=1;1 T, f$ T* n, J- V
        SRCLK=0;
! x; v& {6 w9 F( H  N2 c        _nop_();- Q( c  t# @. {6 Q, c/ I  X& Z
        _nop_();
, y! i6 j5 G* K, ]" q! a* Y' W& K1 q        SRCLK=1;
6 c0 x$ s& l! h/ @8 S5 n; c    }" k! {4 T7 r+ z
9 ~7 [4 Y7 a' O! k: `- x       for(a=0;a<8;a++)        5 @- E+ n: N* D7 s
4 V3 C. M0 \( N% w3 m        SER =dat2>>7;
; L1 e. _  [. U! ^1 ?6 U        dat2<<=1;
3 ]* i: l$ L; N        SRCLK=0;
% W; y9 B- e2 {+ o+ u        _nop_();
3 @! j% G  B  g2 q. ~$ \! t+ n        _nop_();9 ^, c3 k! J3 X/ u: _
        SRCLK=1;
5 _6 U0 S8 q2 g2 k) m    }    2 p" _4 {: I& F* E# @) d8 a; {
       for(a=0;a<8;a++)
3 c. m, [; J/ y: `$ x6 Q9 Y   {3 P3 M9 ^! u3 p2 K
        SER =dat3>>7;
1 _9 e6 V# F" Z$ L# |        dat3<<=1;
/ \. T9 q' d% q5 s        SRCLK=0;+ ?# v7 u$ }2 ^% X
        _nop_();' b0 r8 D. r$ ]( Y' _2 q- k
        _nop_();! Z( Z  S6 W# r& {* c+ ]8 ?0 b
        SRCLK=1;- e% h" ]$ F1 B  X; E
7 b5 d! F5 E. [          for(a=0;a<8;a++)         ! v9 W, I3 u7 |/ A. _; D) Y+ {
   {: v4 x3 z- W8 h9 d& v6 t& g. z* F1 z
        SER =dat4>>7;1 A3 m, \* T$ I1 C1 e+ O
        dat4<<=1;) c$ I1 e% g4 z6 d
        SRCLK=0;! b: M) i: k9 Y# @
        _nop_();5 H) |+ i: S' H3 k* K( q2 }, X
        _nop_();5 A9 q: `* }/ }/ O5 j7 h
        SRCLK=1;
- h) W" F( C% N8 l  J" S9 g    }
  r+ Z+ d) g' S, {% T& n; d& K
1 O, T1 h' S+ L2 Z$ d       RCLK=0;% |# A  z  M% S
           _nop_();0 d  I# u: r1 X
           _nop_();
$ E4 [! z' s& T                 RCLK=1;' u; s6 R; t6 I  a$ {) I- `
" H3 B3 ]1 z; X- G  M4 Y2 T& a$ A& j. \4 g3 T* G
( ~9 }* K5 M8 q( p+ p) e0 X
     void main()2 w" J, `; u5 e9 U
3 i5 e, q/ ]- j  |        u8 i ;1 A8 V  u# b6 G0 C, R# w5 [
7 f* t( }( A: a# E+ j- m
        while(1), a" _- M/ x3 Q5 X# r1 a) Q# G0 J
       {2 Q- [% X8 D3 T0 U8 B6 q( x
                 for(i=0;i<16;i++)
; M4 [  J$ [# B4 p6 ~: E% X3 T- {+ t8 V
                  {% T- N4 n. z1 ?4 f9 Q
                          Hc595sendByte(~ledwei1[i+16],~ledwei1,ledduan1[16+i],ledduan1);( d% \; {; w  T/ d$ z2 b: v
                            delay(10);
7 d* |) Y0 W6 u. G2 _
+ C# t9 I3 p# S                  }
; j' O, a/ ?8 e( c( X* C) i
- X! g& h* \) r7 M$ F$ Z; O- y- \       }/ s# _4 T* |4 J! f1 h
! K0 P: I# ]# V( J# h- L
5 ~$ `$ g1 a. ]
2 K8 j) U, S4 `6 x     }
* v2 d, m4 Q- O( e2 S- ]6 |[img][/img]
 楼主| 发表于 2018-4-15 23:30 | 只看该作者
程序在调试的时候显示的全是led字, 我只想led灯显示一个普字,跑出来全是灯在闪烁,我不清楚到底是哪里出了问题
GMT+8, 2025-10-8 19:42 , Processed in 0.140625 second(s), 23 queries , Gzip On.
